Help with vr6 emission control related faults
mmjojomm
C?ID=287943 (!)
HI Guys,
im having an intermittent problem with engine light coming on and its seems it is due to the emission control.
Ive replaced one of the N112 solenoid valves that operate flaps, ive run secondary air injection pump connected straight to the battery and it seems spin fine and quietly, and replaced new EVAP Purge Control Valve (N80).
Could anyone advise me please in next troubleshooting steps? below is read out from the scan, can i do any in depth analysis with rosstech on the codes below and secondary injection air pump?
cheers
joe
Address 01: Engine Labels: None
Part No SW: 022 906 032 MK HW: 022 906 032
Component: T5-3.2-AQ-EU4 G 3035
Coding: 0001075
Shop #: WSC 02756 790 00000
VCID: 60CE248AB0372A4FF7-5140
16828 - EVAP Purge Control Valve (N80)
P0444 - 004 - Circuit Open - MIL ON
17840 - Secondary Air Injection Solenoid Valve (N112)
P1432 - 004 - Open Circuit - Intermittent
Readiness: 0010 1101
Did you overlay or check wiring for open for feed consumer BUS and current tracks back to ECU yet for respective components?
Fuses!
mmjojomm
C?ID=287943 (!)
Am I right to think that engine components like purge valve related fuses would be in the engine compartment fuse box ? Car is multivan T5 v6
Cheers
mmjojomm
C?ID=287943 (!)
hi all, thank you for help, checked fuses and all good, so since connection was intermittent ive started to undo electrical tape and found broken wire inside the plastic sleeve. so all sorted, all cleared up, and im happy bunny again ( my ocd)
