Results 1 to 7 of 7
Thread: Audi A4 B8 Steering Angle sensor no signal (G85)
    Apr 2020
    Ireland
    Hello everyone, I've been a longtime reader on here but finally made myself a account.
    I've been having some problems with a 2012 A4 that's been giving me some bother the last week or so, usually I'd work on a problem long enough and I'd eventually find a solution but I have to say I'm beat this time.
    The blower motor was replaced this week and I'm trying to see if that's a cause to this. My bother has a older launch diagnostics reader which he used it the clear all fault codes on the car (some where there many months or more) and ever since then there has been 2 recurring fault codes (in the scan I uploaded) basically saying that it cannot communicate with the steering position sensor G85.
    I've the full autoscan in this post for someone more knowledgeable than me to look at.
    I've tried clearing the faults and they immediately come back. I've looked at the measuring blocks for the steering angle position sensor in both the ABS module and Steering wheel module and its reading Zero all the time no matter what
    position the steering wheel is in. Taking the car for a drive did not help at all either.
    I tried to follow the instructions to do a steering angle position zero calibration by going into the ABS Module, Login, Entered the security code successfully, I would then click on basic settings, channel 001 and click go. From here on
    It actually shows the steering angle but unlike the measuring blocks i was in which was showing zero all the time this actually shows the correct angle/position form the sensor. BUT once I click the [ON/OFF/Next] button to activate basic settings which says off it immediately says ERROR Group 001 Not available across the 4 measuring value boxes. From hear on I'm Stumped, I got a second steering wheel sensor and plugged it in and it gave me the exact same problem again so I don't think it's the problem.
    Chassis Type: 8K-AU48 (8T0)
    Scan: 01 03 05 08 09 10 15 16 17 19 42 46 47 52 53 55 56 62 72 77
    VIN: WAUZZZ8KXCA098327   Mileage: 205380km-127617miles
    04-Steering Angle -- Status: Cannot be reached 1100
    Address 01: Engine (J623-CJCB)       Labels:. 03L-906-018-CGL.clb
       Part No SW: 03L 906 018 JR    HW: 03L 906 018 DN
       Component: R4 2.0l TDI   H25 9977
       Revision: 45H25---
       Coding: 0A194012232503080000
       Shop #: WSC 55397 002 1048576
       ASAM Dataset: EV_ECM20TDI01103L906018JR 003007
       ROD: EV_ECM20TDI01103L906018DG.rod
       VCID: 035372A2DB97869FD47-8056
              U1113 00 [047] - -
                        Mileage: 205374 km
                        Date: 2020.04.02
                        Time: 15:31:53
                        Engine speed: 829.50 /min
                        Normed load value: 33.3 %
                        Coolant temperature: 73 °C
                        Intake air temperature: 21 °C
                        Voltage terminal 30: 13.160 V
                        Cruise Control System (CCS): switch position-Bits 0-7: 0
                        Cruise Control System (CCS): status-Bits 0-7: 200
                        Cruise control switch-off: irreversible-Bits 0-7: 2
                        Cruise control switch-off: reversible-Bits 0-7: 255
                        Cruise control switch-off: irreversible w. brake intervention-Bits 0-7: 4
              U1113 00 [047] - -
                        Mileage: 205374 km
                        Date: 2020.04.02
                        Time: 15:31:53
    5608 - No Communications with Steering Angle Sender (G85)
              U0126 00 [047] - -
                        Mileage: 205374 km
                        Date: 2020.04.02
                        Time: 15:31:53
                        Engine speed: 825.50 /min
                        Normed load value: 33.7 %
                        Voltage terminal 30: 13.220 V
                        selected gear-Bits 0-7: 0
    4714 - Steering Column Control Module
              U0212 00 [047] - No Communications
                        Mileage: 205374 km
                        Date: 2020.04.02
                        Time: 15:31:53
                        Engine speed: 830.50 /min
                        Normed load value: 32.9 %
                        Voltage terminal 30: 13.260 V
       Part No SW: 8K0 907 379 BF    HW: 8K0 907 379 BF
       Component: ESP8 front    H04 0030
       Coding: 160504
       Shop #: WSC 06324 000 00000
       VCID: 7EA50356B0F5EB77BB9-802A
                        Reset counter: 126
                        Mileage: 205377 km
                        Date: 2020.04.02
                        Time: 15:39:15
                        Hex Value: 0x0040
                        Hex Value: 0x0702
                        Hex Value: 0x002D
                        Hex Value: 0x31A5
                        Hex Value: 0x00FF
                        Reset counter: 126
                        Mileage: 205377 km
                        Date: 2020.04.02
                        Time: 15:39:15
                        Hex Value: 0x0040
                        Hex Value: 0x0702
                        Hex Value: 0x001C
                        Hex Value: 0x7AA5
                        Hex Value: 0x00FF
       Part No SW: 8K0 907 064 CC    HW: 8K0 907 064 CC
       Component: BCM2 2.0      H05 0435
       Coding: 033100
       Shop #: WSC 06325 000 00000
       VCID: 73B322628BB7B61FC47-8026
       Subsystem 1 - Part No SW: 8T0 959 754 D    HW: 8T0 959 754 D
       Component: FBSAUDIB8 IDG  H60 0072
       Serial number: 0811000189072007
       Serial number: 2311000245288008
       Part No SW: 8T2 820 043 AF    HW: 8T2 820 043 AF
       Component: KLIMA 3 ZONEN H08 0182
       Revision: D0000000    Serial number: 01141120110910
       Coding: 34240000
       VCID: 76B51B7698C5A337E39-8022
       Part No SW: 8K0 907 063 N    HW: 8K0 907 063 N
       Component: BCM1 1.0      H30 0392
       Revision: 09030001    Serial number: 00000001127396
       Coding: 260050914034AF010001000000001D0D001D030806010141000000
       VCID: 3A2DCF46EC5D0757C71-806E
       Subsystem 1 - Part No SW: 8K2 955 119 A    HW: 8T2 955 119   Labels: 1KX-955-119.CLB
       Component: WWS 141111  H06 0070
       Serial number: SWF11110145102
       Coding: 00FD11
       Component: RLS  H04 0003
       Serial number: 11776088
       Coding: 025028
       Component: E1 - LDS  H03 0031
       Serial number: 00000000000511110633
                        Reset counter: 126
                        Mileage: 205374 km
                        Date: 2020.04.02
                        Time: 15:31:00
       Part No SW: 8K0 919 475 T    HW: 8P0 919 475 M
       Component: PARKHILFE 4K  H01 0081
       Revision: 11001001    Serial number: 36861131303812
       Coding: 000003
       VCID: 4ACD9F86BCBD97D7571-801E
       Part No SW: 8K0 959 655 L    HW: 8K0 959 655 L
       Component: AirbagVW-AU10 H44 0610
       Serial number: 003JMD0HG5HQ
       Coding: 30533435363030303030554A3052384B3053
       VCID: 46D5ABB6A82573B7B39-8012
       Serial number: 6334MSME67120E1FJ
       Serial number: 6344MSME67056B20B
       Serial number: 6352QSME39643D50K
       Serial number: 6362QSME0E64494CV
       Serial number: 63732SME0E66157C7
       Serial number: 63832SME1B64025E0
    12658176 - No Communications with Steering Angle Sender (G85)
              U0126 00 [009] - -
              [Steer Angle Control Unit no signal/communication]
                        Reset counter: 126
                        Mileage: 205374 km
                        Date: 2020.04.02
                        Time: 15:31:51
       Component: Lenks.Modul   H17 0014
       Revision: --------    Serial number: 90372KKC000Z7
       Coding: 000016
       Shop #: WSC 06325 123 12345
       VCID: 3D27C45AFD73306FE23-8068
       Component: E221 - MFL  H02 0010
       Part No SW: 8K0 920 981 D    HW: 8K0 920 981 D
       Component: KOMBIINSTR.   H31 0258
       Revision: 00000000    Serial number: EJD249CCC
       Coding: 2F04080002002600010000
       VCID: 3431E17ECE39F1271DD-8060
       Part No SW: 8T0 907 468 AF    HW: 8T0 907 468 H
       Component: GW-BEM 5CAN   H06 0121
       Revision: GB901054    Serial number: 5400G11B028285
       Coding: 00CF07
       VCID: 05576CBAD523B8AFFA3-8050
       Component: J367-BDMHella  H03 8040
       Serial number: 9030785801
       Serial number: 11323001124021200181
                        Reset counter: 126
                        Mileage: 205374 km
                        Date: 2020.04.02
                        Time: 15:31:49
                        Bin. Bits:    11111
                        Voltage: 13.00 V
                        Count: 6
                        Bin. Bits:    10000
                        Time: 5.30 s
       Part No SW: 8T0 959 793 N    HW: 8T0 959 793 B
       Component: TSG FA        H07 1501
       Coding: 011002204001410001
       VCID: 54F181FE6EF9D1273DD-8000
       Revision: 00002001    Serial number: 0162663207
       Coding: 011B062200B904408020013680000000
                        Reset counter: 126
                        Mileage: 205374 km
                        Date: 2020.04.02
                        Time: 15:31:48
    Address 47: Sound System (J525)       Labels:. 8T0-035-223-ASC.clb
       Part No SW: 8T0 035 223 AH    HW: 8T0 035 223
       Component: DSP STD       H07 0230
       Revision: S2200000
       Coding: 0203010102
       VCID: 74B1217E8EB9B127DDD-8020
       Part No SW: 8T0 959 792 N    HW: 8T0 959 792 B
       Component: TSG BF        H07 1501
       VCID: 53F382E26BF7D61F247-8006
       Revision: 00000003    Serial number: 20000000146113
       Serial number: 111109-0002-160
       Coding: 1171941010000300
       ROD: EV_HeadlRegulBasic.rod
       VCID: 2D07F41A2D93A0EF523-8078
       Part No SW: 8T2 035 186 P    HW: 8T2 035 186 P
       Component: Concert3      H06 0350
       Revision: 00000011    Serial number: AUZ5Z6K1669372
       Coding: 0502008201018D00035B070000
       VCID: 45D7ACBA95A378AFBA3-8010
       Subsystem 1 - Part No SW: 8T0 919 603 F    HW: 8T0 919 603 F
       Component: Display
       Part No SW: 8T0 959 795 N    HW: 8T0 959 795 B
       Component: TSG HL        H06 1501
       Coding: 010002204001210001
       VCID: 56F57BF67805C337C39-8002
       Component: TSG HR        H06 1501
       Part No SW: 8T0 862 335 F    HW: 8T0 862 335 E
       Component: FSE_256x BT     H45 0660
       Revision: 00000000    Serial number: 00000005446405
       Coding: 0010320
       VCID: 3D27C45AF173306FE23-8068
    End----------(Elapsed Time: 01:35, VBatt start/end: 14.8V/14.7V)-----------
    If I knew for sure it was a new sensor I needed i don't mind spending the money on it, I just find it strange that its a "no communication" fault I'm getting and nothing else.
    Some help or advice on what to do going forward now would be greatly appreciated.
    All the Best, Michael
  2. Likes Uwe, Dana liked this post
  3. #2
    Hi and welcome.
    I have to agree that this is a head-scratcher.
    Hopefully someone reading it will have some ideas.
  4. Likes Ford5030 liked this post
  5. #3
    United States
    Hmm, G85 failure (which is the entire 16-Steering wheel module/J527) isn't uncommon - but there aren't faults in address 16 for a faulty sensor so this is odd. From a wiring point of view there happen to be 2 fuses to J527 so I'd make sure both are OK. Check your info but I believe those to be ST1 SD5 and ST2 SD12.
    Edit, I just noticed you already plugged in a different 16 module so this clearly isn't module failure. Hopefully one of those fuses are blown.
  6. Likes Uwe, Ford5030, Jack@European_Parts liked this post
  7. #4
    Apr 2020
    Ireland
    Thanks for recommending me to check the fuses, You hit the nail on the head!
    Since It wasn't me who replaced the blower I went and looked at everything again from scratch.
    This all happened while the car was stopped so I looked at the wiring around the blower area and it seems to be all alright, Went then to check the fuse box compartment and found a piggy back fuse holder (aftermarket clearly) with a red wire snaking off deeper into the car, Now I don't know what the wires for but I'd guess a dash cam as I see one mounted in the car. Pulled the fuse and voila, All the lights went out. Took the car for a drive and it must have calibrated itself then as the last of the EPS/ABS lights went out too. Whatever that piggyback fuse is doing it clearly messed with the connection to the steering angle module.
    Can't say how big a relief it is to find the problem, I was contemplating getting a ABS Module or else a brand new steering wheel angle module to try fix the problem. I'm not sure what the slot does that the piggy back fuse is taking power from but I'm not going to touch it now that everything working in case it gives more problems.
  8. #5
    FOD wins again and checking fuses, so why did fuse blow is the question to ask?
  9. Likes Uwe, Ford5030 liked this post
  10. #6
    Apr 2020
    Ireland
    Fuse was intact but loose, I don't think it was making a connection in the socket. I don't know what the socket does but I'd say it's something to do with providing power to the steering wheel module (G85) and it was pulled loose when the blower was installed
    I'd wager whoever installed the dashcam just picked a random fuse not knowing what it does.
  11. Likes Jack@European_Parts, Uwe, Dana liked this post
  12. #7
    United States
    Thanks for the feedback! Because this was an odd one I added Special Notes to both of these pages:
    http://wiki.ross-tech.com/wiki/index...FCommunication
    http://wiki.ross-tech.com/wiki/index.php/U0212
  13. Likes Uwe, Ford5030 liked this post
