Results 1 to 2 of 2
Thread: VW Passat 3c ABS and EPB lost coding
    Mar 2020
    Hi I have a 2006 Passat Variant 3C DK. The EPB control module was replaced with a used unit and needs coded. Unfortunately an auto scan was commenced prior to replacement and coding for ABS and EPB modules appear to be lost or at a default state. Any help in obtaining the correct coding for the ABS and EPB modules would be very much appreciated.
     Saturday,28,March,2020,15:19:38:42114
    VCDS Version: 19.6.2.2 (x64)
    VIN: WVWZZZ3CZ6E190111   License Plate: CP36595
    Mileage: 366230km-227564mi   Repair Order:
    Chassis Type: 3C (3C0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 53 56 62 69 72 7D
    VIN: WVWZZZ3CZ6E190111   Mileage: 366230km-227564miles
    08-Auto HVAC -- Status: Cannot be reached 1100
    53-Parking Brake -- Status: Malfunction 1010
    Address 01: Engine        Labels: 03G-906-018-BKP.clb
       Part No SW: 03G 906 018 CD    HW: 03G 906 018 CD
       Component: R4 2.0l PPD1.5 G    9970
       Revision: --H05---    Serial number: VWZCZ000000000
       Coding: 0000072
       Shop #: WSC 00024 204 84194
       VCID: 69D2302E40DD600712-803C
    18043 - Powertrain Data Bus
                P1635 - 009 - Missing Message from A/C Controller
                        Reset counter: 141
                        Mileage: 366232 km
                        Time: 04:05:18
                        RPM: 832 /min
                        Text:     24    Nm
                        Text:  0.0    %
                        Voltage: 12.66 V
                        Bin. Bits: 00010000
                        Bin. Bits: 00000000
    18061 - Please check DTC Memory of ABS Controller
                P1653 - 008 -
                        Fault Status: 11101000
                        Reset counter: 141
                        Mileage: 366232 km
                        Time: 04:05:18
                        RPM: 832 /min
                        Text:     24    Nm
                        Text:  0.0    %
                        Voltage: 13.90 V
                        Bin. Bits: 00000100
                        Text:    184    Nm
    Readiness: N/A
    Address 03: ABS Brakes        Labels:. 3C0-614-095-C2.clb
       Part No SW: 3C0 614 095 P    HW: 3C0 614 095 P
       Component: ESP 440 C2     H015 0003
       Revision:  H015       Serial number: 0667066037
       Coding: 0013602
       Shop #: WSC 06060 002 104857
       VCID: 2F669E36BEB9CE370C-807A
    00810 - Sensor 1/2 for Brake Pressure
    Address 08: Auto HVAC
    Address 09: Cent. Elect.        Labels:. 3C0-937-049-23-M.lbl
       Part No SW: 3C0 937 049 H    HW: 3C0 937 049 H
       Component: Bordnetz-SG     H37 1301
       Revision: 00H37000    Serial number: 00000005319265
       Coding: 08888F0700041A00000A00000F000000000959435C0000
       Shop #: WSC 05311 000 00000
       VCID: 2E588332B9B3C73F07-807A
       Subsystem 1 - Part No: 3C1 955 119   Labels: 1KX-955-119.CLB
       Component: Wischer VW461  012  0503
       Coding: 00063445
       Shop #: WSC 05311
                        Fault Status: 00101100
                        Reset counter: 173
                        Mileage: 365947 km
                        Voltage: 14.00 V
                        Reset counter: 172
                        Mileage: 366028 km
                        Voltage: 10.95 V
                        Reset counter: 141
                        Mileage: 366225 km
                        Voltage: 11.35 V
                        Reset counter: 174
                        Mileage: 366225 km
                        Voltage: 8.35 V
       Part No SW: 3C0 909 605 J    HW: 3C0 909 605 J
       Component: 04 AIRBAG VW8   029 2521
       Revision: 09029000    Serial number: 003A2P15SAUS
       Coding: 0012340
       VCID: 2D5A843EB4B5BC273E-8078
       Subsystem 1 - Serial number: 6332MSME0D287172
       Subsystem 2 - Serial number: 6342MSME0D28741A
       Subsystem 3 - Serial number: 6351HTS64IKA9AG2
       Subsystem 4 - Serial number: 6361HTS64IKAOJA3
    01578 - Airbag Deactivation Warning Lamp; Passenger Side (K145)
                009 - Open or Short to Ground - MIL ON
       Part No SW: 3C0 953 549 A    HW: 3C0 953 549 A
       Component: Lenks‰ulenmodul 005 0010
       Revision: 00005000    Serial number: 3C9953507C
       Coding: 0000014
       VCID: 2A508F22855BAB1FDB-807E
       Part No SW: 3C0 920 860 H    HW: 3C0 920 860 H
       Revision: X0014000    Serial number: 00000000000000
       Coding: 0007105
       Shop #: WSC 80093 222 69422
       VCID: 2756761696499677C4-8072
                        Reset counter: 179
                        Mileage: 366225 km
                        Time: 06:49:39
                        Reset counter: 179
                        Mileage: 366225 km
                        Time: 00:09:47
    Address 19: CAN Gateway        Labels:. 3C0-907-530-V1.clb
       Revision: 00007000    Serial number: 0700C062010F93
       Coding: 3DFDAC04C22002
       VCID: 2142680EF86D68478A-8074
                        Reset counter: 133
                        Mileage: 366225 km
                        Time: 01:26:55
                        Reset counter: 175
                        Mileage: 366225 km
                        Time: 06:49:40
       Part No SW: 3C0 959 433 K    HW: 3C0 959 433 K
       Component:    IMMO         038 0367
       Revision: 00038000    Serial number: VWZCZ000000000
       VCID: 32609742AD8BE3DF63-8066
       Subsystem 1 - Part No: 3C0 905 861 D
       Component:    ELV          024 0370
       3C0905861D     ELV          024 0370
    02823 - Requirements for Locking the Steering Column Lock not met
                        Fault Status: 00110000
                        Reset counter: 170
                        Mileage: 366180 km
                        Time: 14:47:02
    02827 - Wake-Up request via ESP
                        Reset counter: 170
                        Mileage: 366180 km
                        Time: 14:47:02
    02812 - Supply Voltage (Terminal 30) for Electronic Steering Column Lock
                        Reset counter: 173
                        Mileage: 366225 km
                        Time: 00:11:03
       Part No: 1K0 959 701 K
       Component: Tuer-SG         024 2365
       Coding: 0000181
       VCID: 3668AB5241E3FFFF4F-8062
       Part No: 1K1 909 144 K
       VCID: 336E92465291EAD768-8066
    02546 - Steering Limit Stop
                        Mileage: 6200 km
                        Temperature: 22.0∞C
                        Voltage: 14.00 V
                        Voltage: 13.80 V
       Component:    KSG PQ46 ELV 038 0455
       Coding: 0091020851030E763804941570084F0B603C80
    00950 - Central Locking Motor - tailgate (V53); UNLOCK
                        Fault Status: 00110111
                        Reset counter: 165
                        Mileage: 366028 km
                        Time: 16:48:44
    00896 - Trunk Lock Unit (F256)
                        Fault Status: 00111000
                        Reset counter: 173
                        Mileage: 366028 km
                        Time: 17:10:08
                        Fault Frequency: 14
                        Reset counter: 139
                        Mileage: 366225 km
                        Time: 01:26:55
       Part No: 1K0 959 702 K
       Coding: 0000180
       VCID: 3776A65646E906F754-8062
       Revision:   013
       Coding: 0000012
       Shop #: WSC 00087 204 62012
    02433 - Supply Voltage for Right Parking Brake Motor (V283)
                011 - Open Circuit - MIL ON
                        Fault Status: 11101011
                        Fault Frequency: 15
                        Reset counter: 137
                        Mileage: 366224 km
                        Time: 00:00:26
                        Voltage: 11.49 V
                        Count: 117
    02844 - Lamp for Automatic Parking Function
                        Fault Status: 00101001
                        Reset counter: 181
                        Mileage: 366224 km
                        Time: 00:03:16
                        Voltage: 11.28 V
                        Count: 64
                000 - - - MIL ON
                        Fault Status: 11100000
                        Fault Frequency: 15
                        Reset counter: 137
                        Mileage: 366224 km
                        Time: 00:00:28
                        Voltage: 11.90 V
                        Count: 170
                        Fault Status: 11101101
                        Reset counter: 141
                        Mileage: 306304 km
                        Time: 00:00:33
                        Voltage: 11.28 V
                        Count: 236
       Part No: 1K0 035 186 P
       Component: Radio BVX       016 0023
       Coding: 0040400
       Shop #: WSC 05314 000 00000
       Part No: 3C9 959 703
       Component: Tuer-SG         021 2505
       Coding: 0000144
       VCID: 70E45D4A630791CF55-8024
    Address 69: Trailer        Labels: 1K0-907-383-V1.clb
       Part No SW: 1K0 907 383     HW: 1K0 907 383
       Component: ANHAENGERELEKTR 001 0020
       VCID: 6AD04F2245DB6B1F1B-803E
       Part No: 3C9 959 704
       Coding: 0000144
       VCID: 71E2584E680D98C75A-8024
       Revision: 00800000    Serial number:
                014 - Defective
    End-------------------------(Elapsed Time: 02:08)--------------------------
    HQ
    Thank you for posting a full Auto-Scan!
    As per the VIN, ABS coding looks like it would be 0013581. EPB soft coding would be 0000011.
    However, the 02433 fault code in the EPB module isn't looking too good. You can try the Basic Settings 010 (Function Test) for the EPB and see if you can salvage it after a few tries.
    http://wiki.ross-tech.com/wiki/index..._Parking_Brake
    Best of luck.
    Jef
  3. Likes Jack@European_Parts, Uwe liked this post
