Results 1 to 8 of 8
Thread: Mk7 with Front Assist but no ACC
    Pirate
    Mar 2020
    Romania
    Hi everyone, i ve been searching a while everywhere about this and what i found yesterday really gives me hope. I found a guy on forum who has a very similar car like mine but he is got ACC and Front Assist.
    My car is mk7 2.0 Tdi High-line Estate With Front Assist only, with a lot of options and this guy`s car si very very similar.
    I cheched my car`s log and his car`s log so from what i could see the only differences are that he`s got ACC button and i ve got CNL. We both have same RADAR, same ABS pump etc....could somebody please tell me is is there anyway that i could get ACC withouth upgrading the radar, abs pump etc ? I dont see an option to upload the Log`s. Thank you !
    Part No SW: 5Q0 907 379 L HW: 5Q0 907 379 G
    Address 13: Auto Dist. Reg (J428) ---- Part No SW: 5Q0 907 572 D
    May 2017
    Full autoscan please? You can paste the text between "[code]" tags
    And no, not possible by changing buttons and coding. Front assist or autonomous emergency braking and ACC both are under different feature enable codes and those are used to authorize the functionalities. Officially you get the codes when you buy the equipment as optional upgrades when buying a new car. Aftermarket cannot be bought through official channels.
  3. Likes Uwe liked this post
    Pirate
    Mar 2020
    Romania
    Removed.  Data from a clone/pirate copy of VCDS is not acceptable here.
    Pirate
    Mar 2020
    Romania
    this LOG belong to that car similar with mine but with ACC
    Saturday,19,May,2018,16:55:26:64565
    VIN: WVWZZZAUZFP55****   License Plate:
    Chassis Type: AU-VW37 (5Q0)
    Scan: 01 03 08 09 10 13 15 16 17 19 42 44 47 52 55 5F
    VIN: WVWZZZAUZFP55****   Mileage: 23077km-14339miles
    Address 01: Engine (J623-CHPA)       Labels:. 04E-907-309-V1.clb
       Part No SW: 04E 906 016 F    HW: 04E 907 309 A
       Component: 1,4l R4 TSI   H10 7861
       Revision: WAH10---
       Coding: 01190072234405082000
       Shop #: WSC 00028 028 00070
       ASAM Dataset: EV_ECM14TFS01104E906016F 002011
       ROD: EV_ECM14TFS01104E906016F.rod
       VCID: 2514F89EC56EC57F21E-8070
    Readiness: 0000 0001
       Revision: 00000000    Serial number: 62644000001579
       Coding: 04FA8AA12425296E0380060941C82920512494C0608294F3F4205078C009
       Shop #: WSC 00028 028 00067
       VCID: 45D4581E252E257F01E-8010
       Part No SW: 5G0 907 044 AN    HW: 5G0 907 044 AN
       Component: Climatronic   H03 0907
       Revision: 00001K08
       Coding: 02120004200400011005004200101000
       VCID: 73B0D6C63B3AEBCF7FA-8026
       Part No SW: 5Q0 937 086 AA    HW: 5Q0 937 086 AA
       Component: BCM PQ37BOSCH 028 0106
       Revision: --------    Serial number: 86582509140616
       Coding: 03000A66C24122FB0BA44080B11C07281000000000000000000000000000
       Shop #: WSC 00028 028 00080
       ASAM Dataset: EV_BodyContrModul1UDSBosc 013004
       ROD: EV_BCMBOSCH_013.rod
       VCID: 79ACE4EE1956919F356-802C
       Component: WWS    140828  042 0551
       Serial number:         140909221237
       Component: RLHS  037 0059
       Serial number: S4Y14M09D19H22M35S19
       Coding: 06A8EE
       Serial number: 000000000ZY1421702PK
       Serial number: 00000000000060620911
       Part No SW: 5Q0 919 294 E    HW: 5Q0 919 294 A
       Component: PARKHILFE 8K  H03 0048
       Revision: --------    Serial number: 39311424603534
       Coding: 0071151001
       ROD: EV_EPHVA18AU3700000_002_VW27.rod
       VCID: 3D2430FE4DFE6DBF59E-8068
       Part No SW: 5Q0 907 572 D    HW: 5Q0 907 572 D
       Component: ACC Bosch MQB H05 0304
       Serial number: 13091403211821
       Coding: 00000300FE0739
       VCID: 382A21EA62DC48978A8-806C
    1540 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
              C1103 00 [009] -  -
              [FAULT_MISALIGNMENT_HORIZONTAL]
                        Reset counter: 85
                        Mileage: 23069 km
                        Date: 2018.05.19
                        Time: 11:34:43
                        Control Module temperature: 34 °C
                        Voltage terminal 15: 14.3 V
                        Vehicle speed: 19.23 m/s
                        Acceleration: -0.45 m/s²
    1541 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
              C1103 00 [008] -  -
              [FAULT_MISALIGNMENT_VERTICAL]
                        Reset counter: 125
                        Mileage: 23025 km
                        Date: 2018.05.19
                        Time: 09:28:26
                        Control Module temperature: 23 °C
                        Voltage terminal 15: 14.6 V
                        Vehicle speed: 12.86 m/s
                        Acceleration: -0.82 m/s²
       Component: AirbagVW20    014 0386
       Serial number: 003MLR08TR8G
       Coding: 98FCC0C0000000005C5400CF00C800000065
       Shop #: WSC 00028 028 00065
       VCID: 7F580AF60772BFAF0B2-802A
       Belt Pretensioner left:
       Component: BeltPretRevFL  H35 0341
       Serial number: 34169677B23091440735
       Coding: 333135
       Belt Pretensioner right:
       Component: BeltPretRevFR  H35 0341
       Serial number: 34169676B22091441270
       Coding: 333135
       Subsystem 3 - Part No SW: -----------    HW: 480 001 609 14
       Serial number: 35767000000BE799011.
       Subsystem 4 - Part No SW: -----------    HW: 480 002 209 14
       Serial number: 3586700000048A88111R
       Subsystem 5 - Part No SW: -----------    HW: 480 401 709 14
       Serial number: 3516502AB176A6B3702A
       Subsystem 6 - Part No SW: -----------    HW: 480 401 609 14
       Serial number: 3526502BB176A6B2C2DT
       Subsystem 7 - Part No SW: -----------    HW: 480 401 409 14
       Serial number: 3556502BD175A8D3137M
       Part No SW: 5Q0 953 521 R    HW: 5Q0 953 569 A
       Revision: FF032032    Serial number: 20140924400079
       Coding: 0C00
       ROD: EV_SMLSVALEOMQB.rod
       VCID: 41DC4C0E3106095F3D6-8014
       Part No SW: 5G1 920 950     HW: 5G1 920 950
       Component: KOMBI         304 4270
       Coding: 27A411002F80A60001887E011400000000000000
       VCID: 6696BF9278E80E67E84-8032
    16777018 - Function Restricted due to Interrupted Communications
              U1110 00 [008] - -
              [BAP_Audio_0x31 keine Kommunikation]
                        Reset counter: 123
                        Mileage: 23023 km
                        Date: 2018.05.18
                        Time: 14:05:37
       Part No SW: 5Q0 907 530 T    HW: 5Q0 907 530 M
       Component: GW MQB High   212 2186
       Revision: --------    Serial number: 18091410800272
       Coding: 030100042B085700EF00025E080F00010001050000000000000000000000
       ROD: EV_GatewConti_011_VW37.rod
       VCID: 42DE43023400124724C-8016
       Component: E221__MFL-DC1  H16 0038
       Serial number: 29140002037610024382
       Coding: 2CFFFF
       Serial number: 8991084403
       Part No SW: 5Q4 959 593 C    HW: 5Q4 959 593 B
       Component: TSG FS        009 0015
       Serial number: 0000118719572
       Coding: 003F0220D001028000001000
       Subsystem 1 - Part No SW: 5Q4 959 812 A    HW: 5Q4 959 812 A  Labels: 5QX-959-81X-V1.CLB
       Serial number: 00000000000006622716
       Coding: 0D0000
       Coding: 8103
       ROD: EV_SteerAssisMQB_010.rod
    Address 47: Sound System (J525)       Labels:| 5G0-035-456.clb
       Part No SW: 5G0 035 456     HW: 5G0 035 456
       Component: MIB_lite_amp  H40 0060
       Serial number: VWZ8Z1EC401PDA6
       Coding: 120000008AAA8A0000
       ASAM Dataset: EV_AMPMst12C1ALPI 001005
       ROD: EV_AMPMst12C1ALPI.rod
       VCID: 6390A6868BDA7B4F0FA-8036
       Part No SW: 5Q4 959 592 C    HW: 5Q4 959 592 B
       Component: TSG BFS       009 0015
       Serial number: 0000118732755
       Coding: 003F0020DE01028000801000
       VCID: 44D2451A2E141C77160-8010
       Subsystem 1 - Part No SW: 5Q4 959 811 A    HW: 5Q4 959 811 A  Labels: 5QX-959-81X-V1.CLB
       Serial number: 00000000000006626660
       Coding: 050000
       Coding: 069E00000B000200
       VCID: 40DA490A3A0C0057328-8014
       Subsystem 1 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
       Coding: 2E0000
       Subsystem 2 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
       Coding: 2E0000
       Part No SW: 5G0 035 874     HW: 5G0 035 874
       Component: MU-S-ND-ER    041 0486
       Serial number: V7F02009141726
       Coding: 027302010000000011111202000800031F0200B60100010045
       ROD: EV_MUStd4CPASE_VW37.rod
       VCID: 6788B2967FE2176FD32-8032
       Component: ABT_Std_Nav  H60 0032
       Serial number: VWZ8Z9PS403NCT
       Subsystem 2 - Part No SW: 5G0 919 866 AF    HW: -----------
       Component:  ECE 2017/18  --- 0067
    End----------(Elapsed Time: 01:38, VBatt start/end: 12.5V/12.5V)-----------
    May 2017
    Aha, and what about it? We would specifically need to see the log from YOUR car.
    He posted one in message #3, but I have removed it for the usual reason.
  8. Likes downtime liked this post
    @ClaudiuC:
    Getting help in this forum requires the use of a legitimate VCDS system.
    http://www.ross-tech.com/distributors.php
    Let us know if/when you get one and we'll adjust your forum status.
  10. #8
    Pirate
    Mar 2020
    Romania
    Ah, sorry about that, won't happen again, i ll get a genuine one asap. thank you
