Results 1 to 9 of 9
Thread: 77 Telephone Reset User Profiles
    Mar 2020
    Hi on a VW Golf Mk6 I cannot seem to perform the Adaption to reset the user profiles for the Bluetooth. I think it needs the security code, but I dont know what it is. The little yellow bubbles not popping up like normal. Using 19.6 HexNet. There are 4 profiles and we cant add another phone and it wont let us delete the phones. Any ideas welcome.
    Hi and welcome.
    Please post an Auto-Scan so people can see exactly how the car is equipped and configured. I'm pretty sure not all Mk.6 Golfs have identical Bluetooth setups.
    Jun 2014
    You have to erase the profiles via adaption-channel... Look there... change the value from "not erased" to "erased" and click save/do-it. Took me some time to figure this some time ago!
    Golf VII, 1.6TDI BM Ed. 40 - 110 PK
  4. Likes Dana liked this post
    Mar 2020
    Quote Originally Posted by Mari View Post
    I tried that seems to not work, I assumed I needed the security code first for it to accept.
    Mar 2020
    Hi and welcome.
    Here you go:
    Monday,23,March,2020,17:29:19:16219
    VCDS Version: 19.6.2.2 (x64)  HEX-NET CB: 0.4508.4
    VIN: <excluded>  License Plate: <excluded>
    Mileage: 156680km-97356mi   Repair Order:
    Chassis Type: 1K-VW36 (7N0)
    Scan: 01 03 08 09 10 15 16 17 19 25 2E 42 44 46 52 56 62 72 77
    VIN: WVWZZZ1KZBW204672   Mileage: 156680km-97356miles
    77-Telephone -- Status: Sporadic communication error 1000
    Address 01: Engine (J623-CAYC)       Labels:. 03L-906-023-CAY.clb
       Part No SW: 03L 997 557 P    HW: 03L 907 425 C
       Component: R4 1.6l TDI   H43 9980
       Revision: --H43---    Serial number: 00000000000000
       Coding: 08114014032500080000
       ASAM Dataset: EV_ECM16TDI02103L997557P 003002
       ROD: EV_ECM16TDI02103L997557A.rod
       VCID: C9DAC2626886D907B2-809C
    9873 - Exhaust Gas Recirculation Cooling Valve Control Circuit
              P2427 00 [032] - Short to Plus
                        Fault Frequency: 23
                        Mileage: 156609 km
                        Date: 2020.03.22
                        Time: 12:43:48
                        Engine speed: 1460.25 /min
                        Normed load value: 53.7 %
                        Vehicle speed: 17 km/h
                        Coolant temperature: 78 C
                        Intake air temperature: 20 C
                        Voltage terminal 30: 13.892 V
                        Sensor for temp after charge air cooler: raw value-TBA_MES: 20 C
                        Charge air pressure: actual value-MAP_MMV: 1220.55 hPa
                        Air mass: actual value:: 23.15 g/s
                        Air mass proportion filtered-FAC_MAF_CYL_KGH_RATIO_FIL: 0.96594
                        Sensor for engine block temperature: raw value-Coolant temperature: 78 C
    6116 - Function Restriction due to Faults in Other Modules
              U1113 00 [032] - -
                        Mileage: 156255 km
                        Date: 2020.03.09
                        Time: 07:28:25
                        Engine speed: 1205.50 /min
                        Vehicle speed: 47 km/h
                        Coolant temperature: 44 C
                        Intake air temperature: 8 C
                        Voltage terminal 30: 14.344 V
                        Unlearning counter according OBD: 38
                        Accelerator position: normalized-Accelerator position: 0.00 %
                        Cruise Control System (CCS): switch position-STATE_CRU_SWI_POS: 00000010
       Part No SW: 1K0 907 379 BE    HW: 1K0 907 379 BE
       Component: ESP MK60EC1   H31 0108
       Revision: 00H31001
       Coding: 133B200D092200FEC81104EB901B0081310000
       VCID: F6A0799E41F8E6FF0F-80A2
       Part No SW: 7N0 907 426 K    HW: 7N0 907 426 K
       Component: AC Manuell    H17 0202
       Revision: 00012001
       Coding: 0000000002
       ROD: EV_ClimaBasis_VW36.rod
       VCID: BC34ABB637547CAF39-80E8
    9477141 - Position Sensor for Air Distribution Flap Motor
              B109C 15 [008] - Open or Short to Plus
                        Reset counter: 84
                        Mileage: 156562 km
                        Date: 2020.03.22
                        Time: 10:41:48
              B10AB F0 [009] - Too Low
                        Reset counter: 171
                        Mileage: 119397 km
                        Date: 2017.02.02
                        Time: 14:21:47
       Part No SW: 1K0 937 084 D    HW: 1K0 937 084 D
       Component: BCM PQ35  B   103 0615
       Revision: 00103 AD
       Coding: 48180A3A8825F1C040080080340000E443510088536D8160648000200040
       VCID: AF2E8CFAFE2297378C-80FA
       Subsystem 1 - Part No: 5K2 955 119
       Component: Wischer 03011  26  0512
       Coding: 009795
       Component: RLS 150111 05  54  0403
       Coding: 0330AD
       Component: LIN BACKUP HO  H11 9005
                        Fault Status: 00101010
                        Reset counter: 84
                        Mileage: 148155 km
                        Date: 2013.10.26
                        Time: 12:18:48
                        Voltage: 14.00 V
                            Term 50 Off
                        Reset counter: 60
                        Mileage: 149469 km
                        Date: 2013.12.20
                        Time: 16:37:13
                            Term 15 Off
                        Voltage: 12.05 V
                            Term 50 Off
                        Reset counter: 84
                        Mileage: 156615 km
                        Date: 2014.08.13
                        Time: 17:02:30
                        Voltage: 11.55 V
                            Term 50 Off
       Part No SW: 5K0 919 475 E    HW: 5K0 919 475 E
       Component: PARKHILFE 8K  H01 0012
       Revision: --------    Serial number: 12591035647309
       Coding: 108001
       VCID: B83CB7A60B6C508FDD-80EC
       Part No SW: 5C0 959 655 B    HW: 5C0 959 655 B
       Serial number: 003G5R02G2VG
       Coding: 00003948
       ROD: EV_AirbaVW10SMEVW360.rod
       VCID: B12A8A82E01681C79A-80E4
       Serial number: 3572MSME5F2A315AZZZ1
       Serial number: 3582MSME2372355AZZZV
       Serial number: 3512QSME16036E63ZZZU
       Serial number: 3522QSME06087D06ZZZW
       Part No SW: 5K0 953 507 BC    HW: 5K0 953 549 E
       Revision: --------    Serial number:  90422KAC000WW
       Coding: 1082140000
       ROD: EV_SMLSNGKUDS_A05.rod
       VCID: F2A8458E2590FADF23-80A6
       Serial number: 50000000000000282548
       Coding: E20000
    229139 - Turn Signal Stalk; Switch for Cruise Control
              B1144 F1 [008] - Mechanical Malfunction
                        Reset counter: 82
                        Mileage: 156245 km
                        Date: 2020.03.07
                        Time: 18:48:44
    365080 - Controls in Steering Wheel
              U108E 00 [008] - No Communications
                        Fault Frequency: 208
                        Reset counter: 84
                        Mileage: 118962 km
                        Date: 2017.01.17
                        Time: 07:58:43
    530190 - Local Databus
              U1030 00 [008] - Electrical Malfunction
                        Reset counter: 84
                        Mileage: 156540 km
                        Date: 2020.03.21
                        Time: 23:34:55
       Part No SW: 5K0 920 971 A    HW: 5K0 920 971 A
       Component: KOMBI         H20 0420
       Coding: 470B00
       VCID: AD1296F2FC2EE527BE-80F8
       Part No SW: 7N0 907 530 C    HW: 1K0 907 951
       Component: J533  Gateway H37 0614
       Revision:   H37       Serial number: 180111F2001228
       Coding: 350003
       VCID: B02C8F86E31C88CF95-80E4
                        Reset counter: 84
                        Mileage: 118947 km
                        Date: 2011.06.09
                        Time: 09:16:29
       Component: IMMO          H20 0420
       VCID: EA985DEE0D40321F9B-80BE
       Part No SW: 5N0 035 342 D    HW: 5N0 035 342 D
       Component: SG EXT.PLAYER H13 0150
       Revision: A1001003    Serial number: 7669253307
       VCID: A81C67E6DBCCC00F4D-80FC
       Component: Tuer-SG         009 2120
       Coding: 0000692
       VCID: B12A8A82281681C79A-80E4
       Part No: 1K0 909 144 M
       Component: EPS_ZFLS Kl. 69     3201
       Revision: 00H20000
       VCID: B4248396D704B4EFF1-80E0
                000 - - - MIL ON
                        Fault Status: 11100000
                        Battery Volts: 12.1 V
                            PD
                        Temperature: 30.0C
                        Count: 2
                        Steering Angle: 0.00
                        Count: 1
                            SteerAng n.Init
       Part No SW: 5K0 959 702 C    HW: 5K0 959 702 C
       Coding: 0000948
       VCID: B326808AD20AB3D7E8-80E6
       Part No SW: 3C8 035 195 A    HW: 3C8 035 195 A
       Component: Radio RCD510  041 0166
       Revision: 00000001    Serial number: VWZ1Z3K9800922
       Coding: 0100040004
       VCID: A60069DED1D8D67F7F-80F2
                        Reset counter: 84
                        Mileage: 118947 km
                        Date: 2011.06.09
                        Time: 09:16:29
       Coding: 0000144
       Shop #: WSC 01357 011 1012552
       VCID: B522BE92DC7EADE7C6-80E0
       Coding: 0000144
       VCID: B620B99EC178A6FFCF-80E2
       Part No SW: 5K0 035 730 B    HW: 5K0 035 730 B
       Component: TELEFON       H09 1020
       Revision: 1B001001    Serial number: 00007669235319
       Coding: 0A01000000010101
       ASAM Dataset: UHVNA A01009
       ROD: UHVNA.rod
       VCID: A40473D6AFE4246F61-80F0
  7. Likes Dana liked this post
    I don't see anything obvious there, except the Sporadic/Intermittent Communications faults with the Telephone module that the Gateway is reporting. I wonder if that Telephone module is just plain wonky?
  9. Likes Dana liked this post
  10. #7
    Mar 2020
    Most of the faults cleared out, so I assume I don’t need the code to perform the erase adaption?
  11. Likes Dana liked this post
  12. #8
    United States
    I don't believe it needs a SA code but there were issues with some of the NAR market 9W7 units and a VW TSB suggested rebooting it so that may not hurt if it is wonky.
    Edit, the ADP channel appears to be [*IDE00764*] User profiles but I haven't reset one of those for a while.
  13. Likes Uwe liked this post
  14. #9
    Mar 2020
    Thanks will try that out. That is the code I was trying. Will try to write down the error next it’s a little odd. Something about sub channel not responding or something.
  15. Likes Dana liked this post
