Car has been constantly going flat and when hooking up a battery charger under the bonnet to the remote terminals its ok for about 12 hours then flat again.
Only thing that was done to the car was some coding in 09 Cent Elec to get the DRL to be on while driving. This was changed to 2 so it was selectable in the MMI and seemed to work fine other than the battery going flat.
When auto scanning the car flat it obviously has lots of codes.
Cleared these, took the car for a drive and seems fine now no codes.
Have changed the 09 coding back to having what i think was the original code without the DRL selectable etc and left it on charge and will try starting the car tomorrow.
No idea how old battery is as apparently its under the seat and a pain to access so unsure if the battery is just had it or something else.
How likely is it that the DRL coding has caused this?
This is the scan when car was flat with lots of codes
This is the scan once the car was started and codes cleared
Friday,03,April,2020,14:28:30:30955
VCDS Version: 19.6.2.0 (x64)
VIN: WAUZZZ4L3CD040833 License Plate: Q7 FLAT 3 APRIL 2020
Mileage: 74210km-46111mi Repair Order:
Chassis Type: 4L-AU56 (4F0)
Scan: 01 02 03 05 08 09 0E 15 16 17 19 28 36 42 46 47 4F 52 55 56
57 5F 62 6C 6D 6F 72 76
VIN: WAUZZZ4L3CD040833 Mileage: 74210km-46111miles
57-TV Tuner -- Status: Malfunction 0010
Address 01: Engine (CJT) Labels: None
Part No SW: 4L0 910 551 HW: 4L0 907 551
Component: 3.0l V6 TFSI 0070
Revision: --H08--- Serial number:
Coding: 0121000C290F0128
Shop #: WSC 31414 790 00001
VCID: 65C1E416AC192D6734-8030
U1017 - 000 - - Intermittent
Mileage: 74210 km
Date: 2020.03.07
Time: 11:05:48
RPM: 1536 /min
Mass Air / Rev.: 196.2 mg/str
Temperature: 19.5°C
Bin. Bits: 00000010
Load: 20.4 %
000774 - Cylinder 6
P0306 - 000 - Misfire Detected - Intermittent
Fault Status: 00100001
Mileage: 74210 km
Date: 2020.03.13
Time: 14:38:41
RPM: 672 /min
Mass Air / Rev.: 119.9 mg/str
Temperature: 93.0°C
Bin. Bits: 00000010
Time: 2201.6 s
004874 - Cylinder Disabling
P130A - 000 - - Intermittent
Mileage: 74210 km
Date: 2020.03.13
Time: 14:38:41
RPM: 160 /min
Mass Air / Rev.: 376.1 mg/str
Temperature: 102.0°C
Bin. Bits: 00000001
Time: 0.0 s
004263 - Adaptation of Intake Air Regulating Flap
P10A7 - 000 - Clogged/Dirty - Intermittent
Mileage: 74210 km
Date: 2020.03.24
Time: 11:32:54
RPM: 928 /min
Absolute Pres.: 899.1 mbar
Bin. Bits: 00000000
Bin. Bits: 00000000
Voltage: 4.540 V
Voltage: 0.600 V
004260 - Intake Air Regulating Flap
P10A4 - 000 - Mechanical Malfunction - Intermittent
Mileage: 74211 km
Date: 2020.03.28
Time: 10:17:04
RPM: 96 /min
Absolute Pres.: 1010.8 mbar
(no units): 0.00
(no units): 8.20
Voltage: 0.920 V
(no units): 100.0
Address 02: Auto Trans (J217) Labels:| 0C8-927-750.clb
Part No SW: 0C8 927 750 M HW: 0C8 927 750 M
Component: AL1000 AISIN 001 2087
Coding: 001178
Shop #: WSC 02318 003 1048576
ROD: EV_TCMAL991031_002.rod
VCID: 3663735A893F96FF4D-8062
Address 03: ABS Brakes Labels:. 4L0-910-517-V2.clb
Part No SW: 4L0 910 517 M HW: 4L0 614 517 L
Component: ESP ALLRAD MK25E1 0020
Revision: 00H02001
Coding: 0099409
VCID: 34674952574384EF73-8060
Reset counter: 195
Mileage: 74064 km
Date: 2020.02.15
Time: 16:00:28
Count: 10305
Count: 128
Count: 35072
Fault Status: 00101101
Reset counter: 195
Mileage: 74210 km
Date: 2020.03.13
Time: 14:38:41
Count: 8513
Count: 8196
Count: 51712
Reset counter: 0
Mileage: 74210 km
Count: 128
Count: 11073
Count: 297
Count: 28672
Part No SW: 4F0 910 852 B HW: 4F0 905 852 H
Component: FBSAUDIC6 ELV H08 0200
Revision: 00H08000 Serial number: 10603701987205
Coding: 0000183
VCID: 2541A416EC99ED67F4-8070
Subsystem 1 - Part No: 4F0 910 132 Q
Component: FBSAUDIC6 EZS H04 0020
Component: FBSAUDIC6 KSG H03 0020
00190 - Driver's Door Handle Touch Sensor (G415)
Fault Status: 01110111
Reset counter: 157
Mileage: 73621 km
Date: 2019.10.04
Time: 12:24:00
007 - Short to Ground
Fault Status: 00111011
Reset counter: 191
00532 - Supply Voltage B+
Fault Frequency: 10
Reset counter: 40
Mileage: 74210 km
Date: 2020.03.07
Time: 05:30:27
Fault Frequency: 25
Reset counter: 197
Mileage: 74210 km
Date: 2020.03.07
Time: 05:29:31
Part No SW: 4L0 910 043 D HW: 4L0 820 043 AH
Revision: 00---026 Serial number: 00000000323693
Coding: 000CC446
VCID: 2541A4162C99ED67F4-8070
Fault Frequency: 12
Reset counter: 195
Mileage: 74064 km
Date: 2020.02.15
Time: 16:01:05
Voltage: 9.60 V
Reset counter: 192
Mileage: 74210 km
Date: 2020.03.13
Time: 13:28:22
Voltage: 7.80 V
Part No SW: 4F0 910 279 AG HW: 4F0 907 279 C
Component: ILM Fahrer H31 0400
Coding: 0123122
VCID: 6ED39B3A79EFEE3F45-803A
Subsystem 1 - Part No: 4L2 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AU716 H13 0110
Coding: 00064792
Shop #: WSC 31414
Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB
Coding: 00152619
Shop #: WSC 31414
01800 - Light Switch (E1)
Reset counter: 194
Mileage: 74208 km
Date: 2020.03.13
Time: 14:02:00
Fault Frequency: 12
Reset counter: 197
Mileage: 74064 km
Date: 2020.02.15
Time: 16:01:00
Reset counter: 197
Mileage: 74208 km
Date: 2020.03.07
Time: 05:30:00
Address 0E: Media Player 1 (R41) Labels: 4E0-910-111.lbl
Part No SW: 4F0 035 110 A HW: 4F0 035 110
Component: CDC-MP3-Alp H44 0140
Revision: AA001001
VCID: 152194D6FCF97DE764-8040
Reset counter: 196
Mileage: 74210 km
Date: 2020.03.25
Time: 16:12:28
Voltage: 8.20 V
Address 15: Airbags Labels: 4L0-910-655.lbl
Part No SW: 4L0 910 655 D HW: 4L0 959 655 C
Component: 70 AIRBAG AUDI8RH43 0230
Revision: 04H43000 Serial number: 00399D093VKB
Coding: 0014128
VCID: 2E535B3AB96FAE3F05-807A
Subsystem 1 - Serial number: 6332QSME6C141158D
Subsystem 2 - Serial number: 6342QSME74140F68L
Subsystem 3 - Serial number: 6352QSME3C135348G
Subsystem 4 - Serial number: 6362QSME4D14087ET
Subsystem 5 - Serial number: 63734SME39130176V
Subsystem 6 - Serial number: 63834SME3913196C3
Part No SW: 4F0 910 549 B HW: 4F0 953 549 E
Component: J0527 0830
Revision: 00H08000 Serial number: 90026120890033
Coding: 0112142
VCID: 285FAD229B8BF00FCF-807C
Component: E0221 H03 0030
Fault Frequency: 17
Reset counter: 197
Mileage: 74210 km
Date: 2020.03.07
Time: 05:29:33
Reset counter: 197
Mileage: 74210 km
Date: 2020.03.07
Time: 05:30:28
Address 17: Instruments (J285) Labels:. 4L0-920-xxx-17.clb
Part No SW: 4L0 920 932 Q HW: 4L0 920 932 Q
Component: KOMBIINSTR. H22 0411
Revision: 00200000 Serial number: LMY50NU4D
Coding: 235F63040000000C010904
VCID: 3A7B676AB527729FA9-806E
Reset counter: 192
Mileage: 74210 km
Date: 2020.03.13
Time: 13:27:25
Address 19: CAN Gateway (J533) Labels:. 4F0-907-468.clb
Part No SW: 4F0 907 468 R HW: 4F0 907 468 F
Component: GW-BEM 4CAN-M H06 0057
Revision: LB500035 Serial number: 3500L124020262
Coding: 00C303
VCID: 3E736B7AA90F5EBF95-806A
Subsystem 1 - Part No SW: 8K0 915 181 D HW: 8K0 915 181 D
Component: J367-BDM H07 0125
Serial number: 00000000002790833304
Fault Frequency: 14
Reset counter: 157
Mileage: 74064 km
Date: 2020.02.15
Time: 15:47:33
Bin. Bits: 10111
Voltage: 10.80 V
Count: 7
Fault Frequency: 10
Reset counter: 196
Mileage: 74210 km
Date: 2020.03.07
Time: 05:30:28
Bin. Bits: 00000
Voltage: 7.20 V
Count: 12
Address 28: HVAC, Rear Labels: None
Part No SW: 4L0 910 158 HW: 4L0 919 158 AB
Revision: 00---010 Serial number: 00000000324914
Coding: 0000006
VCID: 68DFED225B0B300F0F-803C
Fault Frequency: 12
Reset counter: 195
Mileage: 74064 km
Date: 2020.02.15
Time: 16:00:59
Voltage: 9.60 V
Fault Status: 01101101
Reset counter: 129
Mileage: 73628 km
Date: 2020.01.14
Time: 04:33:59
Reset counter: 192
Mileage: 74210 km
Date: 2020.03.13
Time: 13:28:22
Voltage: 7.80 V
Part No SW: 4F0 959 760 D HW: 4F0 959 760 D
Component: MEM-FS H08 0064
Revision: AA000000 Serial number: 00000026558213
Coding: 00781B00000011110000
VCID: 326B4F4A6D578ADF61-8066
Fault Frequency: 19
Reset counter: 195
Mileage: 74210 km
Date: 2020.03.07
Time: 05:30:27
Reset counter: 194
Mileage: 74210 km
Date: 2020.03.07
Time: 05:32:44
Address 42: Door Elect, Driver (J386) Labels:. 4F0-959-793.clb
Part No SW: 4F0 959 793 T HW: 8K0 959 793 M
Component: TSG FA H12 0362
Revision: Serial number: 0000028311430
Coding: 011C52205E41440004
VCID: 489F0DA2FBCB100F2F-801C
Fault Frequency: 16
Reset counter: 196
Mileage: 74210 km
Date: 2020.03.07
Time: 05:29:36
Reset counter: 195
Mileage: 74210 km
Date: 2020.03.07
Time: 05:30:30
Address 46: Central Conv. Labels:. 4L0-910-289.lbl
Part No SW: 4L0 910 289 K HW: 4L0 907 289 K
Component: Komfortgeraet H12 0130
Revision: 0130 --- Serial number: 01587026550000
Coding: 3276941
VCID: 387F7D624B2B608F5F-806C
Reset counter: 192
Mileage: 74210 km
Date: 2020.03.07
Time: 05:32:20
Part No SW: 4L0 035 223 J HW: 4L0 035 223 G
Component: BOSE G3 Q7 H04 0160
Revision: CH004000 Serial number: 00000000011550
Coding: 030000
VCID: 2959A8264081C907D0-807C
Reset counter: 163
03405 - Bass Loudspeaker
Reset counter: 197
Part No SW: 4F0 910 280 HW: 4F0 907 280
Component: ILM Beifahrer H16 0100
Revision: Serial number: 00000000642107
Coding: 0011001
VCID: 5EB3CBFA894F7EBFF5-800A
Fault Status: 00110010
Reset counter: 191
Mileage: 74208 km
Date: 2020.03.07
Time: 05:30:00
Voltage: 7.400 V
Temperature: 16.0°C
Reset counter: 192
Mileage: 74208 km
Date: 2020.03.13
Time: 13:37:00
Voltage: 8.100 V
Temperature: 20.0°C
Fault Frequency: 23
Reset counter: 196
Mileage: 74208 km
Date: 2020.03.07
Time: 05:29:00
Voltage: 6.900 V
Temperature: 15.0°C
Address 52: Door Elect, Pass. (J387) Labels:. 4F0-959-792.clb
Part No SW: 4F0 959 792 T HW: 8K0 959 792 M
Component: TSG BF H12 0362
Revision: Serial number: 0000028502402
VCID: 479D0E9EF6D51F7726-8012
Fault Frequency: 16
Reset counter: 196
Mileage: 74210 km
Date: 2020.03.07
Time: 05:29:36
Reset counter: 195
Mileage: 74210 km
Date: 2020.03.07
Time: 05:30:30
Address 55: Headlight Range (J431) Labels:| 8X0-907-357.clb
Part No SW: 8X0 907 357 C HW: 8X0 907 357 B
Component: ****LWR12**** H02 0012
Serial number: 120425-0004-115
Coding: 1147A71010000000
ROD: EV_HeadlRegulBasic.rod
VCID: 428B1F8AD5F73A5FF1-8016
Part No SW: 4G0 035 083 HW: 4G0 035 083
Component: Radio U JP H50 0055
Revision: AB001007 Serial number: 448D00C7531659
Coding: 030005010000000000
VCID: 5EB3CBFA494F7EBFF5-800A
Reset counter: 197
Mileage: 74210 km
Date: 2020.03.07
Time: 05:29:58
Voltage: 6.90 V
02981 - Connection between Radio and Impedance Converter 1
Fault Status: 00101011
Reset counter: 194
Mileage: 74210 km
Date: 2020.02.28
Time: 12:35:16
Voltage: 11.70 V
02982 - Connection between Radio and Impedance Converter 2
Reset counter: 194
Mileage: 74210 km
Date: 2020.03.23
Time: 14:26:58
Voltage: 10.30 V
03455 - Function Restriction due to Faults in Other Modules
Reset counter: 194
Mileage: 74210 km
Date: 2020.03.24
Time: 11:33:18
Bin. Bits: 00000000 00000001
Address 57: TV Tuner (R78) Labels: None
Part No SW: 8F0 919 129 E HW: 8F0 919 129
Component: DTV-JP H07 0760
Revision: R0070000 Serial number: 79300703587601
Coding: 100300
Shop #: WSC 31414 000 90108
Subsystem 1 - Part No SW: 4F0 919 805 HW: 4F0 919 805
Component: R204 TVKLeser H07 0010
Serial number: 2172800600829203
Reset counter: 195
Mileage: 74210 km
Date: 2020.03.07
Time: 05:30:38
Part No SW: 4L2 035 678 HW: 4L2 035 678
Component: H-BN-JP H16 0238
Revision: -------- Serial number: K5FAN1NJAE7ZW
Coding: 18060106030481FF41000345EF632003FC0000020100000000
VCID: 6FED863EBEE5E7374E-803A
Subsystem 1 - Part No: 8R0 060 884 AF
Component: JPN-12.07.11. 7520
Subsystem 2 - Part No SW: 4F0 035 503 E HW: 4F0 035 503 E
Component: ETC-VICS-Ant. H04 0020
Subsystem 3 - Part No SW: 4L0 919 813 E HW: 4L0 919 813 E
Component: Card reader H03 0110
Serial number: 382112030188
Subsystem 4 - Part No SW: 8R0 919 604 HW: 8R0 919 604
Component: DU7 High H41 0104
Serial number: A130D70CS155951
Subsystem 5 - Part No SW: 4L0 919 614 C HW: 4L0 919 614 C
Component: E0380 Bedient H01 0060
Serial number: 00000002006289
Subsystem 6 - Part No: 8R0 060 961 C
Component: CD-Database 3638
Reset counter: 196
Mileage: 74210 km
Date: 2020.03.07
Time: 05:30:28
Voltage: 7.50 V
03367 - Supply Voltage for Display Module
Reset counter: 195
Mileage: 74210 km
Date: 2020.03.07
Time: 05:30:06
Voltage: 7.20 V
Address 62: Door, Rear Left (J388) Labels:. 4F0-959-795.clb
Part No SW: 4F0 959 795 P HW: 4F0 959 795 P
Component: TSG HL H11 0362
Revision: Serial number: 0000027887398
Coding: 010850204041230004
VCID: 4683039AF1DF067FDD-8012
Fault Frequency: 17
Reset counter: 196
Mileage: 74210 km
Date: 2020.03.07
Time: 05:29:35
Fault Frequency: 7
Reset counter: 195
Mileage: 74210 km
Date: 2020.03.07
Time: 05:30:29
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 4L0 910 441 B HW: 4L0 907 441 B
Component: J772__Rearview 0030
Revision: --H07--- Serial number: 525PA8-J24409E
Coding: 1021001
Fault Frequency: 16
Reset counter: 197
Mileage: 74210 km
Reverse OFF
Count: 3
Reset counter: 195
Mileage: 74210 km
Reverse OFF
Count: 3
Reset counter: 157
Mileage: 74211 km
Date: 2020.04.03
Time: 13:23:58
Reverse OFF
Count: 3
Part No SW: 4L0 910 945 HW: 4L0 827 851 E
Component: ValeoHeckdeckel H57 0500
Revision: --H57001 Serial number: E5030000B
Shop #: WSC 98765 666 38354
VCID: 6CD791324FF31C2F6B-8038
Subsystem 3 - Serial number: RD26.04.12--H57001001A0008ÿ
Subsystem 4 - Serial number: 1A0008ÿ
Address 6F: Centr. Conv. II Labels:. 4L0-910-290.lbl
Part No SW: 4L0 910 290 HW: 4L0 907 290
Component: ILM HINTEN 2 H08 0080
Revision: AAH08080 Serial number: 126686823-----
Reset counter: 194
Mileage: 74210 km
Date: 2020.03.07
Time: 05:30:35
Address 72: Door, Rear Right (J389) Labels:. 4F0-959-795.clb
Component: TSG HR H11 0362
Revision: Serial number: 0000027882855
Fault Frequency: 15
Reset counter: 196
Mileage: 74210 km
Date: 2020.03.07
Time: 05:29:35
Reset counter: 195
Mileage: 74210 km
Date: 2020.03.07
Time: 05:30:29
Part No SW: 4L0 910 283 E HW: 4L0 919 283 E
Component: Parkhilfe 8-Kan H03 0100
Revision: 00H03000 Serial number: 37331211201535
Coding: 0221066
VCID: 2C5751328F73DC2F2B-8078
Reset counter: 192
Mileage: 74210 km
Date: 2020.03.13
Time: 13:28:27
Fault Frequency: 9
Reset counter: 195
Mileage: 74210 km
Date: 2020.03.13
Time: 13:27:32
End-------------------------(Elapsed Time: 03:40)--------------------------
Address 01: DTCs cleared
Address 19: DTCs cleared
Address 09,4F0 910 279 AG,recoded (Short coding),from,0123122,to,0123121,(31414/790/00001),
Address 09,4F0 910 279 AG,recoded (Short coding),from,0123121,to,0123101,(31414/790/00001),
Friday,03,April,2020,14:40:50:30955
VIN: WAUZZZ4L3CD040833 License Plate: Q7 CHARGED 3 APR 2020
Mileage: 74211 km
Date: 2020.04.03
Time: 13:34:26
RPM: 96 /min
Absolute Pres.: 1016.1 mbar
(no units): 0.00
(no units): 24.60
Voltage: 1.740 V
(no units): 100.0
Mileage: 74211 km
Date: 2020.04.03
Time: 13:34:27
RPM: 1696 /min
Mass Air / Rev.: 163.5 mg/str
Temperature: 15.0°C
Bin. Bits: 00000010
Load: 15.3 %
Readiness: 0110 0001
Coding: 001178
Revision: 00H02001
Coding: 0099409
Reset counter: 157
Mileage: 74211 km
Date: 2020.04.03
Time: 13:28:45
Count: 8517
Count: 297
Count: 43520
Coding: 0000183
Coding: 000CC446
Coding: 0123101
Coding: 00064792
Shop #: WSC 31414
Coding: 00152619
Shop #: WSC 31414
Revision: AA001001
Coding: 0014128
Coding: 0112142
Coding: 00C303
Reset counter: 197
Mileage: 74211 km
Date: 2020.04.03
Time: 13:29:11
Bin. Bits: 10111
Voltage: 11.90 V
Count: 7
Coding: 0000006
Coding: 3276941
Coding: 030000
Coding: 0011001
Coding: 100300
Coding: 1021001
Coding: 0221066
End---------------------(Elapsed Time: 03:25, udsna)-----------------------
Address 03: DTCs cleared
Address 01: DTCs cleared[/QUOTE]
This is after the codes were cleared and car taken for a drive with no errors on dash
Friday,03,April,2020,14:54:56:30955
VIN: WAUZZZ4L3CD040833 License Plate: Q7 AFTR DRIVE 3 APR 2020 NO CODES
Readiness: 0010 0001
Coding: 001178
Revision: 00H02001
Coding: 0099409
Coding: 0000183
Coding: 000CC446
Coding: 0123101
Coding: 00064792
Shop #: WSC 31414
Coding: 00152619
Shop #: WSC 31414
Revision: AA001001
Coding: 0014128
Coding: 0112142
Coding: 00C303
Reset counter: 197
Mileage: 74211 km
Date: 2020.04.03
Time: 13:29:11
Bin. Bits: 10111
Voltage: 11.90 V
Count: 7
Coding: 0000006
Coding: 3276941
Coding: 030000
Coding: 0011001
Coding: 100300
Coding: 1021001
Coding: 0221066
End-------------------------(Elapsed Time: 03:35)--------------------------
[/url][/IMG][/url][/IMG]
