Results 1 to 2 of 2
Thread: Audi convertible top issue
    Dec 2019
    Hi , I appreciate the video you guys did on the roof operation and your post on the top switch position. I have a 2010 S5 and a bit of water got into the trunk. I placed several of the modules(back up camera, elect suspension, ABS brake) and cleared all the codes...everything is fine in those departments. My convertible top is still throwing some codes, I looked over the fuses, harness and switches and they appear to be clean. I also reset the yellow floppy switches by pushing down the springs(I believe this is for the top comp lid). The top closes fine, but it will not open at all with the "Convertible top can not be operated" message. When I open the top manually(I have gotten really good at this...ha) the cone top lid doesn't close all the way...sticks up about 3/4 of an inch. The previous owner took the car to the dealer and they said he needed a part: 000-979-010-EA (Yellow Wire)– I purchased that, but I don’t know where that wire is located on the vehicle. Below are my codes. Any adea what may be going on? Thank you! Ted
    Address 26: Auto Roof (J256)       Labels:* 8F0-959-255.clb
       Part No SW: 8F0 959 255     HW: 8F0 959 255
       Component: VSG-AUDI-B8   H10 0180
       Coding: 030000
       Shop #: WSC 02135 785 00200
       ASAM Dataset: EV_ElectRoofContr 001008
       ROD: EV_ElectRoofContr.rod
       VCID: 71E9E6CEA0D6ECC758-8025
    0004 - Switch for Convertible Top
              B11A0 02 [009] - Signal Failure
                        Reset counter: 104
                        Mileage: 160634 km
                        Date: 2009.06.26
                        Time: 00:00:31
    0020 - Convertible Top Compartment Switch; Left
              B1181 29 [008] - Signal Implausible
                        Reset counter: 40
                        Mileage: 231151 km
                        Date: 2009.07.25
                        Time: 08:23:21
    0021 - Convertible Top Compartment Switch; Right
              B1182 29 [008] - Signal Implausible
    HQ
    Vehicle support, moved to proper location so more eyes can get on it. Please provide a FULL Auto-Scan!
    If the top is fully closed and locked up, or fully open and secured, what do all the channels for IDE02664 show compared to the data on our wiki page for the A5 top?
    http://wiki.ross-tech.com/wiki/index...(FH)_Auto_Roof
    If you find something different, what IDE location is it and what does it read?
    If the top is partially opened, then post a couple of photos so we have some idea where it is located.
    Jef
  3. Likes Uwe liked this post
