Results 1 to 10 of 11
Thread: New user retrofitting MFSW help needed
    New User
    Mar 2020
    Hi all,
    I have a 2009 Audi A5 with a non MFSW basic steering wheel.
    I have fitted a MFSW with paddles and what I think is the correct slip ring 8K0953568F I have used Vcds to code the new angle sensor and select MFSW with paddles.
    Airbag is fine no errors
    Horn works.
    MFSW buttons light up but don’t work
    Paddles light up but don’t work.
    Any help would be great.
    Thanks
    [IMG][/IMG]
    Jun 2014
    Start posting a complete and unedited autoscan...
    Golf VII, 1.6TDI BM Ed. 40 - 110 PK
  3. Likes PetrolDave, Uwe liked this post
    New User
    Mar 2020
    Saturday,28,March,2020,13:05:48:24439
    VIN: WAUZZZ8F6AN012942   License Plate: D8LCS
    Mileage: 86420km-53698mi   Repair Order:
    Chassis Type: 8F-AU48 (8T0)
    Scan: 01 02 03 05 08 09 15 16 17 19 26 2E 42 46 52 53 56 62 72 77
    VIN: WAUZZZ8F6AN012942   Mileage: 86420km-53698miles
    77-Telephone -- Status: Sporadic communication error 1000
    Address 01: Engine (CL0MA-CDNC)       Labels:| 06H-907-115-CAB.clb
       Part No SW: 8K2 907 115 P    HW: 8K2 907 115 D
       Component: 2.0l R4/4V TF H15 0006
       Revision: E1H15---
       Coding: 011C000C02070060
       Shop #: WSC 02145 785 00200
       ASAM Dataset: EV_ECM20TFS8K2907115P A01008
       ROD: EV_ECM20AVS.rod
       VCID: 3C21356466EE5097D5D-8068
    7150 - Please Check DTC Memory of Steering Wheel Electronics
              P1698 00 [032] - -
                        Mileage: 86420 km
                        Date: 2009.05.28
                        Time: 20:00:14
                        Coolant temperature: 66 °C
                        Intake air temperature: 44 °C
                        Voltage terminal 30: 11.921 V
    7788 - Software Incompatibility with Instrument Panel Control Module
              U0323 00 [047] - -
                        Mileage: 86420 km
                        Date: 2009.05.28
                        Time: 20:00:16
    Readiness: 1110 0100
       Part No SW: 8K0 927 155 AC    HW: 0AW 927 156 H
       Component: 0AW 20TFSIRdW H02 0004
       Revision: --H02---    Serial number: 0000000622
       ASAM Dataset: EV_TCMVL381 A02006
       ROD: EV_TCMVL381.rod
       VCID: 74B1DD440E3ED8D7DDD-8020
       Part No SW: 8K0 907 379 AK    HW: 8K0 907 379 AK
       Component: ESP8 front    H04 0070
       Coding: 080500
       Shop #: WSC 02391 823 56573
       VCID: 025D8B9C440AE667DF1-8056
                013 - Check DTC Memory
                        Fault Status: 01101101
                        Reset counter: 215
                        Mileage: 86421 km
                        Date: 2009.05.29
                        Time: 17:15:23
                        Hex Value: 0x0000
                        Hex Value: 0x0082
                        Hex Value: 0x0032
                        Hex Value: 0x3392
                        Hex Value: 0x00FF
       Part No SW: 8K0 907 064 DC    HW: 8K0 907 064 DC
       Component: BCM2 1.1      H02 0326
       Coding: 011300
       Shop #: WSC 02399 823 56573
       VCID: 74B1DD440EBED8D7DDD-8020
       Subsystem 1 - Part No SW: 8K0 959 754 D    HW: 8K0 959 754 D
       Serial number: 0816000040328017
       Serial number: 0209000068751007
       Part No SW: 8T2 820 043 AD    HW: 8T2 820 043 AD
       Component: KLIMA 1 ZONE  H08 0171
       Revision: B0000000    Serial number: 01011020090405
       Coding: 64070000
       Part No SW: 8K0 907 063 D    HW: 8K0 907 279 D
       Component: BCM1 1.0      H19 0253
       Revision: 05019001    Serial number: 00000000025294
       Coding: 2600D0910014AE010009000000005D5D4C09028800010001000000
       Shop #: WSC 00482 210 80117
       VCID: 30391154BA26A4F7795-8064
       Subsystem 1 - Part No SW: 8F2 955 119     HW: 8K2 955 119   Labels: 1KX-955-119.CLB
       Component: WWS 290909  H05 0021
       Serial number: SWF09090295146
       Coding: 00FD11
       Subsystem 2 - Part No SW: 8K0 941 531 AK    HW: 8K0 941 531 AK
       Component: E1 - LDS  H08 0090
       Serial number: 00000000002309090301
                        Fault Frequency: 8
                        Reset counter: 215
                        Mileage: 86420 km
                        Date: 2009.05.28
                        Time: 20:30:00
    Address 15: Airbags (J234)       Labels:| 8F0-959-655.clb
       Part No SW: 8F0 959 655     HW: 8F0 959 655
       Component: AirbagVW-AU10 H10 0430
       Serial number: 003A4D0615ED
       Coding: 30363635353130303030554A305238463053
       Shop #: WSC 02135 785 00200
       ASAM Dataset: EV_AirbaAU10SMEAU485 001004
       ROD: EV_AirbaECUVWAUDI010.rod
       VCID: 75B7E0400544C1DFEA3-8020
       Serial number: 6334MSME4B03256CG
       Serial number: 6344MSME4B026C50E
       Serial number: 6352QSME053D08107
       Serial number: 6362QSME223B4912C
       Serial number: 63732SME033E1914Y
       Serial number: 63832SME05525076U
       Component: Lenks.Modul   H16 0014
       Revision: --------    Serial number: 90319IKB000BF
       Coding: 000030
       Shop #: WSC 06335 123 12345
       VCID: 3D2738607D74599FE23-8068
    01426 - Controls in Steering Wheel (E221)
                        Reset counter: 214
                        Mileage: 86421 km
                        Date: 2009.05.28
                        Time: 23:15:58
                        Reset counter: 215
                        Mileage: 86421 km
                        Date: 2009.05.29
                        Time: 17:14:12
       Part No SW: 8T0 920 950 P    HW: 8T0 920 950 P
       Component: KOMBIINSTR.   H32 0253
       Revision: 00000000    Serial number: BX6433C59
       Coding: 2347180002002600010000
       VCID: 45D7508015A4115FBA3-8010
       Part No SW: 8T0 907 468 R    HW: 8T0 907 468 H
       Component: GW-BEM 5CAN   H06 0105
       Revision: GB600050    Serial number: 5000G09926840C
       Coding: 00C303
       VCID: 50F971D4DAE6C4F7195-8004
       Component: J367-BDM  H06 0170
       Serial number: 19090EFB100909
                        Reset counter: 0
                        Mileage: 86420 km
                        Date: 2009.05.28
                        Time: 19:39:34
                        Bin. Bits:    10111
                        Voltage: 11.90 V
                        Count: 6
                        Text: FF30752C80220001
                        (no units): 29879.0
                        Reset counter: 0
                        Mileage: 86421 km
                        Date: 2009.05.28
                        Time: 20:37:20
                        Bin. Bits:    10000
                        Voltage: 12.60 V
                        Count: 7
                        Bin. Bits:    10000
    02256 - Quiescent Current
                        Fault Status: 00100001
                        Reset counter: 0
                        Mileage: 86421 km
                        Date: 2009.05.29
                        Time: 00:41:00
                        Reset counter: 0
                        Mileage: 86421 km
                        Date: 2009.05.29
                        Time: 04:41:00
                        Bin. Bits:    00000
                        Voltage: 12.10 V
                        Count: 17
    Address 26: Auto Roof (J256)       Labels:* 8F0-959-255.clb
       Part No SW: 8F0 959 255     HW: 8F0 959 255
       Component: VSG-AUDI-B8   H09 0170
       ASAM Dataset: EV_ElectRoofContr 001007
       ROD: EV_ElectRoofContr.rod
       VCID: 71BFD450712CEDFF36B-8024
       Part No SW: 8T0 035 785     HW: 8T0 035 785
       Revision: 00000000
       Coding: 020202
       VCID: 78A9E97412D6BCB7F15-802C
       Part No SW: 8K0 959 793 H    HW: 8K0 959 793 D
       Component: TSG FA        H11 0306
       Revision:             Serial number: 0000009390296
       Coding: 011042724009330C03
       Revision: 00002001    Serial number: 0121939024
       Coding: 011B07A2003900200230038000000000
       Subsystem 1 - Part No: 8P7 951 177
       Component: DWA-Sensor  H03 0040
       Part No SW: 8K0 959 792 H    HW: 8K0 959 792 D
       Component: TSG BF        H11 0306
       Revision:             Serial number: 0000009365137
       Coding: 011042324009330C03
       VCID: 44D14D841E9E2857ADD-8010
       Revision: 00000003    Serial number: 10000000332788
       VCID: 34311D444E3E98D71DD-8060
       Part No SW: 8T2 035 186 P    HW: 8T2 035 186 P
       Component: Concert3      H04 0310
       Revision: 00000007    Serial number: AUZ5Z6I1280411
       Coding: 050204830403CD028159870902
       Shop #: WSC 00055 022 12345
       Subsystem 1 - Part No SW: 8T0 919 603 G    HW: 8T0 919 603 G
       Component: Display
    00463 - Control Module for Digital Sound Package (J525)
                        Reset counter: 213
                        Mileage: 86420 km
                        Date: 2009.05.28
                        Time: 19:27:43
       Part No SW: 8K0 959 795 E    HW: 4F0 959 795 L
       Component: TSG HL        H10 0306
       Revision:             Serial number: 0000102005371
       Coding: 010002324009370C03
       Component: TSG HR        H10 0306
       Revision:             Serial number: 0000102005332
    Address 77: Telephone
    End----(Elapsed Time: 01:26, VBatt start/end: 11.8V/11.8V. VIgn 11.8V)-----
    New User
    Mar 2020
    can anyone help?
    its driving me mad
    I think you need to get the Component Protection cleared in #09 and #19 as a first step.
  7. Likes Uwe liked this post
    New User
    Mar 2020
    That’s next on my list but can’t see me getting it done anytime soon due to all garages with the Odis diagnostics shut.
    Was hoping to try and figure out why my MFSW wasn’t working as I don’t think the component protection restricts this but I could be wrong
    Apr 2018
    ITALY
    you don't think CP restricts a function based on what assumption? my car was acting very funny when CP triggered due to replacing modules. nobody really know which or what function gets cut/restricted.
    my Golf left the factory with 18 ECUs. now she has 27. and counting
  10. #8
    Tartu, Estonia
    Module 16 clearly tells it's unhappy about coding. Why's that?
    The world is my oyster...
  11. #9
    New User
    Mar 2020
    like i say could be wrong......
    hopefully get it removed when audi re open
  12. #10
    New User
    Mar 2020
    not sure, ive coded it but no joy
