Page 4 of 6 FirstFirst ... 23456 LastLast
Results 31 to 40 of 53
Thread: 2017-5N-Tiguan-Sedan-CCTA 2.0 L-Auto Trans-USA J527 STEERING FAULT IN TRANS
  1. #31
    HQ
    I would be shocked if any dealer had that part number sitting around... heck, shocked if a warehouse had one ready to go. My guess is it will be made to order... a virgin J527 box will be flashed with the "CL" firmware and then sent to the dealer.
    Jef
  2. Likes Mills83 liked this post
  3. #32
    They are out there Jef in EU and from the Sharan too.
  4. #33
    Mar 2020
    Talked with the local VW dealer today a few times today as time permitted. They said the part listed on the new vehicle scan report isn't available in the catalog and therefore they cant get it. Supposedly they contacted parts specifying and were told the same thing. Now they are adamant that the 5K0-953-569-AL is the correct part and it's a supersession of the old. I asked them directly if they could provide me with a catalog note stating that it replaces the native part number from the PMI scan and they could not. So I'm really wondering what data they're using to prove this. The AL is the first module they sent where this whole situation started. I have to admit I am ultra confused at this point.
    Feels like we have some serious contradictions happening. Initially the dealer, citing directly from parts catalog note stated: "Determination of OE installed part number must be read with the diagnostic tester**" Apparently now that they are presented with actual data from the PMI scan (which I would consider nearly as good as old part in hand) they are backing away from the real data and tell me with certainty that the old native part read from car as it rolls in new is somehow worth nothing
  5. #34
    Mar 2020
    Module display with AL part, first part replaced. Module was coded with ODIS but trans fault and wrench light on.
  6. #35
    Mar 2020
    Module display with AK, 4th part replaced. Module accepted coding but fault in trans and wrench light like p/n AL.
  7. #36
    Mar 2020
    Module display with BC, second part replaced. This module was very wrong and wouldn't accept coding
  8. #37
    Mar 2020
    PMI scan report from dealer server archives. Module hardware and software versions highlighted.
  9. #38
    Mar 2020
    Just an observation. Hardware and Software versions match between AL and AK and native modules respectively. BC clearly does not and hence wouldn't accept coding. Third module AS I don't have a scan from because it was so wrong it inhibited car from keying on. Jef mentioned "The Software part number has to do with the firmware put into said box". So I can presume the AL and AK have the same firmware as native module given SW/HW numbers match. This raises the question to me does the P/N hold any addition value or is it really just the hardware/software numbers that matter for module fitment. Or is it possible the part number aside from the HW/SW numbers can dictate changes in pin locations?
    Like usual I'm probably overlooking something obvious. Curious what you all think
  10. #39
    You need part number 5K0-953-501CL according to legacy data and the part indeed exists.
  11. Likes Mills83 liked this post
  12. #40
    HQ
    Well you are in a bit of a pickle here. I talked to my parts manager on this.... so the original part number is "odd" to him and he can't get it. And he comes up with the same results as your parts guy, 5K0-953-569-AL.
    I have two thoughts on this... maybe that is the correct part number and so something else gets tweaked so it works (TCM smacked with hammers or something). Or due to how super rare it is, this was a factory "hack job" to get a very limited run of vehicles out the door since 99.9% of Tiguans are not stripped down like this.... and now the parts departments has no info on said hack.
    Jef
  13. Likes Uwe, Dana, Mills83 liked this post
