Results 1 to 10 of 14
Thread: Received a message saying "please send this scan to Ross-Tech"
    Apr 2019
    Worcester, UK
    Just scanned my 2020 model Touareg with my HEX-NET and using the web interface it said that ASAM data was missing which isn't really surprising.
    I tried the download the first time and tried again but got the same message so I cancelled the download the second time so that I could save the log file but it isn't showing up in saved logs.
    I connected the hex-net to my computer and did a scan. When it finished it said that ROD(s) were missing and asked me to send you the log files. So here it is:
    Saturday,28,March,2020,16:43:16:52412
    VCDS Version: 19.6.2.2 (x64)  HEX-NET CB: 0.4513.4
    VIN: WVGZZZCRZLD003566   License Plate: BJ69LJL
    Mileage: 10801km-6711mi   Repair Order:
    Chassis Type: CR-VW53 (4N2)
    Scan: 01 02 03 06 09 13 15 16 17 19 2B 36 42 44 46 52 5F 69 6C 6D
              74 81 A5 AC BB BC CB D6 D7 DE
    VIN: WVGZZZCRZLD003566   Mileage: 10801km-6711miles
    CB-Rear Axle Steering -- Status: OK 0000
    DE-Charger 1 for mobile dev -- Status: OK 0000
    Address 01: Engine (J623-DENA)       Labels: None
       Part No SW: 760 907 401 G    HW: 059 907 309 L
       Component: 3.0l V6 TDI   H26 0002
       Revision: CAH26---
       Coding: 292A4032057E050335180000000400000000000000000000
       Shop #: WSC 31414 039 00001
       ASAM Dataset: EV_ECM30TDI011760907401G 001002
       ROD: N/A
       VCID: 197A3B6B18550E8742-804C
    No ASAM data for: "EV_ECM30TDI011760907401G" (VW53)
    31519 - ROD - Unknown Error Code
              - 00 [100]
                        Mileage: 10688 km
                        Date: 2020.03.21
                        Time: 13:38:50
    21583 - ROD - Unknown Error Code
              - 00 [032]
    Address 02: Auto Trans (J217)       Labels:* Redir Fail!
       Part No SW: 760 927 158 B    HW: 0D5 927 156 N
       Component: 0D5  30TDIRdW H05 1003
       Revision: --H05---
       Coding: 100000
       ASAM Dataset: EV_TCMALX52011 002014
       ROD: EV_TCMALX52011.rod
       VCID: 1F0E1573067160B7BC-804A
       Part No SW: 4M6 907 379 AC    HW: 4M6 907 379
       Component: ESP9 Premium  H06 0856
       Coding: 1DA732B730A20B99DEA34897188356EAE93AE1B84C0CD07B12186A57975C87
       ASAM Dataset: EV_ESP9BOSCHCMP 004011
       ROD: EV_ESP9BOSCHCMP_VW53.rod
       VCID: 7EB008F7E13BC9BFD7-802A
    200960 - Databus
              [Signal_LWR_Hoehenwert_VL_error_(255)]
       Part No SW: 4M6 959 760 B    HW: 4M6 959 760 B
       Component: MEM-BFS       009 0044
       Serial number: 00000384427733
       Coding: 0138B8000000A88188000101210100008900000707008F8F00000000015000
       Shop #: WSC 31414 043 00001
       ROD: EV_SCMPasseSideCONTIAU736_VW53.rod
       VCID: 3D32CFFBACBD12A78E-8068
       Subsystem 1 - Part No SW: 4N0 907 182     HW: 4N0 907 182
       Component: N477 VB1 BFSv  H04 0011
       Serial number: SJ8001250619402580D7
       Coding: BF2F00
       Part No SW: 4N0 907 063 KG    HW: 4N0 907 063 AG
       Component: BCM1 MLBevo   H10 0691
       Coding: 07501143E1790009070D97085BBE8C40000B30100000009301100800FB2476011BC500BB12B6C6170000010000D128181800000044010104000000000000000000
       ASAM Dataset: EV_BCM1BOSCHAU651 016011
       ROD: EV_BCM1BOSCHAU651_016_VW53.rod
       VCID: 7DB20FFBEC3DD2A7CE-8028
       Subsystem 1 - Part No SW: 762 955 113     HW: 762 955 113
       Component: WIPER 250719  011 0420
       Serial number: VZ1SKA 1000917250719
       Serial number: 23357623X81A955555A0
       Coding: 02006D
       Light switch:
       Subsystem 3 - Part No SW: 762 941 633     HW: 762 941 633
       Component: E1 - LTM  H06 0054
       Serial number: 13S27.06.1900140204
       Subsystem 4 - Part No SW: 3G0 857 511 AL    HW: 3G0 857 511 AL
       Serial number: GX1CE130041920810040
       Coding: 030000
       Interior Light Module:
       Subsystem 5 - Part No SW: 760 947 105 N    HW: 760 947 105 N
       Component: Dachelektroni  H32 0057
       Serial number: 00000774360000000000
    405507 - Functional Limitation due to Energy Management
              B10CD 00 [009] - -
              [Function limitation due to energy management system]
                        Reset counter: 183
                        Mileage: 10801 km
                        Date: 2020.03.27
                        Time: 12:01:12
                        average_Voltage_terminals: 11.40 V
                        Outside air temperature sensor-Resistance: 0.00 kOhm
                        Outside air temperature sensor-Outside air temperature on CAN: 8.50 °C
                        interior_temperature: 15.50 °C
                        Vehicle speed: 0.00 km/h
       Part No SW: 760 907 561 C    HW: 760 907 561
       Component: LRR4R         H04 0333
       Coding: 32657FCB78000400000020A000000010051246484401009E00
       ASAM Dataset: EV_ACCBOSCHAU65X 002023
       ROD: EV_ACCBOSCHAU65X_VW53.rod
       VCID: 1C74227F17677BAF59-8048
       Part No SW: 4M0 959 655 J    HW: 4M0 959 655 J
       Component: AirbagVW31    H07 2720
       Serial number: 003YQM020RRC
       Coding: 88CCC0C00C800000585400EF308D41A80065
       Shop #: WSC 31414 030 00001
       ASAM Dataset: EV_AirbaVW31SMEAU65x 001032
       ROD: EV_AirbaVW31SMEAU65x_VW53.rod
       VCID: 42C8BC07D5436D5FF3-8016
       Subsystem 1 - Part No SW: -----------    HW: 480 002 207 19
       Serial number: 357000000004BC819E3Y
       Subsystem 2 - Part No SW: -----------    HW: 480 002 207 19
       Serial number: 35800000000D0B152E3M
       Subsystem 3 - Part No SW: -----------    HW: 480 032 507 19
       Component: SideSensor_Dr  002 0149
       Serial number: 351001C24B8AC8C07B0L
       Subsystem 4 - Part No SW: -----------    HW: 480 032 507 19
       Component: SideSensor_Pr  002 0149
       Serial number: 352001C1CC740CA03B1A
       Subsystem 5 - Part No SW: -----------    HW: 480 030 606 19
       Component: FrontSensor_D  002 0189
       Serial number: 355001C20FF2EDF0CB95
       Front Sensor Passenger:
       Subsystem 6 - Part No SW: -----------    HW: 480 030 606 19
       Component: FrontSensor_P  002 0189
       Serial number: 356001C20FF326A07ABM
       Pedestrian Protection Driver:
       Subsystem 7 - Part No SW: -----------    HW: 480 032 606 19
       Component: PedP_Sensor_D  002 014A
       Serial number: 228001C208FD7590192A
       Subsystem 8 - Part No SW: -----------    HW: 480 031 807 19
       Component: PedP_Sensor_P  002 014A
       Serial number: 229001C2462C0020BC90
       Pedestrian Protection Center:
       Subsystem 9 - Part No SW: -----------    HW: 480 032 506 19
       Component: PedP_Sensor_C  002 014A
       Serial number: 230001C208F57E711D6B
       Subsystem 10 - Part No SW: -----------    HW: 480 001 406 19
       Serial number: I0M00000000B1438CCBG
       Subsystem 11 - Part No SW: -----------    HW: 480 001 406 19
       Serial number: I0N00000000E1438CCBK
       Part No SW: 760 953 507 B    HW: 760 953 507 B
       Component: Lenks.Modul   H03 0006
       ROD: EV_SMLSKLOAU736_VW53.rod
       Part No SW: 762 920 790 A    HW: 762 920 790 A
       Component: FBenRDW       H12 0208
       Coding: A5A631E27F94260001A86322B0E06808E40000A0
       ASAM Dataset: EV_DashBoardAU65X 001017
       ROD: EV_DashBoardAU65X_VW53.rod
       VCID: 1B76216312697C9750-804E
       Operating Unit Drive Mode Selection:
       Subsystem 1 - Part No SW: 760 927 531 G    HW: 760 927 531 G
       Component: E881 BedieFPA  001 0460
       Serial number: 000000091171SG3000M1
       Level control system control head:
       Subsystem 2 - Part No SW: 760 927 135 B    HW: 760 927 135 B
       Component: E281 BedieNiv  001 0110
       Serial number: 000000091171SG3001CH
       Part No SW: 4N2 907 468 BB    HW: 4N2 907 468 AB
       Component: Gateway       H16 0052
       Revision: BD000001    Serial number: 018BD855619725
       Coding: 0301000300008E407F07000000DB0532589E00070C000000037D078E10000100
       ASAM Dataset: EV_CGateCONTIAU491 004190
       ROD: EV_CGateCONTIAU491_004_VW53.rod
       VCID: 7AB804E7FD13E59FEB-802E
       Subsystem 1 - Part No SW: 5G0 959 442 AB    HW: 5G0 959 442 AB  Labels: 3C8-959-537.CLB
       Component: E221__MFL-MD9  H18 0052
       Serial number: 39190001239260049243
       Coding: 2FFFFF
       Serial number: 7379992105
    8519683 - Energy Management Active
              U140B 00 [009] - -
                        Reset counter: 183
                        Mileage: 10801 km
                        Date: 2020.03.27
                        Time: 12:01:03
                        EM_vehicle_state: 00 10
                        Static current shutdown level: Deactivation stage 1
                        Auxiliary heater activation restriction request-Parking heater: Permitted
                        Auxiliary heater activation restriction request-Allowed parking heater runtime: 0 min
       Part No SW: 3Q0 905 861 C    HW: 3Q0 905 861 C
       Component: ELV-MLBevo    H05 0020
       Serial number: 19000192483014
       Coding: 8800000000000000
       ROD: EV_ELVMarqMQBA0_VW41.rod
       VCID: 3424EADF9FF7D3EF71-8060
       Component: MEM-FS        009 0044
       Serial number: 00000384338324
       Coding: 01389A400000A48188000101210100008900000707008F8F00000000015000
       ROD: EV_SCMDriveSideCONTIAU736_VW38.rod
       Component: N475 VB1 FSv  H04 0011
       Serial number: SJ8001250619402580CF
       Coding: BF2F00
       Part No SW: 4M1 959 593 J    HW: 4M1 959 593 D
       Component: TSG FS002 0421
       Serial number: YE007SFF28625
       Coding: 003F9A00DE01040000013082
       ASAM Dataset: EV_DCU2DriveSideMAXHKLO 001018
       ROD: EV_DCU2DriveSideMAXHKLO_VW53.rod
       VCID: 44C4BA1FCF57636FC1-8010
       Part No SW: 4N0 909 144 E    HW: 4N0 909 144 C
       Component: EPS_MLBEVO2BS H22 0505
       Coding: B2150101000100
       ASAM Dataset: EV_EPSVWBSAU426 010017
       ROD: EV_EPSVWBSAU426_010.rod
       VCID: 3228ECC765E3DDDF63-8066
       Part No SW: 4N0 907 064 DP    HW: 4N0 907 064 P
       Component: BCM2 MLBevo H15 0202
       Coding: 01350000AFB000487329A0041C00480203000000004704502F0400000508803F001F31C4010001
       ASAM Dataset: EV_BCM2CONTIAU651 010009
       ROD: EV_BCM2CONTIAU651_010_VW53.rod
       VCID: 004C760F9BCFBF4FA5-8054
       Ignition key:
       Subsystem 2 - Part No SW: 5Q0 951 172     HW: 5Q0 951 172
       Serial number: 000000000ZY1916516JJ
       Subsystem 3 - Part No SW: 5Q0 951 605 B    HW: 5Q0 951 605 B
       Component: Sirene, DWA  004 0007
       Serial number: 00000000000000487902
       Rear Spoiler Adjustment:
       Part No SW: 4M1 959 592 J    HW: 4M1 959 592 D
       Component: TSG BFS002 0421
       Serial number: YE007SFF3060B
       Coding: 003F9A00DE01040000013080
       ASAM Dataset: EV_DCU2PasseSideMAXHKLO 001018
       ROD: EV_DCU2PasseSideMAXHCONT_VW27.rod
       VCID: 43C6B903CA596457F8-8016
       Part No SW: 760 035 063 A    HW: 760 035 063 A
       Component: MU-H-LND-EU   049 2648
       Coding: 02350601FF00000043110101C08808301F0206E601A004009F
       Shop #: WSC 31414 152 00001
       ASAM Dataset: EV_MUHigGen2pALPI 001001
       ROD: EV_MUHigGen2pALPI_VW53.rod
       VCID: 0F6E4533D691D0372C-805A
       Subsystem 1 - Part No SW: 762 919 618     HW: 762 919 618
       Component: ABT_Prem_R  H40 5211
       Serial number: VWZ6ZGW1710136
       Subsystem 2 - Part No: V03 959 805 HG
       Component: MIB2P_EU_Q119  0360
       Subsystem 3 - Part No: V03 959 800 EG
       Component: Gracenote2  1010
       Volume Control 1:
       Subsystem 4 - Part No SW: 762 927 341     HW: 762 927 341
       Component: VW536LLB  H06 0109
       Serial number: 2019050600000182
       Media socket:
       Subsystem 5 - Part No SW: 5G0 035 953 D    HW: 0
    H08 0014
       Part No SW: 4M0 907 383 G    HW: 4M0 907 383 B
       Component: Anhaenger     H33 0273
       Revision: 9A001003    Serial number: 0522821047
       Coding: 0110000202000000
       ROD: EV_TrailFunctGener2Hella_VW27.rod
       VCID: 3620D0D7898BC1FF4F-8062
    Address 6C: Back-up Cam. (J772)       Labels:* None
       Part No SW: 760 980 568     HW: 760 980 568
       Component: RVC Compact+  H09 0250
       Coding: 0135060123002015000048
       ASAM Dataset: EV_CamSysRVRVCARPANAMLBEv 001001
       ROD: EV_CamSysRVRVCARPANAMLBEv_VW53.rod
       VCID: 618A538B70851647CA-8034
       Part No SW: 4M0 959 107 D    HW: 4M0 959 107 A
       Component: HDSG-Modul    H13 0171
       Revision: --------    Serial number: A2-C737-6252-4
       Coding: 17D8
       ROD: EV_DeckLidCONTIAU736_VW53.rod
    Address 74: Chassis Control (J775)       Labels:* None
       Part No SW: 4M0 907 777 S    HW: 4M0 907 777 B
       Component: Fahrwerk-SG   H37 1253
       Serial number: 0807190824
       Coding: B0504940F8
       ASAM Dataset: EV_ChassContrContiAU426 001004
       ROD: EV_ChassContrContiAU426.rod
       VCID: 49DAAB2BE875BE0732-801C
       Air Suspension Compressor:
       Subsystem 1 - Part No SW: 4M0 907 778     HW: 4M0 907 778
       Component: V66LFKompOLV  H06 0013
       Serial number: 00000000004130657889
       Coding: 303030
       Part No SW: 762 713 041 B    HW: 4M2 713 041 G
       Component: GSM-LL        H10 0077
       Revision: 0L0D5012    Serial number: 19061753171127
       ROD: EV_GSMWaehlZFAU736.rod
       VCID: 116A434BC0A5C6C73A-8044
    Address A5: Frt Sens. Drv. Assist (J1121)       Labels:* None
       Part No SW: 4KE 907 107 AL    HW: 4N0 907 107 G
       Component: zFAS Var B    H09 0293
       Coding: 04C2840000000000000806000090C63C18075300000000000000000000000000000000000000000000000000000000000000000000000000000040000000000000001004000000700000004000000000008040000020
       ASAM Dataset: EV_ZFASAU516 001003
       ROD: EV_ZFASAU516_VW53.rod
       VCID: 095A6B2BA8F5FE07F2-805C
    Address AC: Reductant Control (J880)       Labels: 4M0-907-355.clb
       Part No SW: 4M0 907 355 D    HW: 4M0 907 355 B
       Component: SCR-Stg-G3H05 0006
       ASAM Dataset: EV_RDCMINERGAU736 005012
       ROD: EV_RDCMINERGAU736_VW53.rod
       Part No SW: 4M1 959 595 J    HW: 4M1 959 595 D
       Component: TSG HFS004 0421
       Serial number: YE007SFK23657
       Coding: 003E92000000040000013080
       ASAM Dataset: EV_DCU2RearDriveMAXHKLO 001018
       VCID: 46C0A017F96B517FDF-8012
       Component: TSG HBFS004 0421
       Serial number: YE007SFK23656
       ASAM Dataset: EV_DCU2RearPasseMAXHKLO 001018
    Address CB: Rear Axle Steering (J1019)       Labels:* None
       Part No SW: 4M0 909 145 AA    HW: 4M0 909 145 E
       Component: HAL_MLBevoH08 0698
       Revision: --------    Serial number: CCC_098_B_1122_
       Coding: 42250E00
       ASAM Dataset: EV_RearAxleSteerZFAU736 010018
       ROD: EV_RearAxleSteerZFAU736_010.rod
       VCID: 6FAE25B3B651B0374C-803A
       Part No SW: 7P5 941 591 BH    HW: 7P5 941 591 B
       Component: LED1L         H07 0009
       ROD: EV_LED_PLUS_L_KEBODAVW416_VW27.rod
       VCID: 034679038AD9A457B8-8056
       Component: LED1R         H07 0009
       ROD: EV_LED_PLUS_R_KEBODAVW416_VW53.rod
    Address DE: Charger 1 for mobile dev (J1146)       Labels:* 4N0-035-502.clb
       Part No SW: 4N0 035 502 B    HW: 4N0 035 502 B
       Component: WLC Front     H14 0061
       Coding: 400000
       ASAM Dataset: EV_Charg1MobilDevicAU651 004001
       ROD: EV_Charg1MobilDevicAU651.rod
       VCID: 230619832A19445798-8076
    End----(Elapsed Time: 02:14, VBatt start/end: 11.3V/11.4V. VIgn 11.3V)-----
    Saturday,28,March,2020,16:44:22:52412
  2. Likes NEtech, Uwe, DV52, Dana liked this post
  3. #2
    I expect there will be a new version of VCDS out next week that will address this.
    PS: As this issue is not HEX-NET specific, I'm moving it to VCDS Support.
    Apr 2019
    Worcester, UK
    Thanks very much. I'll keep an eye out for that and report back.
    Apr 2019
    Worcester, UK
    Actually, there are a number of issues here which may or may not be related to each other.
    I forgot to mention that I can't get into the advanced section on the engine (I only wanted to check the adblue level) but I assume that is because of the missing data file.
    Maybe I should have posted them separately?
    Mar 2014
    Europe
    Looking forward to a new version of VCDS too
    I contacted the support this week due to similar issue with new Octavia NX (SK38) which I was not able to scan at all
    Quote Originally Posted by icardiag View Post
    I would not have high hopes for SK38 just yet.
    Mar 2014
    Europe
    I hope at least scanning and adp reading will be available. Regarding SFD, well we'll see...
  9. #8
    You will certainly be able to try, and provide feedback.
  10. Likes icardiag liked this post
  11. #9
    Quote Originally Posted by technodevotee View Post
    Just scanned my 2020 model Touareg with my HEX-NET. So here it is:
    Wow- that's the second-longest long-code string I've seen on a module!!!
  12. Likes PetrolDave, Uwe liked this post
  13. #10
    Kinda makes switching from (very) long coding to all adaptation channels more understandable IMHO.
  14. Likes Uwe liked this post
