Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 45
Thread: 12715520 - No retrofit/stock car - but code doesn't get cleared
  1. #31
    Well being stealthy implies hiding.
    Me personally I think fair is fair, if you are in there, you should be with full disclosure, especially if you expect a warranty if messing with stuff.
    Why should the dealer or OEM be on hook for your tinkering?
    The whole purpose of login of tester credentials was to track repairs/changes between franchises or IRF & to give insight who did what to help with diagnosis testing too.
    Hiding tampering of any kind or to deceive or shift a cost responsibility to me seems unfair.
    Unlike a factory tester, VCDS permits the WSC to be altered anyway, so the OP could always change the WSC back.
  2. #32
    Mar 2020
    gokarty: hmm....... you may be misunderstanding what "Priority 4" means. DTC s have 6 x Priority levels: Priority 1 is the highest - Priority 6 is the lowest. So, viewed from the opposite end - your DTC is two-up from trivial (no offense intended)!
    Don, the Ross Tech manual mentions that a Priority 4 code affects "drivability" and action must be taken. So the DTC is something that I would prefer to get sorted out.
    When I said "high" priority I didn't mean that it's something drastic but more relative
  3. #33
    Mar 2020
    That means your tester is not setup properly yet because you didn't RTFB.
    I believe the USB is all that will need to be hooked up to the computer to configure VCDS but it would be best to have plugged into battery voltage on DLC port.
    This is what the manual/book says:
    Note: If you are an individual user or independent mechanic, just leave the WorkShop Code set to "00000". This allows VCDS to operate in �stealth� mode, keeping whatever WSC that was already in the controller. If you are using VCDS at a Dealership, enter your Dealer's Workshop Code. The Work Shop Code is not easily changed once set on this screen. Contact us for advice if you need to do so.
    Some control modules do not allow themselves to be Coded with the default 00000 WSC in place. VCDS should prompt you with a message to input non-zero values in such cases. You should NOT make such changes in the Options screen itself.
    Also, I am trying to patiently learn. Thanks for your understanding.
  4. #34
    An original factory tester from day one if reading the RTFB & if it was not configured; stated that a tester would not permit coding or a login and or adaption procedure.
  5. #35
    That's correct.
    And VAG-COM / VCDS has defaulted to "stealth mode" since day one.
    "Stealth Mode" is where it tries to put back whatever WSC, Importer, and Equipment Number that was already in the module. This works most of the time, but not always.
  6. #36
    My point was that an un-configured factory tester cripples functions and is only for "looking" & not "telling", further being less perfect or inferior than VCDS!
  7. #37
    Mar 2020
    The dealer may be able to determine the cause however they may not be very enthusiastic about doing so without any functional problems. Jack's battery Jesus suggestion is worth a shot but don't do that if time is limited. You may need to re-calibrate the steering angle sensor to resolve new (battery related) fault codes.
    I do not have maps from that car but you may find some in our forum. I did find this (DRL winking and dimming discussion) when searching for your BCM part number though:
    https://forums.ross-tech.com/showthr...E-TSI-DRL-wink
    If you cannot locate a complete map set from a similar vehicle it might not hurt to post a wanted thread here: https://forums.ross-tech.com/forumdi...on-Broken-Cars
    Since it's the weekend, I'll give the battery disconnect a shot. In older cars it was just plug the battery in, get a radio code to reset the radio.
    Is it the same in these newer Jettas? Or would I need to take it to the dealership/shop for getting all systems back to normal?
    Dana, when you mention recalibrate steering sensor, is that something that can be done via VCDS?
  8. #38
    You should not need a radio code. That stuff is smart enough to know it's in the car it belongs to.
  9. Likes gokarty liked this post
  10. #39
    Mar 2020
    Just did the battery reset. Have multiple warning lights on dash. What do I do now?
    Auto Scan below:
    Saturday,04,April,2020,22:26:26:39190
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64(VirtualBox)
    VCDS Version 20.4.0.1 (x64)  HEX-V2 CB: 0.4508.4
    VIN: 3VWL17AJ2HM299863   License Plate: BATT_RESET
    Mileage: 61140km-37990mi   Repair Order:
    Chassis Type: AJ-VW36 (7E0)
    Scan: 01 02 03 04 05 08 09 13 15 17 19 25 2B 3C 44 5F 61 75
    VIN: 3VWL17AJ2HM299863   Mileage: 61140km-37990miles
    Address 01: Engine (J623-CPRA)       Labels:. 06K-907-425-V2.clb
       Part No SW: 06K 906 071 BE    HW: 06K 907 425 C
       Component: R4 1.8l TFS   H13 4889
       Revision: --H13---
       Coding: 001A0092244400175000
       Shop #: WSC 00066 790 00015
       ASAM Dataset: EV_ECM18TFS02006K906071BE 001009
       ROD: EV_ECM18TFS02006K906071BE.rod
       VCID: 6FBBD54837149D13BA8-803B
    17178 - Implausible Data Received from ESP Control Module
              U0416 00 [039] - -
                        Mileage: 61143 km
                        Date: 2020.04.04
                        Time: 00:03:01
                        Engine speed: 1491.25 /min
                        Normed load value: 5.9 %
                        Coolant temperature: 77 ∞C
                        Intake air temperature: 64 ∞C
                        Voltage terminal 30: 12.050 V
                        Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration: No
                        Drivetrain coordinator: ACC fault status-ACC active: although TSK passive: No
                        Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set: No
                        Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously: No
                        Drivetrain coordinator: ACC fault status-ACC active: although limiter active: No
                        Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking: No
                        Drivetrain coordinator: ACC fault status-ACC sends undefined signals: No
                        Drivetrain coordinator: ACC fault status-ACC active although main switch off: No
                        Drivetrain coordinator: ACC fault status-ACC is active despite driver braking: No
                        Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling: No
    Readiness: 1010 1101
       Part No SW: 09G 927 158 BC    HW: 09G 927 158
       Component: AISIN AG6 G3  202 3114
       ROD: EV_TCMAQ250031_002_VW26.rod
       VCID: 75B7E7205548A7C3704-8021
       Part No SW: 1K0 907 379 CC    HW: 1K0 907 379 CC
       Component: ESP MK60EC1   H46 0175
       Revision: 00H46001
       Coding: A14B400C492B0003851302EA921C004100F0F01A
       Shop #: WSC 00066 790 00295
       VCID: 75B7E72055C8A7C3704-8021
                        Reset counter: 221
                        Mileage: 61143 km
                        Date: 2020.04.04
                        Time: 00:03:00
                        Count: 16386
                        Count: 12
                        Count: 29184
                        Count: 297
                        Count: 43520
                        Count: 254
                        Count: 10496
                        Reset counter: 221
                        Mileage: 61143 km
                        Date: 2020.04.04
                        Time: 00:03:10
                        Count: 2
                        Count: 12
                        Count: 29184
                        Count: 16390
                        Count: 48896
                        Count: 254
       Part No SW: 5K0 959 434 G    HW: 5K0 959 434
       Component: VWKESSYPQ35GP 092 1305
       Revision: 00092000    Serial number: 0418626241
       Coding: 032C0C
       Shop #: WSC 12345 123 61029
       VCID: 392F2B1039D003A354C-806D
    12715520 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                        Reset counter: 221
                        Mileage: 61142 km
                        Date: 2020.04.04
                        Time: 21:30:29
       Part No SW: 1K8 907 044 CL    HW: 1K8 907 044 CL
       Component: Climatronic   H08 0405
       Revision: 00001K05
       Coding: 0050019002
       VCID: 7BA3F118736CF1B3060-802F
       Part No SW: 7E0 937 190 B    HW: 7E0 937 190
       Component: BCM PQ25 Max3 H81 0744
       Revision: B8081001    Serial number: 88003324160043
       Coding: 7B994B9A08AB0B000939268024C886C54BC6720E60A571F0B0A050032844
       VCID: 2B030158C30CA133D60-807F
       Subsystem 1 - Part No: 5K7 955 559 C  Labels: 5K7-955-559.CLB
       Component: RLS 051016 04  42  0106
       Coding: 0228DD
       Subsystem 2 - Part No SW: 6R0 959 801 DF    HW: 6R0 959 801 DF  Labels: 6R0-959-801.CLB
       Component: J386__TSG_FT  022 1467
       Serial number: 14102743161111040253
       Coding: 820000
       Subsystem 3 - Part No SW: 6R0 959 802 DJ    HW: 6R0 959 802 DJ  Labels: 6R0-959-802.CLB
       Component: J387__TSG_BT  022 1467
       Serial number: 14102742161107144632
       Coding: 820000
       Subsystem 4 - Part No SW: 5K0 959 591 A    HW: 6R0 959 591 D
       Component: J245 PS41.402  H03 0004
       Serial number: 0000FST00183XGP00000
       Coding: 180000
       Subsystem 5 - Part No SW: 6C0 959 442 B    HW: 6C0 959 442 B
       Serial number: 2771623205202400AF1B
       Coding: 2C0000
       Subsystem 6 - Part No SW: 6R0 959 811 T    HW: 6R0 959 811 T
       Component: J388__TSG_HL  022 1467
       Serial number: 14102745161111130501
       Subsystem 7 - Part No SW: 6R0 959 812 T    HW: 6R0 959 812 T
       Component: J389__TSG_HR  022 1467
       Serial number: 14202744161107074551
    01800 - Light Switch (E1)
                        Reset counter: 5
                        Mileage: 61142 km
                        Date: 2020.04.04
                        Time: 21:38:46
       Part No SW: 7N0 907 572 C    HW: 7N0 907 572
       Component: ACC Bosch PQx H03 0211
       Serial number: 24111604380638
       Coding: 01005002FE0779
       ASAM Dataset: EV_ACCBEGVW361 001006
       ROD: EV_ACCBEGVW361.rod
       VCID: 3635202C08CEECDBB9E-8063
    1058 - Databus
              [FAULT_CIS_ECD_NOTAVAILABLE]
                        Reset counter: 221
                        Mileage: 61143 km
                        Date: 2020.04.04
                        Time: 00:03:01
                        Control Module temperature: 44 ∞C
                        Voltage terminal 15: 11.8 V
                        Vehicle speed: 0.00 m/s
                        Acceleration: 0.00 m/s≤
    1059 - Databus
              [FAULT_CIS_ESP_FAIL]
                        Reset counter: 221
                        Mileage: 61143 km
                        Date: 2020.04.04
                        Time: 00:03:01
                        Voltage terminal 15: 12.0 V
    1043 - Automatic Distance Control
              B10E7 F0 [009] - Disconnected
              [FAULT_CIS_TSK_IRREV_FAIL]
                        Reset counter: 221
                        Mileage: 61143 km
                        Date: 2020.04.04
                        Time: 00:03:01
                        Voltage terminal 15: 11.9 V
    Address 15: Airbags (J234)       Labels:* 561-959-655.clb
       Part No SW: 561 959 655     HW: 561 959 655
       Component: AirbagVW11    008 0210
       Serial number: 003RXM09RC9D
       Coding: 8CCCF000000000005000001AC20800000065
       ASAM Dataset: EV_AirbaVW11SMEVW411 001002
       ROD: EV_AirbaVW11SMEVW411.rod
       VCID: 6393A978EBDC29732E0-8037
       Serial number: IBH0000000000063C6NA
       Coding: 303146
       Subsystem 2 - Part No SW: -----------    HW: 480 002 510 16
       Serial number: 3570000000075D84DE1.
       Subsystem 3 - Part No SW: -----------    HW: 480 002 510 16
       Serial number: 3580000000094784DE1X
       Subsystem 4 - Part No SW: -----------    HW: 480 020 810 16
       Component: SideSensor_Dr  000 0148
       Serial number: 3510001B72303C93847-
       Subsystem 5 - Part No SW: -----------    HW: 480 020 810 16
       Component: SideSensor_Pr  000 0148
       Serial number: 3520001B72303C93883.
       Subsystem 6 - Part No SW: -----------    HW: 480 022 710 16
       Component: FrontSensor_D  000 0189
       Serial number: 3550001C1223536345FW
       Subsystem 7 - Part No SW: -----------    HW: 480 022 710 16
       Component: FrontSensor_P  000 0189
       Serial number: 35600019D22AFFC6626R
       Part No SW: 5C6 920 976 D    HW: 5C6 920 976 D
       Component: KOMBI         H02 1104
       Coding: 221A010000
       ROD: EV_Kombi_UDS_VDD_RM09_005_VW31.rod
       VCID: 333319381BBCF9F39E0-8067
       Part No SW: 7E0 909 901     HW: 7E0 937 190
       Component: GW-K-CAN TP20 H81 0744
       Revision: B8081001
       Coding: 102203
       VCID: 6889BE54127A4A2BFB2-803D
       Component: IMMO          H02 1104
       Coding: 000007
       Shop #: WSC 00066 790 00318
       VCID: 6A8DC45C0CF6783BED6-803F
       Revision: 00000000    Serial number: 16000164262007
       Coding: 4900000000000000
       ROD: EV_ELVMarquMPVW36X_VW31.rod
       VCID: 313F1330E1A0CBE3ECC-8065
       Serial number: 0419928869
       Coding: 01011101
       ROD: EV_HREntryHella_VW32.rod
       VCID: 3C21320436E2368B4FA-8069
       Component: HRE_Slave  H12 0071
       Serial number: 0417102021
       Coding: 010111
       Part No: 1K0 909 144 R
       Component: EPS_ZFLS Kl. 306    3501
       Revision: 00H22000
       Shop #: WSC 02069 000 90108
       VCID: 392F2B10355003A354C-806D
                000 - - - MIL ON
                        Fault Status: 11100000
                        Battery Volts: 8.7 V
                            PD
                        Temperature: 37.0∞C
                        Count: 2
                        Steering Angle: 0.00∞
                        Count: 1
                            SteerAng n.Init
       Part No SW: 5C0 035 684 B    HW: 5C0 035 684 B
       Component: MU-S-NS-US    H31 0359
       Serial number: VWZAZ2S0626354
       Coding: 02630102BE00000051220001001808009F0100D400200105C6
       ROD: EV_MUStd4CTSAT_VW32.rod
       VCID: 2411EA64AE526E4B17A-8071
       Subsystem 1 - Part No SW: 3G0 919 866 BB    HW: -----------
       Component: NAR 2017  --- 0525
       Part No SW: 7E0 907 534     HW: 7E0 937 190
       Component: Batt.regelung H81 0744
       Coding: 01240859
       Shop #: WSC 45359 001 1048576
                        Date: 2020.04.04
                        Time: 00:00:00
       Part No SW: 561 035 285 A    HW: 561 035 285 A
       Component: OCULowUSA     020 0160
       Serial number: 000003554140557
       Coding: 02630102C24232107F1606000000
       Shop #: WSC 01383 790 50316
       ASAM Dataset: EV_OCULow 002010
       ROD: EV_OCULow_002.rod
       VCID: 1471BAA47EF21ECBE7A-8041
    End----------(Elapsed Time: 01:43, VBatt start/end: 13.7V/13.8V)-----------
  11. #40
    Mar 2020
    SOLVED! and possible bug in VCDS?
    Uwe, Jack, Dana, Don thank you very much for all your help. Honestly, I do not know if "battery Jesus" did the trick but heres what I did to solve it:
    1) Battery Disconnected for 10 min
    2) Battery Reconnected
    3) Drove 10 miles on highway, all dash warning lights turned off automatically
    4) Got back from road, connected VCDS, kessy fault still present and would not clear
    5) Noticed possible bug: In central Electric, when I used VCDS to implement Dana's factory coding, the long coding had the bit "Auto Unlock" and "Auto Lock" set to 0. So following Dana's suggestion, I set both to 1. But! Channel 3 and Channel 4 in adaptations for central electric, still had the value 0 ! Both those channel control the Auto lock and unlock, they should have matched the long coding! (Right?)
    6) So, I set the Channel 3 and Channel 4 values accordingly to match the long coding
    7) Did another battery disconnect
    8) Drove again on highway until dash warnings went away
    9) Came back and and VCDS clears the KESSY DTC
    [Note: I am using the latest VCDS version]
    Auto-Scan below:
    Saturday,04,April,2020,23:53:03:39190
    VIN: 3VWL17AJ2HM299863   License Plate: REFRENCE_SCAN
    Mileage: 61170km-38009mi   Repair Order:
    VIN: 3VWL17AJ2HM299863   Mileage: 61170km-38009miles
       Revision: --H13---
    Readiness: 1110 1101
       Revision: 00H46001
       Coding: 032C0C
       Revision: 00001K05
       Coding: 0050019002
       Coding: 0228DD
       Coding: 820000
       Coding: 820000
       Coding: 180000
       Coding: 2C0000
       Coding: 303146
       Coding: 221A010000
       Revision: B8081001
       Coding: 102203
       Coding: 000007
       Coding: 01011101
       Coding: 010111
       Revision: 00H22000
       Coding: 01240859
    End----------(Elapsed Time: 01:39, VBatt start/end: 13.9V/13.9V)-----------
  12. Likes Uwe, Dana liked this post
