Results 1 to 4 of 4
Thread: Auto trans to manual swap
    Feb 2020
    Palestine
    Unhappy Auto trans to manual swap
    need your help coding this car
    the ECU has been flashed before in another workshop to solve issue that related with TCU ( no communication with tcu ) and now car behave normal on the road but we got faults now in immobilizer
    (( 01315 - Transmission Control Module
    004 - No Signal/Communication ))
    and also on same fault on instrument . and show abs light and brake on dashboard
    ABS record anther fault
    18055 - Check Coding of ECUs on Powertrain Data Bus
    P1647 - 000
    Tuesday,04,February,2020,11:33:51:06524
    VIN: WAUAS78E06A198246   License Plate: 0000
    Mileage: 197810km-122913mi   Repair Order:
              67 69 75 76 77
    VIN: WAUAS78E06A198246   Mileage: 197810km-122913miles
    Address 01: Engine        Labels: 06B-907-557-ALT.lbl
       Part No SW: 8E0 909 557     HW: 8E0 909 057 B
       Component: 2.0L R4/5VS     G   0003
       Coding: 0011501
       Shop #: WSC 00000 000 08192
       VCID: 70B82A47F6B28447397-5184
    18107 - Powertrain Data Bus
                P1699 - 008 - Missing Message from Steering Wheel Electronics - Intermittent
    18044 - Powertrain Data Bus
                P1636 - 008 - Missing Message from Airbag Controller - Intermittent
    16497 - Intake Air Temp. Sensor (G42)
                P0113 - 002 - Signal too High - Intermittent
    17947 - Clutch Pedal Switch (F36)
                P1539 - 004 - Implausible Signal
    17545 - Fuel Trim: Bank 1 (Add)
                P1137 - 002 - System too Rich
    Readiness: 0000 0001
    Address 03: ABS Brakes        Labels: 8E0-910-517.clb
       Part No SW: 8E0 910 517 D    HW: 8E0 614 517 AK
       Component: ESP8 front      H06 0120
       Coding: 0000519
       Shop #: WSC 00011 000 00000
       VCID: 280802270EF28C87A17-807C
                        Reset counter: 40
                        Hex Value: 0x0000
                        Hex Value: 0x4722
                        Hex Value: 0x0014
                        Hex Value: 0x2091
                        Hex Value: 0x0000
                P1647 - 000 -
                        Reset counter: 40
                        Hex Value: 0x0000
                        Hex Value: 0x4722
                        Hex Value: 0x0014
                        Hex Value: 0x1394
                        Hex Value: 0x0000
       Part No: 8E0 820 043 BJ
       Component:   A4 Klimaautomat   2832
       Coding: 00000
       VCID: 6A8C382FD56E7E97773-513C
    Address 09: Cent. Elect.        Labels: 8E0-907-279-8EC.lbl
       Part No: 8E0 907 279 L
       Component: int. Lastmodul  ECE 0504
       Coding: 00031
       Shop #: WSC 06325
       VCID: 3B22CD6BEA74371FDC5-4B00
                30-00 - Open or Short to Plus
    Address 15: Airbags        Labels: 8E0-959-655-94.lbl
       Part No SW: 8E0 959 655 G    HW: 8E0 959 655 G
       Component:    Airbag 9.41  H12 3730
       Revision: 91H12373    Serial number: 0036M00A6CU3
       Coding: 0034622
       Shop #: WSC 06325 000 00000
       VCID: 3B22CD6BEF64371FDC5-806E
       Subsystem 1 - Serial number: 6332DRB402C48E2D
       Subsystem 2 - Serial number: 6342DRB402C64EB3-
       Subsystem 3 - Serial number: 6352ARB400E26199N
       Subsystem 4 - Serial number: 6362ARB400E01ED6V
       Subsystem 5 - Serial number: 63729RB400E55633J
       Subsystem 6 - Serial number: 63829RB400E5562FV
       Part No: 8E0 953 549 Q
       Component: Lenksáulenmodul     0601
       Coding: 00021
       Shop #: WSC 06325
       VCID: 41DEBF8388985DCF869-4B00
    Address 17: Instruments        Labels: 8E0-920-9xx-8EC.lbl
       Part No SW: 8E0 920 901 C    HW: 8E0 920 901 C
       Component: KOMBI+WFS 3     H14 0110
       Revision: 0110        Serial number: AUX6Z0F0182256
       Coding: 0006641
       Shop #: WSC 00050 726 96790
       VCID: 25160B1379F091EF9A1-5184
    01304 - Radio
    Address 25: Immobilizer        Labels: 8E0-920-9xx-8EC.lbl
       Coding: 0006641
    01304 - Radio
       Part No: 8E0 959 433 BQ
       Component: Komfortgerát T01    3332
       Coding: 06720
       Shop #: WSC 00063
       VCID: 015E7F83C8189DCFC69-4B00
       Subsystem 1 - Part No: 8E1959801H
       Component: Tőrsteuer.FS BRM 0606
       Subsystem 2 - Part No: 8E1959802H
       Component: Tőrsteuer.BF BRM 0606
       Component: Tőrsteuer.HL BRM 0606
       Component: Tőrsteuer.HR BRM 0606
    00915 - Window Regulator Switch; Rear Right; Driver (E55)
    00914 - Window Regulator Switch; Rear Left; Driver (E53)
    01705 - Selection Switch for Mirror-Adjust (E48)
       Part No: 8P0 907 357 F
       Coding: 0000005
       VCID: 3D26C373F170392FE21-8068
    00496 - Sensor for Vehicle Leveling; Front
                        Fault Status: 11101010
                        Reset counter: 0
    Address 76: Park Assist        Labels: 8E0-919-283-8EC.lbl
       Part No SW: 8E0 919 283 D    HW: 8E0 919 283 D
       Component: Parkhilfe 4-Kan H06 0010
       Revision: 00H06000    Serial number: 00067802020601
       Coding: 0001004
       VCID: 313EEF433D08CD4F769-5184
    End----------(Elapsed Time: 05:27, VBatt start/end: 12.3V/12.2V)-----------
    Address 01,8E0 909 557 ,recoded (Short coding),from,0011501,to,0011501,(00000/000/08192),
    HQ
    Connect to the Instrument Cluster, go into Adaptation and read channel 60. What is the stored value?
    Jef
    Feb 2020
    Palestine
    sorry for replaying lat , i was at home quarantine.. i just checked it and found (1111) , i tried to changed it for (1117) and the DTC related to TCU disappeared !
    ((Transmission Control Module
    004 - No Signal/Communication)))
    in both controller immobilizer and instrument , but the ABS light is still on and brake light still flashing
    Feb 2020
    Palestine
    i checked airbag module - Channel 051: ESP-Data (Brake) and changed the value to the proper one and it solved !!
    thank u so much Jef !!
