Results 1 to 6 of 6
Thread: VW T6 stop start error message in dash
    Mar 2020
    Scotland
    Hi looking for help on this van new to VCDS
    Getting message on dash stop start error once its started and ready to move. it also stays in vehicle status when you scroll through menu.
    I replaced the auxiliary belt as it was squeaking when weather damp in mornings. Battery also replaced as it was testing low I've managed to get it coded or at least I think Ive done it correctly, as the radio unit isn't showing battery coding message when I try to use bluetooth audio. Now the van had a Varta battery in it with BEM code, but was coded as a JCI ? Ive fitted a larger battery but changed the AH and the last digit of the serial number. I had changed the whole lot as it was a Yuasa I fitted 80AH 800A YBX9115 it seemed to work but after a bit of googling I chickened out and changed it back to original but with the info altered. The van is also fitted with a westfalia towbar wiring kit and I've got that to now put fog light off when connected, different issue though. I found that it has not ok Generator information when looking in VCDS group 016 in measuring blocks. The status is ok on electrical, mechanical and thermal on group 015. not sure if this helps. You can see at address 61 that i changed battery back.
    Three faults showing address 61 Battery Regulation 02252 004 no signal-communication
    01 Engine 25796 u0140 00 (047) body control module central electric no communication
    09 Central Electrics 00446 002 Function limitation due to under voltage
    Is a wiring diagram for this vehicle a long shot as they don't even give you a list of fuses for these. It just tells you to contact your dealer as specifications are constantly changing. Insert curse words here
    Any help greatly appreciated and excuse my crap grammar and punctuation please.
    Friday,20,March,2020,16:21:32:47700
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64 VCDS Version: 19.6.2.2 (x64) HEX-V2 CB: 0.4508.4
    VIN: WV1ZZZ7HZHH008798   License Plate: RV
    Mileage: 59900km-37220mi
    Repair Order: 20.3.2020 no2
    Chassis Type: 7H-VN75 (7E0)
    Scan: 01 03 04 08 09 10 15 17 19 25 5F 61 69 0B
    VIN: WV1ZZZ7HZHH008798 Mileage: 59900km-37220miles
    01-Engine -- Status: Malfunction 0010 03-ABS Brakes -- Status: OK 0000 04-Steering Angle -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: Malfunction 0010 10-Park/Steer Assist -- Status: OK 0000 15-Airbags -- Status: OK 0000 17-Instruments -- Status: OK 0000
    69-Trailer -- Status: OK 0000 -------------------------------------------------------------------- -----------
    Address 01: Engine (2D2D2-CXHA) Labels:. 04L-907-309-V2.clb Part No SW: 04L 906 056 KL HW: 04L 907 445
    Component: R4 2.0l TDI H02 3802
    Revision: 23002001
    Coding: 00194014432401090000
    Shop #: WSC 02737 790 50316
    ASAM Dataset: EV_ECM20TDI03004L906056KL 004003 ROD: EV_ECM20TDI03004L906056KA.rod
    VCID: 015F82C36182AF4FC6B-8054
    25796 - Body Control Module (Central Electric)
    U0140 00 [047] - No Communications Confirmed - Tested Since Memory Clear
    Fault Priority: 2 Fault Frequency: 5 Mileage: 59903 km Date: 2042.01.30 Time: 15:02:52
    Readiness: N/A
    Coolant temperature: 50 ∞C
    Intake air temperature: 16 ∞C
    Ambient air pressure: 1030 mbar
    Voltage terminal 30: 12.031 V
    Unlearning counter according OBD: 40 Accelerator pedal travel: raw value: 0.00 % CAN status - engine control module: 0
    Cruise Control System (CCS): status: passive selected gear: Shifting process active
    Address 03: ABS Brakes (J104) Labels: 7E0-907-37x-MK100ESC.clb PartNoSW:7E0907379P HW:7E0907379M
    Component: ESC H06 0133
    Revision: 00000000 Serial number: 41396000000770
    Coding: 557E409825628486AA7C027FA48A21E6790000 Shop #: WSC 02739 790 50316
    ASAM Dataset: EV_Brake1ESCCONTIVN75XGP2 011001 ROD: EV_Brake1ESCCONTIVN75XGP2_011.rod
    VCID: 3FDB443B57F619BFF0F-806A No fault code found.
    Address 04: Steering Angle (G085) Labels:* 6R0-959-654.clb Part No SW: 6R0 959 654 HW: 6R0 959 654
    Component: LENKW.SENSOR H07 0070
    Serial number: 28051613470337
    Coding: 01
    ASAM Dataset: EV_LWSKLOVW25X 005001 ROD: EV_LWSKLOVW25X.rod
    VCID: 7EA5F93F107CD0B7BB9-802A
    Address 08: Auto HVAC (J301) Labels:| 7E5-907-047.clb Part No SW: 7E0 907 047 AK HW: 7E0 907 047 AK Component: Climatic-T5 H22 0708
    Revision: 00001002
    Coding: 0000000003
    ASAM Dataset: EV_ClimaticT5 A01003 ROD: EV_ClimaT5Basis.rod
    VCID: 73B3D80B2B3E8DDFC47-8026
    Address 09: Cent. Elect. (J519) Labels:. 7E0-937-BCM-V1.clb Part No SW: 7E0 937 090 B HW: 7E0 937 090
    Component: BCM PQ25 Max4 H81 0744
    Revision: B9081001 Serial number: 0982 154160120
       Coding:
    A0A4303A0A61343193284F746CEB8E740F84708F60CC6D60320400220840
    Shop #: WSC 02737 534 1920978 VCID: 2A0D056FBCF48C17B71-807E
    Subsystem 1 - Part No: 5K7 955 559 C Labels: 5K7-955-559.CLB Component: RLS 170516 04 42 0106
    Coding: 0228EE
    Subsystem 2 - Part No SW: 7E0 959 801 P Component: J386__TSG_FT 003 0653 Serial number: KU0KU027051661486410 Coding: 1400B0
    Subsystem 3 - Part No SW: 7E0 959 802 P Component: J387__TSG_BT 003 0653 Serial number: KU0KU027051661485785 Coding: 0400A0
    Subsystem 4 - Part No: 7E1 951 172 Component: DWA-Sensor 00 001 0104 Coding: 000000
    Subsystem 5 - Part No: 1K0 951 605 C Component: LIN BACKUP HO H05 1501 Coding: 000000
    Subsystem 6 - Part No: 7E1 951 172 Component: DWA-Sensor 00 001 0104 Coding: 000000
    Subsystem 7 - Part No SW: 7E0 959 442 Labels: 3C8-959-537.CLB
    Component: E221__MFL-DC1 H02 0103 Serial number: 29160000973990076212 Coding: B0FFFF
    HW: 7E0 959 801 P
    HW: 7E0 959 802 P
    002 - Lower Limit Exceeded - Intermittent Freeze Frame:
                        Reset counter: 220
                        Mileage: 59903 km
    HW: 7E0 959 442
    Time Indication: 0 Date: 2020.03.20 Time: 15:10:27
    Address 10: Park/Steer Assist (J446) Labels:| 7E0-919-475.clb Part No SW: 7E0 919 475 T HW: 1Q0 919 475
    Component: PARKHILFE 4K H03 0212
    Revision: -------- Serial number: 32961609701442
    Coding: 10800A
    ASAM Dataset: EV_VW75XParkAssis4K 001013 ROD: EV_VW75XParkAssis4K_001.rod
    VCID: 43D348CB3B1E7D5F947-8016
    Address 15: Airbags (J234) Labels:| 5K0-959-655.clb PartNoSW:7E0959655G HW:7E0959655G Component: VW10Airbag021 H08 0018
    Revision: -------- Serial number: 003V30010R2O Coding: 000000000000000000000000000000003231
    Shop #: WSC 02734 790 50316
    ASAM Dataset: EV_AirbaVW10BPAVW12X 001028 ROD: EV_AirbaVW10BPAVN750_VW12.rod
    VCID: 3A2D352F4CD43C97C71-806E
    Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb- SRI1
    PartNoSW:7E0920970S HW:7E0920970S Component: KOMBI H03 1104
    Coding: 440B010300
    ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05733 ROD: EV_Kombi_UDS_VDD_RM09_005_VW25.rod VCID: 3A2D352F4CD43C97C71-806E
    Address 19: CAN Gateway (J533) Labels:. 7E0-909-901.clb Part No SW: 7E0 909 901 HW: 7E0 937 090
    Component: GW-K-CAN TP20 H81 0744
    Revision: B9081001
    Coding: 042305
    Shop #: WSC 02737 534 1920978 VCID: 6889BF6762787E07615-803C
    Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb Part No SW: 5K0 953 234 HW: 5K0 953 234
    Component: IMMO H03 1104
    ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03710 ROD: EV_Immo_UDS_VDD_RM09.rod
    VCID: 6A8DC56F7CF44C17771-803E
    Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB- ENT2.clb
    PartNoSW:1K8035150L HW:1K8035150L
    Component: MU-E-D-ER 055 7067
    Serial number: 29041600010715
    Coding: 065700003C00000041111101008000001F0000C60000010001 Shop #: WSC 02737 790 50316
    ASAM Dataset: EV_MUEnt4CGen2LGE 001032 ROD: EV_MUEnt4CGen2LGE_VW12.rod
    VCID: 2E05097F809CE0376B9-807A
    Address 61: Battery Regul. (J840) Labels:. 1K0-907-534.clb Part No SW: 7E0 907 534 HW: 7E0 937 090
    Component: Batt.regelung H81 0744
     Coding: 030B1A73
    Shop #: WSC 02739 790 00000 VCID: 6889BF6762787E07615-803C
    Subsystem 1 - Part No SW: 7E0 915 181 K Component: J367-BDMConti H03 1050 Serial number: 75410903001605191120
    1 Fault Found: 02252 - Generator
    004 - No Signal/Communication Freeze Frame:
    HW: 7E0 915 181 K
    Fault Priority: 2 Fault Frequency: 1 Reset counter: 180 Mileage: 59903 km Time Indication: 0 Date: 2020.03.20 Time: 15:03:34
    Address 69: Trailer (J345) Labels:. 1K0-907-383-V2.clb PartNoSW:1K0907383F HW:1K0907383F
    Component: Anhaenger H12 0100
    Revision: 3A001001 Serial number: 00000474539085 Coding: 4100000100000000
    Shop #: WSC 09550 758 180955 VCID: 303917079A28F6C7795-8064
    End----------(Elapsed Time: 01:49, VBatt start/end: 12.6V/ 12.3V)-----------
    Address 61,7E0 907 534 ,channel 4,adapted from,080 YBX YG00255241,to,080 JCB 1111111112, -------------------------------------------------------------------- ------------ -------------------------------------------------------------------- ------------
    Address 61: DTCs cleared
    Hi and welcome.
    The scan you posted is quite a formatting mess. It seems to be missing most of the white space and newlines. I'm not sure how you achieved this.
    Can you please look in your Scans sub-folder for the copy archived there, open it with Notepad, and paste the contents here so it's legible?
    Thanks!
  3. Likes PetrolDave liked this post
    Mar 2020
    Scotland
    Mileage: 59900km-37220mi   Repair Order: 20.3.2020 no2
       Revision: 23002001
                        Mileage: 59903 km
                        Date: 2042.01.30
                        Time: 15:02:52
                        Coolant temperature: 50 C
                        Intake air temperature: 16 C
    Readiness: N/A
       Part No SW: 7E0 907 379 P    HW: 7E0 907 379 M
       Coding: 01
       Revision: 00001002
       Coding: 0000000003
       Coding: A0A4303A0A61343193284F746CEB8E740F84708F60CC6D60320400220840
       Coding: 0228EE
       Subsystem 2 - Part No SW: 7E0 959 801 P    HW: 7E0 959 801 P
       Coding: 1400B0
       Subsystem 3 - Part No SW: 7E0 959 802 P    HW: 7E0 959 802 P
       Coding: 0400A0
       Subsystem 7 - Part No SW: 7E0 959 442     HW: 7E0 959 442   Labels: 3C8-959-537.CLB
       Coding: B0FFFF
                        Reset counter: 220
                        Mileage: 59903 km
                        Date: 2020.03.20
                        Time: 15:10:27
       Coding: 10800A
       Part No SW: 7E0 959 655 G    HW: 7E0 959 655 G
       Part No SW: 7E0 920 970 S    HW: 7E0 920 970 S
       Coding: 440B010300
       Revision: B9081001
       Coding: 042305
    Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-ENT2.clb
       Part No SW: 1K8 035 150 L    HW: 1K8 035 150 L
       Coding: 030B1A73
       Subsystem 1 - Part No SW: 7E0 915 181 K    HW: 7E0 915 181 K
    02252 - Generator
                        Reset counter: 180
                        Mileage: 59903 km
                        Date: 2020.03.20
                        Time: 15:03:34
    End----------(Elapsed Time: 01:49, VBatt start/end: 12.6V/12.3V)-----------
    Mar 2020
    Scotland
    Erm is this better don't know how it ended up this large, first one was emailed to me then posted via mac book. This is via the laptop its installed on but the note pad didn't allow me to just copy and paste. ended up selecting all then doing it that way. I think I need to brush up on my computer skills.
    That scan looks good (as in legible).
    I would purse the "Generator - No Signal/Communication" fault in the battery regulation module first. There should be a wire that runs between this module and the alternator. Check it for continuity.
    Mar 2020
    Scotland
    Looked at wiring, green yellow wire runs from battery module to alternator as above. No continuity further investigation and loom diagram shows it runs through the grey connector, in the abortion of a rats nest of wiring under battery tray. Abortion being that it's a nightmare to get to the connector but doable. Continuity from module to grey plug pin 1, no continuity pin 1 other side to alternator. Unwrapped loom and the conduit has destroyed wire in about a 6" length rubbed through, corroded etc. wiring now repaired and covered before conduit fitted back on hopefully it will last longer than before. Pretty poor on VW part as not the first van I've dealt with issues on wiring corroding through. Just was easier as it was older, however back to this one. I've cleared codes but had to do it through the individual controllers, as it wouldn't clear them the auto scan area. It's all good so far, everything behaving as it should no codes so far. I will rescan it soon just to check though. Thanks Uwe
  8. Likes Uwe, PetrolDave liked this post
