Page 5 of 6 FirstFirst ... 3456 LastLast
Results 41 to 50 of 53
Thread: 2017-5N-Tiguan-Sedan-CCTA 2.0 L-Auto Trans-USA J527 STEERING FAULT IN TRANS
  1. #41
    United States
    Adding to Jef's comments, something is very odd with that 5K0 953 501 CL "multiple supersession". This won't quote well at all so try to wrap it:
    5K0 953 501 CL steering column multi-switch
    Part number is replaced by several parts (multiple supersession)
    5K0 953 502 L 9B9 steering column multi-switch 1 satin black
    5K0 953 569 AJ electronic modul for steering 1 col. combination switch
    5K0 905 865 ignition starter switch
    5K0 953 223 mounting plate for 1 steering col. comb. switch
    1K0 905 851 B steering lock
    That's one hell of a list of extra parts.
    Moving forward, 5K0 953 569 AJ then supers to 5K0 953 569 AL but it almost looks as if you need to verify all of those other parts are also matching part numbers? If so that doesn't directly explain the initial TCM concern because I don't see how the part number of the ignition switch and mechanical steering lock is gonna help with a Powertrain Data Bus DTC.
  2. Likes Uwe, Jack@European_Parts, Mills83 liked this post
  3. #42
    I will put this out there again.
    Did you all know the CL is still available? .............
  4. Likes Dana liked this post
  5. #43
    HQ
    ....sauce? [sic]
    Jef
  6. #44
    ....sauce? [sic]
    Sounds like the car needs an ultrasound because people are screwing around with FOD!
    https://www.ebay.ie/itm/Lenkstocksch...-/263669712310
  7. Likes Mills83 liked this post
  8. #45
    Mar 2020
    Jef, Dana, and Jack thanks for going above and beyond the call of duty to help out with this little blue devil!
    Spent some time with car today looking at data and more inspection just to be completely certain no faults exist in car. As expected nothing out of place. Car was hit in RF corner and all the repairs look solid. Really no wiring to speak of in RF. Removed TCM in LF wheel housing to inspect and it was clean. Just to be sure scoped data lines and SCCM and TCM. As expected no faults in signals and patterns matched. Data line pins at TCM and SCCM in correct slots and tight. I see no faults with this car like before. I put PMI ODIS scan next to latest VCDS scan with AL part and all modules part numbers, HW/SW VERSION numbers and coding matched. Only difference being J527 P/N.
    Crash picture, however car is repaired/re-assembled
    Shop had picked up another AL to program lol. Knowing its was probably a waste of time I gave it a whirl anyway. Surprise surprise fault 18275 set in trans. Hunted all over car to make sure no aftermarket electronics and none fitted to car. Had shop drive car a ways but fault still wouldn't unlatch to clear. I really have no idea what "missing message" from J527 trans is expecting to see. I should also mention all the column switches function, wipers, signals, lights etc... The thought crossed our mind if we could find a tsb for trans possibly we could flash the garbage out of it. No such luck not appears this trans has no updates.
    Jef "Or due to how super rare it is, this was a factory "hack job" to get a very limited run of vehicles out the door since 99.9% of Tiguans are not stripped down like this.... and now the parts departments has no info on said hack"
    Jef I think this is hilarious but very possibly true. This car was a total cast off anomaly given lack of options, strange part numbers and crazy supers. Otherwise ya could be an issue with TCM but I'm just not willing to go there without a solid baseline J527. Still possible code was pre-existing to repairs and clockspring replacement. Would simply be a massive coincidence. I looked at shops pre scan and it was completely botched. Only 5 modules reported and no codes. Seems they didn't configure scan tool right or something. So the door is shut on the pre-existing debate.
    Dana
    "5K0 953 501 CL steering column multi-switch
    Dana I think you observation with all the steering column part supersession is brilliant. If I'm understanding you right your saying what if the AL J527 needs the updated switches to be compatible to the car."
    Dana thats a brilliant observation!
    Makes me wonder if the AL would need the updated column parts to truly be compatible. Would like to think the parts catalog would lay that out but as we know they can get things twisted up here and there. I'm sort of glad I'm won't be making the call from this point forward considering who knows many pricey modules the dealer might wing at this thing.
    Jack
    Great find with the ebay part! The listing says "Doesn't post to US". Not sure how I could get around that. Also I noticed the pic of part seems to be missing the clockspring ya?
    I'll post a final scan up once the car gets back from dealer. Appreciate the time guys!
  9. Likes Dana, Uwe, Jef, Jack@European_Parts liked this post
  10. #46
    Was an example there are plenty for sale even new when searching online.
  11. #47
    Mar 2020
    Well guys vehicle returned from dealer and is FIXED. I’ll post some data later today when I get a minute. Basically the dealer couldn’t produce the correct part for this hacked Tiguan so they hacked the coding. I’ll explain later...
  12. Likes Dana, Jack@European_Parts liked this post
  13. #48
    HQ
    The follow up Auto-Scan should be interesting and helpful to the person that owns the other stripper Tiggy.
    Jef
  14. Likes Dana, Uwe, Jack@European_Parts liked this post
  15. #49
    Mar 2020
    Well as I mentioned earlier car is fixed.... well depends on the definition of fixed
    I suspect the dealer realized rather quickly from the 5 parts they sent to client shop that legacy part wasn't an option. They ended up falsifying the coding in the J527 Steering module that vehicle is equipped with CRUISE CONTROL!!. Obviously vehicle has no such option on car or on build report. It seems the TCM missing message (18275 - Powertrain Data Bus - P1867 - 000 - Missing Message from Steering Wheel (J527) was the lack of cruise data. Given the fast turn around on this I imagine the tech sent data to VW Support of sorts and they came back with this bullet, but who knows maybe the guys a super genius lol
    Evidently this car can be taught something that doesn't exist and have no ill effects. If this steering module ever looses coding some poor tech somewhere is going to have a real battle on his hands due to false coding. As a tech I find it perplexing that an OE would have to resort to this type of configuration fudging on a 2017! A final question and food for thought wonder why the TCM was looking for cruise data in the first place hmm...
    FINAL AUTO SCAN
    Friday,10,April,2020,11:11:29:41049
    VCDS Version: 20.4.0.1
    VIN: WVGBV7AX7HK045804   License Plate:
    Chassis Type: AX-VW36 (7N0)
    Scan: 01 02 03 08 09 15 16 17 19 22 25 42 44 46 4C 52 53 5F 62 72
    VIN: WVGBV7AX7HK045804   Mileage: 30080km-18690miles
       Part No SW: 06J 906 027 KB    HW: 06J 907 309 A
       Component: MED17.5.2 TFSI 2 07 3231
       Revision: P3H08---    Serial number:
       Coding: 0423010A190F0060
       Shop #: WSC 00040 028 00001
       VCID: 75EBEE841C616F2E21-8020
    Readiness: 0010 0101
       Part No SW: 09G 927 750 PP    HW: 09G 927 750 PP
       Component: AQ 250 6F           3435
       Revision: 00H97000    Serial number:
       Coding: 0000840
       Shop #: WSC 07348 004 104857
       VCID: 0E19A16819F73CF680-805A
    Address 03: ABS Brakes        Labels: 5N0-614-109-C6.clb
       Part No SW: 5N0 614 109 CN    HW: 5N0 614 109 CN
       Component: J104   C6 450M VD4B 0023
       Revision: --H07---    Serial number: 00000009298375
       Coding: 0005161
       VCID: 79F3E2B430790B4E45-802C
       Part No SW: 561 907 426 F    HW: 561 907 426 F
       Component: AC Manuell    H03 0506
       Revision: 00001K02
       Coding: 0010001002
       Shop #: WSC 00040 028 00018
       ASAM Dataset: EV_ACManuaElectGen2BHTC 001002
       ROD: EV_ACManuaElectGen2BHTC_VW36.rod
       VCID: 1E39D12801178C7610-804A
       Part No SW: 5K0 937 084 N    HW: 5K0 937 084 N
       Component: BCM PQ35 B    122 0186
       Revision: BG122001
       Coding: EF1A0A1B80232EC4008800C11000044448010086524D8960648000000040
       VCID: 3D7B36A4A4D1F76E29-8068
       Subsystem 1 - Part No SW: 5N1 955 119 B    HW: 5N1 955 119 B  Labels: 1KX-955-119.CLB
       Component: WWS316 100517  24  0664
       Coding: 009795
       Part No SW: 5N0 959 655 AB    HW: 5N0 959 655 AB
       Component: J234__005 VW10 HI   5418
       Revision: 36023000    Serial number: 003MAP6KD7H.
       Coding: 0012341
       Shop #: WSC 07348 004 1048576
       VCID: 7DFBF6A42451376E69-8028
       Subsystem 1 - Part No: 5N0 959 339 B
       Component: BF-Gewichtsens. 003 0001
       Subsystem 2 - Serial number: 0000000000UHVF
       Subsystem 3 - Serial number: 0024.03.170000300000630116˙†63
       Subsystem 4 - Serial number: 630116˙†6332MTS6341511870˙†63
       Subsystem 5 - Serial number: 511870˙†6342MTS6265511876˙†63
       Subsystem 6 - Serial number: 511876˙†6351HTS6VQC3NEKJS˙†63
       Subsystem 7 - Serial number: 3NEKJS˙†6361HTS66N23NEKR%˙†63
       Subsystem 8 - Serial number: 3NEKR%˙†63727TS69OUITEKJ-˙†63
       Subsystem 9 - Serial number: ITEKJ-˙†63827TS6PK9GTEKJQ˙
       Subsystem 10 - Serial number: GTEKJQ˙
       Part No SW: 5K0 953 569 AL    HW: 5K0 953 569 AL
       Revision: --X01---    Serial number: 20191215200038
       Coding: 5980440000
       Shop #: WSC 32263 003 104857
       VCID: 0201855895AF489614-8056
       Part No SW: 5N0 920 973 M    HW: 5N0 920 973 M
       Component: KOMBI         H02 1104
       Coding: 221F010000
       Shop #: WSC 00040 028 00058
       ROD: EV_Kombi_UDS_VDD_RM09_005_VW31.rod
       VCID: 3E7931A8A1D7EC7630-806A
       Part No SW: 7N0 907 530 BH    HW: 7N0 907 530 AK
       Component: J533  Gateway H57 1682
       Revision:   H57       Serial number: 300517F1000801
       Coding: 356022
       VCID: 77F7E48CC66D1D3E33-8022
       Part No SW: 0AY 907 554 J    HW: 0CQ 525 130
       Component: Haldex4Motion H52 7540
       Serial number: HA1-00029.04.17
       Coding: 0001
       Shop #: WSC 00040 028 00008
       ROD: EV_AllWheelContrHA1VW37X_002.rod
       VCID: 52A17518054F1816E4-8006
       Component: IMMO          H02 1104
       VCID: 6AD1CDF88DDFB0D6BC-803E
       Part No SW: 5N0 959 701 H    HW: 3C0 959 793 H
       Component: TUER-SG FT    002 0601
       Revision: 13100010    Serial number: 0010982374
       Coding: 0004B4
       Shop #: WSC 00040 028 00056
       ASAM Dataset: EV_TSGFPQ35BRFVW46X A04004
       VCID: 3A713DB8BDFFC0560C-806E
       Slave Driver:
       Subsystem 1 - Part No SW: 5N0 959 703 G    HW: 3C0 959 794 D  Labels: 1K0-959-70X-GEN4.CLB
       Component: J388__TSG-HL  010 1505
       Serial number: 00000009890503
       Coding: 000490
       Part No SW: 5N1 909 144 S    HW: 5N1 909 148 K
       Component: J500__APA-BS KL.285 1501
       Revision: 1BH04843    Serial number: 00171430029901
       Coding: 0000258
       VCID: 428145581D2F889654-8016
       Part No SW: 5N0 959 702 H    HW: 3C0 959 792 H
       Component: TUER-SG BT    002 0601
       Revision: 15100010    Serial number: 0011004698
       Coding: 0004B4
       ASAM Dataset: EV_TSGBPQ35BRFVW46X A04004
       VCID: 3B7F38BCB2C5F95E17-806E
       Slave Passenger:
       Subsystem 1 - Part No SW: 5N0 959 704 G    HW: 3C0 959 795 D  Labels: 1K0-959-70X-GEN4.CLB
       Component: J389__TSG-HR  010 1505
       Serial number: 00000009892580
       Coding: 000490
       Part No SW: 3AA 907 801 J    HW: 3AA 907 801 J
       Component: J540 EPB4  VW-63206 0012
       Revision:   H21       Serial number: 00000000017846
       Coding: 0026156
       VCID: 387527B04BF3D246FA-806C
       Part No SW: 561 035 150 B    HW: 561 035 150 B
       Component: MU-E--ER      056 7227
       Serial number: 23061700010694
       Coding: 02130600FF00000041220001001000009F0000140000010000
       ASAM Dataset: EV_MUEnt4CGen2LGE 001032
       ROD: EV_MUEnt4CGen2LGE_VW32.rod
       VCID: 0C1DAB60A7EB0EE66E-8058
    End-------------------------(Elapsed Time: 02:35)--------------------------
    SCAN COMPARISON
  16. #50
    So I guess my question is, was this fault present in OBD2 mode before in transmission and was there an MIL for it?
