2007 130 SHUTTLE BUS 2.5 5 Cylinder Cam position. "operation bring back to life"
johne
Southampton, UK
C?ID=380307
Hi Guys, First post having sold our T2 bay thought it would be a good idea to take on a non running T5 ..slowly working though all the bits that are non working.. now need a little help. After rebuilding the engine have a cam relation with crank..fine i thought easy timing out so take the front off to look ..yep its half a tooth out..using the locking tool , have a friend take a look he said i have not lined up the train gears with the crank ..before fitting the head..hmmm so remove the cam buckets and injectors so i can turn over to try and find the correct position ..after about an hour found a place where it lined up..woop woop..all back together its runs {just} when you turn it off its like the immobiliser is cutting off the engine.. when it is running the driver is very turbo lag..then whooh away you go. still reading ???.. help.. is there any way i can phase the cam using VCDS ? also would like to disarm the immobiliser if poss...john { thanks in advance }
THINGS DONE
new cam sensor..well two really
new crank sensor
lots of swearing and many cups of tea ...lol..
ps..why is it showing BPC as engine code as its a BNZ ??
Sunday,29,March,2020,12:08:30:62543
VIN: WV2ZZZ7HZ8H015277   License Plate: HK
Mileage: 496710km-308641mi   Repair Order: 29.03.
          57 6E 76 77 78 7D
VIN: WV2ZZZ7HZ8H015277   Mileage: 496710km-308641miles
Address 01: Engine        Labels: 070-906-016-BPC.clb
   Part No SW: 070 906 016 DS    HW: 070 906 016 DS
   Component: R5 2,5L EDC  000SG  1585
   Revision: --H05---    Serial number: VWZ7Z0G5463049
   Coding: 0001072
   Shop #: WSC 80093 222 69422
   VCID: 6491AC44A244FBD74DD-5184
008581 - Engine Coolant Temp Sensor on Radiator Outlet (G83)
               P2185 - 000 - Signal too High
                    Mileage: 496719 km
                    Load: 0.0 %
                    Voltage: 12.62 V
                    Bin. Bits: 00000000
                    Temperature: 45.9°C
                    Temperature: 24.3°C
000833 - Camshaft Position Sensor (G40)
               P0341 - 000 - Implausible Signal
                    Mileage: 496719 km
                    RPM: 504 /min
                    Load: 100.0 %
                    Voltage: 11.17 V
                    Bin. Bits: 00000000
                    Idle Stabilization: 0.0°KW
                    (no units): 3.0
012296 - Camshaft Position Sensor (G40)
               P3008 - 000 - Signal Out of Range - Intermittent
                    Mileage: 496719 km
                    RPM: 651 /min
                    Load: 100.0 %
                    Voltage: 11.63 V
                    Bin. Bits: 00000100
                    (no units): 35.0
Address 03: ABS Brakes        Labels:. 7H0-907-37x-ABS.clb
   Part No SW: 7H0 907 379 S    HW: 7H0 907 379 S
   Component: (M)ABS MK25E        0103
   Revision: 00H21001
   Coding: 0000552
   Shop #: WSC 02756 790 00000
   VCID: 45D751C009BEA2DFBA3-5160
   Part No: 7H0 820 045 AL
   Component: CLIMA/AC            0303
   VCID: 6FBBD3687B82488F20F-5160
00229 - Refrigerant Pressure
            002 - Lower Limit Exceeded
   Part No: 7H0 937 049 T
   Component: BORDNETZ SGVER 1.0  2001
   Coding: 0000101
   VCID: 43D34FD8078A9CEF947-5160
01598 - Drive Battery Voltage
            001 - Upper Limit Exceeded
   Part No: 1C0 909 605 A
   Component: 3C AIRBAG VW51      0010
   Coding: 13123
   Shop #: WSC 02756
   VCID: 221DEA5CFDD0B5E7FF1-5160
   Part No: 7H0 920 951 T
   Coding: 00413
   Shop #: WSC 77824
   VCID: 3D273920646EEA1FE23-5160
   WV2ZZZ7HZ8H015277     VWZ7Z0G5463049
01304 - Radio
            49-00 - No Communications
Address 18: Aux. Heat        Labels: 7H0-819-008.lbl
   Part No: 7H0 815 071 F
   Component: Standheizung        0209
   VCID: 2B0307788F1A74AF4C7-5160
   Part No: 6N0 909 901
   Coding: 00006
   Shop #: WSC 02756
   VCID: 70B9D01463BC5777395-5160
01304 - Radio
Address 45: Inter. Monitor        Labels: 7Hx-951-171.lbl
   Part No: 7H0 951 171 B
   Component: Innenraumueberw.    2920
   Coding: 0000022
   Shop #: WSC 02757 790 00000
   VCID: 290FFD7085E666BFBEB-51F2
   Subsystem 1 - Part No: 7H5 951 178
   Component: Innenraumueberw.    1607
   Part No: 7H0 959 433 B
   Component: C11 Komfortgerát     0004
   Coding: 00030
   Shop #: WSC 02756
   VCID: 323D1A1CAD3025670F1-4B1E
End----------(Elapsed Time: 06:13, VBatt start/end: 14.6V/14.5V)-----------
It's not, really. It's showing VCDS using a label file named "070-906-016-BPC". This means that the data for these two engines and ECUs was deemed "close enough" that it could be used for both.
Many newer ECUs actually do report the exact engine type, but this one doesn't (it's too old to do that).
johne
Southampton, UK
C?ID=380307
hi many thanks for taking time to reply, what do you think is my next move ??
johne
Southampton, UK
C?ID=380307
hi, anyone have any ideas ..??? please
johne
Southampton, UK
C?ID=380307
hi,, looking like its "take it apart"..3.7 BTDC looks a bit close. and now the wiper motor has come out in sympathy , last night my dream was to read "no faults found"
Tuesday,31,March,2020,15:33:21:62543
Mileage:    Repair Order: 31/03
                Address 01: Engine  (070 906 016 DS)
15:33:07 Group 001: Injection Quantity
  798 /min  Engine Speed (G28)
  6.0 mg/str  Injection Quantity
  7.1°KW  Injection Duration (specified)
  44.1°C  Coolant Temperature (G62)
15:33:07 Group 002: Idle Speed
  0.0 %  Accel. Pedal Pos. Sensor 1 (G79)
   0 01  0  Operation Status
15:33:07 Group 003: Exhaust Gas Recirculation (EGR)
  230.0 mg/str  Exhaust Gas Recirculat. (spec.)
  485.0 mg/str  Exhaust Gas Recirculat. (actual)
  100.6 %  Exhaust Gas Recirc. Duty Cycle
15:34:36 Group 001: Injection Quantity
  6.3 mg/str  Injection Quantity
  45.9°C  Coolant Temperature (G62)
15:34:36 Group 002: Idle Speed
15:34:36 Group 003: Exhaust Gas Recirculation (EGR)
  480.0 mg/str  Exhaust Gas Recirculat. (actual)
Readiness Status: 00000000 00000110 11100000 10100000
MIL Status: MIL OFF
Comprehensive Components: Passed
Fuel System: Passed
Exhaust Gas Recirculation: Failed or Incomplete
Number of EOBD-related DTC(s): 0
                Address 01: Engine
Control Module Part Number: 070 906 016 DS
  Component and/or Version: R5 2,5L EDC  000SG  1585
           Software Coding: 0001072
            Work Shop Code: WSC 80093
Advanced Identification
     Identification: BPG-810
     Revision: --H05---
     Date: 11.06.07
     Test stand number: 1329
     Manufacturer number: 0625
Flash Status
     Programming Attempts: 3
     Successful Attempts: 3
     Programming Status: 00000000
     Required Conditions: 00000001
     Flash Tool Code: 00032 257 66565
     Flash Date: 00.00.00
Software
     22.12
     TAYF
Misc.
     Hardware number: 070 906 016 DS
Car Info
     Chassis Number: WV2ZZZ7HZ8H015277
VCDS Info:
       Labels: 070-906-016-BPC.CLB
       Readiness: No script available
15:38:24 Group 005: Start Conditions (last Engine Start)
  24.2 mg/str  Starting Torque
  48.0  Start Synchronisation
  51.3°C  Coolant Temperature (G62)
15:38:24 Group 004: Unit Injector
  3.7 °BTDC  Injection Start (specified)
  7.7°KW  Injection Duration (specified)
  0.0°KW  Torsion Value
15:38:24 Group 001: Injection Quantity
Address 01: DTCs cleared
          57 6E 76 77 78 7D
   Coding: 0001072
                    Mileage: 496719 km
                    RPM: 777 /min
                    Load: 0.0 %
                    Voltage: 14.52 V
                    Bin. Bits: 00000000
                    (no units): 48.0
                    Mileage: 496719 km
                    RPM: 777 /min
                    Load: 0.0 %
                    Voltage: 14.52 V
                    Bin. Bits: 00000000
                    Temperature: 51.3°C
                    Temperature: 34.2°C
   Revision: 00H21001
   Coding: 0000552
   Coding: 0000101
00909 - Windshield Wiper Motor (V) Stage 1/2
00077 - Windshield Wiper Stop Switch (F229)
End----(Elapsed Time: 06:45, VBatt start/end: 14.5V/12.7V. VIgn 0.0V)------
johne
Southampton, UK
C?ID=380307
Hi All, Finally found my problem of having the cam gear half a tooth out from the mark.five cylinder 2.5 BNZ ...drum roll..you need to line up the gear train with the crank at TDC ,lock the crank into the block, fit the head mashing the intermediate using a eccentric shaft then line the cam gear with the top on the head lock the cam shaft then bolt the cam gear with the new diamond washer onto the camshaft, remove all the locks turn the engine over twice to check ..job done. ..
Next job is electrical.
          57 6E 76 77 78 7D
VIN: WV2ZZZ7HZ8H015277   Mileage: 496720km-308647miles
   Coding: 0001072
   VCID: 6491AC44A244FBDBD7A-5184
   Revision: 00H21001
   Coding: 0000552
   VCID: 45D751C009BEA2D3204-5160
                    Reset counter: 40
                    Mileage: 496721 km
                    Count: 6145
                    Count: 128
   VCID: 6FBBD3687B824883BA8-5160
   Coding: 0000101
   VCID: 43D34FD8078A9CE30E0-5160
   Coding: 13123
   Shop #: WSC 02756
   VCID: 221DEA5CFDD0B5EB656-5160
   Coding: 00413
   Shop #: WSC 77824
   VCID: 3D273920646EEA13784-5160
01304 - Radio
   VCID: 2B0307788F1A74A3D60-5160
   Coding: 00006
   Shop #: WSC 02756
   VCID: 70B9D01463BC577BA32-5160
01304 - Radio
   Coding: 0000022
   VCID: 290FFD7085E666B324C-51CE
   Coding: 00030
   Shop #: WSC 02756
   VCID: 323D1A1CAD30256B956-4B1E
End----------(Elapsed Time: 05:53, VBatt start/end: 14.5V/14.5V)-----------
johne
Southampton, UK
C?ID=380307
so that was easy new earth from the ecu to the battery earth fixed that..
so now i have no faults .. other then the radio and air-con which are both disconnected
Just to say many thanks for all your help ..happy motoring {well after the lockdown} john
