Results 1 to 10 of 11
Thread: Main bean assist system fault please help
    Mar 2020
    Dublin, Ireland
    Hello can anyone please help i keep getting this message up on my dash main beam assist system fault
    When I turn on my full beam the knock off after about 20secs is there any way of reseting it or turning it off all together thanks for any help
    Mar 2020
    Dublin, Ireland
    Saturday,28,March,2020,20:05:11:42836
    VCDS Version: 19.6.2.2  HEX-V2 CB: 0.4508.4
    VIN: WAUZZZ4G3DN025277   License Plate:
    Chassis Type: 4G-AU57 (4G0)
    Scan: 01 02 03 05 08 09 10 15 16 17 19 3B 42 44 46 52 53 55 5F 62
              72
    VIN: WAUZZZ4G3DN025277   Mileage: 233544km-145117miles
    17-Instruments -- Status: Malfunction 0110
    Address 01: Engine (J623-CGLC)       Labels:. 03L-906-018-CGL.clb
       Part No SW: 03L 906 018 LB    HW: 03L 906 018 JL
       Component: R4 2.0l TDI   X25 9978
       Revision: 45X25---
       Coding: 12034012242401080000
       Shop #: WSC 92521 052 00000
       ASAM Dataset: EV_ECM20TDI01103L906018LB 003012
       ROD: EV_ECM20TDI01103L906018HA.rod
       VCID: 75B7E002B54B43EFEA3-8020
    Address 02: Auto Trans (J217)       Labels:| 0AW-927-156.clb
       Part No SW: 4G0 927 155 T    HW: 0AW 927 156 K
       Component: 0AW 20TDI RdW H04 0005
       Revision: --H04---    Serial number: 0000000532
       Coding: 000001
       Shop #: WSC 02311 785 00200
       ASAM Dataset: EV_TCMVL381 A02430
       ROD: EV_TCMVL381.rod
       VCID: 3C213526D6E1D2A7D5D-8068
    10077 - Valve for Transmission Fluid Cooler
              P2753 00 [047] - Open Circuit
                        Fault Frequency: 21
                        Mileage: 233519 km
                        Date: 2020.03.27
                        Time: 18:31:42
                        Engine speed: 829.00 /min
                        Transmission input speed: 1 /min
                        Transmission output speed: 1 /min
                        Engine torque: 4 Nm
                        Transmission fluid temperature: 61 °C
                        Accelerator position: 0.0 %
                        Clutch status: 13
                        Occurrence_counter_over_length_of_life: 254
       Coding: 06A187016085E180DB00
       VCID: 3635270EE8CD08F7239-8062
    0783 - Function Restriction due to Faults in Other Modules
              U1113 00 [008] - -
              [SCL_LWR_Hoehenwert_HL_Error]
                        Reset counter: 227
                        Mileage: 233519 km
                        Date: 2020.03.27
                        Time: 18:58:00
                        VzRef: 00
                        Bit Info 1: 00
                        Bit Info 2: 40
                        Bit Info 3: 02
                        Bit Info 4: 1F
                        F-Path: 00
                        F-Type: DF
                        Uz: BC
    0782 - Function Restriction due to Implausible Message(s)
              U1112 00 [009] - -
              [SCL_LWR_Hoehenwert_HL_Invalid]
                        Reset counter: 188
                        Mileage: 233519 km
                        Date: 2020.03.27
                        Time: 18:57:56
                        VzRef: 00
                        Bit Info 1: 00
                        Bit Info 2: 40
                        Bit Info 3: 02
                        Bit Info 4: 1F
                        F-Path: 00
                        F-Type: E0
                        Uz: BB
    0784 - Function Restriction due to Implausible Message(s)
              U1112 00 [009] - -
              [SCL_LWR_Hoehenwert_VL_Invalid]
                        Reset counter: 188
                        Mileage: 233519 km
                        Date: 2020.03.27
                        Time: 18:57:56
                        VzRef: 00
                        Bit Info 1: 00
                        Bit Info 2: 40
                        Bit Info 3: 02
                        Bit Info 4: 1F
                        F-Path: 00
                        F-Type: E2
                        Uz: BB
       Part No SW: 4H0 907 064 CN    HW: 4H0 907 064 CN
       Component: BCM2 2.0      H32 0421
       Coding: 01B93046000000000000
       VCID: 77ABEA0AAFC731FFF8F-8022
       Serial number: 2312000124433014
       Part No SW: 4G0 820 043 AB    HW: 4G0 820 043 AB
       Component: KLIMA 2 ZONEN H11 0070
       Serial number: 22061200111751
       Coding: 34220008A1
       ASAM Dataset: EV_AirCondiBasisUDS 002040
       VCID: 5F9BA2AA27B7E9BF90F-800A
    0315 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
              [Sensor für Luftfeuchte innen: kein Signal / Kommunikation]
                        Fault Frequency: 18
                        Reset counter: 187
                        Mileage: 233519 km
                        Date: 2020.03.27
                        Time: 19:05:08
                        Voltage terminal 30: 14.70 V
                        Outside air temperature: 15.0 °C
                        Engine speed: 831 /min
       Part No SW: 4H0 907 063 CE    HW: 4H0 907 063 E
       Revision: 19012002    Serial number: 00000001363889
       Coding: 0640E09559EC8FE0558D008000000050C31DC71A2E080101000004405820
       VCID: 6D87C862DD9B8B2F123-8038
       Component: WWS57X 120512  H35 0080
       Serial number:         120604203030
       Coding: 0045F7
       Serial number: 20362856
       Coding: 02006D
       Subsystem 3 - Part No SW: 4G0 941 531 E    HW: 4G0 941 531 E
       Component: E1 - LDS  H07 0044
       Serial number: 21 06 2012  00001235
       Serial number: 0AD88336000000000001
    7 Faults Found:
    03110 - Active Steering Control Module (J792)
                        Reset counter: 188
                        Mileage: 233533 km
                        Date: 2020.03.28
                        Time: 18:03:00
    00380 - Special Vehicle Control Module (J608)
                        Reset counter: 188
                        Mileage: 233543 km
                        Date: 2020.03.28
                        Time: 19:09:00
    03395 - Control Module for High Beam Assistant
                        Reset counter: 188
                        Mileage: 233533 km
                        Date: 2020.03.28
                        Time: 18:03:00
    03423 - Control Module for Vehicle Positioning System Interface
                        Reset counter: 188
                        Mileage: 233533 km
                        Date: 2020.03.28
                        Time: 18:03:00
    01771 - Control Module for Headlight Range (J431)
                        Reset counter: 188
                        Mileage: 233543 km
                        Date: 2020.03.28
                        Time: 19:46:00
                013 - Check DTC Memory
                        Fault Status: 01101101
                        Reset counter: 188
                        Mileage: 233533 km
                        Date: 2020.03.28
                        Time: 18:04:00
    04046 - Control Module for Night Vision System
                        Reset counter: 188
                        Mileage: 233533 km
                        Date: 2020.03.28
                        Time: 18:03:00
       Part No SW: 4H0 919 475 AG    HW: 4H0 919 475 AG
       Component: PARKHILFE ACC H01 0072
       Revision: 11001001    Serial number: 61061217801958
       Coding: 08C308
       ASAM Dataset: EV_EPHVA18AU57X0000 003008
       VCID: 77ABEA0AAF4731FFF8F-8022
       Revision: --------    Serial number: 003JG0096JF1
       Coding: 30323436313230303235554A305234473053
       Serial number: 3575HRB405T1EVLEAGIN
       Serial number: 3585HRB404T1DEDA7PQ7
       Serial number: 3515JRB40124UH24N9TO
       Serial number: 3525JRB400O4UH24JHJ/
       Serial number: 3554VRB40044UH245OU
       Serial number: 3564VRB40024UH24B8OL
       Revision: 00000000    Serial number: 20120627000989
       Coding: 000035
       VCID: 303911160A2926C7795-8064
       Component: E221 - MFL  H08 0009
       Part No SW: 4G8 920 950 N    HW: 4G8 920 950 N
       Component: MDieGb        H34 0306
       Revision: 26450232    Serial number: 658230612592057
       Coding: B3A711000B412600010400
       Shop #: WSC 09550 758 180955
       ASAM Dataset: EV_RBC7KMID 004045
       ROD: EV_RBC7KMID.rod
       VCID: 3A2D333EDCD5EC97C71-806E
    16776966 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [Daempfer_01_FR keine Kommunikation]
                        Reset counter: 227
                        Mileage: 233521 km
                        Date: 2020.03.27
                        Time: 21:36:47
    16776974 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [SCU_02 keine Kommunikation]
                        Reset counter: 227
                        Mileage: 233521 km
                        Date: 2020.03.27
                        Time: 21:35:22
       Part No SW: 4G0 907 468 AB    HW: 4G0 907 468 AA
       Component: J533--Gateway H10 0028
       Revision: --------    Serial number: 00000000579367
       Coding: 00CF074400
       ASAM Dataset: EV_GatewPkoUDS 001013
       VCID: 70B9D116CA2966C7395-8024
       Component: J367-BDM  H07 0141
       Serial number: 00000000003790439496
       Voltage stabilizer:
       Subsystem 2 - Part No SW: 8K0 959 663 D    HW: 8K0 959 663
       Serial number: 040412000000000002DA
    6151 - Instrument Cluster Control Module on Optical Bus
              U10C0 00 [009] - No Communication
              [Lost Communication With Instrument Panel Cluster (IPC) Control Module]
                        Reset counter: 187
                        Mileage: 233519 km
                        Date: 2020.03.27
                        Time: 18:29:00
                        Voltage terminal 30: 13.7 V
                        Voltage terminal 15: 13.8 V
                        Control Module temperature: 27 °C
                        System status: Terminal 15 on
                        Engine running: On
                        IN ZAS_Te_X: On
                        Terminal 15 status: On
                        Datenfeld: 0
    12290 - Quiescent Current
              U1406 00 [008] - Too High
                        Reset counter: 227
                        Mileage: 233526 km
                        Date: 2020.03.28
                        Time: 00:27:22
                        Voltage terminal 30: 12.2 V
                        Voltage terminal 15: 0.0 V
                        System status: LIN_active
                        Engine running: OFF
                        IN ZAS_Te_X: OFF
                        Terminal 15 status: OFF
                        Datenfeld: 0
              U140B 00 [008] - -
              [Powermanagement active]
                        Reset counter: 227
                        Mileage: 233526 km
                        Date: 2020.03.28
                        Time: 03:30:33
                        Voltage terminal 30: 12.1 V
                        Control Module temperature: 12 °C
                        Engine running: OFF
                        IN ZAS_Te_X: OFF
                        Datenfeld: 1
       Component: SARA 3D       H02 0053
       Revision: --------    Serial number: EJ1BPA72005MUH
       ASAM Dataset: EV_SARA2 005011
       ROD: EV_SARA2.rod
       VCID: 33331E1AFBBF1DDF047-8066
       Component: TSG FA        H03 0506
       Coding: 011F16005C01620002080002
       VCID: 47CB5ACA9FA7817F48F-8012
    02117 - Motor for Mirror Folding
                        Reset counter: 187
                        Mileage: 233519 km
                        Date: 2020.03.27
                        Time: 20:15:17
       Component: RCEPS         H35 0010
       Revision: 00001000    Serial number: 0005630172
       Coding: 101000010000
       ASAM Dataset: EV_RCEPS 009008
       ROD: EV_RCEPS_009.rod
       VCID: 323D1B1E04A514D70F1-8066
       Revision: 00002001    Serial number: 0179242157
       Coding: 017F162230B90080932009040001040F0000000000000000000000000000
    02874 - Control Module 2 for Central Convenience (J773)
                        Reset counter: 187
                        Mileage: 233519 km
                        Date: 2020.03.27
                        Time: 20:06:25
       Component: TSG BF        H03 0506
       VCID: 46D557CE98AD9877B39-8012
                        Reset counter: 187
                        Mileage: 233519 km
                        Date: 2020.03.27
                        Time: 20:15:17
       Part No SW: 4H0 907 801 F    HW: 4H0 907 801 A
       Component: EPB-4         H03 0013
       Revision: --------    Serial number: 00000000385365
       ROD: EV_ParkiBrake_VW51.rod
       VCID: 2B03067A238F451F4C7-807E
       Serial number: 120626-0001-134
       Coding: 1122961110002100
       ROD: EV_HeadlRegulBasic.rod
       VCID: 2C0105662681422745D-8078
       Part No SW: 4G0 035 193 E    HW: 4G0 035 193 D
       Component: RMC Cnct Nav  H53 0775
       Coding: 0101010101415B47082B060301010000010000
       VCID: 2517F04245EB736F9A3-8070
       Subsystem 1 - Part No: 8X0 919 884 D
       Component: P13-50-11.06  0002
       Subsystem 2 - Part No SW: 4G0 919 603     HW: 4G0 919 603
       Component: DU6 Basic  H42 0084
       Serial number: 9464FZ0C2535463
       Subsystem 3 - Part No SW: 4G2 919 610 E    HW: 4G2 919 610 E
       Serial number: 90349NAO000IL
                        Reset counter: 228
                        Mileage: 233533 km
                        Date: 2020.03.28
                        Time: 17:15:15
                        Bin. Bits: 00000000 00000001
                        Bin. Bits: 00000000 00001000
       Component: TSG HL        H03 0506
       VCID: 49CF5CF289B3770F5EB-801C
       Component: TSG HR        H03 0506
    End----------(Elapsed Time: 01:41, VBatt start/end: 14.5V/14.6V)-----------
    May 2017
    Interesting. Other modules yell headlight module errors but that module is just happy.
    Check the level control arm on rear axle (And possibly front as well if the car has one). Check the the level control arm is not broken.
    Mar 2020
    Dublin, Ireland
    I already did there all fine I was looking through vcds and I tink I mite have changed something by mistake but not sure
    Aug 2019
    My car has a high beam assist control unit at address 20 on the gateway installation list, yours doesn’t seem to have that?
    Also, one of the faults in your 09 centr electrics is no communication with HBA control unit.
    Worth checking your gateway installation list?
    Mar 2020
    Dublin, Ireland
    By any chance would you know to check new to vcds so I'm still learning thanks for your help
  7. #7
    This car doesn't seem to have HBA .
    Even if the GVL was wrong, if the module at address 20 existed, the Gateway should see it and flag it "Not Registered".
    However, the J519 at address 09 is coded to for HBA Installed.
    I think the simpler explanation is that J519 is coded incorrectly. If it were mine, I would try turning off Byte 5, Bit 6.
  8. Likes PetrolDave, downtime liked this post
  9. #8
    Mar 2020
    Dublin, Ireland
    That helped but there was more to it in
    09 cent elec
    Byte 4 bit 7 =1
    Byte 5 bit 5 =1
    Byte 5 but 6 and 7 =0
    It took. Me a little while to figure it out but I got it thank you so much for all your help
  10. Likes Uwe liked this post
  11. #9
    Mar 2020
    Dublin, Ireland
    I just realised when I turn on my all weather lights there not working but they are working as cornering lights any one got any ideas
  12. #10
    I suggest you check up your CodingLog.csv file and have a look at the very first entry for your 09/J519 module. The "from" entry of the first relevant line should have the stock coding for comparison purposes.
  13. Likes PetrolDave liked this post
