- Joined
- Mar 21, 2020
- Messages
- 2
- Reaction score
- 0
- Location
- Hesperia, CA, USA
- VCDS Serial number
- C?ID=399544
I bought a 2005 Audi A6 4F and it did not start (will not turn over). He replaced the steering column (J518) and told me all that needs to be done is get the keys programmed. However, I took the key to get checked out and the key is working. A week later of diagnosing and tearing the car apart inside. I found wiring from aftermarket amp poorly spliced into wires in the trunk and some cut and exposed, contacting the sirius xm module (I cant find out the name of that module). I thought there was a short somewhere. MMI was working but now will only turn on with logo and then back off. The instrument cluster is working, but i get fault code for it. I did not get any before. There is a problem with the K Line somewhere because I can not contact anything on the K Line. Here are my latest scans.
Mileage: 296990km-184541mi Repair Order:
The next is the optical bus scan (sometimes the control head scans OK and other time it says ERROR)
Sorry if I am not posting something correctly. I am new. Any help is greatly appreciated.
Chassis Type: 4F0
Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 36 37 42 46 47 4F 52
53 55 56 61 62 67 72 76 77
Mileage: 296990km-184541miles
00-Steering Angle Sensor -- Status: Cannot be reached 1100
02-Auto Trans -- Status: Cannot be reached 1100
03-ABS Brakes -- Status: Cannot be reached 1100
07-Control Head -- Status: Cannot be reached 1100
0E-Media Player 1 -- Status: Cannot be reached 1100
0F-Digital Radio -- Status: Cannot be reached 1100
15-Airbags -- Status: Cannot be reached 1100
53-Parking Brake -- Status: Cannot be reached 1100
55-Headlight Range -- Status: Cannot be reached 1100
67-Voice Control -- Status: Cannot be reached 1100
Address 01: Engine
Address 02: Auto Trans
Address 03: ABS Brakes
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H30 0240
Revision: 07020801 Serial number: 10600300106013
Coding: 0000015
Shop #: WSC 22706 444 105050
VCID: 6393A931E75C88632E0-8036
Subsystem 1 - Part No: 4F0 910 131 L
Component: FBSAUDIC6 EZS H43 0070
Component: FBSAUDIC6 KSG H25 0070
Subsystem 3 - Part No: 4F0 910 220 G
Component: FBSAUDIC6 IDG H44 0060
Address 07: Control Head
Address 08: Auto HVAC Labels: 4F0-910-043.clb
Part No SW: 4F0 910 043 HW: 4F1 820 043 J
Component: KLIMABETAETIGUNGH11 0110
Revision: 00000024 Serial number: 00000000096261
Coding: 0524326
Shop #: WSC 02325 785 00200
VCID: 5BE391D1DF2CB0A3660-800E
Part No SW: 4F0 910 279 HW: 4F0 907 279
Component: ILM Fahrer H14 0080
Coding: 0013123
Shop #: WSC 02335 785 00200
VCID: 6695B025146EFD4BC9E-8032
Subsystem 1 - Component: Fehler Lin-Slave 01
Subsystem 2 - Component: Fehler Lin-Slave 02
Reset counter: 151
Mileage: 262136 km
Date: 2004.10.05
Time: 12:11:00
Address 0E: Media Player 1
Address 0F: Digital Radio
Address 15: Airbags
Part No SW: 4F0 910 549 HW: 4F0 953 549 A
Component: Lenksäulenmodul H07 0230
Revision: 00H07000 Serial number: 90026043440120
Coding: 0002041
Shop #: WSC 02323 785 00200
Component: Lenkradmodul H06 0080
Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
Part No SW: 4F0 910 900 A HW: 4F0 920 950 M
Component: KOMBIINSTR. M73 H10 0570
Revision: 00200000 Serial number: 4R817CHD4
Coding: 0064263
Shop #: WSC 22706 444 105606
VCID: 1E65D8C58CBEE58B41E-804A
02759 - Operating Switch for Instrument Cluster
010 - Open or Short to Plus
Fault Status: 01101010
Reset counter: 151
Mileage: 296992 km
Date: 2004.10.05
Time: 12:11:10
Address 19: CAN Gateway Labels:. 4F0-910-468.clb
Part No SW: 4F0 910 468 A HW: 4F0 907 468 B
Component: Gateway H09 0030
Revision: 09 Serial number: 0800804B30000D
Coding: ECFE73CC1B7904
VCID: 270BFD21D3E42443328-8072
Part No SW: 4F0 910 760 HW: 4F0 959 760
Component: Sitzmemory FS H04 0050
Revision: 00000000 Serial number: 00000000896400
Coding: 0082954
VCID: 619FA339FD409A733CC-8034
00003 - Control Module
Fault Status: 01100101
Reset counter: 151
Mileage: 34848 km
Date: 2004.10.05
Time: 12:11:08
01446 - Sensor for Driver Seat; Seatback Adjust (G230)
Reset counter: 151
Mileage: 34848 km
Date: 2004.10.05
Time: 12:11:09
Address 37: Navigation
Address 46: Central Conv.
Address 47: Sound System
Part No SW: 4F0 910 280 HW: 4F0 907 280 A
Component: ILM Beifahrer H09 0050
Revision: Serial number: 00000000053932
Coding: 0001114
VCID: 5EE598C5CC3EA58B01E-800A
Address 52: Door Elect, Pass.
Address 53: Parking Brake
Address 55: Headlight Range
Address 56: Radio
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: ENERGIEMANAGER H12 0470
Revision: 00000000 Serial number: 00000000094342
Shop #: WSC 22302 444 01392
VCID: 2313E931A7DCC8636E0-8076
Subsystem 1 - Part No: 4F0 915 105 C
Component: von VA0 310124000B
Coding: 344630393135313035432056413033313031323430303042
Address 62: Door, Rear Left
Address 67: Voice Control
Address 72: Door, Rear Right
Part No SW: 4F0 910 283 HW: 4F0 919 283
Component: Parkhilfe 4-Kan H09 0030
Revision: --.--.-- Serial number: 11730432800735
Coding: 0001206
Address 77: Telephone
End----(Elapsed Time: 01:12, VBatt start/end: 11.8V/11.8V. VIgn 0.6V)------
Control Module Part Number: 4F0 910 468 A
Component and/or Version: Gateway H09 0030
Optical Bus Diagnostic : Standard
Controller Electrical Optical
19-CAN Gateway OK ERROR
07-Control Head(High/D3) OK ERROR
0E-Media Player 1 OK ERROR
77-Telephone OK ERROR
47-Sound System OK ERROR
67-Voice Control OK ERROR
56-Radio OK ERROR
37-Navigation OK ERROR
0F-Digital Radio ERROR ERROR
