Results 1 to 10 of 18
Thread: ABS not functioning
    Mar 2020
    Australia
    ABS not functioning
    So I purchased an A6 C7 last year with 100K on it. Had the rear brakes replaced as part of the roadworthy.
    I had to emergency brake and the wheels totally locked up. I have tested it multiple times and there is no sign of the ABS existing.
    I have made sure the fuse is there, I have checked for faults, it says the ABS is ok. No lights, no indication there is anything wrong. So strange with such a sophisticated car!
    I posted elsewhere and someone picked up that there was a fault logged that the "Changing brake lining" mode was still activated. I imagine it couldn't be driven if this was so, plus the EPB has worked fine. I figure they started the car while it was still in the mode, then ended the mode, though the fault code was already stored. Anyway, for good measure, I cycled the modes, made sure it was closed, everything looks ok. Cleared the codes, nothing coming back up.
    I did have the fault "Function Restricted due to Missing Message(s)" against the ABS, though I cleared it before saving (oops) and it hasn't come back since. Here is my autoscan... Any thoughts?
    Thursday,26,March,2020,12:37:28:47930
    VIN: WAUZZZ4G3CN093092   License Plate:
    Mileage: 122088km-75861mi   Repair Order: 01
    Chassis Type: 4G-AU57 (4G0)
    Scan: 01 02 03 05 08 09 10 15 16 17 19 20 28 36 3B 42 44 46 47 52
              53 55 56 5F 62 6C 72
    VIN: WAUZZZ4G3CN093092   Mileage: 122088km-75861miles
    Address 01: Engine (J623-CGWB)       Labels:. 06E-907-551-CGW.clb
       Part No SW: 4G0 907 551 F    HW: 4H0 907 551
       Component: 3.0l V6 TFSIH07 0006
       Revision: --H07---
       Coding: 0A250034052701020000
       Shop #: WSC 02311 785 00200
       ASAM Dataset: EV_ECM30TFS0214G0907551F 001006
       ROD: EV_ECM30TFS0214G0907551F.rod
       VCID: 2C010460468084C745D-8078
       Part No SW: 4G1 927 156 D    HW: 0B5 927 156 F
       Component: 0B5 30TFSIRdW H10 0011
       Revision: --H10---    Serial number: 0000000510
       Coding: 000001
       Shop #: WSC 04940 001 00001
       ASAM Dataset: EV_TCMDL501 A02196
       ROD: EV_TCMDL501.rod
       VCID: 2E050E68709CF6D76B9-807A
       Coding: 44A687012265E180CB00
       VCID: 3635260888CCCE17239-8062
       Part No SW: 4H0 907 064 BT    HW: 4H0 907 064 BT
       Coding: 05B82F06000000000000
       VCID: 7CA1F420F6E0D44795D-8028
       Part No SW: 4G0 820 043 K    HW: 4G0 820 043 K
       Component: KLIMA 4 ZONEN H12 0810
       Serial number: 25111100040548
       Coding: 6621607828
       ASAM Dataset: EV_AirCondiComfoUDS 002044
       VCID: 270BFB4C5F66A79FA8F-8072
    0378 - Coolant Circulation Pump
              B10D0 04 [008] - Internal System Fault
                        Fault Frequency: 7
                        Reset counter: 176
                        Mileage: 120636 km
                        Date: 2020.03.07
                        Time: 12:00:54
                        Voltage terminal 30: 14.63 V
                        Outside air temperature: 17.0 °C
                        Interior temperature: 31.68 °C
    0379 - Supply Voltage Terminal 30 for Coolant Pump
              B11D5 01 [009] - Electrical Failure
                        Reset counter: 138
                        Mileage: 106130 km
                        Date: 2019.07.22
                        Time: 16:14:24
       Part No SW: 4H0 907 063 BG    HW: 4H0 907 063
       Component: BCM1 2.0      H12 0100
       Revision: 11012002    Serial number: 00000001311026
       Coding: 0907A01009749FE00181008380001800CF9DC3082F080101000108542F01
       VCID: 6E85CE68B09CB6D72B9-803A
       Component: WWS57X 111027  H35 0051
       Serial number:         111031140043
       Coding: 0045F7
       Component: RLS  H04 0003
       Serial number: 11794796
       Coding: 02512B
       Subsystem 3 - Part No SW: 4G0 941 531 E    HW: 4G0 941 531 E
       Component: E1 - LDS  H07 0044
       Serial number: 23 11 2011  00000278
       Subsystem 4 - Part No SW: 4H0 907 472 B    HW: 4H0 907 472 B
       Serial number: 00000014111100010196
       Coding: 110000
       Serial number: 00000011111100010572
       Coding: 110000
       Serial number: 38788DD5000000000001
                        Fault Status: 00101100
                        Reset counter: 170
                        Mileage: 121850 km
                        Date: 2020.03.21
                        Time: 16:44:00
                        Reset counter: 170
                        Mileage: 121850 km
                        Date: 2020.03.21
                        Time: 16:44:00
       Part No SW: 4H0 919 475 N    HW: 4H0 919 475 C
       Component: PARKHILFE ACC H07 0050
       Revision: 11001001    Serial number: 55901132503196
       Coding: 280306
       ROD: EV_EPHVA18AU57X0000_002_AU57.rod
       VCID: 3D273924ADFA1D4FE23-8068
       Component: Airbag10.43   H40 0040
       Revision: --------    Serial number: 003JG005K03N
       Coding: 30323436313330303534554A305234473053
       Serial number: 3575HRB405T0TGJE8PLU
       Serial number: 3585HRB405N0VP46591H
       Serial number: 3515JRB404R0R8AAMOF7
       Serial number: 3525JRB40650TGJI1OU9
       Serial number: 3554VRB405J0QBGIE12U
       Serial number: 3564VRB40650Q4PIJ09V
       Revision: 00000000    Serial number: 20141105000371
       Coding: 000034
       Shop #: WSC 52709 002 1048576
       VCID: 303910106A28E027795-8064
       Component: E221 - MFL  H08 0009
       Part No SW: 4G8 920 931 L    HW: 4G8 920 931 L
       Component: TBenRdw       H79 0416
       Revision: 28460177    Serial number: 658211111591017
       Coding: 33AF08000B010008010000
       ASAM Dataset: EV_RBD4K 004045
       ROD: EV_RBD4K_AU57.rod
       VCID: 372B2B0C8FC6371F38F-8062
       Part No SW: 4G0 907 468 G    HW: 4G0 907 468 A
       Component: J533--Gateway H08 0214
       Revision: --------    Serial number: 00000000318662
       Coding: 00CD073000
       ROD: EV_GatewUDS_AU57.rod
       VCID: 34311C009EB0DC071DD-8060
       Component: J367-BDM  H07 0141
       Serial number: 00000000003790165884
       Voltage stabilizer:
       Serial number: 11324000529021200410
       Part No SW: 8K0 857 511 E    HW: 8K0 857 511 A
       Revision: AA001002
       Coding: 04028264747464545425363E
       VCID: 33331F1C9B3EDB3F047-8066
       Part No SW: 4G0 919 158 C    HW: 4G0 919 158 C
       Component: KLIMA FOND    H07 0810
       Serial number: 24111100040944
       Coding: 02
       ASAM Dataset: EV_ClimaContrUnitRearUDS 002022
       VCID: 2F3B136C7796FFDF60F-807A
       Revision: AA000000    Serial number: 00000016661804
       Coding: 00781B0000006001000001010101102030303232203232
       VCID: 77ABEB0CCFC6F71FF8F-8022
       Part No SW: 4G0 907 637     HW: 4G0 907 637
       Component: SARA 3D       H02 0004
       Revision: --------    Serial number: EJ1BPA3200ZBSU0
       ASAM Dataset: EV_SARA 006014
       ROD: EV_SARA_006.rod
       VCID: 6B83C77C830E43FF0C7-803E
       Part No SW: 4G8 959 793 E    HW: 4G8 959 793 A
       Component: TSG FA        H05 0212
       Coding: 011F16204E01620002080002
       Shop #: WSC 02312 785 00200
       VCID: 42DD4AD8D48462B79F1-8016
       Component: RCevo         H53 0202
       Revision: 00000002    Serial number: 0000479077
       Coding: 101000010000
       Shop #: WSC 02263 002 1048576
       ASAM Dataset: EV_RCEPS 106007
       ROD: EV_RCEPS_106.rod
       VCID: 3A2D3238BCD42A77C71-806E
       Revision: 00002001    Serial number: 0163704034
       Coding: 01000E2200B9040581300804000303000000000000000000000000000000
       Subsystem 1 - Part No SW: 7P5 959 591     HW: 4H0 959 591
       Component: J245 PS40.033  H07 0006
       Serial number:     WOO1413314Y
       Coding: 901E00
       Subsystem 2 - Part No SW: 3AA 962 243     HW: 3AA 962 243
       Component: GEB.F.Heckoef  H12 0719
       Serial number: 84183890
                009 - Open or Short to Ground
                        Fault Status: 01101001
                        Reset counter: 131
                        Mileage: 121896 km
                        Date: 2020.03.22
                        Time: 20:13:10
       Revision: CJ007001    Serial number: 00000000007609
       Coding: 030000
       VCID: 1D67D9A40DBA7D4FC23-8048
       Part No SW: 4G8 959 792 E    HW: 4G8 959 792 A
       Component: TSG BF        H05 0212
       VCID: 41DF45D4D18279AF86B-8014
       Revision: --------    Serial number: 00000000193815
       ROD: EV_ParkiBrake_VW51.rod
       VCID: 2A0D02784C749AF7B71-807E
    721152 - Brake Pad Replacement Mode Active
              C1011 00 [000] - -
       Serial number: 111027-0002-016
       Coding: 1121A6601000A300
       ROD: EV_HeadlRegulBasic.rod
       Part No SW: 4G1 035 053 E    HW: 4G1 035 053
       Component: Radio U Basic H41 0093
       Revision: AB001007    Serial number: 227K 0B7510655
       Coding: 040003010000000001
       VCID: 211FE55431C259AFE6B-8074
       Part No SW: 4G0 035 754 G    HW: 4G0 035 754 A
       Component: H-BN-RW       H48 0484
       Revision: --------    Serial number: 430KU0B7512281
       Coding: 050A01000003E1EF45008F2E00000003FC0001020000000000
       VCID: 2A0D02784CF49AF7B71-807E
       Subsystem 1 - Part No: 8R0 060 884 AJ
       Component: ROW 2012  0403
       Subsystem 2 - Part No SW: 4G0 919 605 A    HW: 4G0 919 605 A
       Serial number: AUZ8ZDB13024HVS
       Subsystem 3 - Part No SW: 4G2 919 610 C    HW: 4G2 919 610 C
       Serial number: 90349KKC000B3
       Component: CD-Database  3638
       Part No SW: 4G8 959 795 E    HW: 4G8 959 795 A
       Component: TSG HL        H04 0212
       Coding: 010F14204001620002080002
       VCID: 44D14CC0CE906C87ADD-8010
       Revision: --H04---    Serial number: 525 PA8J1YG2UP
       Coding: 1080004
       VCID: 2615F64854ECBE97939-8072
       Component: TSG HR        H04 0212
    End----------(Elapsed Time: 02:03, VBatt start/end: 14.7V/14.8V)-----------
  2. Likes Dana liked this post
  3. #2
    Have you function-tested the ABS again on gravel road or other slippery surface since you made the adjustments described above?
  4. Likes Dana liked this post
  5. #3
    Mar 2020
    Australia
    With very high hopes, yes. To no avail!
  6. #4
    Strange I see the ABS module was updated, did you try to recode and default module after resetting all then reboot with all adaptations done & run the road tests again, plus post a fresh auto-scan?
    Quote Originally Posted by shezza View Post
    I'm stumped. I've don't recall ever having heard of such behavior.
    VCDS Distributor AIB Wolfgang's Avatar
    Sep 2014
    Hello
    Please look for
    Stop this function and run basic settings.
    Stay healthy
    -Wolfgang
    Drive more talk less
    Quote Originally Posted by AIB Wolfgang View Post
    Please look for
    I think the OP stated he had already fixed that.
  10. #8
    Unfortunately I can't say the same.....
    Hey OP can you post a new complete auto-scan please not just reposted with ABS defaulted?
  11. #9
    Mar 2020
    Australia
    I am a VCDS newbie, that is all gibberish to me unfortunately... Could you simplify it for me please?
    Here is my current auto-scan. Not sure what "please not just reposted with ABS defaulted" means. I don't know how to do anything really besides run the auto-scan and follow basic instructions at this stage.
    Thursday,02,April,2020,16:44:00:47930
    Mileage: 122411km-76062mi   Repair Order:
    VIN: WAUZZZ4G3CN093092   Mileage: 122411km-76062miles
       Revision: --H07---
       VCID: 2C010460468084CBDFA-8078
       Coding: 000001
       VCID: 2E050E68709CF6DBF1E-807A
       VCID: 3635260888CCCE1BB9E-8062
       VCID: 7CA1F420F6E0D44B0FA-8028
       Coding: 6621607828
       VCID: 270BFB4C5F66A793328-8072
                        Fault Frequency: 9
                        Reset counter: 151
                        Mileage: 122199 km
                        Date: 2020.03.28
                        Time: 14:34:04
                        Voltage terminal 30: 13.64 V
                        Outside air temperature: 25.0 °C
                        Interior temperature: 28.00 °C
       VCID: 6E85CE68B09CB6DBB1E-803A
       Coding: 0045F7
       Coding: 02512B
       Coding: 110000
       Coding: 110000
       Coding: 280306
       VCID: 3D273924ADFA1D43784-8068
       Coding: 000034
       VCID: 303910106A28E02BE32-8064
       VCID: 372B2B0C8FC63713A28-8062
       Coding: 00CD073000
       VCID: 34311C009EB0DC0B87A-8060
       Voltage stabilizer:
       Revision: AA001002
       VCID: 33331F1C9B3EDB339E0-8066
       Coding: 02
       VCID: 2F3B136C7796FFD3FA8-807A
       VCID: 77ABEB0CCFC6F713628-8022
       VCID: 6B83C77C830E43F3960-803E
       VCID: 42DD4AD8D48462BB056-8016
       VCID: 3A2D3238BCD42A7B5D6-806E
       Coding: 901E00
                        Reset counter: 142
                        Mileage: 122199 km
                        Date: 2020.03.28
                        Time: 16:01:04
       Coding: 030000
       VCID: 1D67D9A40DBA7D43584-8048
       VCID: 41DF45D4D18279A31CC-8014
       VCID: 2A0D02784C749AFB2D6-807E
       VCID: 211FE55431C259A37CC-8074
       VCID: 2A0D02784CF49AFB2D6-807E
       VCID: 44D14CC0CE906C8B37A-8010
       Coding: 1080004
       VCID: 2615F64854ECBE9B09E-8072
    End----(Elapsed Time: 02:02, VBatt start/end: 11.8V/11.8V. VIgn 11.7V)-----
  12. #10
    Did you read about default of control units & "battery Jesus" reboots?
    Did you power down reboot entire car?
    Did you recode the ABS module with same coding and different WSC & tester number yet with VCDS?
