Key adaptation not working after BCM upgrade from 087J to 090E/189
rhill2901
C?ID=277377
2014 vw jetta TDI came with a 086J BCM and I upgraded it to a 087J without any problems. The remotes paired as per rosstech's website via vcds. I recently installed a 090E BCM and I tried pairing the remotes again, and could not get the same procedure to work and even tried the manual way of pairing. It still didn't work. I thought, well, maybe after I have the newer instrument cluster installed and the new canbus wires added, the problem will rectify itself. Well, no, it didn't. Manual way does nothing. When I try through VCDS, it acts like its going to work, but when I set it to adapt a key, VCDS reports lost communications to the BCM. I tried 2 BCM's, one is a 090E, and the other is a 189. They both do the exact same thing. Is there something else I need to do? Everything else works fine with the car. Ignore the Info-mation system error, since I have a hardware fix on the radio. Also ignore the telephone error, I just need to pull that module out. Terminal 30 errors I am familiar with what I need to do, but would like to tackle the remotes first, unless, of course, the Terminal 30 errors are causing my problem? I doubt it though.
This is the dump from a good working 087J BCM:
Wednesday,25,March,2020,16:39:13:43477
VCDS Version: 19.6.2.2 (x64)
Workshop Code: 001 00001 000001
VIN: 3VW3L7AJ3EM384376   License Plate: BCM 087 SCAN
Chassis Type: AJ-VW36 (6N0)
Scan: 01 03 08 09 15 17 19 25 2E 37 44 56 77
Address 01: Engine (CJA)       Labels: 03L-906-022-CBE.clb
   Part No SW: 03L 997 030 N    HW: 03L 907 309 AA
   Component: R4 2.0l TDI G000SG  9983
   Revision: 12H16---    Serial number:
   Coding: 0050072
   Shop #: WSC 74291 008 00000
   VCID: 3957DC5570F04787A2-806C
Readiness: 0 0 0 1 1
   Revision: 00H31001
   Coding: A14B400C492A00FE850E02EB921F0042A71000
   Shop #: WSC 00001 001 00001
   VCID: 7DDF0845E458BBA7CE-8028
Address 08: Auto HVAC        Labels: 5C0-820-047.clb
   Part No SW: 5C0 820 047 BA    HW: 5C0 820 047 BA
   Component: J301  Klimaanlage   0204
   Revision: 2001012S    Serial number: 00000001832383
   Shop #: WSC 00066 000 00000
   VCID: 60E15131B3EA764FC5-8034
   Part No SW: 5C0 937 087 J    HW: 5C0 937 087 A
   Component: BCM25 JLB H3  H34 0411
   Revision: B2034001    Serial number: 08013124140417
   Coding: 7B994B3808AB0B0000382600240804D400C2502E60004000300010002000
   VCID: 3449ED619792BAEF71-8060
   Subsystem 1 - Part No SW: 6R0 959 802 AS    HW: 6R0 959 802 AS  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  006 5461
   Serial number: 14202584130919072258
   Coding: 820000
   Subsystem 2 - Part No SW: 5K0 959 542 C    HW: 5K0 959 542 C
   Component: E221__MFL-TAS  H31 0037
   Serial number: 0005616 FLE 20130910
   Coding: 820000
   Subsystem 3 - Part No SW: 6R0 959 811 M    HW: 6R0 959 811 M
   Component: J388__TSG_HL  006 5460
   Serial number: 14202587130910161739
   Coding: 800000
   Subsystem 4 - Part No SW: 6R0 959 812 M    HW: 6R0 959 812 M
   Component: J389__TSG_HR  006 5460
   Serial number: 14102586130918162601
   Coding: 800000
                    Reset counter: 71
                    Mileage: 56353 km
                    Date: 2061.14.24
                    Time: 00:46:55
   Part No SW: 5C0 959 655 AD    HW: 5C0 959 655 AD
   Component: AirbagVW10    102 0912
   Serial number: 003MVD01EHL-
   Coding: 00004138
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 74C92D61DF12FAEFB1-8020
   Serial number: 6940000Y130000YG350T
   Coding: 303036
   Serial number: 3572MSME6813067DZZZ.
   Serial number: 3582MSME3C20327CZZZZ
   Serial number: 3516KSME48524227ZZZN
   Serial number: 3526KSME03144127ZZZC
   Serial number: 3556LSME65025328ZZZP
   Serial number: 3566LSME31355328ZZZP
Address 17: Instruments
   Part No SW: 6N0 909 901     HW: 5C0 937 087 A
   Component: GW-K-CAN TP20 H34 0411
   Revision: B2034001
   Coding: 102200
   VCID: 70C12171A30AC6CF55-8024
   Component: IMMO          H04 0809
   VCID: 6AF533198DD63C1F1B-803E
Address 2E: Media Player 3
Address 37: Navigation
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 70     3501
   Revision: 00H22000
   Shop #: WSC 02069 000 90108
Address 56: Radio
   Revision: 1B001001    Serial number: 00007665111546
   Coding: 0A10030081010110
   Shop #: WSC 01383 790 50316
   ROD: EV_UHVUMI.rod
   VCID: 2E7DFF0971BE903F07-807A
9455635 - Telephone Microphone
          B1048 13 [009] - Open Circuit
                    Reset counter: 71
                    Mileage: 56353 km
                    Date: 2061.14.24
                    Time: 00:10:41
9457170 - Right audio channel for speech/telephone
          B104E 12 [009] - Short to GND
                    Reset counter: 71
                    Mileage: 56353 km
                    Date: 2061.14.24
                    Time: 00:10:39
End-------------------------(Elapsed Time: 01:43)--------------------------
Here is the dump from the 189 BCM
Thursday,02,April,2020,14:47:56:43477
VIN: 3VW3L7AJ3EM384376   License Plate: NEW BCM
Mileage: 56400km-35045mi   Repair Order:
Chassis Type: AJ-VW36 (7E0)
Scan: 01 03 04 08 09 15 17 19 25 2E 37 44 5F 77
VIN: 3VW3L7AJ3EM384376   Mileage: 56400km-35045miles
   Coding: 0050072
   Revision: 00H31001
   Part No SW: 7E0 937 189     HW: 7E0 937 189
   Component: BCM PQ25 MMI3 H80 0736
   Revision: BA080001    Serial number: 18007065160193
   Coding: 7B994F3808AB0B0000382600240884C40082502E60000000300050002000
   VCID: 71C72475A800CFC75A-8024
   Subsystem 1 - Part No SW: 6R0 959 801 AN    HW: 6R0 959 801 AN  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  006 5461
   Serial number: 14202585130923125249
   Coding: 820000
   Subsystem 2 - Part No SW: 6R0 959 802 AS    HW: 6R0 959 802 AS  Labels: 6R0-959-802.CLB
   Coding: 820000
   Subsystem 3 - Part No SW: 5K0 959 542 C    HW: 5K0 959 542 C  Labels: 3C8-959-537.CLB
   Coding: 820000
   Subsystem 4 - Part No SW: 6R0 959 811 M    HW: 6R0 959 811 M
   Coding: 800000
   Subsystem 5 - Part No SW: 6R0 959 812 M    HW: 6R0 959 812 M
   Coding: 800000
01516 - Terminal 30; Left
                    Fault Status: 01101011
                    Reset counter: 181
                    Mileage: 56401 km
                    Date: 2020.04.02
                    Time: 02:43:31
00927 - Terminal 30 (Right)
                    Reset counter: 181
                    Mileage: 56401 km
                    Date: 2020.04.02
                    Time: 02:43:31
   Coding: 00004138
   Coding: 303036
   Part No SW: 5C6 920 974 F    HW: 5C6 920 974 F
   Component: KOMBI         H04 0808
   Coding: 271A01
   Shop #: WSC 00066 000 00119
   VCID: 334BEE7D9A9CBDD768-8066
   Part No SW: 7E0 909 901     HW: 7E0 937 189
   Component: GW-K-CAN TP20 H80 0736
   Revision: BA080001
   Coding: 102200
   VCID: 68F149119BDA0E0F0D-803C
   Component: IMMO          H04 0808
   Revision: 00H22000
   Part No SW: 5C0 035 684     HW: 5C0 035 684
   Component: MU-S-NS-US    H22 0245
   Serial number: VWZAZ2S0003962
   Coding: 026301023C00000001220001001808001F0100D400200105C6
   ROD: EV_MUStd4CTSAT_VW36.rod
   VCID: 62E55B3975E6645FD3-8036
   Subsystem 1 - Part No SW: 3G0 919 866 B    HW: -----------
   Component: NAR 2015/16  --- 0220
          U1101 00 [009] - Active
                    Reset counter: 181
                    Mileage: 56401 km
                    Date: 2020.04.02
                    Time: 02:46:43
                    Voltage terminal 30: 11.8 V
2565 - GPS Antenna
          B1054 13 [009] - Open Circuit
                    Reset counter: 181
                    Mileage: 56401 km
                    Date: 2020.04.02
                    Time: 02:46:43
7223 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 181
                    Mileage: 56401 km
                    Date: 2020.04.02
                    Time: 02:46:46
                    BAP-BAP_Function_ID: 02
   ROD: EV_UHVUMI.rod
                    Reset counter: 181
                    Mileage: 56401 km
                    Date: 2020.04.02
                    Time: 02:46:57
                    Reset counter: 181
                    Mileage: 56401 km
                    Date: 2020.04.02
                    Time: 02:46:56
End-------------------------(Elapsed Time: 02:16)--------------------------
rhill2901
C?ID=277377
so nobody knows? or anybody care to help?
iichel
Netherlands, eastern part
C?ID=284912
Are your BCMs and keys all 315MHz? New or used replacement BCM? Factory mode off?
golfi_vend
Tartu, Estonia
C?ID=195131
If You're missing power to pins of bcm, I'm not suprised it doesn't function 100%.
iichel
C?ID=284912
Agree, but these open circuits only apply to the lighting so central locking should be OK
rhill2901
C?ID=277377
I acquired this info from a vw polo website which was posted by those with european cars:
"BCMs with 434 MHz radio carrier frequency ends with the letters B, D, F, H, K, M, P, R, T. Pick up one of these if you are looking to upgrade. These BCMs are used in India, EU, South Africa and Russia."
So all others, I'm assuming is NAR. The bcm came from a NAR car, so its safe to assume its at 315Mhz, the keys are stamped 315Mhz also. Not sure about the 189 bcm, because it doesn't have a letter at the end of its part number, so I'm in the process of acquiring another 090E bcm. I haven't seen versions 90 or higher with anything other than E? Since the 2 bcm's behave exactly the same, I doubt the replacement bcm will help. These bcm's are used, so that is suspect.
Thanks for the help.
Spacewalker
C?ID=159607
7E0 937 090 E is for 433mhz
and you are wrong thinking "other index" is NAR
All other index can be India, or even discontinued item and ETKA not have them in history record
if Etka show - is 433 = 1000000% is 433
in a fact it exist in POLO, so never been in NAR , only "old land"
Also - if you want install BCM after 2018 (accoriding to ETKA) remote key 50/50 will work
from 2019 VW removed "remote match" via BCM
Remote AND KEY is match automatic while Keylearn to cluster - yes - REMOTE and KEY (new cluster with new coding in immo 000002)
for example VW T6 from 2018/2019
rhill2901
C?ID=277377
Thanks for that info Spacewalker. The two BCM's that I have tried are 7H0937090E and 7E0937189, which came from NAR cars? If I am wrong thinking these are correct, could you point me in the right direction? What part numbers could I use? 2014 vw jetta tdi with cluster part # 5C6920974F.
rhill2901
C?ID=277377
I looked on ETKA and its saying all 090's are 434Mhz? If thats true, it might be easier to change my keys to 434Mhz and adapt them to the cluster.
rhill2901
C?ID=277377
Ok, the replacement BCM did it. Could of been the BCM was bad or something up with the coding. There is some differences in the coding, but I can't find any documentation to tell me what they are. I know in my vcds tool it tells me to NOT change them. Odd...
one that didn't work:
one that worked
7B994B3808AB0B0000382600240884D500C2702E60004000300010002000
I modified the new (used one) BCM with the least amount of settings to make it work. There are differences in the byte string that I'm suspecting change the frequency of the internal radio channel for the remotes. Not sure which one though. I encountered a multifunction steering wheel problem and a turn signal problem with the coding of the new BCM with those bytes that are undocumented, so i kept copying the old settings until it worked. The settings that didn't seem to have an effect, I reverted back. One thing I noticed was byte 18, on the one that didn't work was 50 and on the one that worked was 70. VCDS says to not change this, so I didn't. No idea what this was for. I'm suspecting this was the problem.
Hope this helps someone who encounters something similar.
rhill2901
C?ID=277377
By all means, don't take my information as coming from an expert. I'm a novice at best. I enjoy modding though. With proper documentation, youtube and these forums, anything is possible, just have to be persistent.
rhill2901
C?ID=277377
I reinstalled the 2 bcms I had and coded them identical to the one that worked and it was a no go. I bought 2 bad bcm's off of ebay...
