Results 1 to 9 of 9
Thread: VW polo 9N ABS Coding need
    Dec 2018
    hello plese i need ABS coding for polo 9N
    Thursday,26,March,2020,16:18:39:03857
    VCDS Version: Release 19.6.2 (x64) Running on Windows 7 x64
    Arkan Abdulkader
    Address 03: ABS Brakes Labels: 6Q0-907-37x-ESP.lbl
    Control Module Part Number: 6Q0 907 379 M
    Component and/or Version: ESP 5.7 front H02 0001
    Software Coding: 0000000
    Work Shop Code: WSC 00000 000 00000
    VCID: 47DEB12537A2E57726-50D0
    regards
    the vin No, : WVWZZZ9NZ3Y069589
    Please post a complete Auto-Scan for context.
    Dec 2018
    Thursday,26,March,2020,16:48:39:03857
    Dealer/Shop Name: Arkan Abdulkader
    VIN: WVWZZZ9NZ3Y069589   License Plate:
    Chassis Type: 9N (9N - VW Polo (2002 > 2010))
    Scan: 01 02 03 08 09 15 17 19 25 37 44 45 46 56 76
    VIN: WVWZZZ9NZ3Y069589   Mileage: 123680km-76851miles
       Part No: 03C 997 013
       Component: MED7.5.11       G   9500
       Coding: 00071
       Shop #: WSC 46701
       VCID: 638645B5F35AA957DA-5184
       WVWZZZ9NZ3Y069589     VWZ7Z0B5388695
    Readiness: 1110 0101
       Part No: 6Q0 907 379 M
       Component: ESP 5.7 front   H02 0001
       Coding: 0000000
    Address 08: Auto HVAC        Labels: 6Q0-820-045.lbl
       Part No: 6Q0 820 045
       Component: Klimaanlage        X0840
       VCID: 6A9828911470F81F19-50D0
    01596 - Motor for Outside/Recirculated Air Flap (V154)
                29-10 - Short to Ground - Intermittent
    Address 09: Cent. Elect.        Labels:. 6Qx-937-049-C.lbl
       Part No: 6Q1 937 049 C
       Component: 00 BN-SG.           1S33
       Coding: 26542
       Shop #: WSC 00788
       VCID: 3B36DDD52B6AB197B2-50D0
                28-10 - Short to Plus - Intermittent
    00906 - Horn (H1)
    00975 - Heated Rear Window (Z1)
    01598 - Drive Battery Voltage
       Part No: 1C0 909 605 K
       Component: 0K AIRBAG VW51 0N   0008
       Coding: 12363
       Shop #: WSC 00788
       VCID: 2C14EE89DE04262F2B-50D0
    00532 - Supply Voltage B+
    Address 17: Instruments        Labels: 6Q0-920-xxx-17.lbl
       Part No: 6Q0 920 821
       Component: KOMBI+WEGFAHRSP VDO V13
       Coding: 01141
       VCID: 6D92238D259EEF277C-50D0
       Part No: 6N0 909 901
       Component: 08 GATEWAY  CAN    1S33
       Coding: 00014
       Shop #: WSC 00788
       VCID: 70AC3AF932AC02CF57-50D0
       Part No: 6Q0 423 156 M
       Component: LenkhilfeTRW        V210
       Coding: 01210
       Shop #: WSC 48645
       VCID: 393AC7DD21568387A0-50D0
    Address 45: Inter. Monitor        Labels: 6Q0-951-171.lbl
       Part No: 6Q0 951 171 A
       Component: Innenraumueberw.    0018
       VCID: 302CFAF9F22C42CF17-513C
    Address 46: Central Conv.        Labels:. 6Q0-959-433.clb
       Part No: 6Q0 959 433 E
       Component: 3P Komfortgerát     0001
       Coding: 00064
       Shop #: WSC 00788
       VCID: 3D32D3CD357EBFA78C-4B1E
       Subsystem 1 - Part No: 6Q2959802A
       Component: 3P Tőrsteuer.FS TFK 0003
       Subsystem 2 - Part No: 6Q2959801A
       Component: 3P Tőrsteuer.BF TFK 0003
                53-10 - Supply Voltage Too Low - Intermittent
                37-10 - Faulty - Intermittent
    01134 - Alarm Horn (H12)
    End----(Elapsed Time: 02:37, VBatt start/end: 12.4V/12.4V. VIgn 0.0V)------
    Dec 2018
    please i am waiting for you ?
    regards
    Quote Originally Posted by Arkan View Post
    Please, you posted ~30 minutes ago. I have no coding chart for the ABS in this car. Hopefully someone else reading this does.
    Aug 2016
    The Hague, NL
    My best guess so far: 0003416
  7. Likes Uwe liked this post
    Dec 2018
    thanx i have tried it . but didn,t work , maybe i must change ABS control
    regards
  9. #8
    If you in such a hurry, why not tell us upfront, what you have tried
    Else try 0003365
    Use numbers in WSC etc. [Options]
  10. Likes iichel, Uwe, DrPeter liked this post
  11. #9
    16.4905° S, 151.7375° W
    I concur with Ntech, the J104-ABS Controller coding should be [0003365] with the base engine [T74].
    drpeter
  12. Likes Uwe liked this post
