Results 1 to 7 of 7
Thread: 2016 MY16 Passat TDI 140 Highline Diesel (Australian Model) faults
    Mar 2020
    Australia
    Hi everyone,
    I posted a similar post in the new user forum to introduce myself but have decided maybe it should have been posted in here. (Admin can you let me know? Thanks)
    I have fault codes across 5 modules all with the 0010 code. I wonder if anyone can let me know if coding needs to change or something else. By way of context, I upgraded the car with PLA3.0 from Kufatec which had their own coding dongle, I am not sure if that coded other modules or just the Parking/Steering section as it is showing no faults.
    Saturday,28,March,2020,15:39:37:41391
    VIN: WVWZZZ3CZGExxxxxx   License Plate: xxxxxxx
    Mileage: 83672km-51991mi   Repair Order:
    Chassis Type: 3C-VW48 (5Q0)
    Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 3C 42 44 52 5F 6C A5
              CF
    VIN: WVWZZZ3CZGE1xxxxxx   Mileage: 83672km-51991miles
    Address 01: Engine (J623-DFCA)       Labels:. 04L-907-309-V1.clb
       Part No SW: 04L 906 026 FN    HW: 04L 907 309 M
       Component: R4 2,0L EDC   H23 1195
       Revision: B4H23---
       Coding: 011D0012046505083000
       Shop #: WSC 05311 115 00318
       ASAM Dataset: EV_ECM20TDI01104L906026FN 002001
       ROD: EV_ECM20TDI01104L906026FN_002_VW48.rod
       VCID: 7BA3F1D0736F7A2F9C7-802E
       Part No SW: 0D9 300 041 J    HW: 02E 927 770 AQ
       Component: DQ250-6F MQB  H53 4906
       Revision: 06253104    Serial number: TFK01510270727
       Shop #: WSC 05311 115 00089
       ROD: EV_TCMDQ250021.rod
       VCID: 1F1BE5408737C60FD0F-804A
       Revision: 00000000    Serial number: 63185000000703
       Coding: 0EEC928F34230B6E077A060041C64970492CD0E0608292F51862F03AC2A9
       Shop #: WSC 17873 123 50804
       VCID: 7AADF4D47C554327871-802E
    8307 - Databus
              [FCAN: PLA_Status_PLA_ESP signal is invalid]
                        Fault Frequency: 19
                        Reset counter: 36
                        Mileage: 83408 km
                        Date: 2020.02.27
                        Time: 11:34:33
    16401 - Tire Pressure Warning
              C102D 00 [009] - -
                        Reset counter: 245
                        Mileage: 83547 km
                        Date: 2020.03.12
                        Time: 05:59:19
       Part No SW: 3Q0 959 435 C    HW: 3Q0 959 435 C
       Component: VWKESSYMQB    036 0710
       Revision: 00036000    Serial number: 0385786377
       Coding: 0F00100F03
       Shop #: WSC 04174 123 61029
       VCID: 3A2D34D43CD58327C71-806E
       Part No SW: 5G0 907 044 BG    HW: 5G0 907 044 BG
       Component: Climatronic   H04 1202
       Revision: 00001K10
       Coding: 1112010430210000111550401210180A
       ASAM Dataset: EV_ACClimaBHBVW37X 005137
       VCID: 6D87CF883D1BE49F123-8038
       Geber f¸r K‰ltemitteldruck/K‰ltemitteltemperatur:
       Air quality sensor:
    263682 - Exterior Air Quality/Humidity Sensor
              B137A 31 [008] - No Signal
                        Reset counter: 36
                        Mileage: 83651 km
                        Date: 2020.03.24
                        Time: 15:20:21
                        Voltage terminal 30: 14.5 V
                        Outside air temperature: 23.5 ∞C
                        System run time-Engine running time: 255 s
                        System run time-Terminal 15 on: 255 s
       Part No SW: 5Q0 937 086 AJ    HW: 5Q0 937 086 AJ
       Revision: --------    Serial number: 86581111151510
       Coding: 03011B46C2C102FF07A04094B11007281880000000000000000000000000
       ROD: EV_BCMBOSCH_015.rod
       VCID: 025D8C3414850BE7DF1-8056
       Subsystem 1 - Part No SW: 3G2 955 119 A    HW: 3G1 955 119   Labels: 5QX-955-119-V1.CLB
       Component: WWS    150801  043 0607
       Serial number:         150930150330
       Component: RLHS  037 0059
       Serial number: S4Y15M11D19H15M36S17
       Coding: 90A8DD
       Subsystem 3 - Part No SW: 3G0 941 633     HW: 3G0 941 633
       Serial number: 15 06 2015  10000699
       Serial number: 000000000ZY1527208K0
       Component: Sirene, DWA  005 0312
       Serial number: 00000000000033891458
    534549 - Databus
                        Reset counter: 23
                        Mileage: 83408 km
                        Date: 2020.02.27
                        Time: 11:33:16
    540693 - Databus
                        Reset counter: 238
                        Mileage: 83408 km
                        Date: 2020.02.27
                        Time: 11:33:16
    204546 - Remote key 2
                        Reset counter: 238
                        Mileage: 83411 km
                        Date: 2020.02.27
                        Time: 11:48:52
       Part No SW: 5QA 919 298 C    HW: 5QA 919 298 A
       Serial number: 000308417618339
       Coding: 0371167851
       ROD: EV_EPHVA2CAU3700000.rod
       VCID: 50F9767C8A692977195-8004
       Part No SW: 3Q0 907 572 B    HW: 3Q0 907 572 B
       Component: ACC BOSCH MQB H04 0192
       Coding: 320467D251FFC428949C804D
       Shop #: WSC 00015 115 00001
       ASAM Dataset: EV_ACCBOSCHVW48X 001008
       ROD: EV_ACCBOSCHVW48X.rod
       VCID: 34311AEC1EB175571DD-8060
    1538 - Sensor for Automatic Distance Control
              [FAULT_SENSOR_BLIND]
                        Reset counter: 29
                        Mileage: 83497 km
                        Date: 2020.03.06
                        Time: 15:21:06
                        Control Module temperature: 42 ∞C
                        Voltage terminal 15: 12.8 V
                        Velocity_vehicle_reference: 28.51 m/s
                        Longitudinal_acceleration_vehicle_reference: 0.06 m/s≤
                        Status_ACC_System: ACC_activ_controlled
    1542 - Sensor for Automatic Distance Control
              [FAULT_SYSTEM_BLIND]
                        Reset counter: 29
                        Mileage: 83498 km
                        Date: 2020.03.06
                        Time: 15:21:32
                        Control Module temperature: 41 ∞C
                        Voltage terminal 15: 13.0 V
                        Velocity_vehicle_reference: 29.54 m/s
                        Longitudinal_acceleration_vehicle_reference: 0.34 m/s≤
                        Status_ACC_System: ACC_Override
       Part No SW: 3Q0 959 655 BB    HW: 3Q0 959 655 BB
       Component: Airbag VW20   013 0195
       Revision: --------    Serial number: 003STPPAKVGF
       Coding: 98FCC0C0000000005C540000008800000065
       Shop #: WSC 05314 000 00001
       ROD: EV_AirbaVW20TS6VW48X.rod
       VCID: 7F5B05C06777660FB0F-802A
       Subsystem 1 - Part No SW: -----------    HW: 454 000 111 15
       Serial number: 3576U00000065689971G
       Subsystem 2 - Part No SW: -----------    HW: 454 000 111 15
       Serial number: 3586U000000ED489971V
       Subsystem 3 - Part No SW: -----------    HW: 454 800 211 15
       Serial number: 3516R5962C5080000003
       Subsystem 4 - Part No SW: -----------    HW: 454 802 410 15
       Serial number: 3526R6E93BC08000000K
       Subsystem 5 - Part No SW: -----------    HW: 454 801 610 15
       Serial number: 3556V18CCC108000000I
       Part No SW: 3Q0 953 521 B    HW: 5Q0 953 569 A
       Revision: FF033033    Serial number: 20151021400459
       Coding: 0810
       ROD: EV_SMLSVALEOMQB.rod
       VCID: 2F3B1580F797568F60F-807A
       Part No SW: 3G0 920 751 A    HW: 3G0 920 751 A
       Component: KOMBI         301 6421
       Coding: 27A401186798000801887B0B1000000000000000
       VCID: 2313E9B0AB5FE2EFF47-8076
              U1014 00 [009] - -
                        Fault Frequency: 34
                        Reset counter: 251
                        Mileage: 83408 km
                        Date: 2020.02.27
                        Time: 11:31:28
    16776980 - Databus
              [PLA_Status_01 keine Kommunikation]
                        Reset counter: 238
                        Mileage: 83408 km
                        Date: 2020.02.27
                        Time: 11:31:29
       Part No SW: 5Q0 907 530 AJ    HW: 5Q0 907 530 M
       Component: GW MQB High   212 2246
       Revision: --------    Serial number: 09111510800334
       Coding: 030300345F087300FB0002581C0F00010001070000000000000000000000
       ROD: EV_GatewConti_013.rod
       VCID: 79AFEBD87953483F8EB-802C
       Serial number: 29150002186110075451
       Coding: 2CFFFF
       Serial number: 1488858203
       Analog clock:
       Serial number: 15000154107005
       Coding: 0800000000000000
       ROD: EV_ELVMarquMQBB.rod
       VCID: 71BFD3F82123007F36B-8024
       Part No SW: 3Q0 907 566 B    HW: 3Q0 907 566
       Component: MRR1Rear      H16 0230
       Revision: --------
       Coding: 44C002
       VCID: 372B2DE00FC79E4F38F-8062
       Serial number: 220815BHM11588
       Coding: 00351A208001020000000000
       VCID: 43D349304B1FC2EF947-8016
       Subsystem 1 - Part No SW: 5Q4 959 811 E    HW: 5Q4 959 811 E  Labels: 5QX-959-81X-V1.CLB
       Serial number: 00000000000002557486
       Coding: 0D0000
       Component: EPS_MQB_ZFLS  125 1063
       Coding: 9303
       VCID: 44D14A2C4E11C5D7ADD-8010
       Serial number: 011015BIU19426
       Coding: 003510208001020000000000
       VCID: 42DD4C345405CBE79F1-8016
       Subsystem 1 - Part No SW: 5Q4 959 812 E    HW: 5Q4 959 812 E  Labels: 5QX-959-81X-V1.CLB
       Serial number: 00000000000002560819
       Coding: 050000
       Part No SW: 3G0 035 045 G    HW: 3G0 035 045
       Component: MU-H-N-RW     H50 0343
       Serial number: A688J0FB000689
       Coding: 02840108FF00000051510001000828001F0204C601200102DF
       VCID: 221DECB4B445EBE7FF1-8076
       Component: ABT_High  H62 0031
       Serial number: VWZ8Z9RU30423C
       Subsystem 2 - Part No SW: V03 959 806 FQ    HW: -----------
       Component: ROW 2019/2020  --- 0079
       Component: Gracenote2  --- 4008
       Part No SW: 5Q0 980 556     HW: 5Q0 980 556
       Component: RVC Compact   H07 0100
       Coding: 0184010162002017000040
       Shop #: WSC 05311 000 00197
       ROD: EV_CamSysRVRVCPANAMQBAB_005_VW48.rod
       VCID: 77ABEDE04F475E4FF8F-8022
       Part No SW: 3Q0 980 654 C    HW: 3Q0 980 654
       Component: MQB_B_MFK     H04 0023
       Serial number: 12111511K20116
       Coding: 000408010000010100022346C050410084000E000020
       Part No SW: 3Q0 907 590 B    HW: 3Q0 907 590
       Revision: --------
       Coding: 44C002
    End----------(Elapsed Time: 02:07, VBatt start/end: 12.0V/12.0V)-----------
    Quote Originally Posted by free2beee View Post
                        Reset counter: 29
                        Mileage: 83497 km
                        Date: 2020.03.06
                        Time: 15:21:06
                        Reset counter: 29
                        Mileage: 83498 km
                        Date: 2020.03.06
                        Time: 15:21:32
    The problem with ACC is likely caused by this fault code. Did you have to move/remove the front fender/bumper when you did the PLA retrofit?
    In addition, I would inspect the ACC sensor to see if it doesn't have an accumulation of dirt or road grime on it.
    Mar 2020
    Australia
    Hello, yes we had to remove both front and back fender/bumpers to punch the holes for the PLA retrofit. Does this mean a recalibration is necessary or something else?
    Mar 2020
    Australia
    Thanks for closing the other similar post and in answer to your question, I will inspect the sensor for any obstructions.
  6. #6
    It means either:
    - the radar has been moved out of alignment while fitting/removing the bumper; or
    - as Uwe suggests when refitting the bumper the radar has been slightly obscured; or
    - the radar needs recalibrating.
  7. #7
    Mar 2020
    Australia
    It means either:
    Thanks very much for your help on this. I will look further into it. The issue happens only for a short time and then starts working again, it does not happen every time I drive the car with ACC engaged.
