Results 1 to 8 of 8
Thread: AC fault codes
    Apr 2019
    GB
    AC fault codes
    I did a scan of my car 2007 SEAT Altea 1.9 Tdi VIN: VSSZZZ5PZ7R073433 and these faults came up relating to the AC.
    Engine:
    005697 - Please check DTC Memory of A/C Controller
    P1641 - 000 -
    Mileage: 216496 km
    Time: 11:54:32
    RPM: 798 /min
    Load: 0.0 %
    Voltage: 14.06 V
    Bin. Bits: 00001100
    Temperature: 79.2°C
    (no units): 0.0
    Auto HVAC:
    9481748 - High Pressure Sensor
    B10AE 14 [009] - Open or Short to Ground
    Reset counter: 229
    Mileage: 216502 km
    Time: 11:38:46
    Any ideas what could be wrong?
    HQ
    Jef
  3. Likes Uwe liked this post
    16.4905° S, 151.7375° W
    Yes, The fault code in the Auto-HVAC controller says it all! There is a concern with the G65-Refrigerant Pressure Sensor, it's wiring or connections or perhaps the J255-HVAC Controller.
    B10AE/9481748 - High Pressure Sensor: Open or Short to Ground
    This forum post should be helpful.... Tis’ the HVAC Season
    Oh, one quick test is to disconnect the connector form the G65, see if there is any refrigerant/oil leaking from the system, indicating the G65 has a problem!
    If needed, links can be found for the Official Factory Repair Information.
    Hope that helps,
    drpeter
    ps... posting a complete Auto-Scan is best and can be helpful in many different ways..
  5. Likes Uwe liked this post
    Mar 2020
    If this is anything like the golf mk5 the sensors leak and at the front straight down on the left by the radiators. My sister had the same issue on her mk5 golf.
    Apr 2019
    GB
    Sorry didn't realise you had to post full scan. Here is full scan.
    VIN: VSSZZZ5PZ7R073433   License Plate:
    Mileage: 216500km-134526mi   Repair Order:
    Chassis Type: 5P-SE35 (1K0)
    Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 56 62 72 77
    VIN: VSSZZZ5PZ7R073433   Mileage: 216500km-134526miles
    Address 01: Engine        Labels: 03G-906-016-BKC.clb
       Part No SW: 03G 906 021 LN    HW: 03G 906 021 AN
       Component: R4 1,9L EDC G000SG  9246
       Revision: --H07---    Serial number: SEZ7Z0G3843060
       Coding: 0050071
       Shop #: WSC 04941 785 00200
       VCID: 76B6EECDE4C76F57E3B-8022
    005658 - Glowplug for Cylinder 1 (Q10)
                   P161A - 000 - Open Circuit
                        Fault Status: 01110000
                        Mileage: 216233 km
                        Time: 06:07:20
                        RPM: 819 /min
                        Load: 0.0 %
                        Voltage: 10.26 V
                        Bin. Bits: 00001100
                        Temperature: 5.4°C
                        Bin. Bits: 01110000
                   P1641 - 000 -
                        Mileage: 216496 km
                        Time: 11:54:32
                        RPM: 798 /min
                        Load: 0.0 %
                        Voltage: 14.06 V
                        Bin. Bits: 00001100
                        Temperature: 79.2°C
                        (no units): 0.0
    Address 03: ABS Brakes        Labels: 1K0-907-379-MK70.lbl
       Part No: 1K0 907 379 P
       Component: ASR FRONT MK70      0105
       Coding: 0000641
       Shop #: WSC 09025 123 123456
       VCID: 3FD84BE98B7DEE1FF0D-806A
       Part No SW: 5P0 907 044 P    HW: 5P0 907 044 P
       Component: Climatronic   H15 0702
       Revision: 00001001
       Coding: 0000000003
       ROD: EV_ClimaAutoBasis_SE35.rod
       VCID: 3D2431E18DF1FC0FE21-8068
    13701376 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
              [Motorsteuergerät - kein Signal/Kommunikation]
                        Reset counter: 229
                        Mileage: 216502 km
                        Time: 11:38:46
    13701456 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
              [Steuergerät im Schalttafeleinsatz - kein Signal/Kommunikation]
                        Reset counter: 229
                        Mileage: 216502 km
                        Time: 11:38:46
                        Reset counter: 229
                        Mileage: 216502 km
                        Time: 11:38:46
       Revision: 00H52000    Serial number: 00000004826901
       Coding: E1880F2700041000431E00000000000000017F0B5C4000
       VCID: 6C82CCA5AA8BA58705F-8038
       Subsystem 1 - Part No: 5P0 955 119 C  Labels: 1KX-955-119.CLB
       Component: Wischer 270407 022  0601
       Coding: 00056208
       Shop #: WSC 04941
       Subsystem 2 - Part No: 1P0 955 559   Labels: 1P0-955-559.CLB
       Component: REGENLICHTSENSORH04 0090
       Coding: 00137517
       Shop #: WSC 04941
       Component: S9 AIRBAG VW8   020 2300
       Revision: 05020000    Serial number: 0038PD15MXWD
       Coding: 0021305
       VCID: 3D2431E18171FC0FE21-8068
       Subsystem 1 - Serial number: 6332MSME127E395BN
       Subsystem 2 - Serial number: 6342MSME13171D5EH
       Subsystem 3 - Serial number: 6351HSME0D386F61J
       Subsystem 4 - Serial number: 6361HSME0D385B08G
       Part No SW: 1K0 953 549 AQ    HW: 1K0 953 549 AQ
       Coding: 0002042
       VCID: 015C8D11BD0958EFC69-8054
       Component: E0221           005 0060
       Part No: 5P0 920 923 A
       Component: KOMBIINSTRUMENT VO3 0422
       Coding: 0002401
       Shop #: WSC 36435 001 104857
       VCID: 2F381BA95B1D1E9F60D-807A
       Component: J533__Gateway   H16 0202
       Revision:   H16       Serial number: 2700K08626083F
       Coding: E9807F064006020203
       Shop #: WSC 06402 785 00200
       VCID: 353429C1B941244F2A1-8060
       Component: IMMO            VO3 0422
       Shop #: WSC 00001 001 00001
       Part No SW: 1T0 035 680 P    HW: 1T0 035 680 F
       Component: RNS-MID       H06 5238
       Revision: AB001001    Serial number: VWZ6Z7L7160137
       Coding: 04000442040000A00000
       Shop #: WSC 00020 790 12345
       VCID: 3B203FF99365F23FDC5-806E
       Subsystem 1 - Part No: 7N5 051 884 K
       Component: EU West V16  8536
    03138 - Input AUX IN
                        Fault Status: 01101011
                        Reset counter: 229
                        Mileage: 216502 km
                        Time: 11:28:39
       Part No SW: 1T0 959 701 G    HW: 1K0 959 793 M
       Component: J386  TUER-SG FT    1132
       Revision: 31008001    Serial number: 00000024478117
       Coding: 0000688
       VCID: 3B203FF99F65F23FDC5-806E
                        Fault Status: 01101100
                        Reset counter: 229
                        Mileage: 216502 km
       Part No: 1K2 909 144 L
       Component: EPS_ZFLS Kl.077 H07 1806
       Component:    KSG PQ35 G2  020 0203
       Coding: 998000005183CC7F0006050560085F86107C80
       VCID: 03508719A7154AFFD45-8056
       Subsystem 5 - Part No: 5P0 951 171 C
       Component: Innenraumueberw.009 4865
       Coding: 00000000
       Shop #: WSC 00001
       Subsystem 7 - Component:       NGS n.mounted
                014 - Defective
                        Fault Status: 01101110
                        Reset counter: 229
                        Mileage: 216502 km
                        Time: 11:31:22
       Part No SW: 1T0 959 702 G    HW: 1K0 959 792 M
       Component: J387  TUER-SG BT    1132
       Revision: 31008001    Serial number: 00000520678205
       Coding: 0000688
       VCID: 3C223CE59A6BF507D5F-8068
                        Reset counter: 229
                        Mileage: 216502 km
                        Reset counter: 229
                        Mileage: 216502 km
                        Time: 11:28:39
       Part No SW: 1K0 959 703 M    HW: 1K0 959 795 G
       Component: J388   TUER-SG HL   1114
       Revision: 11006001    Serial number: 00000001576879
       Coding: 0000144
       VCID: 3A2E3AFD905FCB37C73-806E
       Part No SW: 1K0 959 704 M    HW: 1K0 959 794 G
       Component: J389   TUER-SG HR   1114
       Revision: 11006001    Serial number: 00000001570316
       Coding: 0000144
       Part No SW: 7P6 035 730 N    HW: 7P6 035 730 N
       Component: TELEFON       H15 4217
       Revision: 1B001001    Serial number: 00007699999999
       Coding: 0A10000000010110
       Shop #: WSC 12345 123 12345
       ASAM Dataset: EV_UHVNA 002720
       ROD: EV_UHVNA_002.rod
    End----------(Elapsed Time: 01:25, VBatt start/end: 14.0V/14.1V)-----------
    Thanks for your replies.
  8. Likes DrPeter liked this post
  9. #6
    Thanks for the Auto-Scan...
    After you fix the "High Pressure Sensor" fault clear all the DTCs and hopefully the " no signal/communication" faults will clear too.
    And. . . do let us all know what you find. Success stories are great and help others here searching for answers to these types of concerns,
    drpeter
  10. Likes Uwe liked this post
  11. #7
    HQ
    The G65 is the High Pressure Sensor. It has 3 wires:
    • /1 = br, ground
    • /2 = li/ge, to HVAC (J255) T20c/2
    • /3 = bl/sw from fuse SC13 (5A)
    Unplug the sensor, make sure the electrical contacts are clean and dry... do you have ground and power on /1 and /3? Is the /2 data wire damaged or broken?
    Jef
  12. Likes Uwe, Fredrick Awuor liked this post
  13. #8
    Apr 2019
    GB
    Thanks Jef and DrPeter for your help will check today let you know if I've managed to fix problem.
  14. Likes DrPeter liked this post
