Results 11 to 20 of 23
Thread: T6 oem MFSW retrofit. Unable to access Engine 01 to activate
    Jan 2019
    Whell that sound strange.
    You can not change anything in the ECU ?
    Whell 90% of coding can not be changed this get's blocked by ECU Firmware, but something must work, i will try with my spare one and report back.
    I myself used VCP and O**s Engeneering to change the CCS Bits in Coding of EU6 ECU in T6.
    I know that it worked with ODB11 Pro for others.
    And a friend who bought a new Hex-2 had no issues with VCDS's, too. I can not verify this because i only own a 3 VIN Version, and don't wont to waste a VIN for this test.
    I suppose that only the old non HEX-2 interface probably have this issues, but again, let UWE clarify this.
  2. Likes audiobull liked this post
  3. #12
    Apr 2020
    Yes if I go straight in and try and change the coding of engine ecu, any coding, not specifically ccs (although that is what I want to do) then I get error:
    coding rejection. Error 00: unknown (0x00) and coding rejection. Error 31: unknown (0x00).
    One of those was because I had the engine running.
    I tried to enter the codes that are available just incase i needed security access but no matter what I try all I get is this error
    Controller refused to send a seed!
    Error 7F: Service not supported in active session.
    I think this is either a vcds problem or a module problem. How I determine which is at fault I am not sure. All other modules I can change both coding and adaptions.
  4. #13
    Jan 2019
    Just did a test with an old VCDS interface and i get always 0x31 in ECU.
    So this looks like an old interface issue.
  5. #14
    Apr 2020
    Brill thank you millions.
    So it looks like I need to nicely ask someone to turn it on for me with another program. I dont really want to pay 450 for a new lead just to change one setting.
  6. Likes dnoermann liked this post
  7. #15
    I assume MFSW retrofit, is correct done, and correct for CC.
    VIN is important!
    Is it an Non UK car (import)?
    If not, I don't understand why it Engine is coded for steering left side Byte 5 Bit 0 ??
    Does kufatec instruction not show Byte 29 Bit 6 for BCM ??
    First:
    [Options]
    [User Interface and Identification]
    write numbers for wsc, importer, device no.
    For example 12345 123 23456
    [Save]
    [Close VCDS]
    Start VCDS
    Charger attached.
    First do Coding in [09] BCM, Byte 17 Bit 2
    VCDS front page > Ign OFF > Wait 10 sec > Ign On
    CC OFF (if ON) > Start/Stop OFF
    [Engine-01]
    [Security access-16] > 20103
    Copy coding: 0019401C432401090000 > [Do it]
    Or 0019401C432501090000 if PR-L0R
    I guess tow bar is not factory installed?
  8. Likes Uwe liked this post
  9. #16
    Apr 2020
    Hi Thanks.
    I have just changed the wiring from pin 17 to pin 36. I have changed byte 29 bit 7. This is all working along with all buttons showing as working in the test. Trip and stereo buttons are doing something but CCS buttons not activating.
    I will start again doing what you suggest and send a scan.
    The van is a UK RHD model. Its not checked in the Engine module and I cannot change it. I have added the towbar. It is a VW genuine westfalia kit but it was not done at factory.
    I do not have any wsc, importer or device numbers in the user interface, should I have these? What should they be?
    Again many thanks. Slowly getting there with this but the Engine module will not let me change anything still.
  10. #17
    Apr 2020
    vin WV2ZZZ7HZGH040660
    I will leave it on the next scan.
  11. #18
    Apr 2020
    This is my user interface
  12. #19
    Apr 2020
    Followed as above.
    This is what I get when I come to do the security section
  13. #20
    Apr 2020
    Saturday,04,April,2020,11:02:49:26804
    VCDS Version: 20.4.0.1 (x64)
    VIN: WV2ZZZ7HZGH040660   License Plate: CAMPER
    Mileage: 22160km-13769mi   Repair Order:
    Chassis Type: 7H-VN75 (7E0)
    Scan: 01 03 04 08 09 15 17 18 19 25 5F 61 69 0B
    VIN: WV2ZZZ7HZGH040660   Mileage: 22160km-13769miles
    Address 01: Engine (2D2D2-CXHA)       Labels:. 04L-907-309-V2.clb
       Part No SW: 04L 906 056 KM    HW: 04L 907 445
       Component: R4 2.0l TDI   H02 6186
       Revision: 23002001
       Coding: 0019401C430401090000
       Shop #: WSC 02737 790 50316
       ASAM Dataset: EV_ECM20TDI03004L906056KM 004013
       ROD: EV_ECM20TDI03004L906056JS_004.rod
       VCID: 020B54C69567A59614-8056
    Readiness: N/A
    Address 03: ABS Brakes (J104)       Labels: 7E0-907-37x-MK100ESC.clb
       Part No SW: 7E0 907 379 P    HW: 7E0 907 379 M
       Component: ESC           H05 0132
       Revision: 00000000    Serial number: 42505000001532
       Coding: 307E40982566847E0C7B027CA48221D3790000
       Shop #: WSC 02739 790 50316
       ROD: EV_Brake1ESCCONTIVN75XGP2_011.rod
       VCID: 3F8D9D32A615087E3B-806A
       Component: LENKW.SENSOR  H07 0070
       Serial number: 26061504650890
       Coding: 01
       ROD: EV_LWSKLOVW25X.rod
       VCID: 7EF32036E19FC17670-802A
    Address 08: Auto HVAC (J301)       Labels:| 7E5-907-047.clb
       Part No SW: 7E0 907 047 R    HW: 7E0 907 047 R
       Component: Climatic-T5   H22 0607
       Revision: 00001002
       Coding: 0000000003
       ROD: EV_ClimaT5Basis.rod
       VCID: 3979F32AB831264E05-806C
    Address 09: Cent. Elect. (J519)       Labels:. 7E0-937-BCM-V1.clb
       Part No SW: 7E0 937 090     HW: 7E0 937 090
       Component: BCM PQ25 Max4 H80 0736
       Revision: B9080001    Serial number: 0771 246150901
       Coding: A0F4793A0A63349392284F642C6A9DD48DA4698960440970320400BF0840
       Shop #: WSC 43013 002 104857
       VCID: 68DF666E9B1B6FC6AA-803C
       Subsystem 1 - Part No SW: 7E0 959 801 K    HW: 7E0 959 801 K  Labels: 7E0-959-80X-V2.CLB
       Component: J386__TSG_FT  003 8654
       Serial number: KU0KU027081552393158
       Coding: 1400B0
       Subsystem 2 - Part No SW: 7E0 959 802 K    HW: 7E0 959 802 K  Labels: 7E0-959-80X-V2.CLB
       Component: J387__TSG_BT  003 8654
       Serial number: KU0KU007091552501498
       Coding: 0400A0
       Subsystem 3 - Part No: 7E1 951 171
       Subsystem 5 - Part No: 7E1 951 171
       Subsystem 6 - Part No SW: 7E0 959 442     HW: 7E0 959 442
       Component: E221__MFL-DC1  H02 0103
       Serial number: 39170002737200037506
       Coding: B0FFFF
    50990 - Unknown Error Code
                Unknown - 014 -
                        Fault Status: 01101110
                        Reset counter: 232
                        Mileage: 22169 km
                        Date: 2020.04.04
                        Time: 14:30:41
       Part No SW: 7E0 959 655 E    HW: 7E0 959 655 E
       Component: VW10Airbag00C 008 0016
       Revision: --------    Serial number: 003PJ000EW8F
       Coding: 000000000000000000000000000000003043
       Shop #: WSC 02734 790 50316
       ASAM Dataset: EV_AirbaVW10BPAVW12X 001028
       ROD: EV_AirbaVW10BPAVN750.rod
       VCID: 387FF62E833B3F46FA-806C
       Serial number: 3495ZRB40693FGI6E89U
       Serial number: 3505ZRB40573FGI67P5P
       Part No SW: 7E0 920 970 L    HW: 7E0 920 970 L
       Component: KOMBI         H05 1008
       Coding: 710D010300
       ROD: EV_Kombi_UDS_VDD_RM09_005_VW31.rod
       VCID: 3365C1029A5DDC1ECF-8066
    Address 18: Aux. Heat (J364)       Labels:| 7E0-963-27X-18.clb
       Part No SW: 7E0 963 273     HW: 7E0 963 273
       Component: STH-T5GP2     002 0007
       Coding: 4101
       Shop #: WSC 02759 790 50316
       ASAM Dataset: EV_AuxilParkiHeateWOST5G2 001010
       ROD: EV_AuxilParkiHeateWOST5G2.rod
       VCID: 6ADB1C668D175DD6BC-803E
    Address 19: CAN Gateway (J533)       Labels:. 7E0-909-901.clb
       Part No SW: 7E0 909 901     HW: 7E0 937 090
       Component: GW-K-CAN TP20 H80 0736
       Revision: B9080001
       Coding: 042305
       Component: IMMO          H05 1008
    Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-ENT2.clb
       Part No SW: 1K8 035 150 E    HW: 1K8 035 150 E
       Component: MU-E-D-ER     857 6495
       Serial number: 28081500012536
       Coding: 065700003C00000041111101008000001F0000860000010001
       ASAM Dataset: EV_MUEnt4CGen2LGE 001025
       ROD: EV_MUEnt4CGen2LGE_VW32.rod
       VCID: 275D25525E85A0BE63-8072
       Part No SW: 7E0 907 534     HW: 7E0 937 090
       Component: Batt.regelung H80 0736
       Coding: 030B1A73
       Shop #: WSC 02739 790 00000
       Subsystem 1 - Part No SW: 7E0 915 181 G    HW: 7E0 915 181 G
       Component: J367-BDM  H08 0223
       Serial number: 52232F34531261520254
       Component: Anhaenger     H12 0100
       Revision: 3A001001    Serial number: 00000495347083
       Coding: 0100000100000000
       VCID: 306FCE0E634BE706B2-8064
    End-------------------------(Elapsed Time: 03:05)--------------------------
