Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: T6 oem MFSW retrofit. Unable to access Engine 01 to activate
    Apr 2020
    I have finished the install of a standard mfsw. I followed a kufatec instruction manual but it assumes the van already has a cruise control wire. It did not work. I added a cable from the T10 connector so I am now fully installed and running on pin 17 of the bcm. Others say to use pin 37 but that gives me no function at all.
    So the trip display, phone, stereo controls work perfectly.
    However I cannot get the cruise to work at all.
    It does not even know the buttons are there.
    I have done most of the coding where I had options to do so. When I can to activating Cruise in the engine 01 module. I cannot seem to change it, I cannot even change any settings to be honest. I get a coding rejection. Error 00: unknown (0x00). I also got a coding rejection. Error 31: unknown (0x00) but that may have been when my engine was running.
    Can anyone please shed some light on what would be stopping me from accessing to code the module?
    I am fully up to date. version 20.4.0
    Hi and welcome.
    Apr 2020
    Thank you thats my bad sorry. Only fault from what I can tell is because I have disconnected rear motion sensor as its a camper now.
    Wheel is connected and all wiring done but no Cruise available and to actvate I need to be able to change it within Engine 01. I get a error every time I try and change anything.
    Friday,03,April,2020,10:06:58:26804
    VCDS Version: 20.4.0.1 (x64)
    VIN: License Plate: CAMPER
    Mileage: 22160km-13769mi   Repair Order:
    Chassis Type: 7H-VN75 (7E0)
    Scan: 01 03 04 08 09 15 17 18 19 25 5F 61 69 0B
    VIN: Mileage: 22160km-13769miles
    Address 01: Engine (2D2D2-CXHA)       Labels:. 04L-907-309-V2.clb
       Part No SW: 04L 906 056 KM    HW: 04L 907 445
       Component: R4 2.0l TDI   H02 6186
       Revision: 23002001
       Coding: 0019401C430401090000
       Shop #: WSC 02737 790 50316
       ASAM Dataset: EV_ECM20TDI03004L906056KM 004013
       ROD: EV_ECM20TDI03004L906056JS_004.rod
       VCID: 020B54C69567A59614-8056
    Readiness: N/A
    Address 03: ABS Brakes (J104)       Labels: 7E0-907-37x-MK100ESC.clb
       Part No SW: 7E0 907 379 P    HW: 7E0 907 379 M
       Component: ESC           H05 0132
       Revision: 00000000    Serial number: 42505000001532
       Coding: 307E40982566847E0C7B027CA48221D3790000
       Shop #: WSC 02739 790 50316
       ROD: EV_Brake1ESCCONTIVN75XGP2_011.rod
       VCID: 3F8D9D32A615087E3B-806A
       Component: LENKW.SENSOR  H07 0070
       Serial number: 26061504650890
       Coding: 01
       ROD: EV_LWSKLOVW25X.rod
       VCID: 7EF32036E19FC17670-802A
    Address 08: Auto HVAC (J301)       Labels:| 7E5-907-047.clb
       Part No SW: 7E0 907 047 R    HW: 7E0 907 047 R
       Component: Climatic-T5   H22 0607
       Revision: 00001002
       Coding: 0000000003
       ROD: EV_ClimaT5Basis.rod
       VCID: 3979F32AB831264E05-806C
    Address 09: Cent. Elect. (J519)       Labels:. 7E0-937-BCM-V1.clb
       Part No SW: 7E0 937 090     HW: 7E0 937 090
       Component: BCM PQ25 Max4 H80 0736
       Revision: B9080001    Serial number: 0771 246150901
       Coding: A0F4793A0A63349392284F642C6A9DD48DA0698960440970320400BF0800
       Shop #: WSC 43013 002 104857
       VCID: 68DF666E9B1B6FC6AA-803C
       Subsystem 1 - Part No SW: 7E0 959 801 K    HW: 7E0 959 801 K  Labels: 7E0-959-80X-V2.CLB
       Component: J386__TSG_FT  003 8654
       Serial number: KU0KU027081552393158
       Coding: 1400B0
       Subsystem 2 - Part No SW: 7E0 959 802 K    HW: 7E0 959 802 K  Labels: 7E0-959-80X-V2.CLB
       Component: J387__TSG_BT  003 8654
       Serial number: KU0KU007091552501498
       Coding: 0400A0
       Subsystem 3 - Part No: 7E1 951 171
       Subsystem 5 - Part No: 7E1 951 171
       Subsystem 6 - Part No SW: 7E0 959 442     HW: 7E0 959 442
       Component: E221__MFL-DC1  H02 0103
       Serial number: 39170002737200037506
       Coding: B0FFFF
    50990 - Unknown Error Code
                Unknown - 014 -
                        Fault Status: 01101110
                        Reset counter: 232
                        Mileage: 22169 km
                        Date: 2020.04.03
                        Time: 14:25:32
       Part No SW: 7E0 959 655 E    HW: 7E0 959 655 E
       Component: VW10Airbag00C 008 0016
       Revision: --------    Serial number: 003PJ000EW8F
       Coding: 000000000000000000000000000000003043
       Shop #: WSC 02734 790 50316
       ASAM Dataset: EV_AirbaVW10BPAVW12X 001028
       ROD: EV_AirbaVW10BPAVN750.rod
       VCID: 387FF62E833B3F46FA-806C
       Serial number: 3495ZRB40693FGI6E89U
       Serial number: 3505ZRB40573FGI67P5P
       Part No SW: 7E0 920 970 L    HW: 7E0 920 970 L
       Component: KOMBI         H05 1008
       Coding: 710D010300
       ROD: EV_Kombi_UDS_VDD_RM09_005_VW31.rod
       VCID: 3365C1029A5DDC1ECF-8066
    Address 18: Aux. Heat (J364)       Labels:| 7E0-963-27X-18.clb
       Part No SW: 7E0 963 273     HW: 7E0 963 273
       Component: STH-T5GP2     002 0007
       Coding: 4101
       Shop #: WSC 02759 790 50316
       ASAM Dataset: EV_AuxilParkiHeateWOST5G2 001010
       ROD: EV_AuxilParkiHeateWOST5G2.rod
       VCID: 6ADB1C668D175DD6BC-803E
    Address 19: CAN Gateway (J533)       Labels:. 7E0-909-901.clb
       Part No SW: 7E0 909 901     HW: 7E0 937 090
       Component: GW-K-CAN TP20 H80 0736
       Revision: B9080001
       Coding: 042305
       Component: IMMO          H05 1008
    Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-ENT2.clb
       Part No SW: 1K8 035 150 E    HW: 1K8 035 150 E
       Component: MU-E-D-ER     857 6495
       Serial number: 28081500012536
       Coding: 065700003C00000041111101008000001F0000860000010001
       ASAM Dataset: EV_MUEnt4CGen2LGE 001025
       ROD: EV_MUEnt4CGen2LGE_VW32.rod
       VCID: 275D25525E85A0BE63-8072
       Part No SW: 7E0 907 534     HW: 7E0 937 090
       Component: Batt.regelung H80 0736
       Coding: 030B1A73
       Shop #: WSC 02739 790 00000
       Subsystem 1 - Part No SW: 7E0 915 181 G    HW: 7E0 915 181 G
       Component: J367-BDM  H08 0223
       Serial number: 52232F34531261520254
       Component: Anhaenger     H12 0100
       Revision: 3A001001    Serial number: 00000495347083
       Coding: 0100000100000000
       VCID: 306FCE0E634BE706B2-8064
    End-------------------------(Elapsed Time: 03:02)--------------------------
    Apr 2020
    If I try 27971 or 12233 I get
    Controller refused to send a seed!
    Error 7F: Service not supported in active session.
    Any ideas anyone?
    Apr 2020
    Also to add just so we can rule it out. I tried it on my daughters laptop. More basic then my high spec laptop and I get the same problem.
    No VIN. What model year is this van?
    I wonder if CCS isn't an FEC in this application...?
  7. #7
    Apr 2020
    Thanks Uwe
    The van is a 2016. Its an early T6 but is an EU6. Happy to pm vin. :-)
    I will have a look see what that means.
  8. #8
    Apr 2020
    I have had a look but the FEC would require an MQB based system where as the BCM and the rest I have are PQ25 based? I think I have understood that correctly.
    Is there any way or reason the Engine 01 module would be locked somehow or is this a vcds or cable problem? May I have to change from vcds to another version?
  9. #9
    Jan 2019
    The T6 is PQ25, no FEC/SWAP are needed for CCS Activation.
    However VCDS does have some issues to enable the Coding in the EU6 ECU's in the T6.
    A lot of users get 0x31 when they try to enable CCS in Coding.
    In the german VCDS Forum someone posted an explanantiation some time agoe, see here: https://forum.vcdspro.de/index.php?/...comment-224024
    Hopefully UWE can give clarification in englisch here.
    And i suppose that this is already fixxed in newest genuine VCDS.
    I seached this error myself for weeks, in the end i used a different tool and it just worked.
    But since you have a EU6 ECU you have to change the wiering of the LIN bus for the MFL to get CCS via MFL working in the T6.
    I already explained this here: https://forums.ross-tech.com/showthr...l=1#post168268
  10. Likes audiobull, Uwe liked this post
  11. #10
    Apr 2020
    Thank you dnoermann
    I can change the pin number over for pin 36 no problem at all. It just seems to be the engine module vcds is not able to change any of the coding for. It is as if it is not powerful enough or has the right permissions. I have no clue to be honest but the van is not a brand new my19 however it is an EU6.
    I have trawled all over the web with no success to get the engine coding changed. I even tried with the bonnet open just in case. no luck.
    I have changed all sorts of things on the van in all other modules but the engine one is not playing ball.
    Can you tell me what tool you used please? I understand my vcds cable is not the brand new one but I do not want to upgrade it to find the new one is still not capable .
