T6 oem MFSW retrofit. Unable to access Engine 01 to activate
audiobull
C?ID=184184
I have finished the install of a standard mfsw. I followed a kufatec instruction manual but it assumes the van already has a cruise control wire. It did not work. I added a cable from the T10 connector so I am now fully installed and running on pin 17 of the bcm. Others say to use pin 37 but that gives me no function at all.
So the trip display, phone, stereo controls work perfectly.
However I cannot get the cruise to work at all.
It does not even know the buttons are there.
I have done most of the coding where I had options to do so. When I can to activating Cruise in the engine 01 module. I cannot seem to change it, I cannot even change any settings to be honest. I get a coding rejection. Error 00: unknown (0x00). I also got a coding rejection. Error 31: unknown (0x00) but that may have been when my engine was running.
Can anyone please shed some light on what would be stopping me from accessing to code the module?
I am fully up to date. version 20.4.0
audiobull
C?ID=184184
Thank you thats my bad sorry. Only fault from what I can tell is because I have disconnected rear motion sensor as its a camper now.
Wheel is connected and all wiring done but no Cruise available and to actvate I need to be able to change it within Engine 01. I get a error every time I try and change anything.
Friday,03,April,2020,10:06:58:26804
VCDS Version: 20.4.0.1 (x64)
VIN: License Plate: CAMPER
Mileage: 22160km-13769mi   Repair Order:
Chassis Type: 7H-VN75 (7E0)
Scan: 01 03 04 08 09 15 17 18 19 25 5F 61 69 0B
VIN: Mileage: 22160km-13769miles
Address 01: Engine (2D2D2-CXHA)       Labels:. 04L-907-309-V2.clb
   Part No SW: 04L 906 056 KM    HW: 04L 907 445
   Component: R4 2.0l TDI   H02 6186
   Revision: 23002001
   Coding: 0019401C430401090000
   Shop #: WSC 02737 790 50316
   ASAM Dataset: EV_ECM20TDI03004L906056KM 004013
   ROD: EV_ECM20TDI03004L906056JS_004.rod
   VCID: 020B54C69567A59614-8056
Readiness: N/A
Address 03: ABS Brakes (J104)       Labels: 7E0-907-37x-MK100ESC.clb
   Part No SW: 7E0 907 379 P    HW: 7E0 907 379 M
   Component: ESC           H05 0132
   Revision: 00000000    Serial number: 42505000001532
   Coding: 307E40982566847E0C7B027CA48221D3790000
   Shop #: WSC 02739 790 50316
   VCID: 3F8D9D32A615087E3B-806A
   Part No SW: 6R0 959 654     HW: 6R0 959 654
   Component: LENKW.SENSOR  H07 0070
   Serial number: 26061504650890
   Coding: 01
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EF32036E19FC17670-802A
   Part No SW: 7E0 907 047 R    HW: 7E0 907 047 R
   Component: Climatic-T5   H22 0607
   Revision: 00001002
   Coding: 0000000003
   ROD: EV_ClimaT5Basis.rod
   VCID: 3979F32AB831264E05-806C
   Part No SW: 7E0 937 090     HW: 7E0 937 090
   Component: BCM PQ25 Max4 H80 0736
   Revision: B9080001    Serial number: 0771 246150901
   Coding: A0F4793A0A63349392284F642C6A9DD48DA0698960440970320400BF0800
   Shop #: WSC 43013 002 104857
   VCID: 68DF666E9B1B6FC6AA-803C
   Subsystem 1 - Part No SW: 7E0 959 801 K    HW: 7E0 959 801 K  Labels: 7E0-959-80X-V2.CLB
   Component: J386__TSG_FT  003 8654
   Serial number: KU0KU027081552393158
   Coding: 1400B0
   Subsystem 2 - Part No SW: 7E0 959 802 K    HW: 7E0 959 802 K  Labels: 7E0-959-80X-V2.CLB
   Component: J387__TSG_BT  003 8654
   Serial number: KU0KU007091552501498
   Coding: 0400A0
   Subsystem 3 - Part No: 7E1 951 171
   Subsystem 5 - Part No: 7E1 951 171
   Subsystem 6 - Part No SW: 7E0 959 442     HW: 7E0 959 442
   Component: E221__MFL-DC1  H02 0103
   Serial number: 39170002737200037506
   Coding: B0FFFF
50990 - Unknown Error Code
            Unknown - 014 -
                    Fault Status: 01101110
                    Reset counter: 232
                    Mileage: 22169 km
                    Date: 2020.04.03
                    Time: 14:25:32
   Part No SW: 7E0 959 655 E    HW: 7E0 959 655 E
   Component: VW10Airbag00C 008 0016
   Revision: --------    Serial number: 003PJ000EW8F
   Coding: 000000000000000000000000000000003043
   Shop #: WSC 02734 790 50316
   ROD: EV_AirbaVW10BPAVN750.rod
   VCID: 387FF62E833B3F46FA-806C
   Serial number: 3495ZRB40693FGI6E89U
   Serial number: 3505ZRB40573FGI67P5P
   Part No SW: 7E0 920 970 L    HW: 7E0 920 970 L
   Component: KOMBI         H05 1008
   Coding: 710D010300
   ROD: EV_Kombi_UDS_VDD_RM09_005_VW31.rod
   VCID: 3365C1029A5DDC1ECF-8066
Address 18: Aux. Heat (J364)       Labels:| 7E0-963-27X-18.clb
   Part No SW: 7E0 963 273     HW: 7E0 963 273
   Component: STH-T5GP2     002 0007
   Coding: 4101
   Shop #: WSC 02759 790 50316
   ASAM Dataset: EV_AuxilParkiHeateWOST5G2 001010
   ROD: EV_AuxilParkiHeateWOST5G2.rod
   VCID: 6ADB1C668D175DD6BC-803E
   Part No SW: 7E0 909 901     HW: 7E0 937 090
   Component: GW-K-CAN TP20 H80 0736
   Revision: B9080001
   Coding: 042305
   Component: IMMO          H05 1008
   Part No SW: 1K8 035 150 E    HW: 1K8 035 150 E
   Component: MU-E-D-ER     857 6495
   Serial number: 28081500012536
   Coding: 065700003C00000041111101008000001F0000860000010001
   ASAM Dataset: EV_MUEnt4CGen2LGE 001025
   ROD: EV_MUEnt4CGen2LGE_VW32.rod
   VCID: 275D25525E85A0BE63-8072
   Part No SW: 7E0 907 534     HW: 7E0 937 090
   Component: Batt.regelung H80 0736
   Coding: 030B1A73
   Shop #: WSC 02739 790 00000
   Subsystem 1 - Part No SW: 7E0 915 181 G    HW: 7E0 915 181 G
   Component: J367-BDM  H08 0223
   Serial number: 52232F34531261520254
   Part No SW: 1K0 907 383 F    HW: 1K0 907 383 F
   Component: Anhaenger     H12 0100
   Revision: 3A001001    Serial number: 00000495347083
   Coding: 0100000100000000
   Shop #: WSC 12345 123 12345
   VCID: 306FCE0E634BE706B2-8064
End-------------------------(Elapsed Time: 03:02)--------------------------
audiobull
C?ID=184184
If I try 27971 or 12233 I get
Controller refused to send a seed!
Error 7F: Service not supported in active session.
Any ideas anyone?
audiobull
C?ID=184184
Also to add just so we can rule it out. I tried it on my daughters laptop. More basic then my high spec laptop and I get the same problem.
No VIN. What model year is this van?
I wonder if CCS isn't an FEC in this application...?
audiobull
C?ID=184184
Thanks Uwe
The van is a 2016. Its an early T6 but is an EU6. Happy to pm vin. :-)
I will have a look see what that means.
audiobull
C?ID=184184
I have had a look but the FEC would require an MQB based system where as the BCM and the rest I have are PQ25 based? I think I have understood that correctly.
Is there any way or reason the Engine 01 module would be locked somehow or is this a vcds or cable problem? May I have to change from vcds to another version?
dnoermann
C?ID=358118
The T6 is PQ25, no FEC/SWAP are needed for CCS Activation.
However VCDS does have some issues to enable the Coding in the EU6 ECU's in the T6.
A lot of users get 0x31 when they try to enable CCS in Coding.
In the german VCDS Forum someone posted an explanantiation some time agoe, see here: https://forum.vcdspro.de/index.php?...m-verweigert-ihr/&tab=comments#comment-224024
Hopefully UWE can give clarification in englisch here.
And i suppose that this is already fixxed in newest genuine VCDS.
I seached this error myself for weeks, in the end i used a different tool and it just worked.
But since you have a EU6 ECU you have to change the wiering of the LIN bus for the MFL to get CCS via MFL working in the T6.
I already explained this here: https://forums.ross-tech.com/showth...op-active-quot&p=168268&viewfull=1#post168268
audiobull
C?ID=184184
Thank you dnoermann
I can change the pin number over for pin 36 no problem at all. It just seems to be the engine module vcds is not able to change any of the coding for. It is as if it is not powerful enough or has the right permissions. I have no clue to be honest but the van is not a brand new my19 however it is an EU6.
I have trawled all over the web with no success to get the engine coding changed. I even tried with the bonnet open just in case. no luck.
I have changed all sorts of things on the van in all other modules but the engine one is not playing ball.
Can you tell me what tool you used please? I understand my vcds cable is not the brand new one but I do not want to upgrade it to find the new one is still not capable .
dnoermann
C?ID=358118
Whell that sound strange.
You can not change anything in the ECU ?
Whell 90% of coding can not be changed this get's blocked by ECU Firmware, but something must work, i will try with my spare one and report back.
I myself used VCP and O**s Engeneering to change the CCS Bits in Coding of EU6 ECU in T6.
I know that it worked with ODB11 Pro for others.
And a friend who bought a new Hex-2 had no issues with VCDS's, too. I can not verify this because i only own a 3 VIN Version, and don't wont to waste a VIN for this test.
I suppose that only the old non HEX-2 interface probably have this issues, but again, let UWE clarify this.
audiobull
C?ID=184184
Yes if I go straight in and try and change the coding of engine ecu, any coding, not specifically ccs (although that is what I want to do) then I get error:
coding rejection. Error 00: unknown (0x00) and coding rejection. Error 31: unknown (0x00).
One of those was because I had the engine running.
I tried to enter the codes that are available just incase i needed security access but no matter what I try all I get is this error
I think this is either a vcds problem or a module problem. How I determine which is at fault I am not sure. All other modules I can change both coding and adaptions.
dnoermann
C?ID=358118
Just did a test with an old VCDS interface and i get always 0x31 in ECU.
So this looks like an old interface issue.
audiobull
C?ID=184184
Brill thank you millions.
So it looks like I need to nicely ask someone to turn it on for me with another program. I dont really want to pay £450 for a new lead just to change one setting.
NEtech
C?ID=56995
I assume MFSW retrofit, is correct done, and correct for CC.
VIN is important!
Is it an Non UK car (import)?
If not, I don't understand why it Engine is coded for steering left side Byte 5 Bit 0 ??
Does kufatec instruction not show Byte 29 Bit 6 for BCM ??
First:
[Options]
[User Interface and Identification]
write numbers for wsc, importer, device no.
For example 12345 123 23456
[Save]
[Close VCDS]
Start VCDS
Charger attached.
First do Coding in [09] BCM, Byte 17 Bit 2
VCDS front page > Ign OFF > Wait 10 sec > Ign On
CC OFF (if ON) > Start/Stop OFF
[Engine-01]
[Security access-16] > 20103
Copy coding: 0019401C432401090000 > [Do it]
Or 0019401C432501090000 if PR-L0R
I guess tow bar is not factory installed?
audiobull
C?ID=184184
Hi Thanks.
I have just changed the wiring from pin 17 to pin 36. I have changed byte 29 bit 7. This is all working along with all buttons showing as working in the test. Trip and stereo buttons are doing something but CCS buttons not activating.
I will start again doing what you suggest and send a scan.
The van is a UK RHD model. Its not checked in the Engine module and I cannot change it. I have added the towbar. It is a VW genuine westfalia kit but it was not done at factory.
I do not have any wsc, importer or device numbers in the user interface, should I have these? What should they be?
Again many thanks. Slowly getting there with this but the Engine module will not let me change anything still.
audiobull
C?ID=184184
vin WV2ZZZ7HZGH040660
I will leave it on the next scan.
audiobull
C?ID=184184
This is my user interface
audiobull
C?ID=184184
Followed as above.
This is what I get when I come to do the security section
audiobull
C?ID=184184
Saturday,04,April,2020,11:02:49:26804
VIN: WV2ZZZ7HZGH040660   License Plate: CAMPER
VIN: WV2ZZZ7HZGH040660   Mileage: 22160km-13769miles
   Revision: 23002001
Readiness: N/A
   Coding: 01
   Revision: 00001002
   Coding: 0000000003
   Coding: A0F4793A0A63349392284F642C6A9DD48DA4698960440970320400BF0840
   Coding: 1400B0
   Coding: 0400A0
   Coding: B0FFFF
            Unknown - 014 -
                    Reset counter: 232
                    Mileage: 22169 km
                    Date: 2020.04.04
                    Time: 14:30:41
   Coding: 710D010300
   Coding: 4101
   Revision: B9080001
   Coding: 042305
   Coding: 030B1A73
End-------------------------(Elapsed Time: 03:05)--------------------------
