Car: 2004 Audi A4 B6 1.9 TDI SE Avant Multitronic
My A4 came with RNS-E retrofitted by a previous owner and it works fine, I really like it. I fancied swapping my standard 4-spoke steering wheel for the multifunction version of the same wheel (not heated or tiptronic buttons).
I thought it would be more straightforward (and cheaper) than it's ended up being but I've come this far and I'm determined to make the damn thing work.
OK, so far I've switched my standard airbag for a MFSW one without telephone facility (8E0880201AB), fitted a brand new MFSW airbag harness (8E0971589S), a MFSW control module (61340351) and the wiring harness for the stereo buttons (8Z0971589E).
I've also re-coded the stereo and the steering wheel with VCDS. The coding I used for the stereo is 03011115 and for the steering wheel 02042. The car has all three steering column stalks ... indicators, cruise, wipers (front and rear) and computer.
The steering column control module is 8E0953549N which research seems to be a midline model and capable of controlling a MFSW. I'm not sure what slip ring mine has as I haven't yet been able to remove the upper cowling to find the part number. But I think it is part number 8E0953541E. I won't know for sure until I can buy a long T8 Torx to get the cowling off.
Anyway, the buttons are dead as a dead thing. None of them work or illuminate when the headlights are on. VCDS throws up the following fault code ...
01426 - Controls in Steering Wheel (E221) 49-00 - No Communications
No airbag faults are coming up and the horn works fine. So it's just the MFSW side of things that's not right.
To double-check I've tried it with two spare MFSW airbags, a spare steering wheel controller and a spare stereo button harness and still no joy.
I feel like I'm so near, yet so far. Do I need to replace yet another part? Column control module and/or slip ring? Is my coding wrong?
Any help would be really appreciated.
TIA
In case it helps my latest scan is this ...
TIA
VCDS-Lite Version: Release 1.2
Monday, 23 March 2020, 12:41:49:45583
Chassis Type: 8E - Audi A4 B6
Scan: 01,02,03,08,09,0F,11,15,16,17,18,36,37,45,46,55,56,57,65,67,69,75,76,77
Address 01: Engine Labels: 038-906-019-AVF.LBL
Controller: 038 906 019 LJ
Component: 1,9l R4 EDC G000AG 5934
Coding: 00001
Shop #: WSC 63251
VCID: 6AA7F3A40567
WAUZZZ8E54A227828 AUZ6Z0D0045638
Readiness: N/A
Address 02: Auto Trans Labels: 01J-927-156.LBL
Controller: 8E2 910 155 B
Component: V30 01J 1.9l PD RdW 3271
Coding: 0000001
Shop #: WSC 00178
VCID: 263FC794D1FF
Address 03: ABS Brakes Labels: 8E0-614-517.LBL
Controller: 8E0 614 517
Component: ABS/ESP front 3429
Coding: 04259
Shop #: WSC 06435
VCID: E5BD00986C79
Address 08: Auto HVAC Labels: 8E0-820-043.LBL
Controller: 8E0 820 043 AC
Component: A4 Klimaautomat 1450
Coding: 00000
VCID: 62B79B84FD57
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.LBL
Controller: 8E0 907 279 F
Component: int. Lastmodul RDW 0517
Coding: 00001
VCID: 351D10D81C59
Address 15: Airbags Labels: 8E0-959-655-84.LBL
Controller: 8E0 959 655 J
Component: Airbag 8.4EP 1002
Coding: 0010602
Shop #: WSC 63251
VCID: 3E0F0FF4296F
Address 16: Steering wheel Labels: 8E0-953-549.LBL
Controller: 8E0 953 549 N
Component: Lenksáulenmodul 0611
Coding: 02042
Shop #: WSC 63251
VCID: 3E0F0FF4296F
Address 17: Instruments Labels: 8E0-920-9xx-8E2.LBL
Controller: 8E0 920 950 M
Component: KOMBI+WEGFAHRS. RB4 D42
Coding: 00401
Shop #: WSC 00001
VCID: 33192EC0122D
Address 37: Navigation Labels: None
Controller: 8E0 035 192 Q
Component: RNS-E HIGH EU H73 0650
Coding: 0301115
Shop #: WSC 06335
VCID: 32172BC4ED37
Address 45: Inter. Monitor Labels: 8E0-951-177.LBL
Controller: 8E0 951 177
Component: Innenraumueberw. 0704
Coding: 00001
VCID: EBA976A08A9D
Address 46: Central Conv. Labels: 8E0-959-433-MAX.LBL
Controller: 8E0 959 433 BC
Component: Komfortgerát T3B 1412
Coding: 01931
Shop #: WSC 73430
VCID: 7399EEC052AD
Address 56: Radio Labels: None
Coding: 0301115
Shop #: WSC 06335
VCID: 32172BC4ED37
Address 76: Park Assist Labels: 8E0-919-283-8E2.LBL
Controller: 8E0 919 283 A
Component: Parkingsyst. A4 RDW D08
Coding: 01114
Shop #: WSC 63251
VCID: 2E2F3FB4F90F
End --------------------------------------------------------------------------------------------------
