16347 - Park Assist EEPROM Error - replaced module but now more probs
Dads VW
C?ID=389647
Dads car has been stood for a while resulting in low battery voltage.
Its caused 16347 - Park Assist EEPROM error.
Part number of the original module was 3C8 919 475.
I replaced it with 3C8 919 475A (original not available anywhere i can find)
I assume the A suffix pertains to an updated version?
Anyway, after fitting and coding, the new module codes fine and is recognised by the vehicle, however it brings up faults for ALL the sensors (Sensor for Parking Aid No Signal/Communication)
The Park Assist was fine prior to the low voltage. Would all 8 sensors really fail? Really??
Or is the new module incompatible?
Old Scan with damaged Park Assist Module
Thursday,19,March,2020,12:05:12:42323
VIN: WVWZZZ3CZ9E034753   License Plate:
Chassis Type: 3C (3C0)
Scan: 01 03 08 09 10 15 16 17 19 25 42 44 46 52 53 56 62 6D 72
VIN: WVWZZZ3CZ9E034753   Mileage: 103730km-64454miles
Address 01: Engine (CBA)       Labels: 03L-906-022-CBA.clb
   Part No SW: 03L 906 022 BL    HW: 03L 907 309
   Component: R4 2,0L EDC G000SG  2650
   Revision: 13H01---    Serial number: VWZCZ000000000
   Coding: 0000072
   Shop #: WSC 00114 210 90236
   VCID: 70B9D71396A946B7395-8024
001299 - Incorrect Immobilizer Key
               P0513 - 000 -  - Intermittent
                    Mileage: 103717 km
                    Date: 2019.10.28
                    Time: 14:46:12
                    RPM: 1035 /min
                    Voltage: 10.94 V
                    Absolute Pres.: 1009.8 mbar
                    Absolute Pres.: 969.0 mbar
                    Temperature: 10.8∞C
                    Temperature: 9.9∞C
Address 03: ABS Brakes        Labels:. 3C0-614-109-C4.clb
   Part No SW: 3C0 614 109 P    HW: 3C0 614 109 P
   Component: J104    C4 440 V2   0011
   Revision: --025---    Serial number: 00000785852562
   Coding: 0001298
   Shop #: WSC 05311 000 00000
   VCID: 2B03007F7F0F656F4C7-807E
   Part No SW: 1K0 820 047 HN    HW: 1K0 820 047 HN
   Component: Climatic PQ35   142 1111
   Revision: 00142031    Serial number: 00000000000000
   VCID: 77ABEC0FF3C7118FF8F-8022
   Part No SW: 3C0 937 049 AH    HW: 3C0 937 049 AH
   Revision: 00H54000    Serial number: 01000008397897
   Coding: E0888F0700041A00470A00000F000000000859435C000120000000000000
   Shop #: WSC 05124 000 00000
   VCID: 6FBBD46F8B97594F20F-803A
   Subsystem 1 - Part No: 3C2 955 119 B  Labels: 1KX-955-119.CLB
   Component: Wischer 100608 022  0601
   Coding: 00046997
   Shop #: WSC 05124
   Component: RLS     140708 054  0402
   Coding: 00209133
   Shop #: WSC 05124
   Part No SW: 3C8 919 475     HW: 3C8 919 475
   Component: PARKHILFE 8K  H07 0007
   Revision: --------    Serial number: 97550819101260
   Coding: 100003
   VCID: 71BFD21791A34FBF36B-8024
16347 - Control Module - EEPROM Error
            014 - Defective
                    Fault Status: 01101110
                    Reset counter: 0
                    Temperature: 0.0∞C
   Part No SW: 5N0 959 655 A    HW: 5N0 959 655 A
   Component: J234__006 VW10 HI   1815
   Revision: 19013000    Serial number: 0039DPDADU5Z
   Coding: 0012342
   VCID: 3B23303F8F6FF5EFDC7-806E
   Subsystem 1 - Serial number: 6333FTS628881658
   Subsystem 2 - Serial number: 6343FTS628951558
   Subsystem 3 - Serial number: 6353ETS67F14UVNH
   Subsystem 4 - Serial number: 6363ETS6C044UVNP
   Part No SW: 3C0 953 549 AE    HW: 3C0 953 549 AE
   Component: J0527               0020
   Revision: 00026000    Serial number: 3C9953507AT
   Coding: 0000112
   Part No SW: 3C0 920 971 E    HW: 3C0 920 971 E
   Component: KOMBIINSTRUMENT VD1 2416
   Revision: V0002000    Serial number: 00000000000000
   Coding: 0007405
   Shop #: WSC 25062 067 57207
   VCID: 270BFC4F63E7410FA8F-8072
Address 19: CAN Gateway        Labels:. 3C0-907-530-V2.clb
   Part No SW: 3C0 907 530 H    HW: 3C0 907 951
   Component: J533__Gateway   H13 0142
   Revision:   H13       Serial number: 2600P08620125B
   Coding: F9A07F060202022003
   VCID: 2615F14B64ED5807939-8072
   Part No SW: 3C0 959 433 R    HW: 3C0 959 433 R
   Component:    IMMO         042 0383
   Revision: 00042000    Serial number: VWZCZ000000000
   VCID: 392F2A378553C7FFCEB-806C
   Component:    ELV          027 0380
   3C0905861G     ELV          027 0380
   Part No SW: 1K0 959 701 AE    HW: 1K0 959 793 P
   Component: J386  TUER-SG FT    1518
   Revision: 71009005    Serial number: 00000802588616
   Coding: 0004791
   VCID: 71BFD2179DA34FBF36B-8024
   Part No: 1K0 909 144 C
   Component: EPS_ZFLS Kl. 195    2301
   Revision: 00H15000
   VCID: 2A0D057B70F57C67B71-807E
   Component:    KSG PQ46 ELV 042 0472
   Coding: 01900A00D1030E763004941570085FCE107C01
01134 - Alarm Horn (H12)
                    Reset counter: 244
                    Mileage: 103733 km
                    Date: 2020.02.05
                    Time: 17:05:42
   Part No SW: 1K0 959 702 AE    HW: 1K0 959 792 P
   Component: J387  TUER-SG BT    1518
   Revision: 71009005    Serial number: 00000560188622
   Coding: 0004790
   VCID: 72BDDD1B98A574A7CF1-8026
   Part No SW: 3C8 907 801 A    HW: 3C8 907 801 A
   Component: J540 EPB3  VW-10498 0003
   Revision:   009       Serial number: 00000000070573
   Coding: 0000057
   VCID: 2809FF736EF94E77A15-807C
02845 - Function Display in Instrument Cluster (!)
            007 - Short to Ground - MIL ON
                    Fault Status: 11100111
                    Reset counter: 244
                    Mileage: 103733 km
                    Date: 2020.02.05
                    Time: 17:03:35
                    Voltage: 12.20 V
                    Count: 78
                    Hex Value: 0x1261
                    Hex Value: 0x0001
                    Hex Value: 0x1010
   Part No SW: 1K0 035 186 AA    HW: 1K0 035 186 AA
   Component: Radio RCD310  012 0029
   Revision: 00000000    Serial number: VWZ1Z2H5344347
   Coding: 0500040004
   Shop #: WSC 05314 000 00000
   VCID: 6597B647556B931F5A3-8030
                    Reset counter: 244
                    Mileage: 103733 km
                    Date: 2020.02.05
                    Time: 17:03:31
   Part No SW: 1K0 959 703 AB    HW: 1K0 959 795 L
   Component: J388   TUER-SG HL   0307
   Revision: 41004101    Serial number: 00000000491845
   Coding: 0000144
Address 6D: Trunk Elect.        Labels: 3C9-827-383.clb
   Part No SW: 3C9 827 383 B    HW: 3C9 827 383 E
   Component: J605  HECKDECKEL    0600
   Revision: 00H27001
   Shop #: WSC 23250 384 715754
   VCID: 30391713562906B7795-8064
   Subsystem 1 - Part No: 3C9 827 384 B
   Component: J756  HECKDECKEL    0600
   Subsystem 2 - Serial number: 0800H27001001B0167ˇ
   Part No SW: 1K0 959 704 AB    HW: 1K0 959 794 L
   Component: J389   TUER-SG HR   0307
   Revision: 41004101    Serial number: 00000000509858
   Coding: 0000144
End----------(Elapsed Time: 01:26, VBatt start/end: 14.5V/14.5V)-----------
Scan with replacement module
Sunday,29,March,2020,15:29:03:42323
   Coding: 0000072
   Coding: 0001298
   Coding: 00046997
   Shop #: WSC 05124
   Coding: 00209133
   Shop #: WSC 05124
   Part No SW: 3C8 919 475 A    HW: 3C8 919 475
   Component: PARKHILFE 8K  H07 0009
   Revision: --------    Serial number: 08790931000415
   Coding: 100001
   Shop #: WSC 05314 123 12345
   VCID: 323D1D1B542534A70F1-8066
8 Faults Found:
                    Reset counter: 244
                    Mileage: 103733 km
                    Date: 2020.02.15
                    Time: 19:09:35
                    Temperature: 5.0∞C
01548 - Sensor for Parking Aid; Rear Right (G206)
                    Reset counter: 244
                    Mileage: 103733 km
                    Date: 2020.02.15
                    Time: 19:09:35
                    Temperature: 5.0∞C
                    Reset counter: 244
                    Mileage: 103733 km
                    Date: 2020.02.15
                    Time: 19:09:35
                    Temperature: 5.0∞C
01547 - Sensor for Parking Aid; Rear Mid-Right (G205)
                    Reset counter: 244
                    Mileage: 103733 km
                    Date: 2020.02.15
                    Time: 19:09:35
                    Temperature: 5.0∞C
01629 - Sensor for Parking-Aid; Front Left (G255)
                    Reset counter: 244
                    Mileage: 103733 km
                    Date: 2020.02.15
                    Time: 19:09:35
                    Temperature: 5.0∞C
01626 - Sensor for Parking-Aid; Front Right (G252)
                    Reset counter: 244
                    Mileage: 103733 km
                    Date: 2020.02.15
                    Time: 19:09:35
                    Temperature: 5.0∞C
01628 - Sensor for Parking-Aid; Front Mid-Left (G254)
                    Reset counter: 244
                    Mileage: 103733 km
                    Date: 2020.02.15
                    Time: 19:09:35
                    Temperature: 5.0∞C
01627 - Sensor for Parking-Aid; Front Mid-Right (G253)
                    Reset counter: 244
                    Mileage: 103733 km
                    Date: 2020.02.15
                    Time: 19:09:35
                    Temperature: 5.0∞C
   Coding: 0012342
   Coding: 0000112
   Coding: 0007405
   Coding: 0004791
   Revision: 00H15000
                    Reset counter: 244
                    Mileage: 103733 km
                    Date: 2020.02.15
                    Time: 19:02:03
   Coding: 0004790
   Coding: 0000057
                    Reset counter: 244
                    Mileage: 103733 km
                    Date: 2020.02.15
                    Time: 19:01:05
                    Voltage: 14.00 V
                    Count: 78
                    Hex Value: 0x1261
                    Hex Value: 0x0001
                    Hex Value: 0x1010
   Coding: 0F00040004
   Coding: 0000144
   Revision: 00H27001
   Coding: 0000144
End----------(Elapsed Time: 01:25, VBatt start/end: 14.5V/14.4V)-----------
