No communication with Batt controler 61 on A4 2010 or Q7 2011
Ryan Sief23
Indiana, USA
C?ID=280213
My Hex Can connector with latest software revision on March 31 2020 can't communicate with the battery controller on both of my vehicles 2011 Q7 with 57K miles and 2010 A4 with 32K miles. I doubt it's the physical hardware since it's on both. What should I do next? Both have new AMG batteries and I'd like to change the settings. Please help. : O )
PetrolDave
Westbury, UK
C?ID=1423
The battery management controller is NOT always at address #61 on all cars, on some it's a subsystem of the CAN Gateway at address 19.
Please post a full unedited VCDS Auto-Scan of both your A4 & Q7 so we can see how your vehicles are configured and suggest what you need to do.
Ryan Sief23
Indiana, USA
C?ID=280213
A4 LED bulb in trunk is throwing the convenience code
Wednesday,01,April,2020,13:03:34:24685
VCDS Version: 19.6.2.2 (x64)
VIN: WAUHFAFLXAN038121   License Plate:
Chassis Type: FL-AU48 (8T0)
Scan: 01 03 05 08 09 15 16 17 19 2E 42 46 47 52 53 55 56 62 72 77
VIN: WAUHFAFLXAN038121   Mileage: 56610km-35175miles
Address 01: Engine (DL0MA-CAEB)       Labels:| 06H-907-115-CAB.clb
   Part No SW: 8K2 907 115 AA    HW: 8K2 907 115 D
   Component: 2.0l R4/4V TF H16 0003
   Revision: E1H16---
   Coding: 0104010A180F0160
   Shop #: WSC 02145 785 00200
   ASAM Dataset: EV_ECM20TFS8K2907115AA A01004
   ROD: EV_ECM20TFS0118K2907115AL.rod
   VCID: 6ED3B1FCB1F7683F47-803A
2643 - ROD - Unknown Error Code
          - 00 [032]
7136 - No Communication with ABS Brake Control Module
          U0121 00 [032] - -
4713 - No Communication with ABS Brake Control Module
          U0121 00 [032] - -
4629 - ECM Power Relay Load Circuit
          P068A 00 [032] - Opens Too Early
   Part No SW: 8K0 907 379 CA    HW: 8K0 907 379 CA
   Component: ESP8 quattro  H04 0030
   Coding: 070D18
   Shop #: WSC 09218 444 83803
   VCID: 7AFB8DACF5BF349FEB-802E
   Part No SW: 8K0 907 064 DG    HW: 8K0 907 064 DG
   Component: BCM2 1.1      H02 0326
   Coding: 0B0100
   Shop #: WSC 02399 823 56573
   VCID: 78FF97A4CBB3268F9D-802C
   Subsystem 1 - Part No SW: 8T0 959 754 A    HW: 8T0 959 754 A
   Serial number: 0509000068109005
   Serial number: 0209000060255016
   Part No SW: 8T1 820 043 AQ    HW: 8T1 820 043 AQ
   Component: KLIMA 3 ZONEN H08 0171
   Revision: C1000000    Serial number: 01211120091040
   Coding: 64002000
   Shop #: WSC 02391 823 56573
   VCID: 000FFF4493636E4FA5-8054
   Part No SW: 8K0 907 063 P    HW: 8K0 907 063 P
   Component: BCM1 1.0      H25 0380
   Revision: 10025001    Serial number: 00000000516735
   Coding: 26001091063CAF010000080300003D0D0F1C120800010161000000
   VCID: 3C774BB4BF0BCAAFB9-8068
   Component: WWS 191109  H06 0070
   Serial number: SWF09110195491
   Coding: 00FD11
   Component: RLS  H04 0003
   Serial number: 10681339
   Coding: 025028
   Subsystem 3 - Part No SW: 8K0 941 531 AL    HW: 8K0 941 531 AL
   Component: E1 - LDS  H08 0090
   Serial number: 00000000001311090067
   Subsystem 4 - Part No SW: 8K0 907 410 B    HW: 8K0 907 410 B
   Component: HOMELINK  H01 0010
   Part No SW: 8K0 959 655 H    HW: 8K0 959 655 H
   Component: AirbagVW-AU10 H39 0560
   Serial number: 003EGD058YCJ
   Coding: 303836354230303030304A55304C384B3053
   Shop #: WSC 02135 785 00200
   VCID: 428B354CD5EFBC5FF3-8016
   Subsystem 1 - Part No SW: 8K0 959 339 B    HW: 8K0 959 339 B
   Component: BF-Gewichtss.  H01 0030
   Serial number: 5810000R09000058SQ
   Serial number: 6334MSME4D657071G
   Serial number: 6344MSME4C6136208
   Serial number: 6352QSME5B44480ER
   Serial number: 6362QSME564306248
   Serial number: 63732SME48421F3E7
   Serial number: 63832SME4B42371E3
   Revision: --------    Serial number: 90304IKO000G2
   Coding: 000016
   VCID: 3D7146B0A411C3A78E-8068
   Part No SW: 8K0 920 950 E    HW: 8K0 920 950 E
   Component: KOMBIINSTR.   H20 0255
   Revision: 00100000    Serial number: CIM10VGC9
   Coding: 8B1409000300D705020000
   VCID: 31696A80684937C71A-8064
   Part No SW: 8T0 907 468 R    HW: 8T0 907 468 H
   Component: GW-BEM 5CAN   H06 0105
   Revision: GB600050    Serial number: 5000G09B1184C6
   Coding: 00C303
   VCID: 50AF0F0403835ECF75-8004
   Subsystem 1 - Part No SW: 8K0 915 181 E    HW: 8K0 915 181 E
   Component: J367-BDM  H06 0170
   Serial number: 1909B425091109
Address 2E: Media Player 3 (R199)       Labels:. 8T0-035-785.clb
   Part No SW: 8T0 035 785 A    HW: 8T0 035 785
   Component: SG ext.Player H08 0280
   Revision: 00000000
   Coding: 020302
   VCID: 397952A0B039FF87A2-806C
   Part No SW: 8K0 959 793 H    HW: 8K0 959 793 D
   Component: TSG FA        H11 0306
   Revision:             Serial number: 0000009627771
   Coding: 011C03204000410001
   VCID: 45812E50CCC18B67D6-8010
   Revision: 00002001    Serial number: 0124213271
   Coding: 0106023A007A444400B0013200000000
   Subsystem 1 - Part No SW: 8K0 959 719     HW: 8K0 959 719
   Component: GTO BF  H06 0050
   Serial number: 00000000000000196115
   Subsystem 3 - Part No SW: 8K0 959 591 A    HW: 8K0 959 591
   Component: J245 PS037  H06 0041
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Fault Frequency: 28
                    Reset counter: 253
                    Mileage: 54600 km
                    Date: 2019.11.23
                    Time: 17:15:41
Address 47: Sound System (J525)       Labels:. 8T0-035-223-BOC.clb
   Part No SW: 8T0 035 223 AR    HW: 8T0 035 223 AJ
   Component: DSP Prem      H19 0320
   Revision: 00019001    Serial number: 34835000269402
   Coding: 0203010302
   Shop #: WSC 03332 444 84063
   VCID: 7EF381BCE99718BFD7-802A
   Part No SW: 8K0 959 792 H    HW: 8K0 959 792 D
   Component: TSG BF        H11 0306
   Revision:             Serial number: 0000009630180
   VCID: 44873354C7FBB26FC1-8010
   Revision: 00000003    Serial number: 10000000375242
   VCID: 34676394975B02EF71-8060
   Part No: 8K5 907 357
   Coding: 0000004
   VCID: 77FD949806AD29F794-8022
   Part No SW: 8T1 035 186 R    HW: 8T1 035 186 R
   Component: Con3 Sirius   H04 0351
   Revision: 00000006    Serial number: AUZ5Z6I1311793
   Coding: 04030002010185004359070800
   VCID: 4683295CF1C7807FDF-8012
   Subsystem 1 - Part No SW: 8T0 919 603 E    HW: 8T0 919 603 E
   Component: Display
                    Fault Frequency: 61
                    Reset counter: 191
                    Mileage: 51470 km
                    Date: 2019.06.11
                    Time: 23:08:53
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 10000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Reset counter: 148
                    Mileage: 2715 km
                    Date: 2011.02.09
                    Time: 12:22:05
   Part No SW: 8K0 959 795 C    HW: 8K0 959 795 C
   Component: TSG HL        H10 0306
   Revision:             Serial number: 0000102353343
   Coding: 010C03204000210001
   VCID: 428B354CDDEFBC5FF3-8016
   Component: TSG HR        H10 0306
   Revision:             Serial number: 0000102353342
   Part No SW: 8T0 862 336 D    HW: 8T0 862 336 D
   Component: FSE_256x BT     H39 0600
   Revision: 00000000    Serial number: 00000005062602
   Coding: 0010370
   Shop #: WSC 02335 785 00200
   VCID: 3C774BB47F0BCAAFB9-8068
End-------------------------(Elapsed Time: 03:50)--------------------------
Ryan Sief23
Indiana, USA
C?ID=280213
2011 Q7. Replaced battery, now has FC1826 after battery replacement that I can't clear. Supply voltage terminal 30. Maybe it's an artifact of the replacement work. After I took it for a short drive the TPMS fault when inactive.
Wednesday,01,April,2020,13:30:30:24685
VIN: WA1WMAFE8BD004147   License Plate:
Gateway Installation List:  4F0 907 468 Q
4C-Tire Pressure II -- Status: Malfunction 0010
You only posted the Gateway Installation List from this vehicle, not the whole scan.
The A4 that you posted the whole scan from has the Battery Monitor as a sub-system of the Gateway:
   Coding: 00C303
