2012 FACELIFT Q7 GOING FLAT
webup
Auckland
C?ID=256879
Car has been constantly going flat and when hooking up a battery charger under the bonnet to the remote terminals its ok for about 12 hours then flat again.
Only thing that was done to the car was some coding in 09 Cent Elec to get the DRL to be on while driving. This was changed to 2 so it was selectable in the MMI and seemed to work fine other than the battery going flat.
When auto scanning the car flat it obviously has lots of codes.
Cleared these, took the car for a drive and seems fine now no codes.
Have changed the 09 coding back to having what i think was the original code without the DRL selectable etc and left it on charge and will try starting the car tomorrow.
No idea how old battery is as apparently its under the seat and a pain to access so unsure if the battery is just had it or something else.
How likely is it that the DRL coding has caused this?
This is the scan when car was flat with lots of codes
Friday,03,April,2020,14:28:30:30955
VCDS Version: 19.6.2.0 (x64)
VIN: WAUZZZ4L3CD040833   License Plate: Q7 FLAT 3 APRIL 2020
Mileage: 74210km-46111mi   Repair Order:
Chassis Type: 4L-AU56 (4F0)
Scan: 01 02 03 05 08 09 0E 15 16 17 19 28 36 42 46 47 4F 52 55 56
          57 5F 62 6C 6D 6F 72 76
VIN: WAUZZZ4L3CD040833   Mileage: 74210km-46111miles
57-TV Tuner -- Status: Malfunction 0010
Address 01: Engine (CJT)       Labels: None
   Part No SW: 4L0 910 551     HW: 4L0 907 551
   Component: 3.0l V6 TFSI        0070
   Revision: --H08---    Serial number:
   Coding: 0121000C290F0128
   Shop #: WSC 31414 790 00001
   VCID: 65C1E416AC192D6734-8030
053271 - Please Check Fault Codes in Control Module for ABS Brakes
               U1017 - 000 -  - Intermittent
                    Mileage: 74210 km
                    Date: 2020.03.07
                    Time: 11:05:48
                    RPM: 1536 /min
                    Mass Air / Rev.: 196.2 mg/str
                    Temperature: 19.5°C
                    Bin. Bits: 00000010
                    Load: 20.4 %
000774 - Cylinder 6
               P0306 - 000 - Misfire Detected - Intermittent
                    Fault Status: 00100001
                    Mileage: 74210 km
                    Date: 2020.03.13
                    Time: 14:38:41
                    RPM: 672 /min
                    Mass Air / Rev.: 119.9 mg/str
                    Temperature: 93.0°C
                    Bin. Bits: 00000010
                    Time: 2201.6 s
004874 - Cylinder Disabling
               P130A - 000 -  - Intermittent
                    Mileage: 74210 km
                    Date: 2020.03.13
                    Time: 14:38:41
                    RPM: 160 /min
                    Mass Air / Rev.: 376.1 mg/str
                    Temperature: 102.0°C
                    Bin. Bits: 00000001
                    Time: 0.0 s
004263 - Adaptation of Intake Air Regulating Flap
               P10A7 - 000 - Clogged/Dirty - Intermittent
                    Mileage: 74210 km
                    Date: 2020.03.24
                    Time: 11:32:54
                    RPM: 928 /min
                    Absolute Pres.: 899.1 mbar
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Voltage: 4.540 V
                    Voltage: 0.600 V
004260 - Intake Air Regulating Flap
               P10A4 - 000 - Mechanical Malfunction - Intermittent
                    Mileage: 74211 km
                    Date: 2020.03.28
                    Time: 10:17:04
                    RPM: 96 /min
                    Absolute Pres.: 1010.8 mbar
                    (no units): 0.00
                    (no units): 8.20
                    Voltage: 0.920 V
                    (no units): 100.0
   Part No SW: 0C8 927 750 M    HW: 0C8 927 750 M
   Component: AL1000 AISIN  001 2087
   Coding: 001178
   Shop #: WSC 02318 003 1048576
   ASAM Dataset: EV_TCMAL991031 002112
   ROD: EV_TCMAL991031_002.rod
   VCID: 3663735A893F96FF4D-8062
Address 03: ABS Brakes        Labels:. 4L0-910-517-V2.clb
   Part No SW: 4L0 910 517 M    HW: 4L0 614 517 L
   Component: ESP ALLRAD MK25E1   0020
   Revision: 00H02001
   Coding: 0099409
   VCID: 34674952574384EF73-8060
                    Reset counter: 195
                    Mileage: 74064 km
                    Date: 2020.02.15
                    Time: 16:00:28
                    Count: 10305
                    Count: 128
                    Count: 35072
                    Fault Status: 00101101
                    Reset counter: 195
                    Mileage: 74210 km
                    Date: 2020.03.13
                    Time: 14:38:41
                    Count: 8513
                    Count: 8196
                    Count: 51712
                    Reset counter: 0
                    Mileage: 74210 km
                    Count: 128
                    Count: 11073
                    Count: 297
                    Count: 28672
   Part No SW: 4F0 910 852 B    HW: 4F0 905 852 H
   Component: FBSAUDIC6 ELV   H08 0200
   Revision: 00H08000    Serial number: 10603701987205
   Coding: 0000183
   VCID: 2541A416EC99ED67F4-8070
   Subsystem 1 - Part No: 4F0 910 132 Q
   Component: FBSAUDIC6 EZS   H04 0020
   Subsystem 2 - Part No: 4F0 910 335 B
   Component: FBSAUDIC6 KSG   H03 0020
00190 - Driver's Door Handle Touch Sensor (G415)
                    Fault Status: 01110111
                    Reset counter: 157
                    Mileage: 73621 km
                    Date: 2019.10.04
                    Time: 12:24:00
            007 - Short to Ground
                    Fault Status: 00111011
                    Reset counter: 191
00532 - Supply Voltage B+
                    Fault Frequency: 10
                    Reset counter: 40
                    Mileage: 74210 km
                    Date: 2020.03.07
                    Time: 05:30:27
                    Fault Frequency: 25
                    Reset counter: 197
                    Mileage: 74210 km
                    Date: 2020.03.07
                    Time: 05:29:31
   Part No SW: 4L0 910 043 D    HW: 4L0 820 043 AH
   Component: KLIMA 4 ZONEN H15 0070
   Revision: 00---026    Serial number: 00000000323693
   Coding: 000CC446
   VCID: 2541A4162C99ED67F4-8070
                    Fault Frequency: 12
                    Reset counter: 195
                    Mileage: 74064 km
                    Date: 2020.02.15
                    Time: 16:01:05
                    Voltage: 9.60 V
                    Reset counter: 192
                    Mileage: 74210 km
                    Date: 2020.03.13
                    Time: 13:28:22
                    Voltage: 7.80 V
   Part No SW: 4F0 910 279 AG    HW: 4F0 907 279 C
   Component: ILM Fahrer      H31 0400
   Coding: 0123122
   VCID: 6ED39B3A79EFEE3F45-803A
   Subsystem 1 - Part No: 4L2 910 113   Labels: 1KX-955-119.CLB
   Component: Wischer AU716   H13 0110
   Coding: 00064792
   Shop #: WSC 31414
   Coding: 00152619
   Shop #: WSC 31414
01800 - Light Switch (E1)
                    Reset counter: 194
                    Mileage: 74208 km
                    Date: 2020.03.13
                    Time: 14:02:00
                    Fault Frequency: 12
                    Reset counter: 197
                    Mileage: 74064 km
                    Date: 2020.02.15
                    Time: 16:01:00
                    Reset counter: 197
                    Mileage: 74208 km
                    Date: 2020.03.07
                    Time: 05:30:00
Address 0E: Media Player 1 (R41)       Labels: 4E0-910-111.lbl
   Part No SW: 4F0 035 110 A    HW: 4F0 035 110
   Component: CDC-MP3-Alp   H44 0140
   Revision: AA001001
   VCID: 152194D6FCF97DE764-8040
                    Reset counter: 196
                    Mileage: 74210 km
                    Date: 2020.03.25
                    Time: 16:12:28
                    Voltage: 8.20 V
   Part No SW: 4L0 910 655 D    HW: 4L0 959 655 C
   Component: 70 AIRBAG AUDI8RH43 0230
   Revision: 04H43000    Serial number: 00399D093VKB
   Coding: 0014128
   VCID: 2E535B3AB96FAE3F05-807A
   Subsystem 1 - Serial number: 6332QSME6C141158D
   Subsystem 2 - Serial number: 6342QSME74140F68L
   Subsystem 3 - Serial number: 6352QSME3C135348G
   Subsystem 4 - Serial number: 6362QSME4D14087ET
   Subsystem 5 - Serial number: 63734SME39130176V
   Subsystem 6 - Serial number: 63834SME3913196C3
   Part No SW: 4F0 910 549 B    HW: 4F0 953 549 E
   Component: J0527               0830
   Revision: 00H08000    Serial number: 90026120890033
   Coding: 0112142
   VCID: 285FAD229B8BF00FCF-807C
   Component: E0221           H03 0030
                    Fault Frequency: 17
                    Reset counter: 197
                    Mileage: 74210 km
                    Date: 2020.03.07
                    Time: 05:29:33
                    Reset counter: 197
                    Mileage: 74210 km
                    Date: 2020.03.07
                    Time: 05:30:28
Address 17: Instruments (J285)       Labels:. 4L0-920-xxx-17.clb
   Part No SW: 4L0 920 932 Q    HW: 4L0 920 932 Q
   Component: KOMBIINSTR.   H22 0411
   Revision: 00200000    Serial number: LMY50NU4D
   Coding: 235F63040000000C010904
   VCID: 3A7B676AB527729FA9-806E
                    Reset counter: 192
                    Mileage: 74210 km
                    Date: 2020.03.13
                    Time: 13:27:25
   Part No SW: 4F0 907 468 R    HW: 4F0 907 468 F
   Component: GW-BEM 4CAN-M H06 0057
   Revision: LB500035    Serial number: 3500L124020262
   Coding: 00C303
   VCID: 3E736B7AA90F5EBF95-806A
   Subsystem 1 - Part No SW: 8K0 915 181 D    HW: 8K0 915 181 D
   Component: J367-BDM  H07 0125
   Serial number: 00000000002790833304
                    Fault Frequency: 14
                    Reset counter: 157
                    Mileage: 74064 km
                    Date: 2020.02.15
                    Time: 15:47:33
                    Bin. Bits:    10111
                    Voltage: 10.80 V
                    Count: 7
                    Fault Frequency: 10
                    Reset counter: 196
                    Mileage: 74210 km
                    Date: 2020.03.07
                    Time: 05:30:28
                    Bin. Bits:    00000
                    Voltage: 7.20 V
                    Count: 12
Address 28: HVAC, Rear        Labels: None
   Part No SW: 4L0 910 158     HW: 4L0 919 158 AB
   Component: KLIMABETAETIGUNGH06 0060
   Revision: 00---010    Serial number: 00000000324914
   Coding: 0000006
   VCID: 68DFED225B0B300F0F-803C
                    Fault Frequency: 12
                    Reset counter: 195
                    Mileage: 74064 km
                    Date: 2020.02.15
                    Time: 16:00:59
                    Voltage: 9.60 V
                    Fault Status: 01101101
                    Reset counter: 129
                    Mileage: 73628 km
                    Date: 2020.01.14
                    Time: 04:33:59
                    Reset counter: 192
                    Mileage: 74210 km
                    Date: 2020.03.13
                    Time: 13:28:22
                    Voltage: 7.80 V
   Part No SW: 4F0 959 760 D    HW: 4F0 959 760 D
   Component: MEM-FS        H08 0064
   Revision: AA000000    Serial number: 00000026558213
   Coding: 00781B00000011110000
   VCID: 326B4F4A6D578ADF61-8066
                    Fault Frequency: 19
                    Reset counter: 195
                    Mileage: 74210 km
                    Date: 2020.03.07
                    Time: 05:30:27
                    Reset counter: 194
                    Mileage: 74210 km
                    Date: 2020.03.07
                    Time: 05:32:44
   Part No SW: 4F0 959 793 T    HW: 8K0 959 793 M
   Component: TSG FA        H12 0362
   Revision:             Serial number: 0000028311430
   Coding: 011C52205E41440004
   VCID: 489F0DA2FBCB100F2F-801C
                    Fault Frequency: 16
                    Reset counter: 196
                    Mileage: 74210 km
                    Date: 2020.03.07
                    Time: 05:29:36
                    Reset counter: 195
                    Mileage: 74210 km
                    Date: 2020.03.07
                    Time: 05:30:30
   Part No SW: 4L0 910 289 K    HW: 4L0 907 289 K
   Component: Komfortgeraet   H12 0130
   Revision: 0130 ---    Serial number: 01587026550000
   Coding: 3276941
   VCID: 387F7D624B2B608F5F-806C
                    Reset counter: 192
                    Mileage: 74210 km
                    Date: 2020.03.07
                    Time: 05:32:20
   Part No SW: 4L0 035 223 J    HW: 4L0 035 223 G
   Component: BOSE G3 Q7    H04 0160
   Revision: CH004000    Serial number: 00000000011550
   Coding: 030000
   VCID: 2959A8264081C907D0-807C
                    Reset counter: 163
03405 - Bass Loudspeaker
                    Reset counter: 197
   Part No SW: 4F0 910 280     HW: 4F0 907 280
   Component: ILM Beifahrer   H16 0100
   Revision:             Serial number: 00000000642107
   Coding: 0011001
   VCID: 5EB3CBFA894F7EBFF5-800A
                    Fault Status: 00110010
                    Reset counter: 191
                    Mileage: 74208 km
                    Date: 2020.03.07
                    Time: 05:30:00
                    Voltage: 7.400 V
                    Temperature: 16.0°C
                    Reset counter: 192
                    Mileage: 74208 km
                    Date: 2020.03.13
                    Time: 13:37:00
                    Voltage: 8.100 V
                    Temperature: 20.0°C
                    Fault Frequency: 23
                    Reset counter: 196
                    Mileage: 74208 km
                    Date: 2020.03.07
                    Time: 05:29:00
                    Voltage: 6.900 V
                    Temperature: 15.0°C
   Part No SW: 4F0 959 792 T    HW: 8K0 959 792 M
   Component: TSG BF        H12 0362
   Revision:             Serial number: 0000028502402
   VCID: 479D0E9EF6D51F7726-8012
                    Fault Frequency: 16
                    Reset counter: 196
                    Mileage: 74210 km
                    Date: 2020.03.07
                    Time: 05:29:36
                    Fault Frequency: 6
                    Reset counter: 195
                    Mileage: 74210 km
                    Date: 2020.03.07
                    Time: 05:30:30
   Part No SW: 8X0 907 357 C    HW: 8X0 907 357 B
   Component: ****LWR12**** H02 0012
   Serial number: 120425-0004-115
   Coding: 1147A71010000000
   ROD: EV_HeadlRegulBasic.rod
   VCID: 428B1F8AD5F73A5FF1-8016
   Part No SW: 4G0 035 083     HW: 4G0 035 083
   Component: Radio U JP    H50 0055
   Revision: AB001007    Serial number: 448D00C7531659
   Coding: 030005010000000000
   VCID: 5EB3CBFA494F7EBFF5-800A
                    Fault Frequency: 6
                    Reset counter: 197
                    Mileage: 74210 km
                    Date: 2020.03.07
                    Time: 05:29:58
                    Voltage: 6.90 V
02981 - Connection between Radio and Impedance Converter 1
                    Fault Status: 00101011
                    Reset counter: 194
                    Mileage: 74210 km
                    Date: 2020.02.28
                    Time: 12:35:16
                    Voltage: 11.70 V
02982 - Connection between Radio and Impedance Converter 2
                    Reset counter: 194
                    Mileage: 74210 km
                    Date: 2020.03.23
                    Time: 14:26:58
                    Voltage: 10.30 V
03455 - Function Restriction due to Faults in Other Modules
                    Reset counter: 194
                    Mileage: 74210 km
                    Date: 2020.03.24
                    Time: 11:33:18
                    Bin. Bits: 00000000 00000001
Address 57: TV Tuner (R78)       Labels: None
   Part No SW: 8F0 919 129 E    HW: 8F0 919 129
   Component: DTV-JP        H07 0760
   Revision: R0070000    Serial number: 79300703587601
   Coding: 100300
   Shop #: WSC 31414 000 90108
   Subsystem 1 - Part No SW: 4F0 919 805     HW: 4F0 919 805
   Component: R204 TVKLeser  H07 0010
   Serial number: 2172800600829203
                    Reset counter: 195
                    Mileage: 74210 km
                    Date: 2020.03.07
                    Time: 05:30:38
   Part No SW: 4L2 035 678     HW: 4L2 035 678
   Component: H-BN-JP       H16 0238
   Revision: --------    Serial number: K5FAN1NJAE7ZW
   Coding: 18060106030481FF41000345EF632003FC0000020100000000
   VCID: 6FED863EBEE5E7374E-803A
   Subsystem 1 - Part No: 8R0 060 884 AF
   Component: JPN-12.07.11.  7520
   Subsystem 2 - Part No SW: 4F0 035 503 E    HW: 4F0 035 503 E
   Component: ETC-VICS-Ant.  H04 0020
   Subsystem 3 - Part No SW: 4L0 919 813 E    HW: 4L0 919 813 E
   Component: Card reader  H03 0110
   Serial number: 382112030188
   Subsystem 4 - Part No SW: 8R0 919 604     HW: 8R0 919 604
   Component: DU7 High  H41 0104
   Serial number: A130D70CS155951
   Subsystem 5 - Part No SW: 4L0 919 614 C    HW: 4L0 919 614 C
   Component: E0380 Bedient  H01 0060
   Serial number: 00000002006289
   Subsystem 6 - Part No: 8R0 060 961 C
   Component: CD-Database  3638
                    Reset counter: 196
                    Mileage: 74210 km
                    Date: 2020.03.07
                    Time: 05:30:28
                    Voltage: 7.50 V
03367 - Supply Voltage for Display Module
                    Reset counter: 195
                    Mileage: 74210 km
                    Date: 2020.03.07
                    Time: 05:30:06
                    Voltage: 7.20 V
   Part No SW: 4F0 959 795 P    HW: 4F0 959 795 P
   Component: TSG HL        H11 0362
   Revision:             Serial number: 0000027887398
   Coding: 010850204041230004
   VCID: 4683039AF1DF067FDD-8012
                    Fault Frequency: 17
                    Reset counter: 196
                    Mileage: 74210 km
                    Date: 2020.03.07
                    Time: 05:29:35
                    Fault Frequency: 7
                    Reset counter: 195
                    Mileage: 74210 km
                    Date: 2020.03.07
                    Time: 05:30:29
   Part No SW: 4L0 910 441 B    HW: 4L0 907 441 B
   Component: J772__Rearview      0030
   Revision: --H07---    Serial number: 525PA8-J24409E
   Coding: 1021001
                    Fault Frequency: 16
                    Reset counter: 197
                    Mileage: 74210 km
                        Term 15 On
                        Reverse OFF
                    Count: 3
                    Reset counter: 195
                    Mileage: 74210 km
                        Term 15 On
                        Reverse OFF
                    Count: 3
                    Reset counter: 157
                    Mileage: 74211 km
                    Date: 2020.04.03
                    Time: 13:23:58
                        Term 15 On
                        Reverse OFF
                    Count: 3
   Part No SW: 4L0 910 945     HW: 4L0 827 851 E
   Component: ValeoHeckdeckel H57 0500
   Revision: --H57001    Serial number: E5030000B
   Shop #: WSC 98765 666 38354
   VCID: 6CD791324FF31C2F6B-8038
   Subsystem 3 - Serial number: RD26.04.12--H57001001A0008ÿ
   Subsystem 4 - Serial number: 1A0008ÿ
   Part No SW: 4L0 910 290     HW: 4L0 907 290
   Component: ILM HINTEN 2    H08 0080
   Revision: AAH08080    Serial number: 126686823-----
   Coding: 0000001
                    Reset counter: 194
                    Mileage: 74210 km
                    Date: 2020.03.07
                    Time: 05:30:35
   Component: TSG HR        H11 0362
   Revision:             Serial number: 0000027882855
                    Fault Frequency: 15
                    Reset counter: 196
                    Mileage: 74210 km
                    Date: 2020.03.07
                    Time: 05:29:35
                    Fault Frequency: 6
                    Reset counter: 195
                    Mileage: 74210 km
                    Date: 2020.03.07
                    Time: 05:30:29
   Part No SW: 4L0 910 283 E    HW: 4L0 919 283 E
   Component: Parkhilfe 8-Kan H03 0100
   Revision: 00H03000    Serial number: 37331211201535
   Coding: 0221066
   VCID: 2C5751328F73DC2F2B-8078
                    Reset counter: 192
                    Mileage: 74210 km
                    Date: 2020.03.13
                    Time: 13:28:27
                    Fault Frequency: 9
                    Reset counter: 195
                    Mileage: 74210 km
                    Date: 2020.03.13
                    Time: 13:27:32
End-------------------------(Elapsed Time: 03:40)--------------------------
Address 01: DTCs cleared
Address 19: DTCs cleared
Address 09,4F0 910 279 AG,recoded (Short coding),from,0123122,to,0123121,(31414/790/00001),
Address 09,4F0 910 279 AG,recoded (Short coding),from,0123121,to,0123101,(31414/790/00001),
This is the scan once the car was started and codes cleared
Friday,03,April,2020,14:40:50:30955
VIN: WAUZZZ4L3CD040833   License Plate: Q7 CHARGED 3 APR 2020
                    Fault Status: 01101000
                    Mileage: 74211 km
                    Date: 2020.04.03
                    Time: 13:34:26
                    RPM: 96 /min
                    Absolute Pres.: 1016.1 mbar
                    (no units): 0.00
                    (no units): 24.60
                    Voltage: 1.740 V
                    (no units): 100.0
                    Mileage: 74211 km
                    Date: 2020.04.03
                    Time: 13:34:27
                    RPM: 1696 /min
                    Mass Air / Rev.: 163.5 mg/str
                    Temperature: 15.0°C
                    Bin. Bits: 00000010
                    Load: 15.3 %
Readiness: 0110 0001
   Coding: 001178
   Revision: 00H02001
   Coding: 0099409
                    Reset counter: 157
                    Mileage: 74211 km
                    Date: 2020.04.03
                    Time: 13:28:45
                    Count: 8517
                    Count: 297
                    Count: 43520
   Coding: 0000183
   Coding: 000CC446
   Coding: 0123101
   Coding: 00064792
   Shop #: WSC 31414
   Coding: 00152619
   Shop #: WSC 31414
   Revision: AA001001
   Coding: 0014128
   Coding: 0112142
   Coding: 00C303
                    Reset counter: 197
                    Mileage: 74211 km
                    Date: 2020.04.03
                    Time: 13:29:11
                    Bin. Bits:    10111
                    Voltage: 11.90 V
                    Count: 7
   Coding: 0000006
   Coding: 3276941
   Coding: 030000
   Coding: 0011001
   Coding: 100300
   Coding: 1021001
   Coding: 0000001
   Coding: 0221066
End---------------------(Elapsed Time: 03:25, udsna)-----------------------
Address 03: DTCs cleared
Address 01: DTCs cleared[/QUOTE]
This is after the codes were cleared and car taken for a drive with no errors on dash
Friday,03,April,2020,14:54:56:30955 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64 VCDS Version: 19.6.2.0 (x64) Data version: 20190930 DS308.0 www.Ross-Tech.com VIN: WAUZZZ4L3CD040833 License Plate: Q7 AFTR DRIVE 3 APR 2020 NO CODES Mileage: 74210km-46111mi Repair Order: -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 4L-AU56 (4F0) Scan: 01 02 03 05 08 09 0E 15 16 17 19 28 36 42 46 47 4F 52 55 56 57 5F 62 6C 6D 6F 72 76 VIN: WAUZZZ4L3CD040833 Mileage: 74210km-46111miles 01-Engine -- Status: OK 0000 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 04-Steering Angle -- Status: OK 0000 05-Acc/Start Auth. -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: OK 0000 0E-Media Player 1 -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: Malfunction 0010 28-HVAC, Rear -- Status: OK 0000 36-Seat Mem. Drvr -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 46-Central Conv. -- Status: OK 0000 47-Sound System -- Status: OK 0000 4F-Centr. Electr. II -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 55-Headlight Range -- Status: OK 0000 56-Radio -- Status: OK 0000 57-TV Tuner -- Status: OK 0000 5F-Information Electr. -- Status: OK 0000 62-Door, Rear Left -- Status: OK 0000 6C-Back-up Cam. -- Status: OK 0000 6D-Trunk Elect. -- Status: OK 0000 6F-Centr. Conv. II -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 76-Park Assist -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine (CJT) Labels: None Part No SW: 4L0 910 551 HW: 4L0 907 551 Component: 3.0l V6 TFSI 0070 Revision: --H08--- Serial number: Coding: 0121000C290F0128 Shop #: WSC 31414 790 00001 VCID: 65C1E416AC192D6734-8030 No fault code found. Readiness: 0010 0001 ------------------------------------------------------------------------------- Address 02: Auto Trans (J217) Labels:| 0C8-927-750.clb Part No SW: 0C8 927 750 M HW: 0C8 927 750 M Component: AL1000 AISIN 001 2087 Serial number: Coding: 001178 Shop #: WSC 02318 003 1048576 ASAM Dataset: EV_TCMAL991031 002112 ROD: EV_TCMAL991031_002.rod VCID: 3663735A893F96FF4D-8062 No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels:. 4L0-910-517-V2.clb Part No SW: 4L0 910 517 M HW: 4L0 614 517 L Component: ESP ALLRAD MK25E1 0020 Revision: 00H02001 Coding: 0099409 Shop #: WSC 31414 790 00001 VCID: 34674952574384EF73-8060 No fault code found. ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. Labels:. 4F0-910-852.clb Part No SW: 4F0 910 852 B HW: 4F0 905 852 H Component: FBSAUDIC6 ELV H08 0200 Revision: 00H08000 Serial number: 10603701987205 Coding: 0000183 Shop #: WSC 31414 790 00001 VCID: 2541A416EC99ED67F4-8070 Subsystem 1 - Part No: 4F0 910 132 Q Component: FBSAUDIC6 EZS H04 0020 Subsystem 2 - Part No: 4F0 910 335 B Component: FBSAUDIC6 KSG H03 0020 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC (J255) Labels: None Part No SW: 4L0 910 043 D HW: 4L0 820 043 AH Component: KLIMA 4 ZONEN H15 0070 Revision: 00---026 Serial number: 00000000323693 Coding: 000CC446 Shop #: WSC 31414 790 00001 VCID: 2541A4162C99ED67F4-8070 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 4F0-910-279.lbl Part No SW: 4F0 910 279 AG HW: 4F0 907 279 C Component: ILM Fahrer H31 0400 Revision: 00000000 Serial number: 4F0907279 Coding: 0123101 Shop #: WSC 31414 790 00001 VCID: 6ED39B3A79EFEE3F45-803A Subsystem 1 - Part No: 4L2 910 113 Labels: 1KX-955-119.CLB Component: Wischer AU716 H13 0110 Coding: 00064792 Shop #: WSC 31414 Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB Component: REGENLICHTSENSORH04 0003 Coding: 00152619 Shop #: WSC 31414 No fault code found. ------------------------------------------------------------------------------- Address 0E: Media Player 1 (R41) Labels: 4E0-910-111.lbl Part No SW: 4F0 035 110 A HW: 4F0 035 110 Component: CDC-MP3-Alp H44 0140 Revision: AA001001 VCID: 152194D6FCF97DE764-8040 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: 4L0-910-655.lbl Part No SW: 4L0 910 655 D HW: 4L0 959 655 C Component: 70 AIRBAG AUDI8RH43 0230 Revision: 04H43000 Serial number: 00399D093VKB Coding: 0014128 Shop #: WSC 31414 790 00001 VCID: 2E535B3AB96FAE3F05-807A Subsystem 1 - Serial number: 6332QSME6C141158D Subsystem 2 - Serial number: 6342QSME74140F68L Subsystem 3 - Serial number: 6352QSME3C135348G Subsystem 4 - Serial number: 6362QSME4D14087ET Subsystem 5 - Serial number: 63734SME39130176V Subsystem 6 - Serial number: 63834SME3913196C3 No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 4F0-910-549.lbl Part No SW: 4F0 910 549 B HW: 4F0 953 549 E Component: J0527 0830 Revision: 00H08000 Serial number: 90026120890033 Coding: 0112142 Shop #: WSC 31414 790 00001 VCID: 285FAD229B8BF00FCF-807C Subsystem 1 - Part No: XXXXXXXXXXX Component: E0221 H03 0030 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels:. 4L0-920-xxx-17.clb Part No SW: 4L0 920 932 Q HW: 4L0 920 932 Q Component: KOMBIINSTR. H22 0411 Revision: 00200000 Serial number: LMY50NU4D Coding: 235F63040000000C010904 Shop #: WSC 31414 790 00001 VCID: 3A7B676AB527729FA9-806E No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels:. 4F0-907-468.clb Part No SW: 4F0 907 468 R HW: 4F0 907 468 F Component: GW-BEM 4CAN-M H06 0057 Revision: LB500035 Serial number: 3500L124020262 Coding: 00C303 Shop #: WSC 31414 790 00001 VCID: 3E736B7AA90F5EBF95-806A Subsystem 1 - Part No SW: 8K0 915 181 D HW: 8K0 915 181 D Component: J367-BDM H07 0125 Serial number: 00000000002790833304 1 Fault Found: 03041 - Energy Management Active 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 7 Fault Frequency: 1 Reset counter: 197 Mileage: 74211 km Time Indication: 0 Date: 2020.04.03 Time: 13:29:11 Freeze Frame: Bin. Bits: 10111 Voltage: 11.90 V Count: 7 ------------------------------------------------------------------------------- Address 28: HVAC, Rear Labels: None Part No SW: 4L0 910 158 HW: 4L0 919 158 AB Component: KLIMABETAETIGUNGH06 0060 Revision: 00---010 Serial number: 00000000324914 Coding: 0000006 Shop #: WSC 31414 790 00001 VCID: 68DFED225B0B300F0F-803C No fault code found. ------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr (J136) Labels: None Part No SW: 4F0 959 760 D HW: 4F0 959 760 D Component: MEM-FS H08 0064 Revision: AA000000 Serial number: 00000026558213 Coding: 00781B00000011110000 Shop #: WSC 31414 790 00001 VCID: 326B4F4A6D578ADF61-8066 No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver (J386) Labels:. 4F0-959-793.clb Part No SW: 4F0 959 793 T HW: 8K0 959 793 M Component: TSG FA H12 0362 Revision: Serial number: 0000028311430 Coding: 011C52205E41440004 Shop #: WSC 31414 790 00001 VCID: 489F0DA2FBCB100F2F-801C No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels:. 4L0-910-289.lbl Part No SW: 4L0 910 289 K HW: 4L0 907 289 K Component: Komfortgeraet H12 0130 Revision: 0130 --- Serial number: 01587026550000 Coding: 3276941 Shop #: WSC 31414 790 00001 VCID: 387F7D624B2B608F5F-806C No fault code found. ------------------------------------------------------------------------------- Address 47: Sound System (J525) Labels: None Part No SW: 4L0 035 223 J HW: 4L0 035 223 G Component: BOSE G3 Q7 H04 0160 Revision: CH004000 Serial number: 00000000011550 Coding: 030000 Shop #: WSC 31414 790 00001 VCID: 2959A8264081C907D0-807C No fault code found. ------------------------------------------------------------------------------- Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl Part No SW: 4F0 910 280 HW: 4F0 907 280 Component: ILM Beifahrer H16 0100 Revision: Serial number: 00000000642107 Coding: 0011001 Shop #: WSC 31414 790 00001 VCID: 5EB3CBFA894F7EBFF5-800A No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. (J387) Labels:. 4F0-959-792.clb Part No SW: 4F0 959 792 T HW: 8K0 959 792 M Component: TSG BF H12 0362 Revision: Serial number: 0000028502402 Coding: 011C52205E41440004 Shop #: WSC 31414 790 00001 VCID: 479D0E9EF6D51F7726-8012 No fault code found. ------------------------------------------------------------------------------- Address 55: Headlight Range (J431) Labels:| 8X0-907-357.clb Part No SW: 8X0 907 357 C HW: 8X0 907 357 B Component: ****LWR12**** H02 0012 Serial number: 120425-0004-115 Coding: 1147A71010000000 Shop #: WSC 31414 790 00001 ASAM Dataset: EV_HeadlRegulBasic 005001 ROD: EV_HeadlRegulBasic.rod VCID: 428B1F8AD5F73A5FF1-8016 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio (R) Labels: Redir Fail! Part No SW: 4G0 035 083 HW: 4G0 035 083 Component: Radio U JP H50 0055 Revision: AB001007 Serial number: 448D00C7531659 Coding: 030005010000000000 Shop #: WSC 31414 790 00001 VCID: 5EB3CBFA494F7EBFF5-800A No fault code found. ------------------------------------------------------------------------------- Address 57: TV Tuner (R78) Labels: None Part No SW: 8F0 919 129 E HW: 8F0 919 129 Component: DTV-JP H07 0760 Revision: R0070000 Serial number: 79300703587601 Coding: 100300 Shop #: WSC 31414 000 90108 VCID: 326B4F4A6D578ADF61-8066 Subsystem 1 - Part No SW: 4F0 919 805 HW: 4F0 919 805 Component: R204 TVKLeser H07 0010 Serial number: 2172800600829203 No fault code found. ------------------------------------------------------------------------------- Address 5F: Information Electr. (J794) Labels:. 4E0-035-6xx-5F.clb Part No SW: 4L2 035 678 HW: 4L2 035 678 Component: H-BN-JP H16 0238 Revision: -------- Serial number: K5FAN1NJAE7ZW Coding: 18060106030481FF41000345EF632003FC0000020100000000 Shop #: WSC 31414 790 00001 VCID: 6FED863EBEE5E7374E-803A Subsystem 1 - Part No: 8R0 060 884 AF Component: JPN-12.07.11. 7520 Subsystem 2 - Part No SW: 4F0 035 503 E HW: 4F0 035 503 E Component: ETC-VICS-Ant. H04 0020 Subsystem 3 - Part No SW: 4L0 919 813 E HW: 4L0 919 813 E Component: Card reader H03 0110 Serial number: 382112030188 Subsystem 4 - Part No SW: 8R0 919 604 HW: 8R0 919 604 Component: DU7 High H41 0104 Serial number: A130D70CS155951 Subsystem 5 - Part No SW: 4L0 919 614 C HW: 4L0 919 614 C Component: E0380 Bedient H01 0060 Serial number: 00000002006289 Subsystem 6 - Part No: 8R0 060 961 C Component: CD-Database 3638 No fault code found. ------------------------------------------------------------------------------- Address 62: Door, Rear Left (J388) Labels:. 4F0-959-795.clb Part No SW: 4F0 959 795 P HW: 4F0 959 795 P Component: TSG HL H11 0362 Revision: Serial number: 0000027887398 Coding: 010850204041230004 Shop #: WSC 31414 790 00001 VCID: 4683039AF1DF067FDD-8012 No fault code found. ------------------------------------------------------------------------------- Address 6C: Back-up Cam. Labels: 4L0-910-441.clb Part No SW: 4L0 910 441 B HW: 4L0 907 441 B Component: J772__Rearview 0030 Revision: --H07--- Serial number: 525PA8-J24409E Coding: 1021001 Shop #: WSC 31414 790 00001 VCID: 2541A416EC99ED67F4-8070 No fault code found. ------------------------------------------------------------------------------- Address 6D: Trunk Elect. Labels: None Part No SW: 4L0 910 945 HW: 4L0 827 851 E Component: ValeoHeckdeckel H57 0500 Revision: --H57001 Serial number: E5030000B Shop #: WSC 98765 666 38354 VCID: 6CD791324FF31C2F6B-8038 Subsystem 1 - Part No: 4L0 910 946 Component: ValeoHeckdeckel H57 0500 Subsystem 2 - Serial number: E5030100B Subsystem 3 - Serial number: RD26.04.12--H57001001A0008ÿ Subsystem 4 - Serial number: 1A0008ÿ No fault code found. ------------------------------------------------------------------------------- Address 6F: Centr. Conv. II Labels:. 4L0-910-290.lbl Part No SW: 4L0 910 290 HW: 4L0 907 290 Component: ILM HINTEN 2 H08 0080 Revision: AAH08080 Serial number: 126686823----- Coding: 0000001 Shop #: WSC 31414 790 00001 VCID: 65C1E416AC192D6734-8030 No fault code found. ------------------------------------------------------------------------------- Address 72: Door, Rear Right (J389) Labels:. 4F0-959-795.clb Part No SW: 4F0 959 795 P HW: 4F0 959 795 P Component: TSG HR H11 0362 Revision: Serial number: 0000027882855 Coding: 010850204041230004 Shop #: WSC 31414 790 00001 VCID: 4683039AF1DF067FDD-8012 No fault code found. ------------------------------------------------------------------------------- Address 76: Park Assist Labels: 4Fx-910-283.lbl Part No SW: 4L0 910 283 E HW: 4L0 919 283 E Component: Parkhilfe 8-Kan H03 0100 Revision: 00H03000 Serial number: 37331211201535 Coding: 0221066 Shop #: WSC 31414 790 00001 VCID: 2C5751328F73DC2F2B-8078 No fault code found. End-------------------------(Elapsed Time: 03:35)--------------------------
[/url][/IMG]
[/url][/IMG]
DV52
C?ID=194404
hmm......... sounds very much like this is a process of elimination problem: the car has a build date of 2012 and it has traveled 74,210kms. So, about 9,000 km/year (give-or-take) - which ain't much!!!
Lot's of possible reasons for the short battery life, including:
nearing the end of the battery's useful life;
mismatch of the charge / discharge ratio when charging from the alternator;
alternator failure (unlikely given the absence of DTCs suggesting this cause);
external leakage currents due to wiring insulation failure, or due to incorrect installation of aftermarket equipment (car radio, alarm system, camera)
I'm not sure given the information provided which of the above is more likely - but an easy-try (without spending any money) might be to check the last option on the list. My colleague, Jack probably has a more professional method for checking leakage currents - but my amateur process is to lift the negative battery lead and place an amp-meter between the battery lead and the battery post (I assume that you don't have a clamp-ammeter). With the ignition key removed and no other accessories running - I normally expect < about 80 milli-amps. Don't be alarmed if the reading is much higher immediately after you make the amp-meter connection - this is not unusual, but you should see a steady decay in the reading.
You could then run a quick test on the alternator voltage with the headlights OFF and ON. If that proves to be OK - the guilty party probably is the battery (I reckon)
Jef
HQ
While I don't think this will be a coding issue, lets be sure it is actually back to the original coding value...
Codinglog.CSV
And of course any time you run Auto-Scan, VCDS automagically saves that Auto-Scan to the \Scans folder, so look for a copy of that BEFORE coding games were played.
To help find what circuit is "hot", please review this thread.
Is the inventory of L&P holding up well?
Maybe pull the battery history?
https://www.ross-tech.com/vcds/tour/history-data.php
I understand the battery is a PITA to get to, but in the end, the best way to tell whether the battery needs to be replaced, or whether the vehicle is pulling it down is to disconnect the batter, charge it, and then see if it self-discharges. If it self-discharges with nothing connected to it, then it obviously needs to be replaced. If it stays fully charged with nothing connected to it, then it's time to start looking for parasitic draw per the link Jef posted above.
webup
Auckland
C?ID=256879
Update: So i looked in VCDS and cant access any battery stats
Charged battery today on charger and put multimeter on it (just touching the positive terminal under bonnet and the earth post under bonnet) and can see the voltage slowly going down and down i.e 12.58, 12.57, 12.56 every few seconds
Codinglog.CSV
Coding log - doesnt make sense to me as i cant see what vehicle each line relates to
Address 19,1K0 907 530 E,recoded (Installation List),from,3F3F0348070003,to,3F3F0300070003,,Saturday,21,January,2017,12:55:53:30955
Address 19,1K0 907 530 L,recoded (Installation List),from,ED817F060002020003,to,ED817F060000020003,,Tuesday,24,January,2017,10:14:49:30955
Address 17,8R0 920 930 A,recoded (Long Coding),from,2F0622003200000C010000,to,230622003200000C010000,(61819/741/94076),Monday,27,February,2017,12:42:55:30955
Address 17,5K0 920 872 ,recoded (Long Coding),from,570F00,to,570D00,(01357/011/00200),Saturday,11,March,2017,13:14:37:30955
Address 19,7N0 907 530 H,recoded (Installation List),from,ED817F060002020000,to,ED817F060000020000,,Saturday,11,March,2017,13:16:17:30955
Address 01,1K0 907 115 A,recoded (Long Coding),from,040300031C070160,to,040300031C050160,(00046/412/00000),Saturday,18,March,2017,15:30:11:30955
Address 01,1K0 907 115 A,recoded (Long Coding),from,040300031C070160,to,040300031C050160,(00046/412/12345),Saturday,18,March,2017,15:30:20:30955
Address 01,1K0 907 115 A,recoded (Long Coding),from,040300031C070160,to,040300031C050160,(00046/412/00000),Saturday,18,March,2017,15:30:49:30955
Address 09,8K0 907 063 P,recoded (Long Coding),from,260010800030AF313F01000300001D0D0F9DC74800010141000000,to,2600D2800030AF313F01000300001D0D0F9DC74800010141000000,(63829/741/109272),Friday,24,March,2017,09:18:47:30955
Address 09,8K0 907 063 P,recoded (Long Coding),from,2600D2800030AF313F01000300001D0D0F9DC74800010141000000,to,2600D2910030AF313F01000300001D0D0F9DC74800010141000000,(63829/741/109272),Friday,24,March,2017,09:20:29:30955
Address 17,8K0 920 930 F,recoded (Long Coding),from,2F071100BA00000C010000,to,234F1100BA00000C010000,(06335/000/00000),Friday,24,March,2017,09:23:33:30955
Address 09,8K0 907 063 D,recoded (Long Coding),from,260010000030AF311F09000300005D5D0F9DC3C800010141000000,to,260092100030AF311F09000300005D5D0F9DC3C800010141000000,(06325/000/00000),Tuesday,18,April,2017,09:40:04:30955
Address 17,8T0 920 931 B,recoded (Long Coding),from,2F0701003A00000C010000,to,2F0F01003A00000C010000,(06325/000/00000),Tuesday,18,April,2017,09:41:51:30955
Address 17,8T0 920 931 B,recoded (Long Coding),from,2F0F01003A00000C010000,to,230F01003A00000C010000,(06325/123/12345),Tuesday,18,April,2017,09:45:33:30955
Address 19,8T0 907 468 P,recoded (Installation List),from,3F73F4ED689600,to,3F73F4EF689600,,Saturday,22,April,2017,15:34:06:30955
Address 09,8K0 907 063 D,recoded (Long Coding),from,260092100030AF311F09000300005D5D0F9DC3C800010141000000,to,260092110030AF311F09000300005D5D4F9DC3C800010141000000,(06325/123/12345),Saturday,22,April,2017,17:02:05:30955
Address 19,1K0 907 530 F,recoded (Installation List),from,7F3F0340070003,to,7F3F0300070003,,Thursday,04,May,2017,09:33:19:30955
Address 09,8K0 907 063 N,recoded (Long Coding),from,260010800030AF010001000000001D0D0F1D470802010141000000,to,2600D2110030AF010001000000001D0D0F1D470802010141000000,(45110/002/1048576),Tuesday,09,May,2017,12:09:55:30955
Address 17,8R0 920 930 B,recoded (Long Coding),from,2F0622000200000C010000,to,230622000200000C010000,(45110/002/1048576),Tuesday,09,May,2017,12:11:37:30955
Address 17,8R0 920 930 B,recoded (Long Coding),from,230622000200000C010000,to,230722000200000C010000,(45110/002/104857),Tuesday,09,May,2017,12:12:09:30955
Address 09,8K0 907 063 DJ,recoded (Long Coding),from,260000008030AFF2110140C300001D0D0F9DC70827090201000008004001010200020034000000,to,260092118030AFF2110140C300001D0D0F9DC70827090201000008004001010200020034000000,(06192/000/00000),Saturday,08,July,2017,13:24:55:30955
Address 09,8K0 907 063 DJ,recoded (Long Coding),from,260000008030AFF2110140C300001D0D0F9DC70827090201000008004001010200020034000000,to,260082008030AFF2110140C300001D0D0F9DC70827090201000008004001010200020034000000,(06192/000/00000),Saturday,08,July,2017,13:25:27:30955
Address 09,8K0 907 063 DJ,recoded (Long Coding),from,260000008030AFF2110140C300001D0D0F9DC70827090201000008004001010200020034000000,to,260000018030AFF2110140C300001D0D0F9DC70827090201000008004001010200020034000000,(06192/000/00000),Saturday,08,July,2017,13:25:47:30955
Address 09,8K0 907 063 DJ,recoded (Long Coding),from,260000018030AFF2110140C300001D0D0F9DC70827090201000008004001010200020034000000,to,260010018030AFF2110140C300001D0D0F9DC70827090201000008004001010200020034000000,(06192/123/12345),Saturday,08,July,2017,13:27:21:30955
Address 09,8K0 907 063 DJ,recoded (Long Coding),from,260000018030AFF2110140C300001D0D0F9DC70827090201000008004001010200020034000000,to,260080018030AFF2110140C300001D0D0F9DC70827090201000008004001010200020034000000,(06192/123/12345),Saturday,08,July,2017,13:28:23:30955
Address 09,8K0 907 063 DJ,recoded (Long Coding),from,260080018030AFF2110140C300001D0D0F9DC70827090201000008004001010200020034000000,to,260090018030AFF2110140C300001D0D0F9DC70827090201000008004001010200020034000000,(06192/123/12345),Saturday,08,July,2017,13:28:45:30955
Address 09,8K0 907 063 DJ,recoded (Long Coding),from,260080018030AFF2110140C300001D0D0F9DC70827090201000008004001010200020034000000,to,260080118030AFF2110140C300001D0D0F9DC70827090201000008004001010200020034000000,(06192/123/12345),Saturday,08,July,2017,13:29:11:30955
Address 19,1K0 907 530 E,recoded (Installation List),from,3F3F0340070003,to,3F3F0300070003,,Wednesday,30,August,2017,11:49:18:30955
Address 19,1K0 907 530 H,recoded (Installation List),from,7F3F034007000003,to,7F3F030007000003,,Tuesday,05,September,2017,09:46:30:30955
Address 19,1K0 907 530 E,recoded (Installation List),from,3F3F0340070003,to,3F3F0300070003,,Friday,08,September,2017,12:20:45:30955
Address 19,1K0 907 530 F,recoded (Installation List),from,3F3F0340070003,to,3F3F0300070003,,Saturday,16,September,2017,13:36:46:30955
Address 19,1K0 907 530 H,recoded (Installation List),from,7F3F034007000003,to,7F3F030007000003,,Tuesday,19,September,2017,09:08:12:30955
Address 55,5M0 907 357 C,recoded (Short coding),from,1443164,to,1443164,(01357/011/00200),Tuesday,03,October,2017,17:08:45:30955
Address 19,1K0 907 530 C,recoded (Installation List),from,3F3F0340070003,to,3F3F0340070003,,Tuesday,24,October,2017,14:21:41:30955
Address 19,1K0 907 530 F,recoded (Installation List),from,7F3F0340070003,to,7F3F0300070003,,Thursday,30,November,2017,16:59:15:30955
Address 19,1K0 907 530 F,recoded (Installation List),from,7F3F0300070003,to,7F3F0340070003,,Thursday,30,November,2017,17:00:23:30955
Address 17,8R0 920 981 M,recoded (Long Coding),from,33E722006E01000C0F0000,to,23E722006E01000C0F0000,(06335/000/00000),Sunday,18,March,2018,09:35:24:30955
Address 02,02E 300 043 C,recoded (Short coding),from,0000020,to,0000020,(44551/111/44551),Tuesday,15,May,2018,14:03:39:30955
Address 02,0AM 300 057 P,recoded (Short coding),from,0000020,to,0000020,(33361/790/00999),Tuesday,14,August,2018,15:31:47:30955
Address 02,0AM 300 057 P,recoded (Short coding),from,0000020,to,0000020,(77100/790/00999),Tuesday,14,August,2018,15:38:13:30955
Address 02,0AM 300 057 P,recoded (Short coding),from,0000020,to,0000020,(77100/790/00999),Tuesday,14,August,2018,15:46:10:30955
Address 02,0AM 300 057 P,recoded (Short coding),from,0000020,to,0000020,(77100/790/00999),Tuesday,14,August,2018,15:55:18:30955
Address 02,0AM 300 057 P,recoded (Short coding),from,0000020,to,0000020,(77100/981/115492),Tuesday,14,August,2018,17:05:28:30955
Address 02,0AM 300 057 P,recoded (Short coding),from,0000020,to,0000020,(77100/981/115492),Tuesday,14,August,2018,17:07:41:30955
Address 09,3C8 937 049 E,recoded (Long Coding),from,EF8F8F2700041500471400001400000000097F075C000100000000000000,to,E78F8F2700041500471400001400000000097F075C000100000000000000,(01357/011/00200),Saturday,15,September,2018,10:40:08:30955
Address 09,1K0 937 087 L,recoded (Long Coding),from,40180A3A88251AC0408800803400082443550088736D8D60E48000240040,to,40180A3A88251AC04088008034000A24435D0088736D8D60E48000240040,(01357/011/00200),Thursday,20,September,2018,15:47:15:30955
Address 09,1K0 937 087 L,recoded (Long Coding),from,40180A3A88251AC04088008034000A24435D0088736D8D60E48000240040,to,40180A3A88251AC04088008034000A24435D0088736D8D60E48020240040,(01357/011/00200),Thursday,20,September,2018,15:50:32:30955
Address 09,1K0 937 087 L,recoded (Long Coding),from,40180A3A88251AC04088008034000A24435D0088736D8D60E48020240040,to,40180A3A88251AC04088008034000B24435D0088736D8D60E48020240040,(01357/011/00200),Thursday,20,September,2018,15:51:53:30955
Address 09,1K0 937 087 L,recoded (Long Coding),from,40180A3A88251AC04088008034000B24435D0088736D8D60E48020240040,to,40180A3A88251AC04088008034000824435D0088736D8D60648000200040,(01357/011/00200),Thursday,20,September,2018,15:53:51:30955
Address 16,1K0 953 549 BS,recoded (Short coding),from,0012142,to,0112142,(01357/011/00200),Wednesday,26,September,2018,09:11:48:30955
Address 16,1K0 953 549 BS,recoded (Short coding),from,0112142,to,0002142,(01357/011/00200),Wednesday,26,September,2018,09:14:26:30955
Address 16,1K0 953 549 BS,recoded (Short coding),from,0002142,to,0010142,(01357/011/00200),Wednesday,26,September,2018,09:19:26:30955
Address 16,1K0 953 549 BS,recoded (Short coding),from,0002142,to,0003142,(01357/011/00200),Wednesday,26,September,2018,09:19:59:30955
Address 16,1K0 953 549 BS,recoded (Short coding),from,0003142,to,0011142,(01357/011/00200),Wednesday,26,September,2018,09:24:00:30955
Address 16,1K0 953 549 CH,recoded (Short coding),from,0001534,to,0001034,(12345/123/12345),Friday,26,October,2018,09:43:27:30955
Address 16,1K0 953 549 CH,recoded (Short coding),from,0001034,to,0001434,(12345/123/12345),Friday,26,October,2018,09:48:35:30955
Address 16,1K0 953 549 CH,recoded (Short coding),from,0001434,to,0001034,(12345/123/12345),Friday,26,October,2018,09:50:34:30955
Address 16,1K0 953 549 CH,recoded (Short coding),from,0001034,to,0001034,(01279/123/12345),Friday,26,October,2018,09:54:37:30955
Address 16,1K0 953 549 CH,recoded (Short coding),from,0001034,to,0012112,(01279/123/12345),Friday,26,October,2018,09:56:18:30955
Address 16,1K0 953 549 CH,recoded (Short coding),from,0001034,to,0012142,(01357/011/00200),Friday,26,October,2018,16:03:15:30955
Address 16,1K0 953 549 CH,recoded (Short coding),from,0001034,to,0012142,(01279/123/12345),Friday,26,October,2018,16:03:28:30955
Address 16,1K0 953 549 CH,recoded (Short coding),from,0001034,to,0001034,(01357/123/12345),Friday,26,October,2018,16:03:44:30955
Address 16,1K0 953 549 CH,recoded (Short coding),from,0001034,to,0001034,(01357/011/12345),Friday,26,October,2018,16:04:06:30955
Address 16,1K0 953 549 CH,recoded (Short coding),from,0001034,to,0001034,(01357/011/00200),Friday,26,October,2018,16:04:51:30955
Address 16,1K0 953 549 CH,recoded (Short coding),from,0001034,to,0012142,(01357/011/00200),Friday,26,October,2018,16:05:50:30955
Address 16,1K0 953 549 CH,recoded (Short coding),from,0001034,to,0001434,(01357/011/00200),Friday,26,October,2018,16:07:02:30955
Address 16,1K0 953 549 CH,recoded (Short coding),from,0001434,to,0001234,(01357/011/00200),Friday,26,October,2018,16:09:55:30955
Address 16,1K0 953 549 CH,recoded (Short coding),from,0001234,to,0001034,(01357/011/00200),Friday,26,October,2018,16:13:26:30955
Address 19,1K0 907 530 Q,recoded (Long Coding),from,ED817F060002020003,to,ED817F060000020003,(01357/011/00200),Friday,26,October,2018,16:16:06:30955
Address 16,1K0 953 549 CH,recoded (Short coding),from,0001034,to,0011142,(01357/011/00200),Friday,26,October,2018,16:24:39:30955
Address 19,1K0 907 530 Q,recoded (Installation List),from,ED817F060000020003,to,ED817F060001020003,,Saturday,01,December,2018,10:31:24:30955
Address 42,1K0 959 701 N,recoded (Short coding),from,0000694,to,0000694,(61310/981/90714),Monday,03,December,2018,16:25:03:30955
Address 5F,5G0 035 832 ,recoded (Long Coding),from,02730000FF00000011330001001000001F0100960100010001,to,02730000FF00000011110001001000001F0100960100010001,(01357/011/00200),Saturday,22,December,2018,17:03:21:30955
Address 17,8R0 920 981 M,recoded (Long Coding),from,23E722006E01000C0F0000,to,23EF22006E01000C0F0000,(06335/123/12345),Saturday,12,January,2019,11:23:05:30955
Address 5F,5G0 035 832 ,recoded (Long Coding),from,02730000FF00000011330001001000001F0100960100010001,to,02730000FF00000011FF0001001000001F0100960100010001,(01357/011/00200),Friday,18,January,2019,13:39:05:30955
Address 5F,5G0 035 050 A,recoded (Long Coding),from,02730006FF00000021330001001000001F0100260100010076,to,02730006FF00000021120001001000001F0100260100010076,(131071/1023/2097151),Tuesday,05,February,2019,09:45:06:30955
Address 5F,5G0 035 050 A,recoded (Long Coding),from,02730006FF00000021120001001000001F0100260100010076,to,02730906FF00000021120001001000001F0100260100010076,(12345/123/12345),Tuesday,05,February,2019,09:48:19:30955
Address 5F,5G0 035 050 A,recoded (Long Coding),from,02730906FF00000021120001001000001F0100260100010076,to,02730906FF00000021110001001000001F0100260100010076,(12345/123/12345),Tuesday,05,February,2019,09:50:01:30955
Address 5F,5G0 035 832 ,recoded (Long Coding),from,02730000FF00000011330001001000001F0203860100010000,to,02730000FF00000011FF0001001000001F0203860100010000,(131071/1023/2097151),Thursday,14,March,2019,16:50:31:30955
Address 5F,5G0 035 832 ,recoded (Long Coding),from,02730000FF00000011330001001000001F0203860100010000,to,02730000FF00000011110001001000001F0203860100010000,(12345/123/12345),Thursday,14,March,2019,16:51:56:30955
Address 5F,5G0 035 832 ,recoded (Long Coding),from,02730000FF00000011330001001000001F0203860100010000,to,02730000FF00000021110001001000001F0203860100010000,(12345/123/12345),Thursday,14,March,2019,16:53:05:30955
Address 5F,5G0 035 832 ,recoded (Long Coding),from,02730000FF00000011330001001000001F0203860100010000,to,02730000FF00000011730001001000001F0203860100010000,(12345/123/12345),Thursday,14,March,2019,16:53:31:30955
Address 5F,5G0 035 832 ,recoded (Long Coding),from,02730000FF00000011330001001000001F0203860100010000,to,02730000FF00000011F30001001000001F0203860100010000,(131071/1023/2097151),Thursday,14,March,2019,16:58:09:30955
Address 5F,5G0 035 832 ,recoded (Long Coding),from,02730000FF00000011330001001000001F0203860100010000,to,02730000FF000000113F0001001000001F0203860100010000,(12345/123/12345),Thursday,14,March,2019,16:58:38:30955
Address 5F,5G0 035 832 ,recoded (Long Coding),from,02730000FF00000011330001001000001F0203860100010000,to,02730000FF00000019330001001000001F0203860100010000,(131071/1023/2097151),Thursday,14,March,2019,17:02:08:30955
Address 5F,5G0 035 832 ,recoded (Long Coding),from,02730000FF00000019330001001000001F0203860100010000,to,02730000FF000000193B0001001000001F0203860100010000,(12345/123/12345),Thursday,14,March,2019,17:03:11:30955
Address 5F,5G0 035 832 ,recoded (Long Coding),from,02730000FF000000193B0001001000001F0203860100010000,to,02730000FF00000019330001001000001F0203860100010000,(12345/123/12345),Saturday,16,March,2019,16:19:38:30955
Address 5F,5G0 035 832 ,recoded (Long Coding),from,02730000FF00000019330001001000001F0203860100010000,to,02730000FF00000019270001001000001F0203860100010000,(12345/123/12345),Monday,18,March,2019,09:49:00:30955
Address 5F,5G0 035 832 ,recoded (Long Coding),from,02730000FF00000019270001001000001F0203860100010000,to,02730000FF00000019101001001000001F0203860100010000,(12345/123/12345),Wednesday,20,March,2019,13:06:06:30955
Address 09,1K0 937 084 J,recoded (Long Coding),from,40180A3A88251AC0408800C0340008244BD50488736D8D20E48400240040,to,40180A3A88251AC0408800C434000A244BD50488736D8D20E48400240040,(01357/011/00200),Tuesday,26,March,2019,10:49:22:30955
Address 17,5K6 920 873 B,recoded (Long Coding),from,570F01,to,170D01,(01357/011/00200),Tuesday,26,March,2019,10:53:07:30955
Address 17,5G6 920 870 C,recoded (Long Coding),from,27AD09187F80000E02886A03040000,to,23AD09187F80000C02886A03040000,(01357/011/00200),Saturday,13,April,2019,16:18:00:30955
Address 5F,5G0 035 050 A,recoded (Long Coding),from,02730006FF00000021330001001000001F0203260100010076,to,02730001FF00000021330001001000001F0203260100010076,(01357/011/00200),Saturday,13,April,2019,16:19:17:30955
Address 5F,5G0 035 050 A,recoded (Long Coding),from,02730001FF00000021330001001000001F0203260100010076,to,02730001FF00000021110001001000001F0203260100010076,(01357/011/00200),Saturday,13,April,2019,16:21:19:30955
Address 5F,5G0 035 050 A,recoded (Long Coding),from,02730001FF00000021110001001000001F0203260100010076,to,02730001FF00000021111101001000001F0203260100010076,(01357/011/00200),Saturday,13,April,2019,16:22:34:30955
Address 5F,5G0 035 050 A,recoded (Long Coding),from,02730001FF00000021111101001000001F0203260100010076,to,02730001FF00000021111101001800001F0203260100010076,(01357/011/00200),Saturday,13,April,2019,16:25:39:30955
Address 5F,5G0 035 050 A,recoded (Long Coding),from,02730001FF00000021111101001000001F0203260100010076,to,02730001FF00000021111101001800001F0203260100010076,(01357/011/00200),Saturday,13,April,2019,16:25:59:30955
Address 09,8K0 907 063 BE,recoded (Long Coding),from,260010800030AF010001000000001D0D0F1D470802010141000000,to,260010810030AF010001000000001D0D0F1D470802010141000000,(51647/001/1048576),Wednesday,24,April,2019,16:38:47:30955
Address 09,8K0 907 063 BE,recoded (Long Coding),from,260010810030AF010001000000001D0D0F1D470802010141000000,to,260018810030AF010001000000001D0D0F1D470802010141000000,(51647/001/104857),Wednesday,24,April,2019,16:42:25:30955
Address 09,8K0 907 063 BE,recoded (Long Coding),from,260018810030AF010001000000001D0D0F1D470802010141000000,to,260098810030AF010001000000001D0D0F1D470802010141000000,(51647/001/104857),Wednesday,24,April,2019,16:43:29:30955
Address 09,8K0 907 063 BE,recoded (Long Coding),from,260098810030AF010001000000001D0D0F1D470802010141000000,to,260098110030AF010001000000001D0D0F1D470802010141000000,(51647/001/104857),Wednesday,24,April,2019,16:44:50:30955
Address 09,8K0 907 063 BE,recoded (Long Coding),from,260098110030AF010001000000001D0D0F1D470802010141000000,to,260090110030AF010001000000001D0D0F1D470802010141000000,(51647/001/104857),Wednesday,24,April,2019,16:45:27:30955
Address 5F,5G0 035 050 A,recoded (Long Coding),from,02730006FF00000021330001001000001F0100260100010076,to,02730006FF00000021110001001000001F0100260100010076,(131071/1023/2097151),Saturday,27,April,2019,08:21:49:30955
Address 17,8R0 920 930 B,recoded (Long Coding),from,2F0622000200000C010000,to,230F22000200000C010000,(06335/000/00000),Thursday,02,May,2019,17:21:06:30955
Address 09,1K0 937 084 J,recoded (Long Coding),from,40180A3A88251AC0408800C434000A244BD50488736D8D20E48400240040,to,40180A3A88251AC0408800C034000A244BD50488736D8D20E48400240040,(01357/011/00200),Tuesday,07,May,2019,13:45:34:30955
Address 42,1K0 959 701 N,recoded (Short coding),from,0000694,to,0000758,(00046/412/00000),Saturday,11,May,2019,14:54:36:30955
Address 52,1K0 959 702 N,recoded (Short coding),from,0000950,to,0001014,(00046/412/00000),Saturday,11,May,2019,14:56:11:30955
Address 09,8K0 907 063 BE,recoded (Long Coding),from,260090110030AF010001000000001D0D0F1D470802010141000000,to,260090110030AF211701000000001D0D0F9D470802010141000000,(51647/001/104857),Tuesday,14,May,2019,15:42:31:30955
Address 09,5Q0 937 085 T,recoded (Long Coding),from,03011A42424122FB49E44000000C07281800000000000000000000000000,to,03011A42424122BB49E44000000C07281800000000000000000000000000,(01357/011/00200),Monday,20,May,2019,16:58:55:30955
Address 09,5Q0 937 085 T,recoded (Long Coding),from,03011A42424122BB49E44000000C07281800000000000000000000000000,to,03011A42424122BB4BE44000000C07281800000000000000000000000000,(01357/011/00200),Tuesday,21,May,2019,09:14:20:30955
Address 09,5Q0 937 085 T,recoded (Long Coding),from,03011A42424122BB4BE44000000C07281800000000000000000000000000,to,03011A42424122FB4BE44000000C07281800000000000000000000000000,(01357/011/00200),Tuesday,21,May,2019,12:58:53:30955
Address 5F,5G0 035 050 A,recoded (Long Coding),from,02730001FF00000021111101001000001F0203260100010076,to,02730006FF00000021111101001000001F0203260100010076,(01357/011/00200),Tuesday,21,May,2019,13:14:10:30955
Address 5F,5G0 035 050 A,recoded (Long Coding),from,02730006FF00000021111101001000001F0203260100010076,to,02730006FF00000021111201001000001F0203260100010076,(01357/011/00200),Tuesday,21,May,2019,13:25:07:30955
Address 09,5Q0 937 085 T,recoded (Long Coding),from,03011A42424122FB4BE44000000C07281800000000000000000000000000,to,03011A42424522FB4BE44000000C07281800000000000000000000000000,(01357/011/00200),Tuesday,21,May,2019,13:45:30:30955
Address 09,5Q0 937 085 T,recoded (Long Coding),from,03011A42424522FB4BE44000000C07281800000000000000000000000000,to,03001A42424522FB4BE44000000C07281800000000000000000000000000,(01357/011/00200),Tuesday,21,May,2019,15:09:19:30955
Address 09,8K0 907 063 BE,recoded (Long Coding),from,260090110030AF211701000000001D0D0F9D470802010141000000,to,260090110030BF211701000000001D0D0F9D470802010141000000,(51647/001/104857),Saturday,25,May,2019,09:05:51:30955
Address 09,1K0 937 087 L,recoded (Long Coding),from,40180A3A88251AC0400800803400092443550488736D8960648000200040,to,40180A3A88251AC0400800003400092443550488736D8960648000200040,(01357/011/00200),Saturday,01,June,2019,13:10:32:30955
Address 09,1K0 937 087 L,recoded (Long Coding),from,40180A3A88251AC0400800003400092443550488736D8960648000200040,to,40180A3A88251AC0400800803400092443550488736D8960648000200040,(01357/011/00200),Saturday,01,June,2019,13:12:47:30955
Address 09,1K0 937 087 L,recoded (Long Coding),from,40180A3A88251AC0400800803400092443550488736D8960648000200040,to,40180A3A88251AC0400800803400092443550488736D8960648600200040,(01357/011/00200),Saturday,01,June,2019,13:16:17:30955
Address 09,1K0 937 087 L,recoded (Long Coding),from,40180A3A88251AC0400800803400092443550488736D8960648600200040,to,40180A3A88251AC0400800803400092443550488736D8960648000200040,(01357/011/00200),Saturday,01,June,2019,13:19:00:30955
Address 10,8K0 919 475 AA,recoded (Long Coding),from,300108,to,301108,(53782/001/1048576),Wednesday,05,June,2019,13:07:42:30955
Address 10,8K0 919 475 AA,recoded (Long Coding),from,300108,to,301108,(53782/001/1048576),Wednesday,05,June,2019,13:07:47:30955
Address 10,8K0 919 475 AA,recoded (Long Coding),from,300108,to,301108,(53782/001/1048576),Wednesday,05,June,2019,13:08:07:30955
Address 6C,8R0 907 441 B,recoded (Short coding),from,1022010,to,1023010,(53782/001/1048576),Wednesday,05,June,2019,13:10:17:30955
Address 6C,8R0 907 441 B,recoded (Short coding),from,1023010,to,1022010,(53782/001/104857),Wednesday,05,June,2019,13:13:24:30955
Address 55,5M0 907 357 C,recoded (Short coding),from,1443164,to,1443164,(01357/011/00200),Friday,02,August,2019,14:43:36:30955
Address 09,1K0 937 086 P,recoded (Long Coding),from,40180A3A88251AC0408800C0340009244B553C88736D8920648400200040,to,40180A3A88251AC0408800C0340009244BD53C88736D8920648400200040,(01357/011/00200),Thursday,29,August,2019,13:48:11:30955
Address 09,1K0 937 086 P,recoded (Long Coding),from,40180A3A88251AC0408800C0340009244BD53C88736D8920648400200040,to,40180A3A88251AC0408800C0340009244BD50088736D8920648400200040,(01357/011/00200),Thursday,29,August,2019,14:04:04:30955
Address 09,1K0 937 086 P,recoded (Long Coding),from,40180A3A88251AC0408800C0340009244BD50088736D8920648400200040,to,40180A3A88251AC0408800C0340009244B550088736D8920648400200040,(01357/011/00200),Thursday,29,August,2019,14:05:41:30955
Address 09,1K0 937 086 P,recoded (Long Coding),from,40180A3A88251AC0408800C0340009244B550088736D8920648400200040,to,40180A3A88251AC0400800803400092443D50088736D8920648000240040,(01357/011/00200),Thursday,29,August,2019,14:07:27:30955
Address 09,1K0 937 086 P,recoded (Long Coding),from,40180A3A88251AC0400800803400092443D50088736D8920648000240040,to,40180A3A88251AC0408800C0340009244B550088736D8920648400200040,(01357/011/00200),Thursday,29,August,2019,14:08:15:30955
Address 09,1K0 937 086 P,recoded (Long Coding),from,40180A3A88251AC0408800C0340009244B550088736D8920648400200040,to,40180A3A88251AC0408800C0340009244B550488736D8920648400200040,(01357/011/00200),Thursday,29,August,2019,14:13:52:30955
Address 09,3C0 937 049 AJ,recoded (Long Coding),from,E78F0F2700041500471400001400000000095D035C000100000000000000,to,E78E0F2700041500471400001400000000095D035C000100000000000000,(00046/000/00000),Monday,09,September,2019,10:31:34:30955
Address 17,1K6 920 864 ,recoded (Short coding),from,0007503,to,0005503,(01925/003/1048576),Monday,09,September,2019,10:34:05:30955
Address 5F,5G0 035 050 ,recoded (Long Coding),from,02730006FF00000021330001001000001F0100260100010076,to,02730006FF00000021510001001000001F0100260100010076,(01357/011/00200),Sunday,29,September,2019,10:53:21:30955
Address 5F,5G0 035 832 ,recoded (Long Coding),from,02730000FF00000011330001001000001F0100960100010001,to,02730000FF00000011030001001000001F0100960100010001,(01357/011/00200),Thursday,07,November,2019,15:15:22:30955
Address 5F,5G0 035 832 ,recoded (Long Coding),from,02730000FF00000011030001001000001F0100960100010001,to,02730000FF00000011010001001000001F0100960100010001,(01357/011/00200),Thursday,07,November,2019,15:16:08:30955
Address 5F,5G0 035 832 ,recoded (Long Coding),from,02730000FF00000011010001001000001F0100960100010001,to,02730000FF00000051110001001000001F0100960100010001,(01357/011/00200),Thursday,14,November,2019,15:09:57:30955
Address 17,4L0 920 932 Q,recoded (Long Coding),from,335663040000000C010904,to,235F63040000000C010904,(31414/790/00001),Saturday,14,December,2019,16:20:43:30955
Address 09,4F0 910 279 AG,recoded (Short coding),from,0123101,to,0123121,(31414/790/00001),Saturday,14,December,2019,16:24:00:30955
Address 09,4F0 910 279 AG,recoded (Short coding),from,0123121,to,0123122,(31414/790/00001),Saturday,14,December,2019,16:33:41:30955
Address 5F,5G0 035 050 ,recoded (Long Coding),from,02730006FF00000021330001001000001F0203260100010076,to,02730006FF00000021110001001000001F0203260100010076,(01357/011/00200),Sunday,22,December,2019,13:30:08:30955
Address 5F,5G0 035 050 ,recoded (Long Coding),from,02730006FF00000021110001001000001F0203260100010076,to,02730006FF00000021111101001000001F0203260100010076,(01357/011/00200),Sunday,22,December,2019,13:34:27:30955
Address 5F,5G0 035 050 ,recoded (Long Coding),from,02730006FF00000021111101001000001F0203260100010076,to,02730006FF00000021111101000900001F0203260100010076,(01357/011/00200),Sunday,22,December,2019,13:38:36:30955
Address 5F,5G0 035 050 ,recoded (Long Coding),from,02730006FF00000021111101001000001F0203260100010076,to,02730006FF00000021111101000900001F0203260100010076,(01357/011/00200),Sunday,22,December,2019,13:38:49:30955
Address 5F,5G0 035 050 ,recoded (Long Coding),from,02730006FF00000021111101001000001F0203260100010076,to,02730006FF00000021111101000900001F0203260100010076,(01357/011/00200),Sunday,22,December,2019,13:39:10:30955
Address 5F,5G0 035 050 ,recoded (Long Coding),from,02730006FF00000021111101001000001F0203260100010076,to,02730006FF00000021111101001800001F0203260100010076,(01357/011/00200),Sunday,22,December,2019,13:39:36:30955
Address 5F,5G0 035 050 ,recoded (Long Coding),from,02730006FF00000021111101001000001F0203260100010076,to,02730006FF00000021111101000900001F0203260100010076,(01357/011/00200),Sunday,22,December,2019,13:40:03:30955
Address 5F,5G0 035 050 ,recoded (Long Coding),from,02730006FF00000021111101001000001F0203260100010076,to,02730006FF00000021111101001800001F0203260100010076,(01357/011/00200),Sunday,22,December,2019,13:40:43:30955
Address 5F,5G0 035 050 A,recoded (Long Coding),from,02730006FF00000021330001001000001F0100360100010076,to,02730006FF00000021110001001800001F0100360100010076,(131071/1023/2097151),Friday,27,December,2019,14:04:11:30955
Address 5F,5G0 035 050 A,recoded (Long Coding),from,02730006FF00000021110001001800001F0100360100010076,to,02730006FF00000021120001001800001F0100360100010076,(12345/123/12345),Friday,27,December,2019,15:03:47:30955
Address 5F,5G0 035 050 A,recoded (Long Coding),from,02730006FF00000021110001001800001F0100360100010076,to,02730006FF00000021111101001800001F0100360100010076,(12345/123/12345),Friday,27,December,2019,15:04:13:30955
Address 5F,5G0 035 050 A,recoded (Long Coding),from,02730006FF00000021110001001800001F0100360100010076,to,02730006FF00000021111101001800001F0100360100010076,(12345/123/12345),Friday,27,December,2019,15:04:41:30955
Address 5F,5G0 035 050 A,recoded (Long Coding),from,02730006FF00000021110001001800001F0100360100010076,to,02730006FF00000021110001005800001F0106360100010076,(12345/123/12345),Friday,27,December,2019,15:06:34:30955
Address 5F,5G0 035 050 A,recoded (Long Coding),from,02730006FF00000021110001001800001F0100360100010076,to,02730006FF00000021510001001800001F0100360100010076,(12345/123/12345),Friday,27,December,2019,15:10:24:30955
Address 5F,5G0 035 050 A,recoded (Long Coding),from,02730006FF00000021110001001800001F0100360100010076,to,02730006FF00000021330001001000001F0100360100010076,(12345/123/12345),Friday,27,December,2019,15:11:04:30955
Address 5F,5G0 035 050 A,recoded (Long Coding),from,02730006FF00000021110001001800001F0100360100010076,to,02730006FF00000021330001001000001F0100360100010076,(12345/123/12345),Friday,27,December,2019,15:11:09:30955
Address 5F,5G0 035 050 A,recoded (Long Coding),from,02730006FF00000021110001001800001F0100360100010076,to,02730006FF00000021330001001000001F0100360100010076,(12345/123/12345),Friday,27,December,2019,15:11:29:30955
Address 5F,5G0 035 050 A,recoded (Long Coding),from,02730006FF00000021110001001800001F0100360100010076,to,02730006FF00000021330001001000001F0100360100010076,(12345/123/12345),Friday,27,December,2019,15:11:51:30955
Address 5F,5G0 035 050 A,recoded (Long Coding),from,02730006FF00000021110001001800001F0100360100010076,to,02730006FF00000021330001001000001F0100360100010076,(12345/123/12345),Friday,27,December,2019,15:12:03:30955
Address 5F,5G0 035 050 A,recoded (Long Coding),from,02730006FF00000021110001001800001F0100360100010076,to,02730006FF00000021330001001000001F0100360100010076,(12345/123/12345),Friday,27,December,2019,15:12:08:30955
Address 5F,5G0 035 050 A,recoded (Long Coding),from,02730006FF00000021110001001800001F0100360100010076,to,02730006FF00000021330001001800001F0100360100010076,(12345/123/12345),Friday,27,December,2019,15:12:44:30955
Address 5F,5G0 035 050 A,recoded (Long Coding),from,02730006FF00000021110001001800001F0100360100010076,to,02730006FF00000021330001001000001F0100360100010076,(12345/123/12345),Friday,27,December,2019,15:13:37:30955
Address 5F,5G0 035 050 A,recoded (Long Coding),from,02730006FF00000021110001001800001F0100360100010076,to,02730006FF00000021330001001000001F0100360100010076,(12345/123/12345),Friday,27,December,2019,15:14:04:30955
Address 5F,5G0 035 050 A,recoded (Long Coding),from,02730006FF00000021330001001000001F0100360100010076,to,02730006FF00000021510001001000001F0100360100010076,(12345/123/12345),Friday,27,December,2019,15:14:37:30955
Address 5F,5G0 035 050 A,recoded (Long Coding),from,02730006FF00000021330001001000001F0203360100010076,to,02730006FF00000021510001001000001F0203360100010076,(131071/1023/2097151),Saturday,28,December,2019,13:05:22:30955
Address 5F,5G0 035 050 A,recoded (Long Coding),from,02730006FF00000021510001001000001F0203360100010076,to,02730006FF00000021510001001800001F0203360100010076,(12345/123/12345),Saturday,28,December,2019,13:06:53:30955
Address 5F,4L2 035 678 ,recoded (Long Coding),from,18060106000481EF41000345EF632003FC0000020100000000,to,18060106030481FF41000345EF632003FC0000020100000000,(31414/790/00001),Saturday,28,December,2019,16:28:15:30955
Address 42,1K0 959 701 Q,recoded (Short coding),from,0000694,to,0004790,(00066/000/00000),Thursday,02,January,2020,10:36:14:30955
Address 17,1K0 920 864 A,recoded (Short coding),from,0007503,to,0005503,(25064/002/1048576),Wednesday,26,February,2020,14:11:31:30955
Address 5F,5G0 035 832 ,recoded (Long Coding),from,02730000FF00000011330001001000001F0203860100010000,to,02730000FF00000011010001001000001F0203860100010000,(131071/1023/2097151),Saturday,29,February,2020,14:31:29:30955
Address 5F,5G0 035 832 ,recoded (Long Coding),from,02730000FF00000011010001001000001F0203860100010000,to,02730000FF00000011110001001000001F0203860100010000,(12345/123/12345),Saturday,29,February,2020,14:33:30:30955
Address 5F,5G0 035 832 ,recoded (Long Coding),from,02730000FF00000011010001001000001F0203860100010000,to,02730000FF00000011011101001000001F0203860100010000,(12345/123/12345),Saturday,29,February,2020,14:33:51:30955
Address 5F,5G0 035 832 ,recoded (Long Coding),from,02730000FF00000011010001001000001F0203860100010000,to,02730000FF00000011010101001000001F0203860100010000,(12345/123/12345),Saturday,29,February,2020,14:34:12:30955
Address 5F,5G0 035 832 ,recoded (Long Coding),from,02730000FF00000011010001001000001F0203860100010000,to,02730000FF00000011110001001000001F0203860100010000,(12345/123/12345),Saturday,29,February,2020,14:35:02:30955
Address 5F,5G0 035 832 ,recoded (Long Coding),from,02730000FF00000011010001001000001F0203860100010000,to,03011A42424122FB49E44000000C0728180A000000000000000000000000,(12345/123/12345),Saturday,29,February,2020,14:48:44:30955
Address 5F,5G0 035 832 ,recoded (Long Coding),from,02730000FF00000011010001001000001F0203860100010000,to,02730000FF00000011330001001000001F0203860100010000,(12345/123/12345),Saturday,29,February,2020,14:50:51:30955
Address 5F,5G0 035 832 ,recoded (Long Coding),from,02730000FF00000011330001001000001F0203860100010000,to,02730000FF00000011010001001000001F0203860100010000,(12345/123/12345),Monday,02,March,2020,12:36:00:30955
Address 17,5N0 920 872 B,recoded (Long Coding),from,511F01,to,111F01,(01324/020/00200),Wednesday,04,March,2020,16:00:39:30955
Address 17,5N0 920 872 B,recoded (Long Coding),from,111F01,to,111701,(01324/020/00200),Wednesday,04,March,2020,16:02:03:30955
Address 09,5K0 937 086 L,recoded (Long Coding),from,40180A3B88251AC0400800C0340009244B550008736D8960648400000040,to,40180A3B88251AC0400800C4340009244B550008736D8960648400000040,(01324/020/00200),Wednesday,04,March,2020,16:06:15:30955
Address 09,5K0 937 086 L,recoded (Long Coding),from,40180A3B88251AC0400800C4340009244B550008736D8960648400000040,to,40180A3B88251AC0400800C4340009644B550008736D8960648400000040,(01324/020/00200),Wednesday,04,March,2020,16:07:39:30955
Address 09,5K0 937 086 L,recoded (Long Coding),from,40180A3B88251AC0400800C4340009644B550008736D8960648400000040,to,40180A3B88251AC0400800C0340009644B550008736D8960648400000040,(01324/020/00200),Wednesday,04,March,2020,16:08:31:30955
Address 5F,5G0 035 832 ,recoded (Long Coding),from,02730000FF00000011010001001000001F0203860100010000,to,02730000FF00000011110001001000001F0203860100010000,(12345/123/12345),Monday,09,March,2020,09:48:07:30955
Address 5F,5G0 035 832 ,recoded (Long Coding),from,02730000FF00000011010001001000001F0203860100010000,to,02730000FF00000011000001001000001F0203860100010000,(12345/123/12345),Monday,09,March,2020,09:48:31:30955
Address 17,5G6 920 870 C,recoded (Long Coding),from,23AD09186F80000E02882A03040000,to,23AD09186E80000E02882A03040000,(93300/981/12345),Monday,09,March,2020,09:54:37:30955
Address 5F,5G0 035 050 ,recoded (Long Coding),from,02730006FF00000021111101001800001F0203260100010076,to,02730006FF00000021330001001800001F0203260100010076,(01357/011/00200),Monday,09,March,2020,10:17:09:30955
Address 5F,5G0 035 832 ,recoded (Long Coding),from,02730000FF00000011010001001000001F0203860100010000,to,02730006FF00000021330001001800001F0203260100010076,(12345/123/12345),Monday,09,March,2020,10:23:42:30955
Address 5F,5G0 035 832 ,recoded (Long Coding),from,02730006FF00000021330001001800001F0203260100010076,to,02730000FF00000001330001001800001F0203260100010076,(12345/123/12345),Monday,09,March,2020,10:25:57:30955
Address 19,5Q0 907 530 M,recoded (Installation List),from,01543C1000000600408C90000000C80000,to,01543C1000000600408C90000000C80000,,Monday,09,March,2020,10:33:57:30955
Address 17,5G6 920 870 C,recoded (Long Coding),from,23AD09186E80000E02882A03040000,to,23AD09186F80000E02882A03040000,(93300/981/12345),Monday,09,March,2020,10:41:29:30955
Address 5F,5G0 035 832 ,recoded (Long Coding),from,02730000FF00000001330001001800001F0203260100010076,to,02730000FF00000001331101001800001F0203260100010076,(12345/123/12345),Monday,09,March,2020,10:44:07:30955
Address 5F,5G0 035 832 ,recoded (Long Coding),from,02730000FF00000001331101001800001F0203260100010076,to,02730001FF00000001111101001800001F0203260100010076,(12345/123/12345),Monday,09,March,2020,13:44:30:30955
Address 17,1K6 920 862 ,recoded (Short coding),from,0007503,to,0005503,(12152/002/1048576),Friday,13,March,2020,11:14:47:30955
Address 5F,5G0 035 050 A,recoded (Long Coding),from,02730006FF00000021510001001000001F0100360100010076,to,02730006FF00000021110001001000001F0100360100010076,(12345/123/12345),Tuesday,17,March,2020,09:17:09:30955
Address 19,7N0 907 530 ,recoded (Installation List),from,ED817F0600020200000003,to,ED817F0600000200000003,,Wednesday,18,March,2020,15:11:32:30955
Address 19,7N0 907 530 ,recoded (Installation List),from,ED817F0600000200000003,to,ED817F0600000200000003,,Wednesday,18,March,2020,15:14:44:30955
Address 09,4F0 910 279 AG,recoded (Short coding),from,0123122,to,0123121,(31414/790/00001),Friday,03,April,2020,14:32:53:30955
Address 09,4F0 910 279 AG,recoded (Short coding),from,0123121,to,0123101,(31414/790/00001),Friday,03,April,2020,14:33:56:30955
See the first field is the address and the second field is the module part number? Cross reference those with the modules on the vehicle you are working on...
webup
Auckland
C?ID=256879
ive got the battery out....what a pain! Now will charge it and check if it goes flat on its own.
I can't tell how old it is. Any ideas?
NEtech
C?ID=56995
[Applications]
[History Data]
- Choose an Address = 19
[Start]
And
[Applications]
[Controller Channel Map]
- Controller Address = 19
- Login or security code: Leave blank
- Function: Measuring values
- Output: CSV file
[Go]
Post both text files here.
webup
Auckland
C?ID=256879
[Applications]
[History Data]
[Start]
And
[Applications]
- Output: CSV file
[Go]
Thanks will hook it up and look there
webup
Auckland
C?ID=256879
Photos of battery after removing form car and charging
It slowly drops voltage
tgNWVeU
U5IusjY
YBx0ihl
2fga7CV
webup
Auckland
C?ID=256879
So if I've done it correctly it is showing this reading 78amps when connected back in the car.
With the ignition off the amps dont go down at all and just sit on 78amps
The battery when it was out of the car and charged up slowly went down from about 12.8v to around 12.2v over maybe 24 hours
webup
Auckland
C?ID=256879
[Applications]
[History Data]
[Start]
And
[Applications]
- Output: CSV file
[Go]
Friday,17,April,2020,14:19:08:30955
VIN:    License Plate: Q7BATT
Control Module Part Number: 4F0 907 468 R
  Component and/or Version: GW-BEM 4CAN-M H06 0057
           Software Coding: 00C303
            Work Shop Code: WSC 31414
                      VCID: 3E736B7AA90F5EBF95-FFFE
History Data
Record 1/16: No-load voltage underranging
2020-04-10-17:19*09.2*00*00901***
2020-04-03-19:35*19.6*00**
2020-03-30-00:50*01.7*00**
2020-03-29-00:50*24.0*00**
2020-03-27-11:51*21.9*00**
2020-03-25-10:05*06.1*00**
2020-03-21-15:50*15.6*00**
2020-04-15-13:44*00.6*00*00601***
2020-04-12-10:07*14.2*00**
2020-04-11-09:53*09.9*00**
2020-04-07-12:50*19.6*00**
2020-04-06-12:49*24.0*00**
2020-04-05-12:48*23.8*00**
2020-03-31-14:45*18.2*00**
2020-04-16-10:08*01.2*00*00526***
2020-04-15-10:08*24.0*00**
2020-04-14-10:08*24.0*00**
2020-04-13-10:08*24.0*00**
2020-04-12-10:07*09.7*00**
2020-04-10-17:01*17.2*00**
2020-04-09-17:01*24.0*00**
Record 2/16: No-load current overranging
2020-03-07-07:30*0003*100*-04.23*0-0-1-0-0-0*0*00*00003**
2018-08-11-13:39*0018*040*-02.26*0-0-1-0-0-0*0*01**
2018-08-11-09:40*0004*050*-02.38*0-0-1-0-0-0*0*01**
2013-08-20-14:59*0002*072*-02.44*0-0-1-0-0-0*0*01**
2000-01-01-00:00*0000*000*+00.00*0-0-0-0-0-0*0*00**
Record 3/16: Shut-off stage history
2020-04-15-13:53*7*0*018*000*-03.13*0-0-0-0-0-0*0*0*00.0*00.0**
2020-04-15-13:53*5*0*018*000*-04.98*0-0-0-0-0-0*0*0*00.0*00.0**
2020-04-15-13:52*1*0*018*000*-06.92*0-0-0-0-0-0*0*0*00.0*00.0**
2020-04-15-13:45*7*0*020*000*-06.83*0-0-0-0-0-0*0*0*00.0*00.0**
2020-04-15-12:51*7*0*022*000*-03.09*0-0-0-0-0-0*0*0*00.0*00.0**
2020-04-15-12:50*5*0*022*000*-05.07*0-0-0-0-0-0*0*0*00.0*00.0**
2020-04-15-12:50*1*0*022*000*-06.79*0-0-0-0-0-0*0*0*00.0*00.0**
2020-04-13-15:41*7*0*016*000*-05.19*0-0-0-0-0-0*0*0*00.4*00.7**
2020-04-13-15:40*5*0*016*000*-07.87*0-0-0-0-0-0*0*0*00.4*00.7**
2020-04-13-15:40*1*0*016*000*-07.93*0-0-0-0-0-0*0*0*00.4*00.7**
2020-04-13-13:02*7*0*017*000*-02.98*0-0-0-0-0-0*0*0*00.4*00.7**
2020-04-13-13:02*2*0*017*000*-06.92*0-0-0-0-0-0*0*0*00.4*00.7**
2020-04-13-12:59*5*0*017*000*-08.55*0-0-0-0-0-0*0*0*00.4*00.6**
2020-04-13-12:59*1*0*017*000*-08.55*0-0-0-0-0-0*0*0*00.4*00.6**
2020-04-13-12:55*7*0*018*000*-06.66*0-0-0-0-0-0*0*0*00.4*00.6**
Record 4/16: Battery change history
2012-05-03-20:11*01*8K0915105F *VA0*924K08L   *09971*00062*0000*0000*0000**
2000-01-01-00:00*00*-----------*XXX*----------*09997*00001*0000*0000*0000**
2000-01-01-00:00*00*-----------*XXX*----------*00000*00000*0000*0000*0000**
Record 5/16: Energy-critical vehicle states
2020-03-05-04:28*-00.06*-00.08*-01.74*11.55*000*09*-10.5*00285*09986*
074210*0-0-0-0-0-0*0*00.0*00.1*131.4*16*00*02**
2020-02-15-15:53*+00.00*-17.58*-16.62*10.36*000*12*-12.1*00214*09994*
074064*0-0-1-0-0-0*0*00.6*00.6*000.6*00*01*01**
2020-01-13-08:06*-00.31*-01.73*-01.85*11.64*000*09*-04.8*07582*09500*
073628*0-0-0-0-0-0*0*00.0*00.7*002.7*03*00*05**
2018-08-12-07:12*-02.37*-02.38*-01.54*11.74*000*06*-57.3*06982*09500*
071153*0-0-0-0-0-0*0*00.0*00.0*024.0*03*00*04**
2018-02-11-17:10*+00.00*-08.50*-11.57*12.29*100*02*-00.1*06658*09506*
067234*0-0-0-0-0-0*0*00.0*00.0*000.0*01*00*03**
Record 6/16: Energy balances (last 20 trips)
2020-04-15-13:47*000*+12*+000.6*00.07**
2020-04-15-12:23*000*+08*+003.0*00.43**
2020-04-03-13:34*012*+14*+000.9*00.60**
2020-03-28-10:30*029*+09*+000.1*00.15**
2020-03-28-10:17*027*+09*+000.5*00.22**
2020-03-27-11:51*009*+14*+000.0*00.01**
2020-03-26-17:56*000*+16*+000.5*00.05**
2020-03-25-16:13*009*+16*+003.4*00.90**
2020-03-24-13:34*036*+11*+000.1*00.01**
2020-03-24-11:32*037*+10*+006.2*01.82**
2020-03-21-11:13*021*+17*+013.2*02.14**
2020-03-14-05:51*032*+15*+000.8*00.21**
2020-03-13-14:01*043*+23*+016.8*01.21**
2020-03-07-11:05*036*+37*+038.3*01.59**
2020-02-29-10:01*025*+19*+000.2*00.02**
2020-02-29-05:35*025*+23*+002.1*00.20**
2020-02-28-11:48*030*+23*+000.1*00.00**
2020-02-28-11:35*028*+23*+000.9*00.18**
2020-02-28-08:49*029*+20*+008.3*00.79**
2020-02-28-07:35*016*+17*+001.1*00.04**
Record 7/16: Energy balances (last 20 standing times)
2020-04-15-12:49*100*-000.9*000.9*00.0*00.0**
2020-04-03-14:10*000*-000.1*288.5*00.7*00.4**
2020-03-28-10:40*004*-001.3*145.9*00.2*00.1**
2020-03-28-10:40*100*-002.6*069.7*00.0*00.0**
2020-03-27-11:52*024*-001.4*025.2*00.0*00.0**
2020-03-26-17:59*007*+008.1*017.8*00.0*00.0**
2020-03-25-17:07*100*-040.6*030.0*00.0*00.0**
2000-01-01-00:00*100*-000.6*000.0*00.0*00.0**
2020-03-24-13:22*035*-000.6*000.1*00.0*00.0**
2020-03-21-13:21*100*-015.5*046.6*00.2*00.0**
2020-03-21-13:21*100*-015.4*046.6*00.2*00.0**
2020-03-21-13:21*100*-012.5*015.9*00.0*00.0**
2020-03-14-06:04*000*-013.1*190.1*00.2*00.0**
2020-03-13-15:15*026*-001.3*014.5*00.0*00.0**
2020-03-08-09:11*100*-015.3*107.4*00.6*00.4**
2020-03-07-12:41*027*-001.6*020.4*00.0*00.0**
2020-02-29-10:02*100*-035.5*171.0*00.2*00.0**
2020-02-29-05:48*025*-001.0*004.1*00.0*00.0**
2020-02-28-11:49*021*-002.8*017.7*00.0*00.0**
2020-02-28-11:46*030*-000.2*000.0*00.0*00.0**
Record 8/16: Battery manipulation (e.g. charging)
2011-08-12-00:00*4*17*00*07*05*2020-04-15-13:54*00**
2020-04-15-13:47*3*17*00*07*04*2000-01-01-00:00*00**
2020-04-15-12:23*3*17*00*06*04*2000-01-01-00:00*00**
2020-04-10-15:39*1*17*00*05*04*2000-01-01-00:00*00**
2020-04-10-10:24*1*16*00*05*04*2000-01-01-00:00*00**
Record 9/16: Battery aging
2020-04-07-16:43*052*059*017*000*00053*11.60*+16*00**
2020-03-21-05:44*053*059*006*000*00329*11.50*+09*00**
2020-03-07-05:29*055*059*018*000*00287*11.70*+14*00**
2020-02-23-10:35*061*068*042*016*00246*12.00*+14*00**
2020-02-09-10:33*063*067*050*024*00180*12.10*+11*00**
2020-01-24-09:42*072*075*044*026*00115*12.00*+19*00**
2020-01-10-09:41*051*064*032*008*07567*11.80*+14*01**
2019-12-09-15:38*056*068*040*011*07554*12.00*+07*01**
2019-11-26-11:52*074*075*053*032*07519*12.10*+11*01**
2019-11-11-14:20*077*075*054*035*07507*12.20*+13*01**
2019-10-26-09:21*079*079*057*040*07494*12.20*+16*01**
2019-10-09-10:22*077*082*064*047*07479*12.30*+18*01**
Record 10/16: Dynamic energy management
2020-04-15-13:51*1*003.9*0*000.0*00.07**
2020-04-15-12:49*1*005.0*0*000.0*00.43**
2020-03-26-17:59*1*002.7*0*000.0*00.05**
2020-03-25-17:07*1*005.0*0*000.0*00.90**
2020-03-24-13:22*1*005.0*0*000.0*01.82**
2000-01-01-00:00*0*0*0*00.00**
2020-04-15-13:51*2*003.9*00.07**
2020-04-15-12:28*2*004.9*00.09**
2020-03-26-17:59*2*002.7*00.05**
2020-03-25-16:18*2*005.0*00.09**
2020-03-24-11:38*2*004.9*00.09**
Record 11/16: Recuperation
2012-11-26-18:11*000*000*007*000*0040*032*00.0*00.1*092*088*092*089*01*00001*00001*00000*00003*00006**
2012-11-25-15:12*000*000*003*007*0040*012*00.0*00.6*089*084*089*083*01**
2012-11-25-14:58*000*000*004*007*0029*012*00.0*00.7*090*084*089*084*01**
2012-11-25-14:42*000*000*001*002*0019*004*00.0*00.3*091*082*090*084*01**
2012-11-25-14:24*000*000*000*006*0054*008*00.0*00.3*091*084*091*083*01**
2012-11-25-13:46*000*000*005*021*0132*028*00.0*01.1*092*083*092*084*01**
2000-01-01-00:00*000*000*000*000*0000*000*00.0*00.0*000*000*000*000*00**
Record 12/16: Start-Stop
2000-01-01-00:00*0-0-0-0-0-0-0-0**
00000*00000*00000*00000*00000*00000*00000*00000**
2020-04-15-13:47*2*018*100*+12*02*-030*-20.46*10.2*0**
2020-04-15-12:23*2*013*000*+07*29*-030*-08.37*09.7*0**
2020-04-03-13:34*2*026*004*+13*13*-030*-18.75*11.7*0**
2020-04-03-13:34*2*026*004*+13*13*-030*-02.19*12.2*0**
2020-03-31-09:17*1*000*100*+11*02*-030*-18.08*10.3*0**
08067*00360*00000**
Record 13/16: Sporadic alternator faults
2020-01-14-11:04*0-0-1-0-0*000.3*00002**
2018-08-16-12:00*0-0-1-0-0*000.4**
2000-01-01-00:00*0-0-0-0-0*000.0**
Record 15/16: Local activ.
2000-01-01-00:00*000*00*00*000*00*00*000*00*00**
Record 16/16: Vehicle energy balance
074216**
00033*01490*06675*00335*00049**
08211*00055*00011*00002**
11842*09090*00386*00000**
01969*03521*01769*01167**
04314*02871*01241**
09259*01005*00173*00002**
00682*00011*00009**
00049*00008*00002**
00058*00002*00000**
00000*00000*00000*00000*00000*00000*00000*00000*00000*00000**
;SW:4F0-907-468-R   HW:4F0-907-468-F ---  CAN Gateway
;Component:GW-BEM 4CAN-M H06 0057	 Coding:00C303
;Friday	17	April	2020	14:19:55:30955
;VCID: 3E736B7AA90F5EBF95-806A
Group	Field 1	Data type	Field 2	Data type	Field 3	Data type	Field 4	Data type
1	0.00 V		10.70 V
2	0x0519		0x0019		0
3	0x00FF		1		0x0400		0x05FF
4	MOST active
5	C-CAN active		P-CAN active		S-CAN active
6	Generator 1		BDM 1
7	159		0		8		0x0000
9	ERROR		No
10	ERROR		ERROR		No
11	118 Ah		110 Ah		0
13	00000000 00000000		00000000 00000000		00000000 00000000		00000000 00000000
14	10.60 V		0.00%		0.000 A		3.00 s
15	OK		OK		OK
16	OK		3		10		0
17	OK		1		8		No
18	10.900 V		-8.2 A		11.0°C		13.0°C
19	59.00%		no Value		52.00%		59.00%
20	16.0 mOhm		5.2 mOhm		100 Ah		12.20 V
21	Inactive		Inactive		StatCurStg 0		Yes
22	0		0		9971 Ah		63 Ah
23	Invalid		Test Complete
24	OFF		Inactive		Inactive		Inactive
25	11111111 11111011		00000000 00000001		Inactive		Inactive
26	0.0 A		0.0 A		0.0 Nm		0 W
27	0		Inactive		Inactive		Inactive
28	00000000 00000000		00000000 00000000		00000000 00000000
29	0		0		10.00 s		30.0 A
30	3E+38
31	0C0C0C0C0C0C0C0C64006400640064006400640064006400
32	0A000A000A000A0000000000280028002800280028002800000000000A000A000A000A000A000A00
33	0000000000000000000000000000080708075A000B0003006D070D00030070173C003C003C003C00
35	67000C7B230926022C004B0B000304000003040000180400001804000003040000
36	172013A91D3A04F948004B0B001804000002040000030400000304000003040000
37	0
38	0
39	0
40	0C45002E028A21D42200D52100
41	EA5B6C2100001200E432000010007807DA59A1010F04D2530000580000005C2B000000005C2B0000
43	0
44	0
45	1E+70
46	0
47	0
48	0
49	00000200FA01000000003B0000007D0CF8000000
50	1E+78
51	1.3E+35
52	3E+34
53	0
54	0
55	0
56	0
57	8A210BC8041537CD2100000000000000000000000000000000
58	8A210BC8041537CD21000000001A040000000000000000
59	8A210BC8041605D721000000000000000000000000000000000000000000000000
60	0B11040420820100
61	0
62	0
70	882114F41A2D1F230D000C04
71	892114F41A2F194C00000C04
72	8A210BC8041205F100000C04
73	80211434141D2B630D000C04
74	82211444181F17A702000C04
75	862114A414163AF637000C04
76	872114B4123508EB12000C04
77	872114D41837086EFC000C04
78	872114D4183A0EE223010C04
79	872114F4181621614F010C04
80	892114F41A2F174900001A04
81	8A2114F41A34192700001A04
82	872114D41A02124825011A04
83	872114D41E2714174A011A04
84	872114D41E2814534A011104
85	882114F41832052600001A04
86	882114F41A2D1F230D001A04
87	892114F41A2E1A1000001804
88	892114F41A2E2A2000001A04
89	892114F41A2E352C00000304
90	86211444182110660000560000004D
91	8A2114F41A301E000000560000004D
92	8A210BC80000088F00000E0000004D
93	7921149321081514AA00020400004B
94	7A211493210C1B830000560000004D
95	7A211493210C1FA90000110400004B
96	7B2114A3191D25B0BD00560000004D
97	7B2114A323372B250A01020400004B
98	7E2114C315122A000000560000004D
99	802114F313130D650000560000004D
100	8A2114F41A3433410000
101	8A2114F41A351F680000
102	8A210BC8041205F10000
103	882114F41A2C14860000
104	882114F41A2D02070D00
105	7A211493210C1E8600000000830000000200830002000100
106	872114D41A02194E250100001E00B4000200270003000000
107	732114F314270F2B900100001E0014000200290002000100
108	732114F31C1B25C9920100001E001E000200390002000100
109	79211493210429CE540000001E001D0002002F0002000100
110	6A2014E108203B760600098100268100000000000000000000
111	0
112	0
113	0
114	0
115	0
116	0
117	0
118	0
119	0
125	Engine 1		Transm. 0		ABS 0
126	Airbag 0		 		HdLtRange 0
127	Steer. ang. 0
130	2-Wire		El.CM Slp.Ind		Central Slp.Ind		DrDoor Slp.Ind
131	PsDoor Slp.Ind		RL Door 1		RR Door 1		Memory Slp.Ind
132	Park Slp.Ind		 		 		SteerWh Slp.Ind
133	 		HVAC Slp.Ind		el.ign. Slp.Ind		BackupCam Sl.In
134	 		El. CE2 Slp.Ind		CenConv2 Sl.In
135	 		A/C R Slp.Ind		 		Rear lid Slp.Ind
140	Radio 1
141	Dig.Soundp. 1		TV-Tuner 1		 		Info.1 1
142	 		 		 		Media P.1 1
143	 		 		 		N/A
148	0.00 V		2000:01:01		0:00 h		0 km
149	0
150	Instrum. Slp.Ind		 		 		N/A
200	 		SDown Suspend		1		OK
201	2		52.50%
202	0
203	0		0		0		1
204	0
205	--------
211	 		N/A		N/A		N/A
212	 		N/A		N/A		N/A
213	 		N/A		N/A		N/A
214	 		N/A		N/A		N/A
215	 		N/A		N/A		N/A
webup
Auckland
C?ID=256879
Video here showing the voltage dropping when its connected to the car....
[video]https://www.veoh.com/watch/v142012146tpjFaacG[/video]
webup
Auckland
C?ID=256879
Did you guys see the results?
Dana
Western PA, USA
I'm not the best person to offer battery analysis (been a while since I've used NEtech's VCDS Toolbox for this feature) however that battery is discharging extremely quickly per the video and the Battery change history dates back to 2012:
If you haven't the battery tested I would do so to rule it out. If you are stuck at home and don't want to make a special trip for battery testing or to purchase a new one then I'd be tempted to borrow a battery from another vehicle (if possible) that has similar specifications.
Moving forward, if that battery is good or a replacement discharges at that rate you might be able to locate the source of the draw based on temp. For instance, I have found amplifier and window motor draws based on the module getting warm to the touch. Those are rare and extreme cases but I figured I'd mention it.
The fuse/voltage drop method linked above is the best way.
