Results 1 to 3 of 3
Thread: Need Help . .2008 Audi A4 B7 2.0T
    Feb 2019
    On the dashboard i get Check Engine, Swerve Curves with the Car, Battery, EPC lights.
    Thursday,26,March,2020,16:38:37:05454
    VIN: WAUAF78E68A103681   License Plate:
    Mileage: 277150km-172213mi   Repair Order:
              67 69 75 76 77
    VIN: WAUAF78E68A103681   Mileage: 277150km-172213miles
       Part No SW: 8E1 910 115 G    HW: 8E0 907 115 D
       Component: 2.0l R4/4V TFSI     0010
       Revision: 5EH15---    Serial number: XXXXXXXXXXXXXX
       Coding: 0104010A02070120
       Shop #: WSC 11111 111 45725
       VCID: 2616FE4194E659D7939-8072
    005445 - Throttle Valve Controller
                   P1545 - 002 - Malfunction
                        Fault Status: 01100010
                        Mileage: 277153 km
                        Load: 0.0 %
                        Temperature: 95.0°C
                        Temperature: 45.0°C
                        Absolute Pres.: 970.0 mbar
                        Voltage: 12.192 V
    Readiness: 0000 0100
    Address 02: Auto Trans        Labels: 01J-927-156.lbl
       Part No SW: 8E5 910 155 A    HW: 01J 927 156 HT
       Component: V30 01J 2.0TFSI USA 0010
       Revision: 00000009    Serial number: 00000001155902
       Shop #: WSC 06325 000 00000
       VCID: 280AF0799EF24FA7A15-807C
    006231 - Load Signal
                   P1857 - 000 - Error Message from ECU - Intermittent
                        RPM: 96 /min
                        (no units): 13.0
                        Torque: -6.0 Nm
                        Temperature: 47.0°C
                        T.B. Angle: 0.0°
                        Bin. Bits: 0101 0 1
       Part No SW: 8E0 910 517 H    HW: 8E0 614 517 BF
       Component: ESP8 FRONT      H06 0140
       Coding: 0004525
       VCID: 2C020C698A0A638745D-8078
                013 - Check DTC Memory
                        Fault Status: 01101101
                        Reset counter: 40
                        Hex Value: 0x00C0
                        Hex Value: 0x4006
                        Hex Value: 0x0025
                        Hex Value: 0x019A
                        Hex Value: 0x0000
       Part No: 8E0 820 043 BL
       Component:   A4 Klimaautomat   3233
       Coding: 00000
       VCID: 6C82CC694F9AA38705D-5118
    00716 - Air recirculation Flap Positioning Motor (V113)
                41-10 - Blocked or No Voltage - Intermittent
       Part No: 8E0 907 279 N
       Component: int. Lastmodul  USA 0907
       Coding: 00003
       Shop #: WSC 06325
       VCID: 3D24312D6460FA0FE23-4AA4
       Part No SW: 8E0 959 655 M    HW: 8E0 959 655 M
       Component:    Airbag 9.41  H01 4240
       Revision: 91H01424    Serial number: 003CS0001BCO
       Coding: 0032607
       VCID: 41DC4DDD1D889EEF86B-8014
       Subsystem 1 - Part No: 8E0 910 339 D
       Component: BF-Gewichtsens. H03 0080
       Subsystem 2 - Serial number: 01K8U
       Subsystem 3 - Serial number: 0001.01.0000H0300000000000˙†63
       Subsystem 4 - Serial number: 000000˙†6332DRB40610CFAD/˙†63
       Subsystem 5 - Serial number: 0CFAD/˙†6342DRB406054A22D˙†63
       Subsystem 6 - Serial number: 54A22D˙†6352ARB402F8178AX˙†63
       Subsystem 7 - Serial number: 8178AX˙†6362ARB402F81784S˙†63
       Subsystem 8 - Serial number: 81784S˙†63729RB402B8B895.˙†63
       Subsystem 9 - Serial number: 8B895.˙†63829RB402B893D8 ˙
       Subsystem 10 - Serial number: 893D8 ˙
       Part No: 8E0 953 549 Q
       Component: Lenksįulenmodul     0801
       Coding: 04141
       Shop #: WSC 06325
       VCID: 41DC4DDD18989EEF86B-4AA4
       Part No SW: 8E0 920 951 N    HW: 8E0 920 951 N
       Component: KOMBI+WFS 4     H14 0200
       Revision: 0200        Serial number: 00000000000000
       Coding: 0022268
       Shop #: WSC 22130 444 00023
       VCID: 3534290D5950224F2A3-50F4
       Coding: 0022268
       Part No: 8E0 959 433 CP
       Component: Komfortgerįt T7B    4336
       Coding: 11820
       Shop #: WSC 06325
       VCID: 015C8DDD58185EEFC6B-4AA4
       Component: Tõrsteuer.FS BRM 0706
       Subsystem 2 - Part No: 8E1959802G
       Component: Tõrsteuer.BF BRM 0706
    Address 65: Tire Pressure        Labels: 8E0-907-273.lbl
       Part No SW: 8E0 907 273 A    HW: 8E0 907 273 A
       Component: Reifendruck 3   H04 0130
       Coding: 0042121
       Shop #: WSC 06435 000 00000
       VCID: 2A0E0A7180DE7DB7B71-5160
       Part No SW: 8P0 862 335 R    HW: 8P0 862 335 R
       Component: FSE_255x BT     H26 0350
       Revision: 00000000    Serial number: 00000005055881
       Coding: 0001677
       VCID: 45D459CD09B0B2CFBA3-50D0
    End----------(Elapsed Time: 05:30, VBatt start/end: 12.4V/12.3V)-----------
    Feb 2019
    Uwe,
    Thank you will try suggestions. . .
