Results 21 to 30 of 35
Thread: Immobilizer/gauge replacement
  1. #21
    Quote Originally Posted by drdfblackm View Post
    Is there a FAQ on posting images. This is on Google Photos
    Yes, see: How to Post Pictures. But note that Google Photos is not particularly forum friendly.
    Those links work.
  2. #22
    Yeah well how about a picture of forward key section not remote?
    Find-lay Jokeswagen huh?.........
    Supersession
    PART NUMBER RIGHT DESCRIPTION REMARK MODEL
    1T0 837 246 C INB main key with change code
    transponder for radio control
    central locking system
    (folding key shaft, FOR
    rectangular key pad)
    inner profile
    Vehicle intelligent genuine part.
    Order only with additional instructions.
  3. #23
    Dallas (McKinney) ,TX ,USA
    I guess no one look his older post :
       Part No SW: 1K6 920 973 A    HW: 1K6 920 973 A
       Component: IMMO            VDD 1610
       Revision: V0003000    Serial number: VWZ7Z0F8079630
       VCID: 313F13013D2CEB2F76B-8064
    00003 - Control Module
                014 - Defective
                        Fault Status: 01101110
                        Mileage: 67433 km
                        Time: 14:25:33
    Programing of the key can be done but not with Odis , Odis will reject programing when this code is store. It is possible that car had Flat battery , I have seen many times this code after flat battery, or Someone in past play with Eeprom.
    Cluster will be fine ,just need to use different tool.
    Immobilizer/ECU
    /Cluster Programing (Used or NEW)
    email: marinmm2001@gmail.com , info@advancedcarelectronics.com
    https://www.advancedcarelectronics.com/
  4. Likes Uwe liked this post
  5. #24
    Mar 2020
    Flagstaff AZ, USA
    Good to know.....what other tool are you referring to?
    I am sure it had a bad battery because previous owner put wrong size battery in it. I mean it fits but the top cover will not fit.
  6. #25
    Certainly no sign of a login default attempt & code erase either and is standard operation procedure for a dealer doing a FaZit session, no?
    I saw the scan which is why I stated the aforementioned already & with an auto-scan inserted, didn't you see it?
  7. Likes drdfblackm liked this post
  8. #26
    Mar 2020
    Flagstaff AZ, USA
    Actual notes from write-up:
    UNABLE TO PROGRAM NEW IGNITION KEY ,DUE TO "STATIC" FAULT IN IMMOBILIZER ( CONTROL MODULE FAULTY ) THE IMMOBILIZER /INSTRUMENT CLUSTER WILL NEED TO BE REPLACED. PROGRAMMED KEY FOB TO COMFORT SYSTEM
    It was thru the key programming that led us to recommend a new odometer/instrument cluster. You will not be able to program a key to this component without replacement. The fob is programmed and works.
  9. Likes Jack@European_Parts, Jetta ,97 liked this post
  10. #27
    Exactly what I said in my post.
    Immobilizer/ECU
  11. #28
    Is it not better to know or verify, versus speculate?
  12. Likes drdfblackm liked this post
  13. #29
    Mar 2020
    Flagstaff AZ, USA
    Post visit to VW autoscan:
    Thursday,02,April,2020,18:18:00:23322
    VIN: WVWEV71K17W058934   License Plate:
    Chassis Type: 1K (1K0)
    Scan: 01 03 08 09 0F 15 16 17 19 1C 25 42 44 46 52 55 56 65
    VIN: WVWEV71K17W058934   Mileage: 214010km-132979miles
    56-Radio -- Status: Not registered 0001
       Part No SW: 1K0 907 115 H    HW: 8P0 907 115 B
       Revision: 5BH14---    Serial number: VWZ7Z0F8079630
       Coding: 0403010A18070160
       Shop #: WSC 65728 1018 854933
       VCID: 2B0301691F0081FF4C7-807E
       Revision: 00H11001
       Coding: 0021122
       Shop #: WSC 01279 785 00200
       VCID: 73B3D90987B0993FC47-8026
       Part No SW: 1K0 907 044 BJ    HW: 1K0 907 044 BJ
       Component: ClimatronicPQ35 090 0909
       Revision: 00090016    Serial number: 00000000000000
       VCID: 70B9D605F6A6A227395-8024
       Part No SW: 3C0 937 049 Q    HW: 3C0 937 049 Q
       Revision: 00H46000    Serial number: 00000006003607
       Coding: B78F8F21400415000014000000140000001D770B5C0000
       Shop #: WSC 08319 444 84786
       VCID: 372B2D19D348351F38F-8062
       Component: Wischer 200706 020  0501
       Coding: 00038805
       Shop #: WSC 08319
    01593 - Heated Windshield (Z2)
                        Fault Status: 00101010
                        Fault Frequency: 14
                        Reset counter: 198
                        Mileage: 213804 km
                        Voltage: 14.00 V
                        Fault Status: 01101010
                        Reset counter: 159
                        Mileage: 213804 km
                        Voltage: 13.80 V
                        Reset counter: 159
                        Mileage: 213804 km
                        Voltage: 13.85 V
                        Fault Status: 01111010
                        Reset counter: 159
                        Mileage: 213825 km
                        Voltage: 11.70 V
                        Reset counter: 159
                        Mileage: 213806 km
                        Voltage: 12.10 V
       Part No SW: 8E0 035 593 F    HW: 8E0 035 593 F
       Component: SDAR SIRIUS     H03 0120
       Revision: 00000000    Serial number: AUZ4Z7F1029378
       VCID: 2C0102751A0E86C745D-8078
                        Reset counter: 155
                        Mileage: 213804 km
                        Time: 23:11:35
       Component: 5L AIRBAG VW8R  034 8000
       Revision: 05034000    Serial number: 003B6D0661WZ
       Coding: 0013644
       Shop #: WSC 01269 785 00200
       VCID: 6C81C275DA8E46C705D-8038
       Subsystem 1 - Part No: 1K0 959 339 G
       Component: BF-Gewichtsens. 007 0007
       Subsystem 2 - Serial number: 6332MSME156B5B46K
       Subsystem 3 - Serial number: 6342MSME12267E0AE
       Subsystem 4 - Serial number: 6352QSME127B030DE
       Subsystem 5 - Serial number: 6362QSME10331F39D
       Subsystem 6 - Serial number: 63727SME0A5F05746
       Subsystem 7 - Serial number: 63827SME0A5F077BG
       Part No SW: 1K0 953 549 AJ    HW: 1K0 953 549 AJ
       Component: J0527           034 0070
       Coding: 0002022
       VCID: 7AADF42DA0DAE877871-802E
       Coding: 0005107
       Shop #: WSC 65536 645 97773
       Revision:   H12       Serial number: 3100106714082B
       Coding: 7D8F03200F004000
       Shop #: WSC 24313 444 999999
                        Reset counter: 155
                        Mileage: 213804 km
                        Time: 23:11:28
       Part No SW: 1K6 919 879     HW: 1K6 919 879
       Component: Kompass         001 0002
       Revision: 00001000    Serial number: 1225223T1HLL02
       VCID: 7DA7FF31B1F4DF4FA23-8028
                014 - Defective
                        Mileage: 67433 km
                        Time: 14:25:33
       Component: Tuer-SG         005 0967
       Coding: 0001077
       VCID: 38292E25DE563A67315-806C
                008 - Implausible Signal
       Part No: 1K1 909 144 L
       Component: EPS_ZFLS Kl.074 H07 1806
       Shop #: WSC 00000 028 00001
       VCID: 34311A15C23EDE071DD-8060
       Part No SW: 1K0 959 433 CD    HW: 1K0 959 433 CD
       Component:    KSG PQ35 RDK 051 0215
       Revision: 00051000    Serial number: 00000000000000
       Coding: 139006885103083F6D04058FB0080A04889C00
       Shop #: WSC 63495 001 1048576
       VCID: 74B1DA1582BE9E07DDD-8020
    00896 - Trunk Lock Unit (F256)
                        Fault Status: 01101000
                        Reset counter: 156
                        Mileage: 213806 km
                        Time: 09:15:18
       Coding: 0001076
       VCID: 392F2B21E55C236FCEB-806C
       Part No: 1T0 907 357
       Coding: 0000003
       Part No SW: 1K0 035 180 G    HW: 1K0 035 180 G
       Component: Radio PM6       017 0019
       Revision: 00017000    Serial number: VWZ5Z7F2086914
       Coding: 0040401
       VCID: 2411EA5572DE4E878DD-8070
       Component:    RDK              0420
       Coding: 0100101
                        Reset counter: 155
                        Mileage: 213804 km
                        Time: 23:11:24
    End----------(Elapsed Time: 01:11, VBatt start/end: 12.5V/12.5V)-----------
  14. #30
    Well no login attempt....... Sigh
