Results 1 to 10 of 11
Thread: Code 00003 abs
    Mar 2017
    Code 00003 abs
    I recently had this fault appear on my S3 8p 2009 reg car and looked it up and found within ross-tech how i could correct this code , so i followed the tuturial on youtube ( ross-tech ) explaining what i was suppose to and have since done it but what i have found are my brakes are very responsive and make a grinding noise when coming to a halt os this what should happen once they have been calibrated . Thanks
    I really doubt that a grinding noise from the brakes are related to this fault code. Grinding noises warrant an immediate physical inspection of the brakes.
    As to the fault code, please post an Auto-Scan for context.
  3. Likes PetrolDave, DrPeter liked this post
    Mar 2017
    hello again Uwe. this is an update on my problem 00003 that i am still getting .
    now some back ground i recently got my high line door module ( 8P0 959 801 P ) reprogrammed using Eeprom so i could get my S3 registered 2009 but 2010 model wing mirrors to close using key fob and open on ignition , now this works ok but i noticed the 00003 problem afterwards so i followed Ross-techs video about channel 25 / 26 followed it to the letter and got ABS calibrated ( well it look liked it did in video when all done correctly ) and when i heard the grinding noise from brakes i assumed this fault had caused it but i have found now that after a bit off driving around the brakes sound fine ,.
    so i re-scanned car and noticed i had same fault plus module 22 fault i tried to get into module but it says no response from controller any idea's how to sort out any off these 2 problems , the nav+ radio problem i know how to fix and the hvac again a retrofit ( be nice if you could shed some light on that problem too as i know a lot off guys have it when they fitted the Q3 8P Climate control to there A3/S3 8P models
    Saturday,04,April,2020,12:46:46:03294
    VIN: WAUZZZ8P5AA039310   License Plate:
    Chassis Type: 8P-AU35 (1K0)
    Scan: 01 03 08 09 10 15 16 17 19 22 25 37 42 44 46 52 55 56 77
    VIN: WAUZZZ8P5AA039310   Mileage: 164740km-102364miles
    22-AWD -- Status: Cannot be reached 1100
    Address 01: Engine (CDL)       Labels:. 06F-907-115-CDL.clb
       Part No SW: 8P0 907 115 AP    HW: 8P0 907 115 B
       Component: 2.0l R4/4V TFSI     0010
       Revision: 5BH16---    Serial number: AUX7Z0I6FNN0S8
       Coding: 0103000C180F0160
       Shop #: WSC 23056 238 00000
       VCID: 005875B5F603CEEB532-8054
    10 Faults Found:
                        Temperature: -40.0C
                        Temperature: -40.0C
                        Absolute Pres.: 0.0 mbar
                        Voltage: 0.000 V
    008852 - Fuel Pressure Regulator Valve (N276)
                   P2294 - 004 - Open Circuit - Intermittent
                        Mileage: 164749 km
                        Date: 2020.04.02
                        Time: 05:53:20
                        RPM: 1162 /min
                        Load: 35.3 %
                        Temperature: 29.0C
                        Temperature: 14.0C
                        Absolute Pres.: 1010.0 mbar
                        Voltage: 14.097 V
    001092 - EVAP Purge Control Valve (N80)
                   P0444 - 004 - Circuit Open - Intermittent
                        Mileage: 164749 km
                        Date: 2020.04.02
                        Time: 05:53:21
                        RPM: 1147 /min
                        Load: 40.4 %
                        Temperature: 29.0C
                        Temperature: 14.0C
                        Voltage: 13.970 V
    000051 - Turbocharger Bypass Valve Control Circuit
                   P0033 - 004 - Malfunction / Open Circuit - Intermittent
                        Mileage: 164749 km
                        Date: 2020.04.02
                        Time: 05:53:21
                        RPM: 1147 /min
                        Load: 40.4 %
                        Temperature: 29.0C
                        Temperature: 14.0C
                        Voltage: 14.224 V
    000579 - Solenoid Valve  for Boost Pressure Control (N75)
                   P0243 - 004 - Malfunction - Intermittent
                        Mileage: 164749 km
                        Date: 2020.04.02
                        Time: 05:53:21
                        RPM: 1132 /min
                        Load: 55.7 %
                        Temperature: 29.0C
                        Temperature: 14.0C
                        Voltage: 13.970 V
    000048 - Oxygen (Lambda) Sensor B1 S1: Heating Circuit
                   P0030 - 004 - Malfunction / Open Circuit - Intermittent
                        Mileage: 164749 km
                        Date: 2020.04.02
                        Time: 05:53:56
                        RPM: 1065 /min
                        Load: 22.7 %
                        Temperature: 36.0C
                        Temperature: 14.0C
                        Voltage: 14.224 V
                   P0300 - 001 -
                        Fault Status: 01100001
                        Mileage: 164749 km
                        Date: 2020.04.02
                        Time: 05:55:00
                        RPM: 775 /min
                        Load: 25.5 %
                        Temperature: 42.0C
                        Temperature: 15.0C
                        Voltage: 14.351 V
    000769 - Cylinder 1
                   P0301 - 001 - Misfire Detected
                        Mileage: 164749 km
                        Date: 2020.04.02
                        Time: 05:55:00
                        RPM: 775 /min
                        Load: 25.5 %
                        Temperature: 42.0C
                        Temperature: 15.0C
                        Voltage: 14.351 V
    004874 - Cylinder Disabling
                   P130A - 001 -  - Intermittent
                        Fault Status: 00100001
                        Mileage: 164749 km
                        Date: 2020.04.02
                        Time: 05:55:46
                        RPM: 780 /min
                        Load: 24.7 %
                        Temperature: 45.0C
                        Temperature: 15.0C
                        Voltage: 14.097 V
    012423 - Voltage Supply Relay for Engine Components
                   P3087 - 004 - Electrical Malfunction - Intermittent
                        Mileage: 164749 km
                        Date: 2020.04.02
                        Time: 06:18:13
                        RPM: 220 /min
                        Load: 63.9 %
                        Temperature: 38.0C
                        Temperature: 17.0C
                        Voltage: 11.049 V
    Readiness: 0110 0100
       Revision: 00H45001
       Coding: 1642801249250003680E01E5921900813800
       Shop #: WSC 00857 210 11996
       VCID: 005875B5FA03CEEB532-8054
                        Reset counter: 137
                        Mileage: 164749 km
                        Date: 2020.04.03
                        Time: 00:51:23
                        Count: 2
                        Count: 2
                        Count: 12800
                        Count: 8202
                        Count: 43008
                        Count: 1
       Part No SW: 8U0 820 043 G    HW: 8U0 820 043 G
       Component: E87  Klimavoll      0210
       Revision: 00H05000    Serial number: 8U0820043G
       VCID: 3536D461F941BB43B04-8060
                        Fault Frequency: 7
                        Reset counter: 134
    Address 09: Cent. Elect. (J519)       Labels:. 8P0-907-063.clb
       Part No SW: 8P0 907 063 A    HW: 8P0 907 063 A
       Component: BCM PQ35  M   104 0575
       Revision: 00104 AH
       Coding: 06000AAFB017F080207241E00100094C437E25AA315DD929E40008840040
       Shop #: WSC 00561 210 89589
       VCID: 323CEF7D042FAC7B956-8066
       Subsystem 1 - Part No SW: 8P2 955 119 F    HW: 8P2 955 119 F  Labels: 1KX-955-119.CLB
       Component: Wischer AU350  H10 0040
       Coding: 00DD13
       Subsystem 2 - Part No: 8P0 951 177
       Component: Innenraumuebe  H04 0020
       Subsystem 4 - Part No: 1K0 907 719 C
       Component: Neigungssenso  005 0003
    Address 10: Park/Steer Assist (J446)       Labels:. 8P0-919-475-7X1.clb
       Part No SW: 8P0 919 475 G    HW: 8P0 919 475
       Component: PARKHILFE 4K  H06 0120
       Revision: 11001001    Serial number: 93640920206918
       Coding: 000002
       Shop #: WSC 06314 123 12345
       VCID: 42DCBFBDB48F1CFB056-8016
    Address 15: Airbags (J234)       Labels:* 8P0-959-655-10.clb
       Part No SW: 8P0 959 655 P    HW: 8P0 959 655 P
       Component: Airbag AU1042 H06 0140
       Revision: --------    Serial number: 003FB002DSVH
       Coding: 303142413039303030384A55305238503053
       Shop #: WSC 06314 000 00000
       ROD: EV_Airba10AURB4.rod
       VCID: 4FFA8689775DE1939A8-801A
       Serial number: 34928RB400004F10F9D$
       Serial number: 35028RB400004F2618AK
       Serial number: 35128RB400004F10B84I
       Serial number: 35228RB400004F2618DP
       Serial number: 35547RB400004EF08A8$
       Serial number: 35647RB400004EF08A7$
       Part No SW: 8P0 953 549 K    HW: 8P0 953 549 K
       Coding: 0004042
       VCID: 46D4A3AD94A720DB29E-8012
       Component: E0221           H06 0030
    Address 17: Instruments        Labels: 8P0-920-xxx-17-MY8.clb
       Part No SW: 8P0 920 982 K    HW: 8P0 920 982 K
       Component: KOMBIINSTR. VDO H02 0980
       Revision: D0H02002    Serial number: 2246I002000289
       Coding: 0005428
       Shop #: WSC 00561 067 57207
       VCID: 41DEB0B1BD8907E31CC-8014
    00003 - Control Module
                        Fault Status: 01100101
                        Mileage: 164749 km
                        Date: 2020.04.03
                        Time: 00:51:22
       Part No SW: 1K0 907 530 AA    HW: 1K0 907 951
       Component: J533  Gateway   H16 5223
       Revision:   H16       Serial number: 4120K097200630
       Coding: E9A31F06400602004101
       Shop #: WSC 80093 222 69422
       VCID: 6694432DF46700DBC9E-8032
                        Reset counter: 137
                        Mileage: 164749 km
    Address 22: AWD
       Revision: D0H02002    Serial number: AUX7Z0I6FNN0S8
    Address 37: Navigation        Labels: 8E0-035-192-RNSE.clb
       Part No SW: 8P0 035 193 G    HW: 8P0 035 193 G
       Component: RNS-E PU EU     H07 0220
       Revision: 0000013S    Serial number: AUZBZ7MD218544
       Coding: 0259755
       Shop #: WSC 19428 000 104857
       VCID: 3430E965F23BA24B87A-8060
                007 - Short to Ground
                        Fault Status: 01100111
                        Reset counter: 137
                        Mileage: 164749 km
                        Date: 2020.04.03
                        Time: 00:51:34
                        Mileage: 164740 km
                        Count: 304
                        Clock: 00:51
    02005 - Coding Pin
                        Reset counter: 137
                        Mileage: 164749 km
                        Date: 2020.04.03
                        Time: 00:51:34
    Address 42: Door Elect, Driver        Labels: 8P0-959-801-MAX3.lbl
       Part No SW: 8P0 959 801 P    HW: 8P0 959 801 P
       Component: Tuer-SG         H04 0101
       Coding: 0135932
       VCID: 48C8AD959EB336ABDB2-801C
       Part No: 1K0 909 144 J
       Component: EPS_ZFLS Kl. 234    3001
       Revision: 00H17000
       Shop #: WSC 00561 210 91540
       VCID: 313EE0710D299763ECC-8064
       Part No SW: 8P0 959 802 P    HW: 8P0 959 802 P
       Coding: 0004734
       VCID: 49CEA89185B9CFA3C4C-801C
       Part No: 8P3 907 357
       Coding: 0000013
       VCID: 7AAC075D90DF943B1D6-802E
    Address 56: Radio        Labels: 8E0-035-192-RNSE.clb
       Coding: 0259755
                        Reset counter: 137
                        Mileage: 164749 km
                        Date: 2020.04.03
                        Time: 00:51:34
                        Mileage: 164740 km
                        Count: 304
                        Clock: 00:51
    02005 - Coding Pin
                        Reset counter: 137
                        Mileage: 164749 km
                        Date: 2020.04.03
                        Time: 00:51:34
       Part No SW: 8P0 862 335 AA    HW: 8P0 862 335 S
       Component: FSE_256x BT     H34 0600
       Revision: 00000000    Serial number: 00000005109446
       Coding: 0011492
       VCID: 75B61461B9C1FB43704-8020
    End----------(Elapsed Time: 01:17, VBatt start/end: 12.8V/12.1V)-----------
  5. Likes Dana liked this post
  6. #4
    I think the first thing to do here is to figure out why your 22: AWD (Haldex) controller is off-line. Check fuses/power first.
  7. Likes Jetta ,97 liked this post
  8. #5
    Mar 2017
    I did a bit off research on here and noticed a reply ( i think from jack ) about rebooting so i unplugged battery and left it for over 2hrs . I then reconnected it back together and did a autoscan but again the fault 00003 was there and fault on module 22, would i find the fuse for 22 in the interior fuse box or engine box do you know .
    I have got the manual but it says i should have fuses in certain places on 54fuse box ie terminal 15 #49 fuse but i have fuses in #47&#48 but none in #49 , i have orginal data sheet for my vin from elsawin ( took sites advice for 24hr ) so if that is helpful to help sort this problem please let me know thanks .
  9. #6
    Mar 2017
    Uwe could it be down to my battery this module 22 fault as i have noticed in the week twice it has dropped voltage . Will check battery is coded correctly for car
  10. #7
    United States
    Per the Audi A3 Current Flow Diagram No. 76 / 1 All-wheel drive From May 2008 diagram I located fuse SC19 powers J492 (Address 22/Haldex). That's a 10Amp fuse which receives switched power via Terminal 15 relay. SC19 is located in the SC panel which is "under left dash panel". The left/right description may not be accurate for your RHD car but SC is always inside the car.
    SA and SB fuses are located at the under-hood panel on Mk5/6 based cars.
    There are two connectors in-between that fused power and the Haldex so I'd also want to verify the powers and grounds are OK at the module even if the fuse is OK. You don't want to replace the module to find out this was an issue at the T6q connector prior to it.
    Also, fuse SC49 appears to be driving school vehicle or German special police/doctor on call vehicle specific so believe the lack-of a fuse in that position is OK.
    Next, checking the battery and replacing it (if needed) is a great starting point however this car doesn't use start-stop so battery coding doesn't apply. If you have a draw this thread should be very helpful: https://forums.ross-tech.com/showthr...itic-Draw-Test
  11. Likes Uwe liked this post
  12. #8
    Mar 2017
    Cheers for your reply and all the info that came with it , i took battery out overnight and put back in this morning . Car started fine but esp problem still there plus i still cant talk to 22awd contorller.
    I will try the next steps with the fuse , going by manual it is #14 esp ( control unit) Automatic gearbox ( control unit ) parking systems & selector gate for Auromatic gearbox .
  13. #9
    Mar 2017
    Dana , do you think there would be any problems if i recoded Esp module with the same soft coding from an earlier scan like say a month ago when there was no malfunction ot would that cause more problems as i am scratching my head here wondering why this Esp & module 22 awd fault has come about . Thanks i advance
  14. #10
    Mar 2017
    Another update on my problem , i now have module 22awd talking again ( was a fuse # 19 problem so cheers Dana but still have the esp problem and now abs will post new scan tomorrow.
    Saturday,11,April,2020,20:03:00:03294
    VIN: WAUZZZ8P5AA039310 Mileage: 164800km-102401miles
    Revision: 00H45001
    01487 - System Function Test
    Reset counter: 144
    Mileage: 164799 km
    Date: 2020.04.09
    Time: 03:37:50
    Count: 4608
    Count: 321
    Count: 50733
    Count: 5
    Reset counter: 143
    Mileage: 164774 km
    Date: 2020.04.09
    Time: 02:14:30
    Count: 3
    Count: 2
    Count: 12800
    Count: 320
    Count: 42752
    Count: 1
    Reset counter: 183
    Mileage: 164774 km
    Date: 2020.04.09
    Time: 06:07:23
    Fault Frequency: 7
    Reset counter: 134
    Revision: 00104 AH
    Coding: 06000AAFB017F080207241E00100094C437E25AA315DD929E4 0008840040
    Coding: 00DD13
    00059 - Terminal 30 for Interior Lighting
    Fault Status: 00101011
    Reset counter: 184
    Mileage: 164802 km
    Term 15 Off
    Voltage: 12.70 V
    Term 50 Off
    Coding: 000002
    Coding: 0004042
    Coding: 0005428
    Mileage: 164774 km
    Date: 2020.04.09
    Time: 02:11:52
    Part No SW: 0BR 907 554 A HW: 0BR 907 554 A
    Component: Haldex 4Motion 3016
    Coding: 0000005
    VCID: 43D2BAB9A79515F30E0-8016
    Coding: 0259755
    02005 - Coding Pin
    Reset counter: 143
    Mileage: 164774 km
    Date: 2020.04.09
    Time: 02:12:12
    Coding: 0135932
    Revision: 00H17000
    Coding: 0004734
    Coding: 0000013
    Coding: 0259755
    02005 - Coding Pin
    Reset counter: 143
    Mileage: 164774 km
    Date: 2020.04.09
    Time: 02:12:12
    Coding: 0011492
    End----------(Elapsed Time: 01:20, VBatt start/end: 12.3V/12.3V)-----------
