Results 1 to 10 of 10
Thread: Retrofitting 12-button MK6 steering wheel in place of 8-button MK5 steering wheel
    Feb 2016
    Jamaica
    I just swapped a 12-button MK6 Golf steering wheel in place of my 8-button MK5 Golf steering wheel. The swap went well, and all 12 buttons work. My issue is that the horn button does not work. I had swapped over the steering wheel control module from the stock ***AQ model to the ***CD model as it supports lin 1.3 and 2.0. I also replaced my old revision-C clock-spring with a new one as I wanted to ensure I had no wiring issues due to a previous airbag related fault in my old steering wheel (which appears to have now gone). I didn't make any coding changes to the new steering wheel control module, as I noticed a new fault in some modules about not being able to see the steering angle sensor (although the steering assistance "feels" fine). I had disconnected the main battery during the swap since I was replacing the driver's airbag.
    Here is the AUTOSCAN after the swap with the new steering wheel and second-hand control module with airbag (however horn does not work).
    Friday,27,March,2020,15:22:39:39976VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
    VCDS Version: 19.6.2.2 (x64)
    Dealer/Shop Name: Matthew Taylor
    VIN: WVWZZZ1KZ8W111078   License Plate:
    Chassis Type: 1K-VW35 (7N0)
    Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 55 56
    VIN: WVWZZZ1KZ8W111078   Mileage: 191360km-118905miles
    04-Steering Angle -- Status: Cannot be reached 1100
       Part No SW: 1K0 907 115 R    HW: 8P0 907 115 B
       Revision: 5BH16---    Serial number: VWX7Z0G83NA8OV
       Coding: 040300101C070160
       Shop #: WSC 66565 257 00032
       VCID: 354FD8585CDD5EE746-8060
    Readiness: 0110 0001
       Part No SW: 02E 300 044 J    HW: 02E 927 770 AD
       Component: GSG DSG         082 1407
       Revision: 05108020    Serial number: 00001009061622
       Shop #: WSC 04940 001 00001
       VCID: 1C192DFCDF37EFAF59-8048
    18036 - Powertrain Data Bus
                P1628 - 000 - Missing Message from Steering Angle Sensor
                        Fault Frequency: 255
                        Reset counter: 40
                        Mileage: 191365 km
                        Date: 2014.08.18
                        Time: 00:07:27
       Revision: 00H11001
       Coding: 0004738
       Shop #: WSC 12345 123 12345
       VCID: 73CB2640122900D7A8-8026
       Part No SW: 5K0 907 044 ES    HW: 5K0 907 044 ES
       Component: Climatronic   H18 1112
       Revision: 00001004
       Coding: 0000014002
       Shop #: WSC 12345 123 61029
       VCID: 0021798C9B9F2B4FA5-8054
              B10A4 15 [009] - Open or Short to Plus
                        Reset counter: 81
                        Mileage: 191365 km
                        Date: 2020.03.27
                        Time: 00:07:28
       Part No SW: 3C0 937 049 AJ    HW: 3C0 937 049 AJ
       Revision: 00H54000    Serial number: 01000007456322
       Coding: F78F8B270004800047140A001400008000191C075C00010D000000000000
       Shop #: WSC 12345 111 45725
       VCID: 71C72C48683532C75A-8024
       Component: Wischer 300807 021  0501
       Coding: 00039861
       Shop #: WSC 12345
       Subsystem 2 - Part No: 1K0 955 559 AF  Labels: 1K0-955-559-AF.CLB
       Component: RLS     130907 046  0204
       Coding: 00208933
       Shop #: WSC 12345
       Component: 3A AIRBAG VW8   020 2300
       Revision: 05020000    Serial number: 0038PD1FKU0T
       Coding: 0013121
       Shop #: WSC 01269 785 00200
       VCID: 3D5FC07864ED86A78E-8068
       Subsystem 1 - Serial number: 6332MSME2C406B29H
       Subsystem 2 - Serial number: 6342MSME2C42223ED
       Subsystem 3 - Serial number: 6352QSME3D213635D
       Subsystem 4 - Serial number: 6362QSME3C0B0C41L
    00655 - Seat Belt Tensioner Igniter; Passenger Side (N154)
    02756 - Redundant signal path of Airbag cut-off switch - front passenger side (E224)
       Part No SW: 1K0 953 549 CD    HW: 1K0 953 549 CD
       Coding: 0001632
       VCID: 76CD1F54015B15FF8F-8022
       Subsystem 1 - Part No: 5K0 959 542   Labels: 3C8-959-537.CLB
       Component: E221__MFL-TAS   H06 0010
       Coding: 00000131
       Part No SW: 5K6 920 972 E    HW: 5K6 920 972 E
       Component: KOMBI         H04 0617
       Coding: 170C01
       VCID: 3851D16C83CFA38F5D-806C
       Part No SW: 7N0 907 530 M    HW: 1K0 907 951
       Component: J533  Gateway H42 1623
       Revision:   H42       Serial number: 030312F2002329
       Coding: 350001
       VCID: 3A55CB64B5C3B19FAB-806E
                        Reset counter: 81
                        Mileage: 191365 km
                        Date: 2014.08.18
                        Time: 00:07:38
       Component: IMMO          H04 0617
       VCID: 6AF53B248DE3C11F1B-803E
       Component: Tuer-SG         006 120B
       Coding: 0000560
       VCID: 3851D16C4BCFA38F5D-806C
       Part No: 1K0 909 144 P
       Component: EPS_ZFLS Kl. 207    3305
       Revision: 00H22000
       Shop #: WSC 00028 028 00001
       VCID: 3753D25046D1ACF754-8062
                000 - - - MIL ON
                        Fault Status: 11100000
                        Mileage: 191365 km
                        Date: 2014.08.18
                        Time: 00:07:38
                        Battery Volts: 13.6 V
                            DU
                        Temperature: 40.0°C
                        Count: 2
                        Steering Angle: 0.00°
                        Count: 1
                            SteerAng n.Init
       Coding: 98900A085103007F42000F0FF0CA5A0610BC40
       VCID: 032B768042893057B8-8056
    01134 - Alarm Horn (H12)
                        Reset counter: 81
                        Mileage: 191365 km
                        Date: 2014.08.18
                        Time: 00:07:39
       Coding: 0000564
       VCID: 3957D46870C5BA87A2-806C
       Part No: 1T0 907 357
       Coding: 0000003
       Shop #: WSC 00000 785 00200
       VCID: 74C9255C172707EFB1-8020
       Part No SW: 1K0 035 180 AE    HW: 1K0 035 180 AE
       Component: Radio Prem-8  H02 0016
       Revision: -----16S    Serial number: VWZ4Z7L3180243
       Coding: 00000401000005
       VCID: 63EB560062C99057D8-8036
                        Fault Status: 01101011
                        Reset counter: 81
                        Mileage: 191365 km
                        Date: 2014.08.18
                        Time: 00:07:42
    02633 - Antenna for Satellite Tuner
                        Reset counter: 81
                        Mileage: 191365 km
                        Date: 2014.08.18
                        Time: 00:07:42
                        Reset counter: 81
                        Mileage: 191365 km
                        Date: 2014.08.18
                        Time: 00:07:42
                        Reset counter: 81
                        Mileage: 191365 km
                        Date: 2014.08.18
                        Time: 00:10:51
    End-------------------------(Elapsed Time: 01:24)--------------------------
    Here is the AUTOSCAN prior to the swap with the horn working on my 8-button steering wheel, but original clock-spring and steering wheel control module
    Friday,07,February,2020,06:36:12:39976VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
    VCDS Version: 19.6.2.0 (x64)
    Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 55 56 77
    VIN: WVWZZZ1KZ8W111078   Mileage: 190190km-118178miles
    77-Telephone -- Status: Sporadic communication error 1000
       VCID: 354FD8585CDD5EE744-8060
    000054 - Oxygen (Lambda) Sensor B1 S2: Heating Circuit
                   P0036 - 004 - Malfunction / Open Circuit
                        Mileage: 190182 km
                        Date: 2020.02.07
                        Time: 04:28:14
                        RPM: 823 /min
                        Load: 28.2 %
                        Temperature: 89.0°C
                        Temperature: 57.0°C
                        Absolute Pres.: 1000.0 mbar
                        Voltage: 13.589 V
    Readiness: 0110 0101
       VCID: 1C192DFCDF37EFAF5B-8048
       Revision: 00H11001
       Coding: 0004738
       VCID: 73CB2640122900D7AA-8026
    7 Faults Found:
       Revision: 00001004
       Coding: 0000014002
       VCID: 0021798C9B9F2B4FA7-8054
                        Reset counter: 243
                        Mileage: 190182 km
                        Date: 2020.02.07
                        Time: 04:28:07
       Coding: F78F8B270004800047140A001400008000197E075C00010C000000000000
       VCID: 71C72C48683532C758-8024
       Coding: 00039861
       Shop #: WSC 12345
       Coding: 00208933
       Shop #: WSC 12345
    01502 - Bulb for Rear Fog; Left (L46)
                        Fault Status: 01101100
                        Reset counter: 243
                        Mileage: 190182 km
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 13.20 V
       Coding: 0013121
       VCID: 3D5FC07864ED86A78C-8068
       Part No SW: 1K0 953 549 AQ    HW: 1K0 953 549 AQ
       Coding: 0012122
       VCID: 01277C8858952247A8-8054
       Coding: 170C01
       VCID: 3851D16C83CFA38F5F-806C
       Coding: 350001
       VCID: 3A55CB64B5C3B19FA9-806E
                        Reset counter: 27
                        Mileage: 190187 km
                        Date: 2020.02.07
                        Time: 04:50:41
       VCID: 6AF53B248DE3C11F19-803E
       Coding: 0000564
       Shop #: WSC 11111 111 45799
       VCID: 3851D16C4BCFA38F5F-806C
    00109 - Left Mirror Turn Signal Lamp (L131)
       Revision: 00H22000
       VCID: 3753D25046D1ACF756-8062
                        Fault Status: 11100101
                        Mileage: 190182 km
                        Date: 2020.02.07
                        Time: 04:28:19
                            DU
                        Temperature: 44.0°C
                        Count: 3
                        Count: 1
                            SteerAng n.Init
       Coding: 98900A085103007F42040F0FF00A5A0690BC00
       VCID: 032B768042893057BA-8056
                        Reset counter: 242
                        Mileage: 190182 km
                        Date: 2020.02.07
                        Time: 04:28:19
       Coding: 0000564
       VCID: 3957D46870C5BA87A0-806C
       Coding: 0000003
       VCID: 74C9255C172707EFB3-8020
       Coding: 01000401000005
       VCID: 63EB560062C99057DA-8036
                        Reset counter: 242
                        Mileage: 190182 km
                        Date: 2020.02.07
                        Time: 04:28:21
                        Reset counter: 242
                        Mileage: 190182 km
                        Date: 2020.02.07
                        Time: 04:28:21
                        Reset counter: 242
                        Mileage: 190185 km
                        Date: 2020.02.07
                        Time: 04:45:08
    Address 77: Telephone
    End-------------------------(Elapsed Time: 01:29)--------------------------
    Can someone please suggest suitable coding for me, as I forgot to look at the configuration from my previous steering wheel configuration information before I pulled the module from the vehicle.
    Tartu, Estonia
    Your old module had G85 sensor built in. Your current CD doesn't.
    Luckily You have a gen3 zf steering rack with built in sensor. Check the adaptions there and turn on steering rack internal sensor.
    The world is my oyster...
  3. Likes NitrousOxide liked this post
    Feb 2016
    Jamaica
    Thanks, I'll try it when next I get to the car.
    Do you have any suggestions on my non functioning horn?
    Tartu, Estonia
    Quote Originally Posted by NitrousOxide View Post
    Is wiring correct?
    You may wanna look at Measuring Values in Module 16 if SWCM sees signal from MFSW-module. And then MVB in 09 module if they are transmitted from SWCM(16) module.
  6. Likes NitrousOxide, Uwe liked this post
    Feb 2016
    Jamaica
    Thanks Golf_vendi, I forgot o mention that my horn actually started working perfectly without me having to do anything else. All 12 buttons on my steering wheel also work perfectly as well.
    Jan 2019
    The Netherlands
    You should swap slib ring to newer type
    To 1K0959653C
    Edit
    This evening new try with slib ring extention C
    Again same problem.
    We took the slib ring from a 2008 golf5
    Old slib ring was exact the same part number
    Jan 2019
    The Netherlands
    Conclusion
    We used the wrong steering electronics.
    With also extention CD. This has to be the version with extention CH. That one does support G85 sensor.
  10. #8
    Feb 2016
    Jamaica
    I'm happy to hear that you've found the root cause for your issues.
    Were you able to source and fit a suitable replacement as yet?
  11. #9
    Jan 2019
    The Netherlands
    Fix is we have to buy the correct module and sell the wrong one.
    Solution is on this site
    http://wiki.ross-tech.com/wiki/index...odule_Versions
    I’ve found one here in the erea. Tomorrow my mate will pick it up.
  12. #10
    Jan 2019
    The Netherlands
    Two days later we changed the module. All is now working as should be. We only had one other obstackle. The Cruiseconrol wasn't funcitoning anymore.
    After some searching it was clear that the stalk wasn't defect, but wiring has changed.
    We changed wiring to new version and also that obstackle was behind us. Now happy mate with his Golf5 GTI
    Passat B6 2.0 TDI CR DSG Tuned by Cardrik Tuning
  13. Likes NitrousOxide, PetrolDave, Uwe liked this post
