Results 1 to 7 of 7
Thread: 2007 130 SHUTTLE BUS 2.5 5 Cylinder Cam position. "operation bring back to life"
    Verified VCDS User johne's Avatar
    Mar 2020
    Southampton, UK
    Hi Guys, First post having sold our T2 bay thought it would be a good idea to take on a non running T5 ..slowly working though all the bits that are non working.. now need a little help. After rebuilding the engine have a cam relation with crank..fine i thought easy timing out so take the front off to look ..yep its half a tooth out..using the locking tool , have a friend take a look he said i have not lined up the train gears with the crank ..before fitting the head..hmmm so remove the cam buckets and injectors so i can turn over to try and find the correct position ..after about an hour found a place where it lined up..woop woop..all back together its runs {just} when you turn it off its like the immobiliser is cutting off the engine.. when it is running the driver is very turbo lag..then whooh away you go. still reading ???.. help.. is there any way i can phase the cam using VCDS ? also would like to disarm the immobiliser if poss...john { thanks in advance }
    THINGS DONE
    new cam sensor..well two really
    new crank sensor
    lots of swearing and many cups of tea ...lol..
    ps..why is it showing BPC as engine code as its a BNZ ??
    Sunday,29,March,2020,12:08:30:62543
    VIN: WV2ZZZ7HZ8H015277   License Plate: HK
    Mileage: 496710km-308641mi   Repair Order: 29.03.
              57 6E 76 77 78 7D
    VIN: WV2ZZZ7HZ8H015277   Mileage: 496710km-308641miles
    Address 01: Engine        Labels: 070-906-016-BPC.clb
       Part No SW: 070 906 016 DS    HW: 070 906 016 DS
       Component: R5 2,5L EDC  000SG  1585
       Revision: --H05---    Serial number: VWZ7Z0G5463049
       Coding: 0001072
       Shop #: WSC 80093 222 69422
       VCID: 6491AC44A244FBD74DD-5184
    008581 - Engine Coolant Temp Sensor on Radiator Outlet (G83)
                   P2185 - 000 - Signal too High
                        Mileage: 496719 km
                        Load: 0.0 %
                        Voltage: 12.62 V
                        Bin. Bits: 00000000
                        Temperature: 45.9C
                        Temperature: 24.3C
    000833 - Camshaft Position Sensor (G40)
                   P0341 - 000 - Implausible Signal
                        Mileage: 496719 km
                        RPM: 504 /min
                        Load: 100.0 %
                        Voltage: 11.17 V
                        Bin. Bits: 00000000
                        Idle Stabilization: 0.0KW
                        (no units): 3.0
    012296 - Camshaft Position Sensor (G40)
                   P3008 - 000 - Signal Out of Range - Intermittent
                        Mileage: 496719 km
                        RPM: 651 /min
                        Load: 100.0 %
                        Voltage: 11.63 V
                        Bin. Bits: 00000100
                        (no units): 35.0
    Address 03: ABS Brakes        Labels:. 7H0-907-37x-ABS.clb
       Part No SW: 7H0 907 379 S    HW: 7H0 907 379 S
       Component: (M)ABS MK25E        0103
       Revision: 00H21001
       Coding: 0000552
       Shop #: WSC 02756 790 00000
       VCID: 45D751C009BEA2DFBA3-5160
       Part No: 7H0 820 045 AL
       Component: CLIMA/AC            0303
       VCID: 6FBBD3687B82488F20F-5160
    00229 - Refrigerant Pressure
                002 - Lower Limit Exceeded
       Part No: 7H0 937 049 T
       Component: BORDNETZ SGVER 1.0  2001
       Coding: 0000101
       VCID: 43D34FD8078A9CEF947-5160
    01598 - Drive Battery Voltage
                001 - Upper Limit Exceeded
       Part No: 1C0 909 605 A
       Component: 3C AIRBAG VW51      0010
       Coding: 13123
       Shop #: WSC 02756
       VCID: 221DEA5CFDD0B5E7FF1-5160
       Part No: 7H0 920 951 T
       Coding: 00413
       Shop #: WSC 77824
       VCID: 3D273920646EEA1FE23-5160
       WV2ZZZ7HZ8H015277     VWZ7Z0G5463049
    01304 - Radio
                49-00 - No Communications
    Address 18: Aux. Heat        Labels: 7H0-819-008.lbl
       Part No: 7H0 815 071 F
       Component: Standheizung        0209
       VCID: 2B0307788F1A74AF4C7-5160
       Part No: 6N0 909 901
       Coding: 00006
       Shop #: WSC 02756
       VCID: 70B9D01463BC5777395-5160
    01304 - Radio
    Address 45: Inter. Monitor        Labels: 7Hx-951-171.lbl
       Part No: 7H0 951 171 B
       Component: Innenraumueberw.    2920
       Coding: 0000022
       Shop #: WSC 02757 790 00000
       VCID: 290FFD7085E666BFBEB-51F2
       Subsystem 1 - Part No: 7H5 951 178
       Component: Innenraumueberw.    1607
       Part No: 7H0 959 433 B
       Component: C11 Komfortgert     0004
       Coding: 00030
       Shop #: WSC 02756
       VCID: 323D1A1CAD3025670F1-4B1E
    End----------(Elapsed Time: 06:13, VBatt start/end: 14.6V/14.5V)-----------
    Quote Originally Posted by johne View Post
    It's not, really. It's showing VCDS using a label file named "070-906-016-BPC". This means that the data for these two engines and ECUs was deemed "close enough" that it could be used for both.
    Many newer ECUs actually do report the exact engine type, but this one doesn't (it's too old to do that).
    Mar 2020
    Southampton, UK
    hi many thanks for taking time to reply, what do you think is my next move ??
    Mar 2020
    Southampton, UK
    hi, anyone have any ideas ..??? please
    Mar 2020
    Southampton, UK
    hi,, looking like its "take it apart"..3.7 BTDC looks a bit close. and now the wiper motor has come out in sympathy , last night my dream was to read "no faults found"
    Tuesday,31,March,2020,15:33:21:62543
    Mileage:    Repair Order: 31/03
                    Address 01: Engine  (070 906 016 DS)
    15:33:07 Group 001: Injection Quantity
      798 /min  Engine Speed (G28)
      6.0 mg/str  Injection Quantity
      7.1KW  Injection Duration (specified)
      44.1C  Coolant Temperature (G62)
    15:33:07 Group 002: Idle Speed
      0.0 %  Accel. Pedal Pos. Sensor 1 (G79)
       0 01  0  Operation Status
    15:33:07 Group 003: Exhaust Gas Recirculation (EGR)
      230.0 mg/str  Exhaust Gas Recirculat. (spec.)
      485.0 mg/str  Exhaust Gas Recirculat. (actual)
      100.6 %  Exhaust Gas Recirc. Duty Cycle
    15:34:36 Group 001: Injection Quantity
      6.3 mg/str  Injection Quantity
      45.9C  Coolant Temperature (G62)
    15:34:36 Group 002: Idle Speed
    15:34:36 Group 003: Exhaust Gas Recirculation (EGR)
      480.0 mg/str  Exhaust Gas Recirculat. (actual)
    Readiness Status: 00000000 00000110 11100000 10100000
    MIL Status: MIL OFF
    Comprehensive Components: Passed
    Fuel System: Passed
    Exhaust Gas Recirculation: Failed or Incomplete
    Number of EOBD-related DTC(s): 0
                    Address 01: Engine
    Control Module Part Number: 070 906 016 DS
      Component and/or Version: R5 2,5L EDC  000SG  1585
               Software Coding: 0001072
                Work Shop Code: WSC 80093
    Advanced Identification
         Identification: BPG-810
         Revision: --H05---
         Date: 11.06.07
         Test stand number: 1329
         Manufacturer number: 0625
    Flash Status
         Programming Attempts: 3
         Successful Attempts: 3
         Programming Status: 00000000
         Required Conditions: 00000001
         Flash Tool Code: 00032 257 66565
         Flash Date: 00.00.00
    Software
         22.12
         TAYF
    Misc.
         Hardware number: 070 906 016 DS
    Car Info
         Chassis Number: WV2ZZZ7HZ8H015277
    VCDS Info:
           Labels: 070-906-016-BPC.CLB
           Readiness: No script available
    15:38:24 Group 005: Start Conditions (last Engine Start)
      24.2 mg/str  Starting Torque
      48.0  Start Synchronisation
      51.3C  Coolant Temperature (G62)
    15:38:24 Group 004: Unit Injector
      3.7 BTDC  Injection Start (specified)
      7.7KW  Injection Duration (specified)
      0.0KW  Torsion Value
    15:38:24 Group 001: Injection Quantity
    Address 01: DTCs cleared
              57 6E 76 77 78 7D
       Coding: 0001072
                        Mileage: 496719 km
                        RPM: 777 /min
                        Load: 0.0 %
                        Voltage: 14.52 V
                        Bin. Bits: 00000000
                        (no units): 48.0
                        Mileage: 496719 km
                        RPM: 777 /min
                        Load: 0.0 %
                        Voltage: 14.52 V
                        Bin. Bits: 00000000
                        Temperature: 51.3C
                        Temperature: 34.2C
       Revision: 00H21001
       Coding: 0000552
       Coding: 0000101
    00909 - Windshield Wiper Motor (V) Stage 1/2
    00077 - Windshield Wiper Stop Switch (F229)
    End----(Elapsed Time: 06:45, VBatt start/end: 14.5V/12.7V. VIgn 0.0V)------
  6. #6
    Mar 2020
    Southampton, UK
    Hi All, Finally found my problem of having the cam gear half a tooth out from the mark.five cylinder 2.5 BNZ ...drum roll..you need to line up the gear train with the crank at TDC ,lock the crank into the block, fit the head mashing the intermediate using a eccentric shaft then line the cam gear with the top on the head lock the cam shaft then bolt the cam gear with the new diamond washer onto the camshaft, remove all the locks turn the engine over twice to check ..job done. ..
    Next job is electrical.
              57 6E 76 77 78 7D
    VIN: WV2ZZZ7HZ8H015277   Mileage: 496720km-308647miles
       Coding: 0001072
       VCID: 6491AC44A244FBDBD7A-5184
       Revision: 00H21001
       Coding: 0000552
       VCID: 45D751C009BEA2D3204-5160
                        Reset counter: 40
                        Mileage: 496721 km
                        Count: 6145
                        Count: 128
       VCID: 6FBBD3687B824883BA8-5160
       Coding: 0000101
       VCID: 43D34FD8078A9CE30E0-5160
       Coding: 13123
       Shop #: WSC 02756
       VCID: 221DEA5CFDD0B5EB656-5160
       Coding: 00413
       Shop #: WSC 77824
       VCID: 3D273920646EEA13784-5160
    01304 - Radio
       VCID: 2B0307788F1A74A3D60-5160
       Coding: 00006
       Shop #: WSC 02756
       VCID: 70B9D01463BC577BA32-5160
    01304 - Radio
       Coding: 0000022
       VCID: 290FFD7085E666B324C-51CE
       Coding: 00030
       Shop #: WSC 02756
       VCID: 323D1A1CAD30256B956-4B1E
    End----------(Elapsed Time: 05:53, VBatt start/end: 14.5V/14.5V)-----------
  7. Likes NZDubNurd, Uwe liked this post
    Mar 2020
    Southampton, UK
    so that was easy new earth from the ecu to the battery earth fixed that..
    so now i have no faults .. other then the radio and air-con which are both disconnected
    Just to say many thanks for all your help ..happy motoring {well after the lockdown} john
  9. Likes PetrolDave, Uwe liked this post
