2019 Audi A6 55TFSI Head Up Display Fault Codes
jambo1
TX, USA
C?ID=39295
I never had these before and these two fault codes keep on showing up even though everything appears to be working normally. Thanks in advance.
Monday,16,March,2020,18:04:31:30686
VCDS Version: 19.6.2.2 (x64)  HEX-NET CB: 0.4513.4
VIN: WAUM2AF20KN041354   License Plate:
Chassis Type: F2-AU58 (4K0)
Scan: 01 02 03 06 09 13 15 16 17 19 22 36 3C 42 44 46 47 52 5F 61
          6D 75 81 82 A5 BB BC C4 CA CC CD CF D6 D7 DB DC DE
VIN: WAUM2AF20KN041354   Mileage: 16497km-10250miles
82-Heads Up Display -- Status: Malfunction 0010
C4-DC/DC Converter -- Status: OK 0000
CA-Sunroof -- Status: OK 0000
CC-Starter-Generator -- Status: OK 0000
CD-Laser Scanner -- Status: Malfunction 0010
DB-Frt Corner Rdar 1 -- Status: OK 0000
DC-Frt Corner Rdar 2 -- Status: OK 0000
Address 01: Engine (J623-DLZA)       Labels: None
   Part No SW: 4K0 907 559 A    HW: 06M 907 309 G
   Component: V6 3.0l TFSI  H11 0004
   Revision: B8H11000
   Coding: 0A6500122366010E34286000000400000000000000000000
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ECM30TFS0114K0907559A 001004
   ROD: EV_ECM30TFS0114K0907559A.rod
   VCID: 33260DEB9A42B6D768-8066
Readiness: 0010 0101
Address 02: Auto Trans (J217)       Labels:| 0CJ-927-156.clb
   Part No SW: 4K0 927 153 M    HW: 0HL 927 156 B
   Component: 0HL 30TFSINAR H01 0003
   Revision: --H01---    Serial number: 0000000111
   ASAM Dataset: EV_TCMDL382021 002031
   ROD: EV_TCMDL382021_AU58.rod
   VCID: 373E39FB8E3A5AF754-8062
   Manual Transmission Fluid Pump:
   Subsystem 1 - Part No SW: 0CK 927 152 AA    HW: 0CK 321 281 L
   Component: V553 MTFP  003 0576
   Serial number: 75145041180268001313
Address 03: ABS Brakes (J104)       Labels: 4M0-907-379-PRE-V1.clb
   Part No SW: 4N0 907 379 AC    HW: 4N0 907 379 P
   Component: ESP9 Premium  H06 0850
   Coding: 58AA159729A60B9711A14C96208152E2F439891AA894D08832044A472F9C91
   ROD: EV_ESP9BOSCHCMP_004_AU65.rod
   VCID: 79BAFFC3F8AE8C87E2-802C
Address 06: Seat Mem. Pass (J521)       Labels:* None
   Part No SW: 4M6 959 760 B    HW: 4M6 959 760 B
   Component: MEM-BFS       009 0042
   Serial number: 00000347898799
   Coding: 001CB2400001BEA14843010101010000810000070700878700000000000000
   ROD: EV_SCMPasseSideCONTIAU736_VW53.rod
   VCID: 3D322BD3AC0670A78E-8068
   Valve Block 1 In Passenger Side Front Seat:
   Subsystem 1 - Part No SW: 4N0 907 182     HW: 4N0 907 182
   Component: N477 VB1 BFSv  H04 0011
   Serial number: SJ800107101840258315
   Coding: BF2F00
   Valve Block 2 In Passenger Side Front Seat:
   Subsystem 2 - Part No SW: 4N0 907 182 D    HW: 4N0 907 182 D
   Component: N478 VB2 BFSv  H04 0010
   Serial number: SJ8001081018114701B1
Address 09: Cent. Elect. (J519)       Labels:* 4N0-907-063-V2.clb
   Part No SW: 4N0 907 063 DE    HW: 4N0 907 063 AE
   Component: BCM1 MLBevo   H10 0652
   Coding: 07000363C0291CDD070E57881CEF9C2A131B37110406009781010A0019331C0108690A024010000000000303004308180802000044010100000000000000000000
   ASAM Dataset: EV_BCM1BOSCHAU651 014010
   ROD: EV_BCM1BOSCHAU651_014.rod
   VCID: 74A4CEF7DFCCF1EFB1-8020
   Subsystem 1 - Part No SW: 4K1 955 119     HW: 4K1 955 119
   Component: J400FRWISCH  063 0740
   Serial number: 00000001808060400547
   Coding: 7DC727
   Serial number: 21947255X81A955555A0
   Coding: 02006E
   Subsystem 3 - Part No SW: 4K1 941 501 C    HW: 4K1 941 501 C
   Component: E1 - LTM  H09 0086
   Serial number: 14S12.10.1800690852
   Subsystem 4 - Part No SW: 4N0 907 410 B    HW: 4M0 907 410 A
   Component: USHL5  H10 0100
   Serial number: 0000009600368Z00PB02
   Coding: 250000
   Subsystem 5 - Part No SW: 8W0 857 511 B    HW: 8W0 857 511 B
   Component: Y7_Innenspieg  H01 0002
   Serial number: GX1CE123071823610551
   Interior Light Module:
   Subsystem 6 - Part No SW: 4K0 947 135 E    HW: 4K0 947 135 E
   Component: Dachmodul  H42 0413
   Serial number: C00095765
   Coding: 0D0104
   Electrically Adjustable Steering Column:
   Subsystem 7 - Part No SW: 80A 907 705     HW: 80A 907 705
   Component: J866-EVLS-SG  H03 0100
   Serial number: WA134401000055556319
   Coding: 0A0700
   Seat Backrest Fan 1 Front Left:
   Subsystem 8 - Part No SW: 4N0 963 575     HW: 4N0 963 575
   Component: V512 LLR1SLvL  H01 0012
   Serial number: Q98AI28401787
   Seat Cushion Fan 1 Front Left:
   Subsystem 9 - Part No SW: 4N0 963 575     HW: 4N0 963 575
   Component: V514 LLR1SKvL  H01 0012
   Serial number: Q98AI28401790
   Seat Backrest Fan 1 Front Right:
   Subsystem 10 - Part No SW: 4N0 963 575     HW: 4N0 963 575
   Component: V516 LLR1SLvR  H01 0012
   Serial number: Q98AI28401789
   Seat Cushion Fan 1 Front Right:
   Subsystem 11 - Part No SW: 4N0 963 575     HW: 4N0 963 575
   Component: V518 LLR1SKvR  H01 0012
   Serial number: Q98AI28401802
   Front windshield washer pump:
   Subsystem 12 - Part No SW: 4N0 907 605 A    HW: 4N0 907 605 A
   Component: J1100/SWP  H09 0005
   Serial number: 00000000001828201070
   Coding: 020000
   Part No SW: 4K0 907 561 E    HW: 760 907 561 A
   Component: LRR4R         H04 0332
   Coding: D2659F5458082C00010360E1000000BE4A1246484481009E04
   ASAM Dataset: EV_ACCBOSCHAU65X 002023
   ROD: EV_ACCBOSCHAU65X_AU58.rod
   VCID: 302C02E76B548DCF15-8064
2342 - Databus
          [FAULT_ACA_QF_STATUS_DISPLAY_ERROR]
                    Reset counter: 169
                    Mileage: 16496 km
                    Date: 2020.03.16
                    Time: 17:58:04
                    Control Module temperature: 41 °C
                    Voltage terminal 15: 12.5 V
                    Velocity_vehicle_reference: 21.09 m/s
                    Longitudinal_acceleration_vehicle_reference: 0.25 m/s²
                    Steering_angle-Data: 2.700 °
                    Yaw_rate-Data: 0.163 rad/s
                    adjustment_calculation: On
                    Misalignment angle: horiz: -0.032 °
                    Misalignment angle: horiz: fast algorithm: 0.147 °
                    Congestion pilot: status: OFF
                    Outside air temperature: 22.00 °C
                    Sensor blindness: radar: no blindness detected
2341 - Databus
          [FAULT_LIDAR_ERROR]
                    Reset counter: 169
                    Mileage: 16495 km
                    Date: 2020.03.16
                    Time: 17:58:03
                    Voltage terminal 15: 12.4 V
                    Velocity_vehicle_reference: 20.88 m/s
                    Longitudinal_acceleration_vehicle_reference: 0.08 m/s²
                    Status_ACC_System: ACC_Override
                    Steering_angle-Data: 2.900 °
   Part No SW: 4N0 959 655 K    HW: 4N0 959 655 K
   Component: AirbagVW31    H02 2710
   Serial number: 003YUM00DKLE
   Coding: BFCCF0C000C00000A000003FF20D410000C5
   ASAM Dataset: EV_AirbaVW31SMEAU65x 001032
   ROD: EV_AirbaVW31SMEAU65x_VW53.rod
   VCID: 44C45E37CFEC016FC1-8010
   Belt Pretensioner left:
   Subsystem 1 - Part No SW: 4N0 980 945 A    HW: 4N0 980 945 A
   Component: BeltPretRevFL  H10 0115
   Serial number: 00AI2018271645900000
   Coding: 04F001
   Belt Pretensioner right:
   Subsystem 2 - Part No SW: 4N0 980 946 A    HW: 4N0 980 946 A
   Component: BeltPretRevFR  H10 0115
   Serial number: 00AI2018267007600000
   Coding: 04F001
   Occupant Detection:
   Subsystem 3 - Part No SW: 4M0 959 339     HW: 4M0 959 339
   Component: BF-Gewichtss.  H11 0022
   Serial number: IBH0000J18000A7NQ80J
   Coding: 303136
   Subsystem 4 - Part No SW: -----------    HW: 480 002 809 18
   Serial number: 35700000000F41BCA33V
   Subsystem 5 - Part No SW: -----------    HW: 480 002 909 18
   Serial number: 3580000000021D78A33K
   Subsystem 6 - Part No SW: -----------    HW: 480 030 810 18
   Serial number: 351001C140CA38B0AF0A
   Subsystem 7 - Part No SW: -----------    HW: 480 030 810 18
   Serial number: 352001C140A279B03EFD
   Subsystem 8 - Part No SW: -----------    HW: 480 030 810 18
   Component: FrontSensor_D  002 0149
   Serial number: 355001C149EE6090AD2M
   Front Sensor Passenger:
   Subsystem 9 - Part No SW: -----------    HW: 480 030 810 18
   Component: FrontSensor_P  002 0149
   Serial number: 356001C149E62E80CD0O
   Part No SW: 4N0 907 129 N    HW: 4N0 907 129 N
   ROD: EV_SMLSKLOAU736_VW53.rod
   VCID: 3C3426D7B71C79AFB9-8068
   Part No SW: 4K0 920 890 C    HW: 4K0 920 890 C
   Component: FBenUSAACC--- H11 0153
   Coding: 83FF21C3EF88D7050283E760D880481018002000
   ROD: EV_DashBoardAU65X_VW53.rod
   VCID: 2E101C9F71609B3F07-807A
   Part No SW: 4K0 907 468 C    HW: 4K0 907 468 C
   Component: Gateway       H05 0118
   Serial number: 18F01007254701
   Coding: 020100050004064054960000005B0132DC3A004710000000097D078E10000000
   ASAM Dataset: EV_Gatew31xAU65x 003160
   ROD: EV_Gatew31xAU65x_AU58.rod
   VCID: 34240EF79F4CB1EF71-8060
   Subsystem 1 - Part No SW: 4K0 951 523 J    HW: 4K0 951 523 J
   Component: E221__MFL  H06 0003
   Serial number: 00000000000000000000
   Subsystem 2 - Part No SW: 4K0 915 181     HW: 4K0 915 181
   Serial number: 74186312001809300646
Address 22: AWD (J492)       Labels:* None
   Part No SW: 4K0 927 755     HW: 0CJ 927 749 A
   Component: C8_DL4_N_SD2H01 0008
   Serial number: 18208B0543
   Coding: 110C0000
   ASAM Dataset: EV_AWDCQUOD31 001052
   ROD: EV_AWDCQUOD31.rod
   VCID: 72A8C8EFA5D8FFDFA3-8026
   Component: MEM-FS        009 0042
   Serial number: 00000347898798
   Coding: 001C9A400001BEA14803010101010000810000070700878700000000004000
   ROD: EV_SCMDriveSideCONTIAU736_VW38.rod
   Valve Block 1 In Driver Side Front Seat:
   Component: N475 VB1 FSv  H04 0011
   Serial number: SJ80010710184025831B
   Coding: BF2F00
   Valve Block 2 In Driver Side Front Seat:
   Component: N476 VB2 FSv  H04 0010
   Serial number: SJ8001081018114701C0
   Part No SW: 4N0 907 566 F    HW: 4N0 907 566 A
   Component: MRR_HR H12 0266
   Coding: 0FDC00
   ASAM Dataset: EV_RearRadarS1DelphAU651 001018
   ROD: EV_RearRadarS1DelphAU651_AU58.rod
   VCID: 393A3FC3B82E4C87A2-806C
   Part No SW: 4M1 959 793 D    HW: 4M1 959 793 D
   Component: TSG FS001 0188
   Serial number: YE007RII16166
   Coding: 001DDB0152001482A009A030
   VCID: 40CC5227DBF41D4FE5-8014
   Part No SW: 4N0 909 144 D    HW: 4N0 909 144 A
   Component: EPS_MLBEVO2BS H21 0504
   Coding: B4002101010000
   ASAM Dataset: EV_EPSVWBSAU426 009015
   ROD: EV_EPSVWBSAU426_009.rod
   VCID: 312A07E3605E84C71A-8064
   Part No SW: 4N0 907 064 BG    HW: 4N0 907 064 G
   Component: BCM2 MLBevo H14 0145
   Coding: 0134000049A000C0657FA0046C01090603034000810422502F0400000F04823F001E0101010F01
   ASAM Dataset: EV_BCM2CONTIAU651 008007
   ROD: EV_BCM2CONTIAU651_008.rod
   VCID: 75A2F3F3D4B6E8E786-8020
   Ignition key:
   Subsystem 1 - Part No SW: 4N0 959 754 K    HW: 4N0 959 754 K
   Component: ID-Geber  H09 0231
   Serial number: 3618000162528015
   Subsystem 2 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
   Serial number: 00000000000045516895
   Rear Light Left 1:
   Subsystem 3 - Part No SW: 4K0 945 217 A    HW: 4K0 945 217 A
   Component: SHL_li1  004 0002
   Serial number: 00000000000000421290
   Subsystem 4 - Part No SW: 3G0 962 243 C    HW: 3G0 962 243 C
   Component: GEB.F.Heckoef  H17 0906
   Serial number: 11229697
   Rear Light Left 2:
   Subsystem 5 - Part No SW: 4K5 945 093 E    HW: 4K5 945 093 E
   Component: SHL_li2  004 0002
   Serial number: 00000000000000423379
   Rear Light Right 1:
   Subsystem 6 - Part No SW: 4K0 945 218 A    HW: 4K0 945 218 A
   Component: SHL_re1  004 0002
   Serial number: 00000000000000410332
   Rear Light Right 2:
   Subsystem 7 - Part No SW: 4K5 945 094 E    HW: 4K5 945 094 E
   Component: SHL_re2  004 0002
   Serial number: 00000000000000423130
   Part No SW: 4N0 035 223 B    HW: 4N0 035 223
   Component: MIB2_amp_P_D5 H01 0150
   Revision: 00000001    Serial number: AUZ8ZAJ6S00J0E%
   Coding: 0185010000AAAA2FAA0000010000
   ASAM Dataset: EV_AMPMst16C1Gen2pALPI 001006
   ROD: EV_AMPMst16C1Gen2pALPI.rod
   VCID: 2306FDAB2AA2265798-8076
   Part No SW: 4M1 959 792 D    HW: 4M1 959 792 D
   Component: TSG BFS001 0188
   Serial number: YE007RJ310564
   Coding: 001DDB015E001482A009A030
   VCID: 3FCE51DBA60A62B79C-806A
Address 5F: Information Electr. (J794)       Labels:* 4G1-035-MIB-HGH2.clb
   Part No SW: 4K0 035 084 A    HW: 4K0 035 084 A
   Component: MU-H-LNS-US   046 2482
   Coding: 0185010200000000C1220002061C00302F0001E401F008008E
   ROD: EV_MUHigGen2pALPI_AU27.rod
   VCID: 2404FEB72FAC216FE1-8070
   Subsystem 1 - Part No: V03 959 804 CD
   Component: MIB2P_NA_Q119  0366
   Subsystem 2 - Part No SW: 4K1 919 605     HW: 4K1 919 605
   Component: DU AU58x Top  H41 0137
   Serial number: BHB00118101803200457
   Component: Gracenote2  3006
   Volume Control 1:
   Subsystem 4 - Part No SW: 4K1 919 616 A    HW: 4K1 919 616 A
   Component: LSR-D5/C8  H33 0108
   Serial number: 00004418000204527007
   Display Unit 5 For Multimedia System:
   Subsystem 5 - Part No SW: 4K1 919 603     HW: 4K1 919 603
   Component: DU AU58x Bot  H42 0137
   Serial number: BHB00118101803200282
   Media socket:
   Subsystem 6 - Part No SW: 4N0 035 726 A    HW: 4N0 035 726
   Component: MediaConnectL  014 0133
   Serial number: 051800631054004
Address 61: Battery Regul. (J1120)       Labels: None
   Part No SW: 4N0 915 105 B    HW: 4N0 915 105 B
   Component: BMS_48V_LiIon H06 0108
   ASAM Dataset: EV_BMS48VLiIonLGAU536 001001
   ROD: EV_BMS48VLiIonLGAU536_AU58.rod
   VCID: 291AEF83488EFC07D2-807C
Address 6D: Trunk Elect. (J605)       Labels:* None
   Part No SW: 8W5 959 107 D    HW: 8W5 959 107
   Component: HDSG-Modul    H13 0170
   Revision: --------    Serial number: A2-C744-8791-0
   Coding: 1130
   ASAM Dataset: EV_DeckLidCONTIAU736 001016
   ROD: EV_DeckLidCONTIAU736_AU38.rod
   VCID: 47DE493BFEDA2A7724-8012
   Part No SW: 4K1 035 283 A    HW: 4K1 035 283 A
   Component: ConBox        H08 0100
   Serial number: 005CCA12F040114
   Coding: 01C020FF4040800000
   ASAM Dataset: EV_ConBoxAU651 001004
   ROD: EV_ConBoxAU651_001_AU58.rod
   VCID: 2600E4BF5990D37FFF-8072
   Part No SW: 4K1 713 041 H    HW: 4K1 713 041 H
   Component: GSM-LL H14 0050
   Serial number: 18.275 40364
   ASAM Dataset: EV_GSMKAMAU581 001005
   ROD: EV_GSMKAMAU581.rod
   VCID: 281CEA875384C50FCD-807C
Address 82: Heads Up Display (J898)       Labels:* None
   Part No SW: 4K1 919 617 A    HW: 4K1 919 617 A
   Component: HeadupDisplay H11 1815
   Coding: 4700FE
   ASAM Dataset: EV_HeadUpDisplAU65X 001010
   ROD: EV_HeadUpDisplAU65X_AU58.rod
   VCID: 322808EF6558BFDF63-8066
16777050 - Function Restricted due to Interrupted Communications
          U1110 00 [008] - -
                    Fault Frequency: 17
                    Reset counter: 209
                    Mileage: 16492 km
                    Date: 2020.03.16
                    Time: 17:31:09
16777048 - Function Restricted due to Interrupted Communications
          U1110 00 [008] - -
                    Reset counter: 209
                    Mileage: 16492 km
                    Date: 2020.03.16
                    Time: 17:31:09
Address A5: Frt Sens. Drv. Assist (J1121)       Labels:* None
   Part No SW: 4KE 907 107 AC    HW: 4N0 907 107 H
   Component: zFAS Var C    H09 0291
   Coding: 020186000000000000FFD60000F0050C139F760000000000000000000096D401019BA8000000000000000080000000000000000000000000F980400000000000000078D0008000B000800080000000000080400000E0
   ASAM Dataset: EV_ZFASAU516 001003
   ROD: EV_ZFASAU516_001_AU58.rod
   VCID: 004C92279B74DD4FA5-8054
2114638 - Databus
          [LS1_SensorHeader_LS1_Fehler]
                    Reset counter: 169
                    Mileage: 16495 km
                    Date: 2020.03.16
                    Time: 17:58:03
4107 - Databus
          [reversibler_Fehler_im_ACC_System]
                    Reset counter: 169
                    Mileage: 16496 km
                    Date: 2020.03.16
                    Time: 17:58:04
   Part No SW: 4M1 959 795 D    HW: 4M1 959 795 D
   Component: TSG HFS003 0188
   Serial number: YE007RJ215714
   Coding: 000DDB0100001482E008A020
   VCID: 42C8582FD5F80F5FF3-8016
   Component: TSG HBFS003 0188
   Serial number: YE007RIP29733
Address C4: DC/DC Converter (A7)       Labels: None
   Part No SW: 4K0 959 663     HW: 4K0 959 663
   Component: DCDC_GEN_2 H20 0307
   Serial number: DC18373000040
   ASAM Dataset: EV_DCDC48VFLEXAU581 004001
   ROD: EV_DCDC48VFLEXAU581_VW38.rod
   Part No SW: 4K0 907 594 AC    HW: 4K0 907 594
   Component: SAD_STG_1     005 0002
   Coding: 268040058101
   ROD: EV_SunRoofCONTIAU736_009_VW27.rod
Address CC: Starter-Generator (----)       Labels:* None
   Part No SW: 4N0 903 028 N    HW: 4N0 903 028 N
   Component: BSG-HP1-65    H17 0523
   Serial number: 18101800010234
   Coding: 20000400000000
   ASAM Dataset: EV_Start48VAU651 001006
   ROD: EV_Start48VAU651_001.rod
   VCID: 362034FF8930A3FF4F-8062
Address CD: Laser Scanner (J1122)       Labels: None
   Part No SW: 4K8 907 660 B    HW: 4N0 907 660
   Component: LASER_SCANNER H36 0201
   ASAM Dataset: EV_LaserScannAU651 013013
   ROD: EV_LaserScannAU651_013.rod
   VCID: 352233F39436A8E746-8060
11575303 - Dynamic Calibration
          C1106 F0 [009] - Limit Exceeded
          [Misalignment_Pitch_Angle_fast]
                    Reset counter: 169
                    Mileage: 16495 km
                    Date: 2020.03.16
                    Time: 17:58:03
                    Control Module temperature-Host: external temperature: 43 °C
                    Control Module temperature-Zynq: internal temperature: 58 °C
                    Control Module temperature-Host: internal temperature: 38 °C
                    Control Module temperature-Zynq: external temperature: 41 °C
                    Voltage terminal 15: 12.575 V
                    Vehicle speed: 72.35 km/h
                    Misalignment angle-Yaw angle: -4.03 °
                    Misalignment angle-Pitch angle: 1.80 °
                    Misalignment angle-Roll angle: 0.90 °
                    Heating and cleaning management-Visibility: 0 %
                    Heating and cleaning management-Degree of contamination: 25 %
                    Heating and cleaning management-Heating status: 02
                    Heating and cleaning management-Cleaning status: 02
                    Performed adjustment-Year: 2000
                    Performed adjustment-Month: 2
                    Performed adjustment-Day: 20
                    Performed adjustment-recorded yaw angle: -4.20 °
                    Performed adjustment-Saved pitch angle: 0.39 °
                    Performed adjustment-Store sway angle: 1.95 °
                    Outside air temperature: 22 °C
                    online_calibration_angles-pitch_angle_online_calibration: -327.67 °
                    online_calibration_angles-roll_angle_online_calibration: -327.67 °
                    online_calibration_angles-yaw_angle_online_calibration: 0.28 °
Address CF: Lane Chge Asst 2 (J770)       Labels:* None
   Component: MRR_HL H12 0266
   Coding: 0FDC00
   ASAM Dataset: EV_RearRadarS2DelphAU651 001018
   ROD: EV_RearRadarS2DelphAU651_AU58.rod
   Part No SW: 4K0 941 592 BC    HW: 4K0 941 592 B
   Component: LMS_MLBevo    H11 0030
   ASAM Dataset: EV_LMSLeftHELLAAU58X 001013
   ROD: EV_LMSLeftHELLAAU58X_AU38.rod
   Dynamic left front turn signal:
   Subsystem 1 - Part No SW: 4K0 941 035 B    HW: 4K0 941 035 B
   Component: M134DynTurnFL  004 0005
   Serial number: 17081800001990X04111
   ASAM Dataset: EV_LMSRightHELLAAU58X 001013
   ROD: EV_LMSRightHELLAAU58X_AU38.rod
   Dynamic right front turn signal:
   Subsystem 1 - Part No SW: 4K0 941 036 B    HW: 4K0 941 036 B
   Component: M135DynTurnFR  004 0005
   Serial number: 21091800002956X04111
Address DB: Frt Corner Rdar 1 (J1089)       Labels:* None
   Part No SW: 4N0 907 669 F    HW: 4N0 907 669 A
   Component: MRR_VR H12 0266
   Coding: 001000
   ASAM Dataset: EV_FrontCorneRadarS1AU651 001018
   ROD: EV_FrontCorneRadarS1AU651_AU58.rod
Address DC: Frt Corner Rdar 2 (J1088)       Labels:* None
   Component: MRR_VL H12 0266
   Coding: 001000
   ASAM Dataset: EV_FrontCorneRadarS2AU651 001018
   ROD: EV_FrontCorneRadarS2AU651_AU58.rod
Address DE: Charger 1 for mobile dev (J1146)       Labels:* None
   Part No SW: 4K0 035 502 A    HW: 4K0 035 502 A
   Component: WLC Front     H10 0057
   Coding: 800000
   ROD: EV_Charg1MobilDevicAU651.rod
   VCID: 1F0EF15B06CA02B7BC-804A
End----------(Elapsed Time: 02:16, VBatt start/end: 12.7V/12.7V)-----------
You definitely have some issues with the front sensors in this car.
If it were mine, I would try clearing the fault codes from the modules that have them, but I'd suspect they'll be back and some sensor calibration will be required.
DrPeter
16.4905° S, 151.7375° W
You may want to do a visual of the J1122-Laser Distance Regulation Control Module, make sure it is clean and has not been impacted/loose or moved slightly.
You can see this in the freeze frame data in your Auto-Scan..
Misalignment angle-Roll angle: 0.90 °​
The J1122 lives in the right side of the front grill.
If it looks okay, I would say bring it in for warranty work/calibration.
Hope this helps,
drpeter
jambo1
TX, USA
C?ID=39295
Thanks gentlemen. The dealership did indeed remove the front bumper for some warranty work unrelated to sensors, and initially I had to take it back three times due to ACC not working. With their overconfidence in everything that they do, they finally acknowledged that ACC calibration was way off. But with both your responses, it does look like this has not been resolved. I will take it back to them. Thanks so much.
jambo1
TX, USA
C?ID=39295
The calibration was off, and that seems to have been fixed, but still get the Head Up Display faults codes - are these related to the previous issue?
Saturday,04,April,2020,20:41:47:30686
VCDS Version: 20.4.0.1 (x64)  HEX-NET CB: 0.4513.4
VIN: WAUM2AF20KN041354   Mileage: 17203km-10689miles
CD-Laser Scanner -- Status: OK 0000
   Revision: B8H11000
   VCID: 33260DEB9A42B61ECF-8066
Readiness: 1110 0101
   VCID: 373E39FB8E3A5A3EF3-8062
   VCID: 79BAFFC3F8AE8C4E45-802C
   ROD: EV_SCMPasseSideCONTIAU736_VWE3.rod
   VCID: 3D322BD3AC06706E29-8068
   Coding: BF2F00
   Shop #: WSC 00025 444 00000
   VCID: 74A4CEF7DFCCF12616-8020
   Coding: 7DC727
   Coding: 02006E
   Coding: 250000
   Coding: 0D0104
   Coding: 0A0700
   Coding: 020000
   VCID: 302C02E76B548D06B2-8064
   VCID: 44C45E37CFEC01A666-8010
   Coding: 04F001
   Coding: 04F001
   Occupant Detection:
   Coding: 303136
   ROD: EV_SMLSKLOAU736_AU58.rod
   VCID: 3C3426D7B71C79661E-8068
   VCID: 2E101C9F71609BF6A0-807A
   ROD: EV_Gatew31xAU65x.rod
   VCID: 34240EF79F4CB126D6-8060
   Coding: 110C0000
   VCID: 72A8C8EFA5D8FF1604-8026
   Coding: BF2F00
   Coding: 0FDC00
   VCID: 393A3FC3B82E4C4E05-806C
   Part No SW: 4M1 959 793 J    HW: 4M1 959 793 D
   Component: TSG FS001 0425
   Coding: 001DCB0152001482A009A030
   ROD: EV_DCU2DriveSideMAXHKLO.rod
   VCID: 46C0443FF9D033B678-8012
   VCID: 312A07E3605E840EBD-8064
   ROD: EV_BCM2CONTIAU651_008_AU58.rod
   VCID: 75A2F3F3D4B6E82E21-8020
   Ignition key:
   Rear Light Left 1:
   Rear Light Left 2:
   Rear Light Right 1:
   Rear Light Right 2:
   VCID: 2306FDAB2AA2269E3F-8076
   Part No SW: 4M1 959 792 J    HW: 4M1 959 792 D
   Component: TSG BFS001 0425
   Coding: 001DCB015E001482A009A030
   ROD: EV_DCU2PasseSideMAXHKLO.rod
   VCID: 45C24333C4D638AE71-8010
   VCID: 2404FEB72FAC21A646-8070
   Volume Control 1:
   Media socket:
   VCID: 291AEF83488EFCCE75-807C
   Coding: 1130
   ROD: EV_DeckLidCONTIAU736_VW27.rod
   VCID: 47DE493BFEDA2ABE83-8012
   VCID: 2600E4BF5990D3B658-8072
   VCID: 281CEA875384C5C66A-807C
   Coding: 4700FE
   ROD: EV_HeadUpDisplAU65X_VW53.rod
   VCID: 322808EF6558BF16C4-8066
          U1110 00 [009] - -
          [BAP_Clock_0x11 communication error bap_error_timeout heartbeat]
                    Fault Frequency: 14
                    Reset counter: 194
                    Mileage: 17203 km
                    Date: 2020.04.04
                    Time: 20:38:09
          U1110 00 [009] - -
          [BAP_BC_MFA_0x0F communication error bap_error_timeout heartbeat]
                    Reset counter: 194
                    Mileage: 17203 km
                    Date: 2020.04.04
                    Time: 20:38:09
   ROD: EV_ZFASAU516_001.rod
   VCID: 004C92279B74DD8602-8054
   Part No SW: 4M1 959 795 J    HW: 4M1 959 795 D
   Component: TSG HFS003 0425
   Coding: 000DCB0100001482E008A020
   VCID: 48DC4A07F3C425C68A-801C
   Component: TSG HBFS003 0425
   VCID: 362034FF8930A336E8-8062
   VCID: 352233F39436A82EE1-8060
   Coding: 0FDC00
   ROD: EV_LMSLeftHELLAAU58X_AU27.rod
   ROD: EV_LMSRightHELLAAU58X_AU27.rod
   Coding: 001000
   Coding: 001000
   Coding: 800000
   VCID: 1F0EF15B06CA027E1B-804A
End----(Elapsed Time: 02:30, VBatt start/end: 11.8V/11.8V. VIgn 11.9V)-----
Have you tried clearing those codes in 82-Heads Up Display?
jambo1
TX, USA
C?ID=39295
Yes, the codes come back on immediately.
Then I am not sure what is wrong there, but if there are no functional problems with the Heads Up Display, I wouldn't worry about it too much either.
jambo1
TX, USA
C?ID=39295
Thanks for all your help Uwe. I looked at my original coding which was 4700E0, and that solved the problem. Not sure how those values were changed, but I was curious as to which bits were causing the DTCs and through a process of elimination, it was "STA available" and "Clock".
DrPeter
VCDS has Experimental Coding for the Coding helper in the [82-Heads Up Display] controller.
Looking at the coding in the Coding Helper, you can see that in byte (2), bits (1,2,3 & 4) are unchecked with the coding [47 00 E0].
And checked in the coding [47 00 FE]
These bits are as follows..
Lap-timer activated - Not available / Available
Clock - Not available / Available
STA - Not available / Available
Telephone - Not available / Availablee​
Check you Coding Logs, perhaps you may have changed this coding at some point?
But, if you are fault free, then I would not worry about it ... ;)
Hope this helps,
drpeter
