Results 1 to 4 of 4
Thread: Incorrect Date?
    Mar 2020
    Incorrect Date?
    Hi, went to attempt a Service Regeneration today and VCDS had an update to V20.4.0 which went smoothly.
    Fired up the car and ran a diagnosis and a Service Regeneration which worked up to a point, but that is a question for another day.
    However, on checking the log it comes up with a date of: 2047.14.9 which knowing the USA way of showing dates is 9th April 2047, why has it come up with this date? No issues before the update.
    Thursday,02,April,2020,17:22:30:08428
    VIN: TMBGE21Z7C2140161   License Plate: YR12 FEP
                    Address 01: Engine       Labels: 03L-906-018-CFF.clb
    Control Module Part Number: 03L 906 018 C    HW: 03L 906 018 BR
      Component and/or Version: R4 2.0l TDI   H24 9978
               Software Coding: 00190012042500080000
                Work Shop Code: WSC 22007 210 00000
                  ASAM Dataset: EV_ECM20TDI01103L906018C 003008 (SK35)
                           ROD: EV_ECM20TDI01103L906018C.rod
                          VCID: 2A0D056D4C7D279B2D6-807E
    4891 - EGR Valve (N18)
              P0403 00 [237] - Malfunction
                        Mileage: 312472 km
                        Date: 2047.14.09
                        Time: 16:04:05
                        Engine speed: 789.50 /min
                        Normed load value: 45.1 %
                        Coolant temperature: 49 C
                        Intake air temperature: 21 C
                        Voltage terminal 30: 13.960 V
                        Air mass: actual value (mg/stroke): 413.7 mg/stroke
                        EGR Vacuum Regulator Solen.val.: activation: 100.00 %
                        EGR Solen.val.: actual value: 83.59 %
                        EGR valve: offset closed: -4.99 %
                        Actuator for high pressure EGR: status-Bits 0-7: 0
                        Actuator for high pressure EGR: status-Bits 0-7: 55
                        Actuator for high pressure EGR: status-Bits 0-7: 7
                        High press EGR actuator: actual unconditioned volt val: 1642.0 mV
    4892 - EGR Valve (N18)
                        Mileage: 312472 km
                        Date: 2047.14.09
                        Time: 16:04:05
                        Engine speed: 778.00 /min
                        Normed load value: 42.7 %
                        Coolant temperature: 50 C
                        Voltage terminal 30: 14.060 V
                        Air mass: actual value (mg/stroke): 296.6 mg/stroke
                        EGR Vacuum Regulator Solen.val.: activation: 15.00 %
                        EGR Solen.val.: actual value: 40.31 %
                        High press EGR actuator: actual unconditioned volt val: 2941.0 mV
    Readiness: 1 2 0 0 1
                    Address 01: Engine  (03L 906 018 C)
    18:24:09
      IDE03270   Exh.gas temp.sen 1: unconditioned voltage 4965.6 mV
      IDE03271   Exh.gas temp.sen 2: unconditioned voltage 0.0 mV
      IDE03273   Exh.gas temp.sen 3: unconditioned voltage 4354.6 mV
      IDE03275   Exh.gas temp.sen 4: unconditioned voltage 3968.6 mV
    2012 Skoda Octavia II Estate 2.0Tdi 140PS Manual
    2015 Skoda Octavia III Estate 2.0Tdi 4 x 4 150PS Manual
    2017 VW Sharan 2.0Tdi SE Bluemotion 163PS Manual
    2019 Seat Alhanbra 2.0Tdi LUX Ecomotive 150PS Manual
    "Ever Since the Update", eh?
    Do you have a data from a previous version, done the same way (apparently outside of an Auto-Scan), with this same fault code, that shows the date correctly?
    In some cases, the date data in freeze-frames is an offset rather than an absolute value, and if VCDS doesn't have the correct base-value, then the date shown will be incorrect. There are a number of other reasons why the date in freeze-frames can be incorrect as well.
    If the date in a freeze-frame is obviously implausible, ignore it and look at the mileage instead.
  3. Likes Dana, Eric, DrPeter, Sebastian, Boki Ar liked this post
    Mar 2020
    Unfortunately no I don't but what I can do tomorrow is run a scan on one of my other cars and see what happens? Up to now usually only ran an Autoscan as I haven't had it long and just starting to get into a bit deeper
    Apr 2019
    Worcester, UK
    I've had this as well but in my case it was 2042.14.28.
    I've also had 2000.00.00 come up on certain modules a few times.
    It seemed to coincide with the battery being a bit low on charge and various lights on the dash being lit. I've read posts by other people on various forums about their dashboard being lit up like a Christmas Tree and all the problems going away once the battery was charged so I've always ignored it.
  6. Likes Uwe liked this post
