Results 1 to 7 of 7
Thread: 7 Speed DSG clutch set up
    Apr 2020
    Hi, I have recently replaced the clutches in a 7 speed dsg (dry
    clutch) golf mk5 2008 model.
    There were previously no shifting problems but just a small amount of
    clutch slip on the odd numbered gears.
    The only fault codes were that the clutch had reached its limit of
    adjustment.
    Hence, the replacement of the clutches.
    Both clutches were set up according to the VW manual and appropriate
    shims used.
    The whole assembly, including clutch assembly, release forks,
    bearings, thrust pad, flywheel, were all replaced.
    I have followed the Ross Tech basic setting procedure and conducted
    the prescribed road test but there is now some juddering in some of
    the gears.
    The car seems to change ok using the Tiptronic changer but in Drive
    it does not operate without juddering.
    I wondered if there is a specific set up procedure for the 7 speed dry
    clutch dsg with transmission code KHM.
    The engine is a 1.9 diesel PD code BLS.
    Any help you could offer would be much appreciated.
    Auto scan pasted below.
    > VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64 VCDS
    > Version: 19.6.2.0 (x64) Data version: 20190930 DS308.0
    > www.Ross-Tech.com
    > VIN: WVWZZZ1KZ8M289699   License Plate:
    > Chassis Type: 1K (1K0)
    > Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
    > VIN: WVWZZZ1KZ8M289699   Mileage: 143440km-89129miles
    > 01-Engine -- Status: Malfunction 0010
    > 02-Auto Trans -- Status: Malfunction 0010
    > 03-ABS Brakes -- Status: OK
    > 0000 04-Steering Angle -- Status: OK 0000
    > 08-Auto HVAC -- Status: OK
    > 0000 09-Cent. Elect. -- Status: Malfunction 0010
    > 15-Airbags -- Status: OK 0000
    > 16-Steering wheel -- Status: Malfunction 0010
    > 17-Instruments -- Status: OK 0000
    > 19-CAN Gateway -- Status: OK 0000
    > 25-Immobilizer -- Status: OK 0000
    > 42-Door Elect, Driver -- Status: Malfunction 0010
    > 44-Steering Assist -- Status: OK 0000
    > 46-Central Conv. -- Status: OK 0000
    > 52-Door Elect, Pass. -- Status: OK 0000
    > 56-Radio -- Status: OK 0000
    > 62-Door, Rear Left -- Status: OK 0000
    > 72-Door, Rear Right -- Status: OK 0000
    > Address 01: Engine        Labels: 03G-906-021-BLS.clb
    >     Part No SW: 03G 906 021 TM    HW: 03G 906 021 AB
    >     Component: R4 1,9L EDC G000AG  2763
    >     Revision: --H08---    Serial number: VWX7Z0H424H01J
    >     Coding: 0000077
    >     Shop #: WSC 00066 000 00000
    >     VCID: 7DF7892724A7E9A7CC-8028
    > 1 Fault Found:
    > 008825 - Leak in Air Intake System
    >                 P2279 - 000 -  - Intermittent
    >               Freeze Frame:
    >                      Fault Status: 00110000
    >                      Fault Priority: 1
    >                      Fault Frequency: 1
    >                      Reset counter: 255
    >                      Mileage: 143418 km
    >                      Time Indication: 0
    >                      Date: 2000.00.00
    >                      Time: 18:29:27
    >               Freeze Frame:
    >                      RPM: 1932 /min
    >                      Speed: 35.0 km/h
    >                      Temperature: 13.5C
    >                      Absolute Pres.: 999.6 mbar
    >                      Absolute Pres.: 1999.2 mbar
    >                      (no units): 0.32
    > Readiness: 0 0 0 0 0
    > Address 02: Auto Trans        Labels: 0AM-927-769.clb
    >     Part No SW: 0AM 300 048 G    HW: 0AM 927 769 D
    >     Component: GSG DSG AG7     431 2472
    >     Revision: 00043014    Serial number: 00001309158034
    >     Coding: 0000020
    >     Shop #: WSC 04940 001 00001
    >     VCID: 34616C03576DE8EF73-8060
    > 6 Faults Found:
    > 006011 - Clutch 1
    >                 P177B - 003 - Tolerance Limit Reached - Intermittent
    >               Freeze Frame:
    >                      Fault Status: 00100011
    >                      Fault Priority: 0
    >                      Fault Frequency: 1
    >                      Reset counter: 10
    >                      Mileage: 143424 km
    >                      Time Indication: 0
    > 006012 - Clutch 2
    >                 P177C - 003 - Tolerance Limit Reached - Intermittent
    >               Freeze Frame:
    >                      Fault Priority: 0
    >                      Fault Frequency: 1
    >                      Reset counter: 10
    >                      Mileage: 143428 km
    >                      Time Indication: 0
    > 002113 - Transmission Fluid Pressure Sensor/Switch 1
    >                 P0841 - 000 - Implausible Signal - Intermittent
    >               Freeze Frame:
    >                      Fault Status: 00100000
    >                      Fault Priority: 0
    >                      Fault Frequency: 9
    >                      Reset counter: 40
    >                      Mileage: 143429 km
    >                      Time Indication: 0
    > 006293 - Functional Restriction due to Pressure Drop
    >                 P1895 - 000 -  - Intermittent
    >               Freeze Frame:
    >                      Fault Priority: 0
    >                      Fault Frequency: 4
    >                      Reset counter: 5
    >                      Mileage: 143435 km
    >                      Time Indication: 0
    > 005981 - Clutch 1 Opens Unintentionally
    >                 P175D - 000 -  - Intermittent
    >               Freeze Frame:
    >                      Fault Priority: 0
    >                      Fault Frequency: 3
    >                      Reset counter: 40
    >                      Mileage: 143435 km
    >                      Time Indication: 0
    >                 P0841 - 001 - Implausible Signal - Intermittent
    >               Freeze Frame:
    >                      Fault Priority: 0
    >                      Fault Frequency: 9
    >                      Reset counter: 40
    >                      Mileage: 143429 km
    >                      Time Indication: 0
    > Address 03: ABS Brakes        Labels:. 1K0-614-517-MK60AT.clb
    >     Part No SW: 1K0 614 517 AC    HW: 1K0 614 517 AC
    >     Component: ESP FRONT MK60-AT   0102
    >     Revision: 00H14001
    >     Coding: 0053889
    >     VCID: 68D9C8735B255C0F0F-803C
    > No fault code found.
    > Address 08: Auto HVAC        Labels: 1K0-820-047.lbl
    >     Part No SW: 1K0 820 047 HM    HW: 1K0 820 047 HM
    >     Component: Climatic PQ35   142 1111
    >     Revision: 00142031    Serial number: 00000000000000
    >     Shop #: WSC 00000 000 00000
    >     VCID: 76E5960B0191BAFF8D-8022
    > Address 09: Cent. Elect.        Labels:. 3C0-937-049-30-M.lbl
    >     Part No SW: 3C0 937 049 AH    HW: 3C0 937 049 AH
    >     Component: Bordnetz-SG     H54 2202
    >     Revision: 00H54000    Serial number: 00000000957656
    >     Coding: E4890F2700041500470000001C00000000087B075C000100000000000000
    >     VCID: 6FEBA36F7ECB8B374E-803A
    >     Subsystem 1 - Part No: 1K2 955 119 E  Labels: 1KX-955-119.CLB
    >     Component: Wischer 270508 021  0501
    >     Coding: 00038805
    >     Shop #: WSC 00066
    >     Subsystem 2 - Part No: 1K0 955 559 AF  Labels: 1K0-955-559-AF.CLB
    >     Component: RLS     060508 046  0204
    >     Coding: 00208933
    >     Shop #: WSC 00066
    > 1 Fault Found:
    > 02389 - Release Signal Transmission; Position P/N
    >              008 - Implausible Signal - Intermittent
    >               Freeze Frame:
    >                      Fault Status: 00101000
    >                      Fault Priority: 2
    >                      Fault Frequency: 10
    >                      Reset counter: 254
    >                      Mileage: 143407 km
    >                      Time Indication: 0
    >                      Date: 2005.09.13
    >                      Time: 31:63:63
    >               Freeze Frame:
    >                          ON
    >                      Voltage: 11.85 V
    >                          ON
    >                          ON
    >                          OFF
    >                          OFF
    >                          ON
    > Address 15: Airbags        Labels: 1K0-909-605.lbl
    >     Part No SW: 1K0 909 605 T    HW: 1K0 909 605 T
    >     Component: 5S AIRBAG VW8   020 2300
    >     Revision: 05020000    Serial number: 0038PD1Z4C8N
    >     Coding: 0013651
    >     VCID: 3D774927642729A78C-8068
    >     Subsystem 1 - Serial number: 6332MSME353458201
    >     Subsystem 2 - Serial number: 6342MSME396173001
    >     Subsystem 3 - Serial number: 6351HSME147927546
    >     Subsystem 4 - Serial number: 6361HSME147A082DD
    > Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
    >     Part No SW: 1K0 953 549 BF    HW: 1K0 953 549 BF
    >     Component: J0527           051 0101
    >     Coding: 0010042
    >     VCID: 77FB9B0F069BC3F796-8022
    > 4 Faults Found:
    > 00576 - Terminal 15
    >              012 - Electrical Fault in Circuit - Intermittent
    > 00883 - Ignition Switch (D) Terminal S
    > 00884 - Ignition Switch (D) Terminal X
    > 01744 - Ignition Switch Terminal P (D)
    > Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
    >     Part No SW: 1K0 920 964 B    HW: 1K0 920 964 B
    >     Component: KOMBIINSTRUMENT 3HL 1212
    >     Revision: V0002000    Serial number: VWX7Z0H424H01J
    >     Coding: 0003403
    >     Shop #: WSC 00638 210 54241
    >     VCID: 2C5174638F5DB02F2B-8078
    > Address 19: CAN Gateway        Labels:. 1K0-907-530-V3.clb
    >     Part No SW: 1K0 907 530 L    HW: 1K0 907 951
    >     Component: J533  Gateway   H07 0052
    >     Revision:   H07 01    Serial number: 140408F1000916
    >     Coding: ED807F060002022003
    >     VCID: 30696013A375D4CF17-8064
    > Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
    >     Component: IMMO            3HL 1212
    > Address 42: Door Elect, Driver        Labels:. 1K0-959-701-MAX3.clb
    >     Part No SW: 1K0 959 701 AE    HW: 1K0 959 793 P
    >     Component: J386  TUER-SG FT    1520
    >     Revision: 71009005    Serial number: 00000283388501
    >     Coding: 0004790
    >     VCID: 71EFA51768FF9DC758-8024
    > 1 Fault Found:
    > 00932 - Electric Window Motor; Drivers Side (V147)
    >              005 - No or Incorrect Basic Setting / Adaptation - Intermittent
    >               Freeze Frame:
    >                      Fault Status: 00100101
    >                      Fault Priority: 6
    >                      Fault Frequency: 1
    >                      Reset counter: 253
    >                      Mileage: 0 km
    >                      Time Indication: 0
    > Address 44: Steering Assist        Labels: 1Kx-909-144-G2V3.clb
    >     Part No: 1K2 909 144 M
    >     Component: EPS_ZFLS Kl.070 H08 1901
    >     Shop #: WSC 02069 000 90108
    >     VCID: 3665560B4111FAFF4D-8062
    > Address 46: Central Conv.        Labels:. 1K0-959-433-MAX.clb
    >     Part No SW: 1K0 959 433 BT    HW: 1K0 959 433 BT
    >     Component:    KSG PQ35 G2  020 0204
    >     Revision: 00020000    Serial number: 00000000000000
    >     Coding: 8190020052830C7F2D0484057008DFC690FCA0
    >     VCID: 0303FFDF42439F57BA-8056
    >     Subsystem 1 - Part No: 1K0 951 605 C
    >     Component: LIN BACKUP HORN H03 1301
    >     Subsystem 2 - Part No: 3C0 951 171 C
    >     Component: Neigungssensor  004 0611
    >     Subsystem 3 - Part No: 3C0 951 171 C
    >     Component: Innenraumueberw.004 0611
    > Address 52: Door Elect, Pass.        Labels:. 1K0-959-702-MAX3.clb
    >     Part No SW: 1K0 959 702 AE    HW: 1K0 959 792 P
    >     Component: J387  TUER-SG BT    1520
    >     Revision: 71009005    Serial number: 00000519288502
    >     Coding: 0005046
    >     VCID: 72EDAA1B6DF9A6DFA1-8026
    > Address 56: Radio        Labels: 1K0-035-1xx-56.lbl
    >     Part No: 1K0 035 186 AD
    >     Component: Radio GR0       034 0033
    >     Revision: 0003404S    Serial number: VWZ2Z2H7220524
    >     Coding: 0040400
    > Address 62: Door, Rear Left        Labels:. 1K0-959-703-GEN3.clb
    >     Part No SW: 1K0 959 703 P    HW: 1K0 959 795 G
    >     Component: J388   TUER-SG HL   1120
    >     Revision: 11006001    Serial number: 00000003085744
    >     Coding: 0000144
    > Address 72: Door, Rear Right        Labels:. 1K0-959-704-GEN3.clb
    >     Part No SW: 1K0 959 704 P    HW: 1K0 959 794 G
    >     Component: J389   TUER-SG HR   1120
    >     Revision: 11006001    Serial number: 00000003095104
    >     Coding: 0000144
    >     VCID: 3E754E2B692132BF95-806A
    > End-------------------------(Elapsed Time: 02:04)--------------------------
  2. Likes Dana, Fredrick Awuor liked this post
  3. #2
    United States
    Thanks for bringing this to forum. This is the best place to receive assistance from users that have access to vehicles with that 0AM transmission installed.
    This is a snip from the Support e-mail Peter sent yesterday:
    The Ross-Tech wiki procedure we have for the "7-Speed Direct Shift
    Gearbox (DSG/0AM)" is what we have.
    http://wiki.ross-tech.com/wiki/index...rbox_(DSG/0AM)
    When you run this Basic Settings and it completes, you should see:
    [254 | 0 | 0 ] ===> This is to confirm a successful Basic Settings.
    If you have any other values in the fields, please let me know what
    they are, so we can try and figure out the reason why it did not
    complete correctly.
    And if the Basic Settings complete correctly, do you still have these
    fault codes as per the Auto-Scan you sent? Do they clear or come back?
    - We recommended to use the Factory Wiring Diagrams/Repair Manuals when
    attempting to diagnose and repair these vehicles.
    For factory repair information please see the Ross-Tech wiki page linked
    below for some good sources of repair information.
    Do let us know if that Basic Setting operation was successful (resulting in 254 | 0 | 0) or not in addition to which of those DTCs reoccur first after a test drive.
  4. Likes Uwe, ai_Ingo, DrPeter, Jack@European_Parts liked this post
  5. #3
    Jul 2017
    Kenya
    Quote Originally Posted by TCCmotorengineers View Post
    adjustment.
    shims used.
    the gears.
    > www.Ross-Tech.com
    >     Coding: 0000077
    > 1 Fault Found:
    >               Freeze Frame:
    >                      Fault Priority: 1
    >                      Fault Frequency: 1
    >                      Reset counter: 255
    >                      Mileage: 143418 km
    >                      Time Indication: 0
    >                      Date: 2000.00.00
    >                      Time: 18:29:27
    >               Freeze Frame:
    >                      RPM: 1932 /min
    >                      Speed: 35.0 km/h
    >                      Temperature: 13.5C
    >                      (no units): 0.32
    >     Coding: 0000020
    > 6 Faults Found:
    > 006011 - Clutch 1
    >               Freeze Frame:
    >                      Fault Priority: 0
    >                      Fault Frequency: 1
    >                      Reset counter: 10
    >                      Mileage: 143424 km
    >                      Time Indication: 0
    > 006012 - Clutch 2
    >               Freeze Frame:
    >                      Fault Priority: 0
    >                      Fault Frequency: 1
    >                      Reset counter: 10
    >                      Mileage: 143428 km
    >                      Time Indication: 0
    >               Freeze Frame:
    >                      Fault Priority: 0
    >                      Fault Frequency: 9
    >                      Reset counter: 40
    >                      Mileage: 143429 km
    >                      Time Indication: 0
    >               Freeze Frame:
    >                      Fault Priority: 0
    >                      Fault Frequency: 4
    >                      Reset counter: 5
    >                      Mileage: 143435 km
    >                      Time Indication: 0
    >               Freeze Frame:
    >                      Fault Priority: 0
    >                      Fault Frequency: 3
    >                      Reset counter: 40
    >                      Mileage: 143435 km
    >                      Time Indication: 0
    >               Freeze Frame:
    >                      Fault Priority: 0
    >                      Fault Frequency: 9
    >                      Reset counter: 40
    >                      Mileage: 143429 km
    >                      Time Indication: 0
    >     Revision: 00H14001
    >     Coding: 0053889
    >     Coding: 00038805
    >     Shop #: WSC 00066
    >     Coding: 00208933
    >     Shop #: WSC 00066
    > 1 Fault Found:
    >               Freeze Frame:
    >                      Fault Priority: 2
    >                      Fault Frequency: 10
    >                      Reset counter: 254
    >                      Mileage: 143407 km
    >                      Time Indication: 0
    >                      Date: 2005.09.13
    >                      Time: 31:63:63
    >               Freeze Frame:
    >                          ON
    >                      Voltage: 11.85 V
    >                          ON
    >                          ON
    >                          OFF
    >                          OFF
    >                          ON
    >     Coding: 0013651
    >     Coding: 0010042
    > 4 Faults Found:
    > 00576 - Terminal 15
    >     Coding: 0003403
    >     Coding: 0004790
    > 1 Fault Found:
    >               Freeze Frame:
    >                      Fault Priority: 6
    >                      Fault Frequency: 1
    >                      Reset counter: 253
    >                      Mileage: 0 km
    >                      Time Indication: 0
    >     Coding: 0005046
    >     Coding: 0040400
    >     Coding: 0000144
    >     Coding: 0000144
    looks like your mech unit got internal leakage,low fluid level etc,worth trying Dana's suggestions above,but am wondering if basic settings will be successful if low pressure issue is present
  6. Likes Dana, Jack@European_Parts liked this post
  7. #4
    Apr 2020
    Update on this issue.
    I have cleared all fault codes, done another basic setting reset and performed another prescribed test drive.
    I still have some juddering on some of the changes and a couple of faults have come up after the road test. The post road test scan is attached.
    Any help would be much appreciated.
    Tuesday,07,April,2020,14:32:47:22151
    VCDS Version: 20.4.0.1 (x64)
    VIN: WVWZZZ1KZ8M289699   Mileage: 143560km-89204miles
       Coding: 0000077
       VCID: 7DF7892724A7E96E69-8028
       VCID: 34616C03576DE826D6-8060
    006011 - Clutch 1
                        Reset counter: 10
                        Mileage: 143553 km
                        Reset counter: 40
                        Mileage: 143554 km
       Revision: 00H14001
       Coding: 0053889
       VCID: 68D9C8735B255CC6AA-803C
       VCID: 76E5960B0191BA3628-8022
       VCID: 6FEBA36F7ECB8BFEEB-803A
       Coding: 00038805
       Shop #: WSC 00066
       Coding: 00208933
       Shop #: WSC 00066
                        Reset counter: 4
                        Mileage: 143545 km
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 13.65 V
       Coding: 0013651
       VCID: 3D7749276427296E29-8068
       Coding: 0010042
       VCID: 77FB9B0F069BC33E33-8022
       Coding: 0003403
       VCID: 2C5174638F5DB0E68E-8078
       VCID: 30696013A375D406B2-8064
       Coding: 0004790
       VCID: 71EFA51768FF9D0EFD-8024
       VCID: 3665560B4111FA36E8-8062
       VCID: 0303FFDF42439F9E1F-8056
       Coding: 0005046
       VCID: 72EDAA1B6DF9A61604-8026
       Coding: 0040400
       Coding: 0000144
       Coding: 0000144
       VCID: 3E754E2B6921327630-806A
    End-------------------------(Elapsed Time: 02:05)--------------------------
  8. Likes Dana liked this post
  9. #5
    Apr 2020
    Just to confirm, when the basic scan is performed I achieve (254) (0) (0)
  10. Likes Dana liked this post
  11. #6
    16.4905 S, 151.7375 W
    006011 - Clutch 1
    The above does not look good!... The P177B fault could indicate there is a concern with the clutch adjuster or clutch ...
    And I agree with Fredrick Awuor...
    The P0841 fault could be due to:
    - Hydraulic pump failure
    - Oil level too low
    - Oil level too high (cavitation/air)
    - Internal pressure leaks, etc..
    Pressure would need to drop below 40 bar for this code to set.
    Hope it works out for you,
    drpeter
  12. #7
    Re-torque of Mech or using a thickening agent in addition to bleeding the fluid to actuator and topping off as needed to pump to ensure accumulator is holding sometimes helps too, right guys?
    An FYI PSSSSST .........Did you know the accumulators can be modified to raise the static hold PSI for increased useful life function and better shift quality?
    Did you know some racer X's hang an external accu-sump bomb now too custom fabricated and monitor the PSI by gauge in car?
    Some even shim the bypass to hold better PSI & the housings were revised thicker and seal kits are indeed available.
