Results 1 to 5 of 5
Thread: EPB Replaced but ABS will not save Steering/Lateral or Longitudinal adaptions.
    Mar 2020
    Hi folks
    First post to try and save my elderly fathers passat. 2009 model with only 64k miles. Be a shame to scrap it. Please help.
    Background - car was fine until battery went flat after long time with no use. (mum passed away) On starting up after recharging battery - 1 fault found:
    02845 - Function Display in Instrument Cluster (!)
    So i purchased a replacement EPB module of the same part number and revision code.
    Followed the instructions on this site to recode and put back in order. Managed to recode ABS with saved coding details.
    HOWEVER - i cannot get the ABS module to save the Steering Angle Sensor adaptions. i input them all and they show correctly in Measuring Blocks.
    Then move onto Lateral Acceleration Sensor, shows Error in Block 063 under Basic Settings.
    Same with the rest of the procedures on these instructions; http://wiki.ross-tech.com/wiki/index...tronics#Coding
    I cannot seem to be able to do any of the basic settings apart from the Steering Sensor Adaptions. However they do not save. As soon as i quite VCDS or stop engine/remove ignition key, the settings are lost.
    Most recent scan shown below. (note most of the faults showing are due to center console and heating/climate panel removed.
    First scan shown at bottom:
    Please help
    Sunday,29,March,2020,16:22:06:42323
    VIN: WVWZZZ3CZ9E034753   License Plate:
    Chassis Type: 3C (3C0)
    Scan: 01 03 08 09 10 15 16 17 19 25 42 44 46 52 53 56 62 6D 72
    VIN: WVWZZZ3CZ9E034753   Mileage: 103730km-64454miles
    Address 01: Engine (CBA)       Labels: 03L-906-022-CBA.clb
       Part No SW: 03L 906 022 BL    HW: 03L 907 309
       Component: R4 2,0L EDC G000SG  2650
       Revision: 13H01---    Serial number: VWZCZ000000000
       Coding: 0000072
       Shop #: WSC 00114 210 90236
       VCID: 70B9D71396A946B7395-8024
    Address 03: ABS Brakes        Labels:. 3C0-614-109-C4.clb
       Part No SW: 3C0 614 109 P    HW: 3C0 614 109 P
       Component: J104    C4 440 V2   0011
       Revision: --025---    Serial number: 00000785852562
       Coding: 0001298
       Shop #: WSC 05311 000 00000
       VCID: 2B03007F7F0F656F4C7-807E
       Part No SW: 1K0 820 047 HN    HW: 1K0 820 047 HN
       Component: Climatic PQ35   142 1111
       Revision: 00142031    Serial number: 00000000000000
       VCID: 77ABEC0FF3C7118FF8F-8022
       Part No SW: 3C0 937 049 AH    HW: 3C0 937 049 AH
       Revision: 00H54000    Serial number: 01000008397897
       Coding: E0888F0700041A00470A00000F000000000859435C000120000000000000
       Shop #: WSC 05124 000 00000
       VCID: 6FBBD46F8B97594F20F-803A
       Subsystem 1 - Part No: 3C2 955 119 B  Labels: 1KX-955-119.CLB
       Component: Wischer 100608 022  0601
       Coding: 00046997
       Shop #: WSC 05124
       Component: RLS     140708 054  0402
       Coding: 00209133
       Shop #: WSC 05124
       Part No SW: 3C8 919 475 A    HW: 3C8 919 475
       Component: PARKHILFE 8K  H07 0009
       Revision: --------    Serial number: 08790931000415
       Coding: 100001
       Shop #: WSC 05314 123 12345
       VCID: 323D1D1B542534A70F1-8066
       Part No SW: 5N0 959 655 A    HW: 5N0 959 655 A
       Component: J234__006 VW10 HI   1815
       Revision: 19013000    Serial number: 0039DPDADU5Z
       Coding: 0012342
       VCID: 3B23303F8F6FF5EFDC7-806E
       Subsystem 1 - Serial number: 6333FTS628881658
       Subsystem 2 - Serial number: 6343FTS628951558
       Subsystem 3 - Serial number: 6353ETS67F14UVNH
       Subsystem 4 - Serial number: 6363ETS6C044UVNP
       Part No SW: 3C0 953 549 AE    HW: 3C0 953 549 AE
       Component: J0527               0020
       Revision: 00026000    Serial number: 3C9953507AT
       Coding: 0000112
       Part No SW: 3C0 920 971 E    HW: 3C0 920 971 E
       Component: KOMBIINSTRUMENT VD1 2416
       Revision: V0002000    Serial number: 00000000000000
       Coding: 0007405
       Shop #: WSC 25062 067 57207
       VCID: 270BFC4F63E7410FA8F-8072
    Address 19: CAN Gateway        Labels:. 3C0-907-530-V2.clb
       Part No SW: 3C0 907 530 H    HW: 3C0 907 951
       Component: J533__Gateway   H13 0142
       Revision:   H13       Serial number: 2600P08620125B
       Coding: F9A07F060202022003
       VCID: 2615F14B64ED5807939-8072
       Part No SW: 3C0 959 433 R    HW: 3C0 959 433 R
       Component:    IMMO         042 0383
       Revision: 00042000    Serial number: VWZCZ000000000
       VCID: 392F2A378553C7FFCEB-806C
       Component:    ELV          027 0380
       3C0905861G     ELV          027 0380
       Part No SW: 1K0 959 701 AE    HW: 1K0 959 793 P
       Component: J386  TUER-SG FT    1518
       Revision: 71009005    Serial number: 00000802588616
       Coding: 0004791
       VCID: 71BFD2179DA34FBF36B-8024
       Part No: 1K0 909 144 C
       Component: EPS_ZFLS Kl. 195    2301
       Revision: 00H15000
       VCID: 2A0D057B70F57C67B71-807E
       Component:    KSG PQ46 ELV 042 0472
       Coding: 01900A00D1030E763004941570085FCE107C01
    01134 - Alarm Horn (H12)
                        Reset counter: 244
                        Mileage: 103733 km
                        Date: 2020.02.15
                        Time: 21:22:48
       Part No SW: 1K0 959 702 AE    HW: 1K0 959 792 P
       Component: J387  TUER-SG BT    1518
       Revision: 71009005    Serial number: 00000560188622
       Coding: 0004790
       VCID: 72BDDD1B98A574A7CF1-8026
       Part No SW: 3C8 907 801 A    HW: 3C8 907 801 A
       Component: J540 EPB3  VW-10498 0003
       Revision:   009       Serial number: 00000000070573
       Coding: 0000057
       VCID: 2809FF736EF94E77A15-807C
                007 - Short to Ground - MIL ON
                        Fault Status: 11100111
                        Reset counter: 244
                        Mileage: 103733 km
                        Date: 2020.02.15
                        Time: 21:22:01
                        Voltage: 13.90 V
                        Count: 78
                        Hex Value: 0x1261
                        Hex Value: 0x0001
                        Hex Value: 0x1010
       Part No SW: 1K0 035 186 AA    HW: 1K0 035 186 AA
       Component: Radio RCD310  012 0029
       Revision: 00000000    Serial number: VWZ1Z2H5344347
       Coding: 0F00040004
       VCID: 6597B647556B931F5A3-8030
       Part No SW: 1K0 959 703 AB    HW: 1K0 959 795 L
       Component: J388   TUER-SG HL   0307
       Revision: 41004101    Serial number: 00000000491845
       Coding: 0000144
    Address 6D: Trunk Elect.        Labels: 3C9-827-383.clb
       Part No SW: 3C9 827 383 B    HW: 3C9 827 383 E
       Component: J605  HECKDECKEL    0600
       Revision: 00H27001
       Shop #: WSC 23250 384 715754
       VCID: 30391713562906B7795-8064
       Subsystem 1 - Part No: 3C9 827 384 B
       Component: J756  HECKDECKEL    0600
       Subsystem 2 - Serial number: 0800H27001001B0167ˇ
       Part No SW: 1K0 959 704 AB    HW: 1K0 959 794 L
       Component: J389   TUER-SG HR   0307
       Revision: 41004101    Serial number: 00000000509858
       Coding: 0000144
    End----------(Elapsed Time: 01:24, VBatt start/end: 14.3V/14.3V)-----------
    Scan prior to EPB change;
    Tuesday,31,March,2020,14:59:12:42323
    08-Auto HVAC -- Status: Cannot be reached 1100
       Coding: 0000072
    049508 - No Communications with HVAC Control Module (J301)
                   U0164 - 000 -
                        Fault Frequency: 12
                        Mileage: 103733 km
                        Date: 2020.02.17
                        Time: 17:53:47
                        Temperature: 4.5∞C
                        Voltage: 11.40 V
                        Bin. Bits: 00000000
                        Torque: 219.0 Nm
                        Temperature: 6.3∞C
                   U1017 - 000 -
                        Mileage: 103733 km
                        Date: 2020.02.17
                        Time: 17:53:49
                        RPM: 1035 /min
                        Voltage: 11.63 V
                        Bin. Bits: 00001110
                        Bin. Bits: 00000000
                        (no units): 0.0
                   U1017 - 000 -  - Intermittent
                        Mileage: 103733 km
                        Date: 2020.02.17
                        Time: 17:53:51
                        RPM: 920 /min
                        Voltage: 14.44 V
                        Torque: 0.0 Nm
                        Hex Value: 0xFF00
                        Bin. Bits: 00001110
                   U1017 - 000 -
                        Mileage: 103733 km
                        Date: 2020.02.17
                        Time: 17:53:51
                        RPM: 897 /min
                        Voltage: 14.29 V
                        Bin. Bits: 11001110
                        Bin. Bits: 00000000
                        (no units): 0.0
       Coding: 0001298
    01542 - Yaw Rate Sensor (G202)
       Coding: 00046997
       Shop #: WSC 05124
       Coding: 00209133
       Shop #: WSC 05124
                        Reset counter: 244
                        Mileage: 103733 km
                        Date: 2020.02.15
                        Time: 22:14:00
                        Voltage: 14.30 V
       Coding: 100001
    8 Faults Found:
                        Reset counter: 244
                        Mileage: 103733 km
                        Date: 2020.02.15
                        Time: 21:26:58
                        Temperature: 5.0∞C
    01548 - Sensor for Parking Aid; Rear Right (G206)
                        Reset counter: 244
                        Mileage: 103733 km
                        Date: 2020.02.15
                        Time: 21:26:59
                        Temperature: 5.0∞C
                        Reset counter: 244
                        Mileage: 103733 km
                        Date: 2020.02.15
                        Time: 21:26:59
                        Temperature: 5.0∞C
    01547 - Sensor for Parking Aid; Rear Mid-Right (G205)
                        Reset counter: 244
                        Mileage: 103733 km
                        Date: 2020.02.15
                        Time: 21:26:59
                        Temperature: 5.0∞C
    01629 - Sensor for Parking-Aid; Front Left (G255)
                        Reset counter: 244
                        Mileage: 103733 km
                        Date: 2020.02.15
                        Time: 21:26:59
                        Temperature: 5.0∞C
    01626 - Sensor for Parking-Aid; Front Right (G252)
                        Reset counter: 244
                        Mileage: 103733 km
                        Date: 2020.02.15
                        Time: 21:26:59
                        Temperature: 5.0∞C
    01628 - Sensor for Parking-Aid; Front Mid-Left (G254)
                        Reset counter: 244
                        Mileage: 103733 km
                        Date: 2020.02.15
                        Time: 21:26:59
                        Temperature: 5.0∞C
    01627 - Sensor for Parking-Aid; Front Mid-Right (G253)
                        Reset counter: 244
                        Mileage: 103733 km
                        Date: 2020.02.15
                        Time: 21:26:59
                        Temperature: 5.0∞C
       Coding: 0012342
    01578 - Airbag Deactivation Warning Lamp; Passenger Side (K145)
                009 - Open or Short to Ground - MIL ON
                        Fault Status: 11101001
                        Reset counter: 244
                        Mileage: 103733 km
                        Date: 2020.02.17
                        Time: 17:53:48
       Coding: 0000112
       Coding: 0007405
                        Reset counter: 244
                        Mileage: 103733 km
                        Date: 2020.02.15
                        Time: 22:14:57
       Coding: 0004791
                        Reset counter: 244
                        Mileage: 103733 km
                        Date: 2020.02.15
                        Time: 22:14:59
       Revision: 00H15000
                        Fault Status: 11100101
                        Mileage: 103733 km
                        Date: 2020.02.17
                        Time: 19:37:13
                        Battery Volts: 14.2 V
                            DU
                        Temperature: 28.0∞C
                        Count: 9
                        Steering Angle: 15.40∞
                            SteerAng n.Init
                        Reset counter: 244
                        Mileage: 103733 km
                        Date: 2020.02.15
                        Time: 21:22:48
                        Reset counter: 244
                        Mileage: 103733 km
                        Date: 2020.02.15
                        Time: 22:14:58
       Coding: 0004790
    00132 - Outside Door Handle Illumination/mirror Light Passenger Side
                        Fault Status: 00101100
                        Reset counter: 29
                        Mileage: 103733 km
                        Date: 2020.02.16
                        Time: 04:31:27
                        Reset counter: 244
                        Mileage: 103733 km
                        Date: 2020.02.15
                        Time: 22:14:59
       Revision:   009       Serial number: 00000000127728
       Coding: 0000057
    02844 - Lamp for Automatic Parking Function
                        Fault Status: 11111001
                        Reset counter: 244
                        Mileage: 103733 km
                        Date: 2020.02.17
                        Time: 19:54:23
                        Voltage: 12.30 V
                        Count: 83
                        Hex Value: 0x1250
                        Hex Value: 0x0001
                        Hex Value: 0x0101
       Coding: 0F00040004
       Coding: 0000144
       Revision: 00H27001
       Coding: 0000144
    End----------(Elapsed Time: 01:45, VBatt start/end: 14.2V/14.3V)-----------
    Tartu, Estonia
    The issue is known to be in HW of these units. Better replace it with superseeded correct 3AA part.
    The world is my oyster...
    Mar 2020
    cheers for the reply...
    you mean the EPB module? How would that affect input and saving of Steering/Lat/Long sensors?
    Tartu, Estonia
    Lateral and Longitunal sensors are located inside epb module.
    Per instructions, is car driven before trying to do basic settings?
    Mar 2020
    Yes it was driven at walking space for about 5-10 metres.
    This is where I'm struggling.
    When I follow the procedure for Latteral Sensor Basic Settings and enter group 063 in the box and select go, there is a error reported in the field boxes.
