Results 1 to 5 of 5
Thread: VW caddy 2016 DPF regeneration
    Jan 2020
    Israel
    Hello All
    I hope everyone is well and in good health
    I encountered this problem several times
    when i try to do DPF regeneration it say *aborted for security reasons*
    here an autoscan for one of the cars
    Sunday,29,March,2020,17:42:47:04619
    VIN: WV2ZZZ2KZGX008749   License Plate:
    Chassis Type: 2K-VN35 (7N0)
    Scan: 01 03 08 09 10 13 15 16 17 19 25 42 44 46 4C 52 5F 61
    VIN: WV2ZZZ2KZGX008749   Mileage: 108950km-67698miles
    Address 01: Engine (J623-CUUD)       Labels:. 04L-907-309-V1.clb
       Part No SW: 04L 906 016 CA    HW: 04L 907 309 K
       Component: R4 2,0L EDC   H20 1850
       Revision: 8AH20---
       Coding: 01110012042415090000
       Shop #: WSC 06356 002 1048576
       ASAM Dataset: EV_ECM20TDI01104L906016CA 001005
       ROD: EV_ECM20TDI01104L906016BJ_001_VW36.rod
       VCID: 6A8DC493FCFEC9E7771-803E
    5188 - Diesel Particle Filter
              P2463 00 [175] - Excessive Soot Accumulation
                        Mileage: 108957 km
                        Date: 2020.03.29
                        Time: 02:44:48
                        Engine speed: 829.00 /min
                        Normed load value: 18.4 %
                        Coolant temperature: 98 C
                        Intake air temperature: 63 C
                        Voltage terminal 30: 12.820 V
                        Counter for regeneration time of diesel particle filter: 0.00 s
                        Particle filter: kilometers since last regeneration: 533254 m
                        Particle filter: soot mass measured: 0.36 g
                        Particle filter: soot mass calculated: 42.23 g
                        Particl.filt.: differential pressur.sensor 1 bank 1: dyn.offset: 0 hPa
    18875 - Cruise Control Switch (E45)
              P0568 00 [039] - Implausible Signal
                        Mileage: 108957 km
                        Date: 2020.03.29
                        Time: 02:44:48
                        Engine speed: 829.50 /min
                        Normed load value: 20.0 %
                        Voltage terminal 30: 12.800 V
                        ACC variants-Bits 0-7: 0
                        Cruise control switch actuation-Bits 0-7: 0
                        Cruise control switch actuation-Bits 0-7: 32
                        ACC variants (coding)-Bits 0-7: 1
                        Acceleration: 0.000 m/s
    Readiness: 1 1 0 0 1
    Address 03: ABS Brakes (J104)       Labels: 7E0-907-37x-MK100ESC.clb
       Part No SW: 7E0 907 379 P    HW: 7E0 907 379 M
       Component: ESC           H05 0132
       Revision: 00000000    Serial number: 41575000001232
       Coding: 1479409BB362A486287C027ACD8B25D378F100
       Shop #: WSC 35110 790 50316
       ROD: EV_Brake1ESCCONTIVN75XGP2_011.rod
       VCID: 3FDB45C7D7FC9C4FF0F-806A
    0397 - TPMS Warning
              C102D F0 [137] - Pressure Loss
                        Reset counter: 162
                        Mileage: 108957 km
                        Date: 2020.03.29
                        Time: 02:20:50
       Part No SW: 1K8 907 426 AB    HW: 1K8 907 426 AB
       Component: AC Manuell    H20 0808
       Revision: 00001002
       Coding: 0010004003
       VCID: 73B3D9F7AB34082FC47-8026
       Part No SW: 5K0 937 086 AA    HW: 5K0 937 086 AA
       Component: BCM PQ35 M+   122 0183
       Revision: BD122001
       Coding: 611A0A3A8025086F088800829400016403D10008426F8120648087000041
       Shop #: WSC 35110 377 08192
       VCID: 73B3D9F7ABB4082FC47-8026
       Subsystem 1 - Part No: 1T1 955 119 A  Labels: 1KX-955-119.CLB
       Component: Wischer 05061  27  0512
       Coding: 009795
       Subsystem 2 - Part No: 5K7 955 559 B  Labels: 5K7-955-559.CLB
       Component: RLS 140615 03  37  0059
       Coding: 0228DD
                010 - Open or Short to Plus
                        Fault Status: 01101010
                        Reset counter: 162
                        Mileage: 108957 km
                        Date: 2020.03.29
                        Time: 02:32:58
                        Voltage: 12.85 V
    02738 - Bulb for Tail/Brake Light; Left
                        Reset counter: 162
                        Mileage: 108957 km
                        Date: 2020.03.29
                        Time: 02:33:40
                        Voltage: 12.75 V
    02739 - Bulb for Tail/Brake Light; Right
                        Reset counter: 162
                        Mileage: 108957 km
                        Date: 2020.03.29
                        Time: 02:33:40
                        Voltage: 12.90 V
       Part No SW: 1K8 919 465     HW: 5Q0 919 283
       Component: PARKHILFE 4K  H10 0479
       Revision: --------    Serial number: 39291516114077
       Coding: 0001050001
       ASAM Dataset: EV_EPHVA14VW364GP00 001006
       ROD: EV_EPHVA14VW364GP00_VW36.rod
       VCID: 76B5E0E3B8461D07E39-8022
    Address 13: Auto Dist. Reg (J428)       Labels:| 7N0-907-572.clb
       Part No SW: 7N0 907 572 A    HW: 7N0 907 572
       Component: ACC Bosch PQx H03 0111
       Serial number: 24061577090763
       Coding: 00000000FE0339
       ASAM Dataset: EV_ACCBEGVW361 001004
       ROD: EV_ACCBEGVW361_VW32.rod
       VCID: 34311AEBEEBA4F171DD-8060
    1380 - Internal Fault
              B200F F0 [008] - Unknown Error Elaboration
              [FAULT_ADC_VZ_BELOW_RADAR_OPERATION_LIMIT]
                        Reset counter: 194
                        Mileage: 108872 km
                        Date: 2020.03.26
                        Time: 21:52:44
                        Control Module temperature: 35 C
                        Voltage terminal 15: 7.2 V
                        Vehicle speed: 0.00 m/s
                        Acceleration: 0.00 m/s
    1071 - Databus
              [FAULT_CIS_AXV_INVALID]
                        Reset counter: 175
                        Mileage: 108563 km
                        Date: 2020.03.20
                        Time: 22:41:28
                        Control Module temperature: 27 C
                        Voltage terminal 15: 12.2 V
    1058 - Databus
              [FAULT_CIS_ECD_NOTAVAILABLE]
                        Reset counter: 175
                        Mileage: 108343 km
                        Date: 2020.03.18
                        Time: 00:14:18
                        Control Module temperature: 20 C
                        Voltage terminal 15: 12.3 V
    1059 - Databus
              [FAULT_CIS_ESP_FAIL]
                        Reset counter: 165
                        Mileage: 108343 km
                        Date: 2020.03.18
                        Time: 00:14:18
    1097 - Databus
              [FAULT_CIS_STPL_FAIL]
                        Fault Frequency: 23
                        Reset counter: 162
                        Mileage: 49438 km
                        Date: 2018.05.12
                        Time: 11:45:23
                        Control Module temperature: 28 C
       Part No SW: 2K5 959 655 A    HW: 2K5 959 655 A
       Component: VW10Airbag00G 008 0016
       Revision: --------    Serial number: 003QX0003WKV
       Coding: 000000000000000000000000000000003047
       ASAM Dataset: EV_AirbaVW10BPAVW12X 001028
       VCID: 3A2D34D3CCDEB967C71-806E
       Serial number: 3497ARB405P3B2JMKA4O
       Serial number: 3507ARB405N3B2JMRH6U
       Serial number: 3517ARB405P3B2JM7A11
       Serial number: 3527ARB405N3B2JMFP9V
       Part No SW: 5K0 953 521 GE    HW: 5K0 953 569 BF
       Component: LENKS.MODUL   018 0230
       Revision: FF010042    Serial number: 20150615101023
       Coding: 1082460008
       ROD: EV_SMLSNGVOLWSR8C.rod
       VCID: 75B7E7EFA540161FEA3-8020
       Subsystem 1 - Part No SW: 2K0 959 442     HW: 2K0 959 442   Labels: 3C8-959-537.CLB
       Component: E221__MFL-TAT  H04 0020
       Serial number: 1521515074201490BA1B
       Coding: 280000
       Part No SW: 2K5 920 876 A    HW: 2K5 920 876 A
       Component: KOMBI         H04 1009
       Coding: 180A011200
       VCID: 333319F7EBB4482F047-8066
       Part No SW: 7N0 907 530 BG    HW: 7N0 907 530 AN
       Component: J533  Gateway H56 1674
       Revision:   H56       Serial number: 110615F1002118
       Coding: 357420
       Shop #: WSC 00000 416 354292
       VCID: 76B5E0E3B8C61D07E39-8022
       Component: IMMO          H04 1009
    9456681 - Key
              B104C 29 [008] - Implausible Signal
                        Mileage: 43325 km
                        Date: 2018.02.18
                        Time: 15:01:19
       Part No SW: 2K5 959 701     HW: 2K5 959 701
       Component: Tuer-SG         009 2143
       Coding: 0132144
       VCID: 71BFD3FFDDA83A3F36B-8024
       Part No: 1K0 909 144 R
       Component: EPS_ZFLS Kl. 140    3501
       Revision: 00H22000
       VCID: 392F2BDFC558B27FCEB-806C
       Part No SW: 2K5 959 702     HW: 2K5 959 702
       Coding: 0132144
       VCID: 72BDDCF3D8AE0127CF1-8026
       Part No SW: 5K7 035 200 D    HW: 5K7 035 200 D
       Component: MU-S--ER      H20 0240
       Serial number: VWZAZ2R8656651
       Coding: 06330700BE00000011110001000808001F0100C40020010003
       ROD: EV_MUStd4CTSAT_SK26.rod
       VCID: 2517F7AF5560269F9A3-8070
       Component: Batt.regelung H56 1674
       Coding: 030F1873
       VCID: 71BFD3FFD1A83A3F36B-8024
       Component: J367-BDM  H07 0180
       Serial number: 42155G55481491192815
    End----------(Elapsed Time: 01:04, VBatt start/end: 12.8V/12.9V)-----------
    what can i do for this problem
    Jan 2020
    Germany (Auto-Intern)
    Hi, if i remember correctly, the maximum value is 40 grams for the service regeneration. In your case the calculated soot mass is at 42.23 grams. I think that's the reason why it is canceled for security reasons.
  3. Likes Uwe, Fredrick Awuor liked this post
    Jan 2020
    Israel
    so what should i do in these cases because its affecting the car air intake
    should i remove it ?
    Remove DPF, clean it and refit it.
  6. Likes ai_Ingo, Uwe liked this post
    Jan 2020
    Just as Patrol Dave wrote, clean or replace the DPF. Then the DPF must be reset with VCDS. But this can only happen if it has either been cleaned or replaced. An overloaded DPF that is reset could cause a vehicle fire if regeneration is initiated.
  8. Likes Uwe liked this post
