Page 3 of 3 FirstFirst 123
Results 21 to 23 of 23
Thread: T6 oem MFSW retrofit. Unable to access Engine 01 to activate
  1. #21
    Quote Originally Posted by audiobull View Post
    This is my user interface
    Change it as I wrote.
    [Options]
    [User Interface and Identification]
    write numbers for wsc, importer, device no.
    For example: 12345 123 23456
    [Save]
    [Close VCDS]
    Start VCDS
    You probably tried to many wrong Security keys, look at IDE00323. measurement.
    Engine controller changed or other history about this ?
    And with trailer engine is Byte 5 Bit 4
    0019401C433501090000
    or
    0019401C443501090000
    Coding for trailer is often:
    410D000103000000
  2. Likes Uwe liked this post
  3. #22
    Apr 2020
    Thank you
    I tried the interface code, restarted. Does the same.
    I am not sure how to pull the history up. Tried it using the history application but it said error not supported.
    This is the advanced id screen for the engine 01 module and the screen shot of the ide00323 measurement.
    I have no idea if the module has been changed. I purchased at 9500mile last October from a vw dealer. Nothing was mentioned.
  4. #23
    Jan 2019
    Just did the Test with HEX-V2.
    The coding change in CCS is working as expected now.
    So this is prooven: T6 EU6 ECU's DCM6.2 from DELPHI can only be coded with the new HEX-V2.
    Thanks to Uwe
  5. Likes Uwe, audiobull liked this post
