VW Passat 3c ABS and EPB lost coding
Cramer
C?ID=37486
Hi I have a 2006 Passat Variant 3C DK. The EPB control module was replaced with a used unit and needs coded. Unfortunately an auto scan was commenced prior to replacement and coding for ABS and EPB modules appear to be lost or at a default state. Any help in obtaining the correct coding for the ABS and EPB modules would be very much appreciated.
 Saturday,28,March,2020,15:19:38:42114
VCDS Version: 19.6.2.2 (x64)
VIN: WVWZZZ3CZ6E190111   License Plate: CP36595
Mileage: 366230km-227564mi   Repair Order:
Chassis Type: 3C (3C0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 53 56 62 69 72 7D
VIN: WVWZZZ3CZ6E190111   Mileage: 366230km-227564miles
08-Auto HVAC -- Status: Cannot be reached 1100
53-Parking Brake -- Status: Malfunction 1010
Address 01: Engine        Labels: 03G-906-018-BKP.clb
   Part No SW: 03G 906 018 CD    HW: 03G 906 018 CD
   Component: R4 2.0l PPD1.5 G    9970
   Revision: --H05---    Serial number: VWZCZ000000000
   Coding: 0000072
   Shop #: WSC 00024 204 84194
   VCID: 69D2302E40DD600712-803C
18043 - Powertrain Data Bus
            P1635 - 009 - Missing Message from A/C Controller
                    Reset counter: 141
                    Mileage: 366232 km
                    Time: 04:05:18
                    RPM: 832 /min
                    Text:     24    Nm
                    Text:  0.0    %
                    Voltage: 12.66 V
                    Bin. Bits: 00010000
                    Bin. Bits: 00000000
18061 - Please check DTC Memory of ABS Controller
            P1653 - 008 -
                    Fault Status: 11101000
                    Reset counter: 141
                    Mileage: 366232 km
                    Time: 04:05:18
                    RPM: 832 /min
                    Text:     24    Nm
                    Text:  0.0    %
                    Voltage: 13.90 V
                    Bin. Bits: 00000100
                    Text:    184    Nm
Readiness: N/A
Address 03: ABS Brakes        Labels:. 3C0-614-095-C2.clb
   Part No SW: 3C0 614 095 P    HW: 3C0 614 095 P
   Component: ESP 440 C2     H015 0003
   Revision:  H015       Serial number: 0667066037
   Coding: 0013602
   Shop #: WSC 06060 002 104857
   VCID: 2F669E36BEB9CE370C-807A
Address 08: Auto HVAC
   Part No SW: 3C0 937 049 H    HW: 3C0 937 049 H
   Component: Bordnetz-SG     H37 1301
   Revision: 00H37000    Serial number: 00000005319265
   Coding: 08888F0700041A00000A00000F000000000959435C0000
   Shop #: WSC 05311 000 00000
   VCID: 2E588332B9B3C73F07-807A
   Subsystem 1 - Part No: 3C1 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer VW461  012  0503
   Coding: 00063445
   Shop #: WSC 05311
                    Fault Status: 00101100
                    Reset counter: 173
                    Mileage: 365947 km
                    Voltage: 14.00 V
                    Reset counter: 172
                    Mileage: 366028 km
                    Voltage: 10.95 V
                    Reset counter: 141
                    Mileage: 366225 km
                    Voltage: 11.35 V
                    Reset counter: 174
                    Mileage: 366225 km
                    Voltage: 8.35 V
   Part No SW: 3C0 909 605 J    HW: 3C0 909 605 J
   Component: 04 AIRBAG VW8   029 2521
   Revision: 09029000    Serial number: 003A2P15SAUS
   Coding: 0012340
   VCID: 2D5A843EB4B5BC273E-8078
   Subsystem 1 - Serial number: 6332MSME0D287172
   Subsystem 2 - Serial number: 6342MSME0D28741A
   Subsystem 3 - Serial number: 6351HTS64IKA9AG2
   Subsystem 4 - Serial number: 6361HTS64IKAOJA3
01578 - Airbag Deactivation Warning Lamp; Passenger Side (K145)
            009 - Open or Short to Ground - MIL ON
   Part No SW: 3C0 953 549 A    HW: 3C0 953 549 A
   Component: Lenks‰ulenmodul 005 0010
   Revision: 00005000    Serial number: 3C9953507C
   Coding: 0000014
   VCID: 2A508F22855BAB1FDB-807E
   Part No SW: 3C0 920 860 H    HW: 3C0 920 860 H
   Component: KOMBIINSTRUMENT VD1 4240
   Revision: X0014000    Serial number: 00000000000000
   Coding: 0007105
   Shop #: WSC 80093 222 69422
   VCID: 2756761696499677C4-8072
                    Reset counter: 179
                    Mileage: 366225 km
                    Time: 06:49:39
                    Reset counter: 179
                    Mileage: 366225 km
                    Time: 00:09:47
Address 19: CAN Gateway        Labels:. 3C0-907-530-V1.clb
   Revision: 00007000    Serial number: 0700C062010F93
   Coding: 3DFDAC04C22002
   VCID: 2142680EF86D68478A-8074
                    Reset counter: 133
                    Mileage: 366225 km
                    Time: 01:26:55
                    Reset counter: 175
                    Mileage: 366225 km
                    Time: 06:49:40
   Part No SW: 3C0 959 433 K    HW: 3C0 959 433 K
   Component:    IMMO         038 0367
   Revision: 00038000    Serial number: VWZCZ000000000
   VCID: 32609742AD8BE3DF63-8066
   Subsystem 1 - Part No: 3C0 905 861 D
   Component:    ELV          024 0370
   3C0905861D     ELV          024 0370
02823 - Requirements for Locking the Steering Column Lock not met
                    Fault Status: 00110000
                    Reset counter: 170
                    Mileage: 366180 km
                    Time: 14:47:02
02827 - Wake-Up request via ESP
                    Reset counter: 170
                    Mileage: 366180 km
                    Time: 14:47:02
02812 - Supply Voltage (Terminal 30) for Electronic Steering Column Lock
                    Reset counter: 173
                    Mileage: 366225 km
                    Time: 00:11:03
   Part No: 1K0 959 701 K
   Component: Tuer-SG         024 2365
   Coding: 0000181
   VCID: 3668AB5241E3FFFF4F-8062
   Part No: 1K1 909 144 K
   Component: EPS_ZFLS Kl.5   D06 1701
   VCID: 336E92465291EAD768-8066
02546 - Steering Limit Stop
                    Mileage: 6200 km
                    Temperature: 22.0∞C
                    Voltage: 14.00 V
                    Voltage: 13.80 V
   Component:    KSG PQ46 ELV 038 0455
   Coding: 0091020851030E763804941570084F0B603C80
00950 - Central Locking Motor - tailgate (V53); UNLOCK
                    Fault Status: 00110111
                    Reset counter: 165
                    Mileage: 366028 km
                    Time: 16:48:44
00896 - Trunk Lock Unit (F256)
                    Fault Status: 00111000
                    Reset counter: 173
                    Mileage: 366028 km
                    Time: 17:10:08
                    Fault Frequency: 14
                    Reset counter: 139
                    Mileage: 366225 km
                    Time: 01:26:55
   Part No: 1K0 959 702 K
   Coding: 0000180
   VCID: 3776A65646E906F754-8062
   Revision:   013
   Coding: 0000012
   Shop #: WSC 00087 204 62012
02433 - Supply Voltage for Right Parking Brake Motor (V283)
            011 - Open Circuit - MIL ON
                    Fault Status: 11101011
                    Fault Frequency: 15
                    Reset counter: 137
                    Mileage: 366224 km
                    Time: 00:00:26
                    Voltage: 11.49 V
                    Count: 117
02844 - Lamp for Automatic Parking Function
                    Fault Status: 00101001
                    Fault Frequency: 8
                    Reset counter: 181
                    Mileage: 366224 km
                    Time: 00:03:16
                    Voltage: 11.28 V
                    Count: 64
            000 - - - MIL ON
                    Fault Status: 11100000
                    Fault Frequency: 15
                    Reset counter: 137
                    Mileage: 366224 km
                    Time: 00:00:28
                    Voltage: 11.90 V
                    Count: 170
01316 - ABS Control Module
                    Fault Status: 11101101
                    Reset counter: 141
                    Mileage: 306304 km
                    Time: 00:00:33
                    Voltage: 11.28 V
                    Count: 236
   Part No: 1K0 035 186 P
   Component: Radio BVX       016 0023
   Coding: 0040400
   Shop #: WSC 05314 000 00000
   Part No: 3C9 959 703
   Component: Tuer-SG         021 2505
   Coding: 0000144
   VCID: 70E45D4A630791CF55-8024
Address 69: Trailer        Labels: 1K0-907-383-V1.clb
   Part No SW: 1K0 907 383     HW: 1K0 907 383
   Component: ANHAENGERELEKTR 001 0020
   Coding: 0000001
   VCID: 6AD04F2245DB6B1F1B-803E
   Part No: 3C9 959 704
   Coding: 0000144
   VCID: 71E2584E680D98C75A-8024
            014 - Defective
End-------------------------(Elapsed Time: 02:08)--------------------------
Jef
HQ
Thank you for posting a full Auto-Scan! :thumbs:
As per the VIN, ABS coding looks like it would be 0013581. EPB soft coding would be 0000011.
However, the 02433 fault code in the EPB module isn't looking too good. You can try the Basic Settings 010 (Function Test) for the EPB and see if you can salvage it after a few tries.
http://wiki.ross-tech.com/wiki/index.php/VW_Passat_(3C)_Parking_Brake
Best of luck.
