Results 1 to 7 of 7
Thread: 2010 Audi A4 wagon door lock issue
    Dec 2017
    Canada
    Hi guy's
    I replaced the right rear door lock on this car last week. The issue is that it will not open from the outside after locking/unlocking the car. Unless you open the door from the inside. Then the door is able to be opened from the outside, until the car is locked again.
    Is there a coding for the right rear door that I have omitted??
    Russ
    Friday,03,April,2020,10:54:22:09539
    VCDS Version: 20.4.0.1 (x64)  HEX-NET CB: 0.4508.4
    Dealer/Shop Name: Autospiel German Auto
    VIN: WAUSFCFL7AA084515   License Plate: THORPE_04.03.20
    Mileage: 78160km-48566mi   Repair Order:
    Chassis Type: FL-AU48 (8E - Audi A4/S4/RS4 B6/B7 (2001 > 2008))
              67 69 75 76 77
    VIN: WAUSFCFL7AA084515   Mileage: 78160km-48566miles
    Address 01: Engine (DL0MA-CAEB)       Labels:| 06H-907-115-CAB.clb
       Part No SW: 8K2 907 115 AL    HW: 8K2 907 115 D
       Component: 2.0l R4/4V TF H15 0001
       Revision: E1H15---
       Coding: 010C010A190F0160
       Shop #: WSC 91445 999 100729
       ASAM Dataset: EV_ECM20TFS0118K2907115AL 001001
       ROD: EV_ECM20TFS0118K2907115AL.rod
       VCID: 79BACA23F8FC114E45-802C
    4060 - Cylinder 3
              P0303 00 [096] - Misfire Detected
    4057 - Cylinder 2
              P0302 00 [096] - Misfire Detected
    4051 - Random/Multiple Cylinder Misfire Detected
              P0300 00 [096] - -
    7780 - Engine Off Timer Performance
              P150A 00 [032] - -
    Address 02: Auto Trans (J217)       Labels:| 0B6-927-156.clb
       Part No SW: 8K0 927 158 J    HW: 0B6 927 156
       Component: 0B6 20TFSIUSA H05 0008
       Revision: --H05---
       Coding: 001012
       Shop #: WSC 06335 000 00000
       ASAM Dataset: EV_TCMAL651 A01006
       ROD: EV_TCMAL651.rod
       VCID: 3D321E33AC54ED6E29-8068
       Part No SW: 8K0 907 379 AL    HW: 8K0 907 379 AL
       Component: ESP8 quattro  H04 0080
       Coding: 150500
       VCID: 0346A8CB82305B9E1F-8056
                        Fault Status: 00101101
                        Reset counter: 251
                        Mileage: 78023 km
                        Date: 2020.03.13
                        Time: 14:08:33
                        Hex Value: 0x0000
                        Hex Value: 0x00A2
                        Hex Value: 0x002E
                        Hex Value: 0x0291
                        Hex Value: 0x00FF
       Part No SW: 8T1 820 043 AN    HW: 8T1 820 043 AN
       Component: KLIMA 1 ZONE  H08 0171
       Revision: A1000000    Serial number: 01311020091794
       Coding: 64002000
       VCID: 7DB2DE33E4D42D6E69-8028
       Part No SW: 8K0 907 063 P    HW: 8K0 907 063 P
       Component: BCM1 1.0      H28 0380
       Revision: 10028001    Serial number: 00000000500299
       Coding: 26001096463C00010000080300003D0D0F1C460802010001000000
       Shop #: WSC 91445 999 06574
       VCID: 3C341337BF4EE4661E-8068
       Component: WWS 291009  H06 0070
       Serial number: SWF09100296223
       Coding: 00FD11
       Subsystem 2 - Part No SW: 8K0 941 531 AK    HW: 8K0 941 531 AK
       Component: E1 - LDS  H08 0090
       Serial number: 00000000002710090389
       Part No SW: 8K0 959 655 H    HW: 8K0 959 655 H
       Component: AirbagVW-AU10 H39 0560
       Serial number: 003EGD0559N2
       Coding: 30453635423030303030554A304C384B3053
       VCID: 42C86DCFD5AA929654-8016
       Serial number: 6334MSME4B2419048
       Serial number: 6344MSME4C517773K
       Serial number: 6352QSME01424F306
       Serial number: 6362QSME084005061
       Serial number: 63732SME50405122I
       Serial number: 63832SME67411A00T
       Revision: --------    Serial number: 90315IK3000KG
       Coding: 000017
       VCID: 3D321E33A454ED6E29-8068
       Part No SW: 8K0 920 900 B    HW: 8K0 920 900 B
       Component: KOMBIINSTR.   H20 0255
       Revision: 00000000    Serial number: CIJ16VUA9
       Coding: 8B06110002000008020000
       VCID: 291ADA6340DC61CE75-807C
       Part No SW: 8K0 907 064 DG    HW: 8K0 907 064 DG
       Component: BCM2 1.1      H02 0326
       Revision: 00002001    Serial number: 0123484835
       Coding: 0126023A203A001400B0023200000000
       VCID: 78BCCF27CBF608463A-802C
       Subsystem 2 - Part No SW: 8K0 959 591 A    HW: 8K0 959 591
       Component: J245 PS133  H06 0041
       Subsystem 3 - Part No SW: 8K0 959 591 A    HW: 8K0 959 591
       Component: J394 PS228  H06 0041
       Part No: 8K5 907 357
       Coding: 0000004
       Shop #: WSC 06334 000 00000
       VCID: 77BECC1B06E8073E33-8022
       Part No SW: 8T1 035 186 R    HW: 8T1 035 186 R
       Component: Con3 Sirius   H04 0301
       Revision: 00000006    Serial number: AUZ5Z6I1297232
       Coding: 25020000010207000158070000
       VCID: 46C071DFF182AEB678-8012
       Subsystem 1 - Part No SW: 8T0 919 603 E    HW: 8T0 919 603 E
       Component: Display
                        Reset counter: 54
                        Mileage: 72293 km
                        Date: 2018.11.19
                        Time: 10:24:30
    End----(Elapsed Time: 04:48, VBatt start/end: 11.9V/11.8V. VIgn 11.8V)-----
    So I'm wondering: Where are the doors controllers in this scan. Then I noticed that you pocked the wrong chassis type. This in not an 8E chassis A4. It's an 8K chassis A4. Please run another scan and just use Auto-Detect instead of choosing a chassis manually.
  3. Likes Dana, DrPeter, PetrolDave liked this post
    Dec 2017
    Canada
    Thanks Uwe, will do
  5. Likes Dana liked this post
  6. #4
    Dec 2017
    Canada
    Here it is
    Friday,03,April,2020,12:19:35:09539
    VIN: WAUSFCFL7AA084515   License Plate: THORPE_8K_04.03,20
    Chassis Type: FL-AU48 (8T0)
    Scan: 01 02 03 05 08 09 15 16 17 19 42 46 47 52 53 55 56 62 72
       Revision: E1H15---
    Readiness: 1110 0101
       Revision: --H05---
       Coding: 001012
       Coding: 150500
       Coding: 090200
       Subsystem 1 - Part No SW: 8T0 959 754 A    HW: 8T0 959 754 A
       Serial number: 0509000060568015
       Serial number: 0209000075520005
       Coding: 64002000
       Coding: 00FD11
       Coding: 000017
       Part No SW: 8T0 907 468 R    HW: 8T0 907 468 H
       Component: GW-BEM 5CAN   H06 0105
       Revision: GB600050    Serial number: 5000G09A178168
       Coding: 00C303
       VCID: 50EC578703C67006D2-8004
       Subsystem 1 - Part No SW: 8K0 915 181 E    HW: 8K0 915 181 E
       Component: J367-BDM  H06 0170
       Serial number: 19096397131009
       Part No SW: 8K0 959 793 H    HW: 8K0 959 793 D
       Component: TSG FA        H11 0306
       Revision:             Serial number: 0000009572888
       Coding: 011C03204000410001
       VCID: 45C276D3CC84A5AE71-8010
    Address 47: Sound System (J525)       Labels:. 8T0-035-223-ASC.clb
       Part No SW: 8R0 035 223 F    HW: 8R0 035 223 E
       Component: DSP STD       H11 0440
       Revision: 00000000    Serial number: 00000000000001
       Coding: 0203010101
       VCID: 2F2E347B7E380FFEAB-807A
       Part No SW: 8K0 959 792 H    HW: 8K0 959 792 D
       Component: TSG BF        H11 0306
       Revision:             Serial number: 0000009586029
       VCID: 44C46BD7C7BE9CA666-8010
       Revision: 00000003    Serial number: 10000000360313
       VCID: 34243B17971E2C26D6-8060
       Coding: 0000004
       Component: Display
                        Reset counter: 227
                        Mileage: 78166 km
                        Date: 2020.04.03
                        Time: 10:49:28
       Part No SW: 8K0 959 795 C    HW: 8K0 959 795 C
       Component: TSG HL        H10 0306
       Revision:             Serial number: 0000102218177
       Coding: 010C03204000210001
       VCID: 42C86DCFDDAA929654-8016
       Component: TSG HR        H10 0306
       Revision:             Serial number: 0000102216581
    End----(Elapsed Time: 01:22, VBatt start/end: 11.7V/11.7V. VIgn 11.7V)-----
  7. Likes Dana, Uwe liked this post
  8. #5
    Dec 2017
    Canada
    I think its a defective door lock.
    Looking at the value block in 72, I can see the 4 th digit switch between 1 and 0 when the door lock button on the front door is operated. But the lock does not unlock until physically unlocked by operating the inside door handle!!
    Im going to order another lock!
    Russ
  9. #6
    United States
    Make sure the cable from the latch to the exterior door handle isn't overly tensioned. If it is too tight that can cause goofy behavior.
    The coding appears to be OK.
  10. Likes Uwe, DrPeter, Jack@European_Parts liked this post
  11. #7
    Jun 2014
    Newcastle, England
    You can take a look here too...
