Results 1 to 7 of 7
Thread: W12 Cold start mifires
    Mar 2020
    Bakersfield, CA, USA
    I'm having Issues with cold misfires on Turbo w12 in a 2007 Bentley continental, they occur on only bank one I've Installed new plugs as the original OE plugs were still in the car at some 80k miles. I'm still having issues, Watching Counters live it seems to be all cylinders but only on one bank, and as soon as it warms up it runs great. Also there are some boot control position implausible codes in both banks that clear and come right back I'm wondering if this will have anything to do with it. If Anyone has any insight into these 2 code, which I can find no info about or where to start with cold misfires on this thing, its basically 2 vr6 motors side by side with turbos, I'm kind of at a loss on this thing.
    Here is an autoscan:
    Friday,27,March,2020,09:13:08:26287
    VCDS Version: 19.6.2.2 (x64)  HEX-NET CB: 0.4508.4
    VIN: SCBCR73W37C040340   License Plate:
    Mileage: 131010km-81405mi   Repair Order: bently
    Chassis Type: 3W (3W - Bentley Continental (2004 > 2007))
    Scan: 01 02 03 05 06 07 08 09 11 13 15 16 17 18 19 23 26 28 34 36
              37 38 46 47 53 54 57 65 66 68 69 6C 71 75 76 77
    VIN: SCBCR73W37C040340   Mileage: 131010km-81405miles
    Address 01: Engine        Labels: 07C-906-018-BWR1.clb
       Part No SW: 07C 906 018 BR    HW: 07C 906 018 EC
       Component: BY-6.0L-TT      G  6789
       Revision: --H01---    Serial number: VWZ3Z0F7477543
       Coding: 0001175
       Shop #: WSC 00083 000 00000
       VCID: 76A03E9800A192FF8F-5160
    009571 - Turbocharger Boost Control Position Sensor Circuit
                   P2563 - 008 - Implausible Signal
                        Mileage: 131016 km
                        RPM: 1168 /min
                        Load: 35.3 %
                        Temperature: 40.0C
                        Temperature: 27.0C
                        Absolute Pres.: 990.0 mbar
                        Voltage: 12.827 V
    006435 - Please Check DTC Memory of ECU Number 2
                   P1923 - 008 -
                        Mileage: 131016 km
                        Temperature: 47.0C
                        Temperature: 18.0C
                        Absolute Pres.: 1000.0 mbar
                        Voltage: 12.446 V
    Readiness: 0110 0101
       Part No SW: 09E 927 760 S    HW: GS1 911 4
       Component: AG6 09E 6.0L W12TT  2807
       Revision: 00000001    Serial number:        0084554
       Coding: 0000111
       VCID: 40CC984012E56C4FE5-5160
    Address 03: ABS Brakes        Labels: 3W0-614-517-V1.lbl
       Part No: 3W0 614 517 D
       Component: ESP 5.7 4WD     H01 0021
       Coding: 0007878
       Shop #: WSC 03266 000 00000
       VCID: 3620FE984021D2FF4F-51CE
       Part No SW: 3D0 909 137 C    HW: 5WK 484 97
       Component: FE Kessy            6700
       Revision: 67006015    Serial number: VWZ3Z0F7477543
       Coding: 0405741
       VCID: 271E23DC978BBB77C4-5160
    Address 06: Seat Mem. Pass        Labels: 3W0-959-759.clb
       Part No: 3W0 959 759 A
       Component:    CM Seat Pass.    0009
       Shop #: WSC 02288 003 1048576
       VCID: 47DE835C37CB5B7724-5160
    01903 - Seat Tilt Adjustment Motor (V231)
    Address 07: Control Head        Labels: 3D0-035-00x-07.lbl
       Part No: 3W0 035 008 D
       Component:    ZAB COCKPIT      2089
       Coding: 0400325
       VCID: 2E10D6F8B871EA3F07-5160
    Address 08: Auto HVAC        Labels: 3W7-907-040.clb
       Part No: 3W0 907 040 F
       Component: Climatronic BY614   2014
       Coding: 0000112
       VCID: 3424C490565DC0EF71-5160
    00714 - Centre Right Vent Positioning Motor (V111)
    Address 09: Cent. Elect.        Labels: 3D0-937-049-V1.clb
       Part No: 3D0 937 049 H
       Component: STG.Bordnetz        5101
       Coding: 0000107
       VCID: 2F2ECBFCBF7BE3370C-5160
    00576 - Terminal 15
    00884 - Ignition Switch (D) Terminal X
    Address 11: Engine II        Labels: 07C-906-018-BWR2.clb
       Coding: 0001175
    7 Faults Found:
    009607 - Turbocharger Boost Control Position Sensor 2
                   P2587 - 008 - Implausible Signal
                        Mileage: 131016 km
                        RPM: 1152 /min
                        Load: 34.5 %
                        Temperature: 40.0C
                        Temperature: 30.0C
                        Voltage: 12.954 V
                   P0300 - 008 -
                        Mileage: 131016 km
                        RPM: 582 /min
                        Load: 20.4 %
                        Temperature: 55.0C
                        Temperature: 17.0C
                        Voltage: 13.589 V
    000769 - Cylinder 1
                   P0301 - 008 - Misfire Detected
                        Mileage: 131016 km
                        RPM: 537 /min
                        Load: 19.6 %
                        Temperature: 57.0C
                        Temperature: 17.0C
                        Voltage: 13.716 V
    000771 - Cylinder 3
                   P0303 - 008 - Misfire Detected
                        Mileage: 131016 km
                        RPM: 537 /min
                        Load: 19.6 %
                        Temperature: 57.0C
                        Temperature: 17.0C
                        Voltage: 13.716 V
    000774 - Cylinder 6
                   P0306 - 008 - Misfire Detected
                        Mileage: 131016 km
                        RPM: 537 /min
                        Load: 19.6 %
                        Temperature: 57.0C
                        Temperature: 17.0C
                        Voltage: 13.716 V
    000770 - Cylinder 2
                   P0302 - 008 - Misfire Detected
                        Mileage: 131016 km
                        RPM: 537 /min
                        Load: 19.6 %
                        Temperature: 57.0C
                        Temperature: 17.0C
                        Voltage: 13.716 V
    000772 - Cylinder 4
                   P0304 - 008 - Misfire Detected
                        Mileage: 131016 km
                        RPM: 537 /min
                        Load: 19.6 %
                        Temperature: 57.0C
                        Temperature: 17.0C
                        Voltage: 13.716 V
    Address 15: Airbags        Labels: None
       Part No SW: 3W8 909 601     HW: 3W8 909 601
       Component: 12 Airbag 9.41  H13 0040
       Revision: 91H13004    Serial number: 0039L0001C69
       Coding: 0012594
       VCID: 7BB62FAC3B83CF97F0-5160
       Subsystem 1 - Part No: 3W7 959 339
       Component: BF-Gewichtsens. H02 0004
       Subsystem 2 - Serial number: 3BP96
       Subsystem 3 - Serial number: 0001.01.0000H0200000000000†63
       Subsystem 4 - Serial number: 000000†63328RB4012FCDD5$†63
       Subsystem 5 - Serial number: FCDD5$†63428RB4012FCD24S†63
       Subsystem 6 - Serial number: FCD24S†63528RB4012FCD88$†63
       Subsystem 7 - Serial number: FCD88$†63628RB4012FCD55Y†63
       Subsystem 8 - Serial number: FCD55Y†63700RB4        I†63
       Subsystem 9 - Serial number:      I†63800RB4        J
       Subsystem 10 - Serial number:      J
    Address 16: Steering wheel        Labels: 3D0-953-549.lbl
       Part No: 3D0 953 549 D
       Component: Lenksulenmodul     3401
       Coding: 0000012
    Address 17: Instruments        Labels: 3Wx-920-xxx-17.lbl
       Part No: 3W8 920 840 C
       Component: KOMBIINSTRUMENT RB8 0610
       Coding: 0023203
       VCID: 3C34ECB07E0D08AFB9-5160
       Part No: 6N0 909 901
       Coding: 0000006
       VCID: 70AC088062C5BCCF55-5160
    00456 - Control Module for Access and Start Control (J518)
    Address 34: Level Control        Labels: 3Wx-907-553-34.clb
       Part No: 3W0 907 553 A
       Component: LUFTFDR.-CDC- 3C3V0 7203
       Coding: 0005561
       VCID: 383CF0A04A35248F5D-5160
    Address 36: Seat Mem. Drvr        Labels: 3W0-959-759.clb
       Part No: 3W0 959 760 A
       Component:    CM Seat Driver   0008
       Shop #: WSC 03245 104 67957
       VCID: 3FCE9BBC6F1B13B79C-5160
    01174 - Driver Seat Height Adjustment Motor (V138)
    Address 37: Navigation        Labels: None
       Part No: 3W0 919 887 F
       Component:    NAVIGATION       2085
       Coding: 0400000
       VCID: 4AD8BA6824D9A61F3B-5160
    Address 38: Roof Electronics        Labels: None
       Part No: 3W0 907 135 E
       Component: Dachmodul           0707
       Coding: 0002493
    Address 46: Central Conv.        Labels: 3D0-959-933.lbl
       Part No: 3D0 959 933 F
       Component: 52 HSG              0101
       Coding: 0000040
       VCID: 3326C78C5353C7D768-4B1E
       Subsystem 1 - Part No: 3W8 959 701 B
       Component: Tuersteuergeraet FS 1002
       Subsystem 2 - Part No: 3W8 959 702 B
       Component: Tuersteuergeraet BF 1002
       Subsystem 3 - Part No: 3W8 959 703 B
       Component: Tuersteuergeraet HL 0401
       Subsystem 4 - Part No: 3W8 959 704 B
       Component: Tuersteuergeraet HR 0401
       Subsystem 5 - Part No: 3W0 909 610 F
       Component: 14 HDSG             1809
       Subsystem 6 - Part No: 7L0 907 719 A
       Component:    Neigungssensor   0020
    6 Faults Found:
    00927 - Terminal 30 (Right)
    01516 - Terminal 30; Left
    00926 - Terminal 30
    00576 - Terminal 15
    Address 47: Sound System        Labels: 7Lx-035-4xx-47.lbl
       Part No: 3W8 035 456
       Component: 12K-AUDIOVERST      3000
       VCID: 79BA35A431BFFD87E2-5160
    Address 53: Parking Brake        Labels: 3W0-907-801.clb
       Part No SW: 3W0 907 801 D    HW: 3W0 907 801 D
       Component: EPB  BC6HX24    HC6 X240
       Coding: 0022401
       VCID: 373EF39C472B2BF754-5160
    00576 - Terminal 15
                        Reset counter: 35
                        Voltage: 11.59 V
                        Count: 41
                        Reset counter: 35
                        Voltage: 11.59 V
                        Count: 247
    Address 54: Rear Spoiler        Labels: 1C0-959-733.lbl
       Part No: 1C0 959 733 H
       Component: Heckspoiler         0002
       VCID: 302CC880F245FCCF15-51F2
    Address 65: Tire Pressure        Labels: Redir Fail!
       Part No: 3W7 907 273
       Component: Reifendruckueberw.  0003
       Coding: 0480311
       VCID: 7DB221B42597C1A7CE-5160
    Address 68: Wiper Electr.        Labels: 3Wx-955-023.clb
       Part No: 3W1 955 023 E
       Component: Wische$
       Shop #: WSC 00000 725 65552
    00003 - Control Module
                014 - Defective
    Address 71: Battery Charger        Labels: 3D0-915-181.lbl
       Part No: 3D0 915 181 D
       Component: Batteriemanagement  2800
       VCID: 240434D0E6BD506FE1-5160
       Part No: 3W0 919 283 A
       Component: 02 Einparkhilfe     0303
       VCID: 3B36EFAC7B030F97B0-5160
    Address 77: Telephone        Labels: None
       Part No SW: 3W0 035 385 S    HW: 3W0 035 385 S
       Component: rSAP ECU            0054
       Coding: 0000272
       VCID: 45C289540DC74967D6-5160
    End----(Elapsed Time: 07:43, VBatt start/end: 13.8V/13.8V. VIgn 0.0V)------
    16.4905 S, 151.7375 W
    You may need to drop the engine/transmission. If the vacuum lines behind the engine/on top of the transmission have never been replaced, this could be a source for vacuum leaks.
    When the engine is cold, the air/fuel mixture is depending upon a map for it's adjustment, any false air leaks (vacuum leaks) can sometimes be seen as cold misfires. As the engine warms up and when the Oxygen sensors come on line(ready/closed loop), the air/fuel mixture is adjusted accordingly and misfires typically can disappear.
    You can see evidence of this in the Measuring Value Block group [032] in both the [01-Engine] and [11-Engine II]. Any positive number would be an indication that the fuel mixture is lean (having to add fuel due to a vacuum leak). In the first field on both banks 1 and 2, the mixture should be close to [0.00] (+/-) 2-3%, depending on engine wear, fuel quality, atmospheric conditions, etc.
    This may help: Fuel Trim Info - Understanding Fuel Trim
    The vacuum lines on the 6.0L W12 engine of the early Bentley vehicles are a hard plastic and are known to fail/crack/split.
    Complete engine removal is the way I replace these vacuum lines, some people have suggested to access then through the power steering rack area with the rack removed. I like to do this type of job right and it is much easier to do extended service work, oil leak repairs, suspension work, etc.. You could be in the 5-digit range, in parts and labor, just depends..
    Here are some pics of what you will see.... I had to drop this engine for a new alternator, vacuum line replacement and all the wear parts of the suspension, along with a major service and taking care of some oil leaks.
    Also, with the engine out, you can access the turbo and it's boost control components, hoses, electrical connections, etc
    Top down view of transmission
    Left Side view eng/trans
    Whole Transmission, top view
    You will need a good source of Bentley parts (internet search) and the Official Factory Repair Information
    Hope this helps,
    drpeter
    Just kills me they couldn't extend all the metal pipes to place that switched stuff in a box underside or in bay for service.
    Mar 2020
    Wow, Thanks, I'm going to smoke check it now, at least I have a direction, thank you.
    Mar 2020
    Also, by chance do you have an idea of book time or ballpark labor for engine/ trans R&R? should it go that way.
    It's in any crash book or RTFB?
  7. #7
    Quote Originally Posted by GermanDreamsPerformance View Post
    Hi, I have seen some dealerships charge as much as 40 hours for this type of work. It really depends on what you find the vehicle needs. There maybe labor times on the erWin Bentley Motors, I do not recall seeing any, but I did not look either.
    In some cases, you "might as well" replace worn/damaged parts, service items and take care of any potential issues, leaking seals, brittle plastics, etc.. and all that adds up and gets expensive!
    So, I just tell these types of customers, what every time it takes, it takes... On that note, sometimes these vehicles end up getting parted out due to the amount of money it can cost to fix these vehicles properly. And it does not help that the resale value of these vehicles is still dropping.
    Again, hope this helps,
    dpeter
  8. Likes Uwe, Jack@European_Parts liked this post
