Results 1 to 9 of 9
Thread: Seat cruise control issue
    Nov 2019
    Norwich, UK
    I have got the job of sorting a mess up the person has fitted a new Squib and has binned the original so no coding available from original ive managed to get steering buttons ect all working but the cruise I cant I can see the switch working in measuring blocks and all faults now clear on 16: steering wheel that was present however there is a fault in 01: engine I cant seem to get my head round it experimental coding all in German which does not help either.
    if someone could have a look at the coding would appreciate it or offer some advice
    regards
    Marty
    Thursday,26,March,2020,11:45:23:16673
    VIN: VSSZZZ1PZBR059418   License Plate: SEAT
    Mileage: 168460km-104676mi   Repair Order:
    Chassis Type: 1P-SE35 (7N0)
    Scan: 01 03 08 09 15 16 17 19 25 2E 42 44 46 52 56 62 72
    VIN: VSSZZZ1PZBR059418   Mileage: 168460km-104676miles
    Address 01: Engine (BK2-CAXC)       Labels:. 03C-906-016-CAX2.clb
       Part No SW: 03C 906 016 AP    HW: 03C 906 016 AP
       Component: 1.4l R4/4V TS H12 8179
       Revision: LCH12---    Serial number:
       Coding: 00190012002400000000
       Shop #: WSC 06402 785 00200
       ASAM Dataset: EV_ECM14TFS01103C906016AP 001006
       ROD: EV_ECM14TFS01103C906016AP.rod
       VCID: 6D87CEB6AD15EC7F123-8038
    4714 - Steering Column Control Module
              U0212 00 [039] - No Communications
                        Mileage: 168462 km
                        Date: 2020.03.26
                        Time: 11:41:21
                        Coolant temperature: 94 C
                        Intake air temperature: 57 C
                        Voltage terminal 30: 12.415 V
                        CAN status - engine control module-Bits 0-7: 00000000
                        Generator power: 0 W
                        CAN TimeOut meter - gateway-Bits 0-7: 00000000
    Readiness: 1110 0101
       Part No SW: 1K0 907 379 BE    HW: 1K0 907 379 BE
       Component: ESP MK60EC1   H31 0108
       Revision: 00H31001
       Coding: 133B401209270003C80F02E590210080350800
       Shop #: WSC 04941 000 00000
       VCID: 76B5E1DAD8C32FA7E39-8022
       Part No SW: 5P0 907 044 P    HW: 5P0 907 044 P
       Component: Climatronic   H15 0702
       Revision: 00001001
       Coding: 0000000002
       ROD: EV_ClimaAutoBasis_SE35.rod
       VCID: 3D273EF6BDF5BCFFE23-8068
    Address 09: Cent. Elect.
       Part No SW: 5N0 959 655 R    HW: 5N0 959 655 R
       Component: J234__A0E VW10 HI   1918
       Revision: 22014000    Serial number: 003K0P3018EV
       Coding: 0012357
       VCID: 4CC16332FACF057765D-8018
       Subsystem 1 - Serial number: 6332MTS644130321
       Subsystem 2 - Serial number: 6342MTS648160321
       Subsystem 3 - Serial number: 6351HTS6UBQCP9KJ
       Subsystem 4 - Serial number: 6361HTS6HI7DP9KJ
       Part No SW: 5K0 953 569 AL    HW: 5K0 953 569 AL
       Revision: --X01---    Serial number: 20191016200241
       Coding: 1002100008
       Shop #: WSC 01286 386 08256
       ROD: EV_SMLSNGVOLWS.rod
       VCID: 025D8D0A848B0307DF1-8056
       Subsystem 1 - Part No SW: 1P0 959 538 C    HW: 1P0 959 538 C  Labels: 3C8-959-537.CLB
       Component: E221__MFL-TAP  H02 0102
       Serial number: 00000000000000239363
       Coding: E20000
       Part No SW: 1P0 920 910 M    HW: 1P0 920 910 M
       Component: KOMBI         H06 0404
       Coding: 410B00
       VCID: 333318CE8BB17A8F047-8066
       Part No SW: 7N0 907 530 C    HW: 1K0 907 951
       Component: J533  Gateway H37 0614
       Revision:   H37       Serial number: 260211F2000399
       Coding: 350203
       VCID: 303917C27A274197795-8064
       Component: IMMO          H06 0404
       VCID: 6A8DC5AA9CFBFB47771-803E
       Part No SW: 5N0 035 342 D    HW: 5N0 035 342 D
       Component: SG EXT.PLAYER H13 0150
       Revision: A1001003    Serial number: 7669489500
       VCID: 2809FFA242F70957A15-807C
       Part No SW: 3C8 959 701     HW: 3C0 959 793 C
       Component: TUER-SG FT    002 0508
       Revision: 12110009    Serial number: 0001823611
       Coding: 0012B0
       Slave Driver:
       Subsystem 1 - Part No SW: 1K0 959 704 AF    HW: 1K0 959 794 S
       Component: J389__TSG-HR  006 1401
       Serial number: 00000005596206
       Coding: 000290
       Part No: 1K0 909 144 M
       Component: EPS_ZFLS Kl. 142    3201
       Revision: 00H20000
       VCID: 34311BD2823F7DB71DD-8060
    Address 46: Central Conv.
       Part No SW: 3C8 959 702     HW: 3C0 959 792 C
       Component: TUER-SG BT    002 0508
       Revision: 14110009    Serial number: 0001821946
       Coding: 0012B0
       VCID: 6E85C9BAA01317672B9-803A
       Slave Passenger:
       Subsystem 1 - Part No SW: 1K0 959 703 AF    HW: 1K0 959 795 S
       Component: J388__TSG-HL  006 1401
       Serial number: 00000005583882
       Coding: 000290
       Part No SW: 5P0 035 186     HW: 5P0 035 186
       Component: Media2.0      H01 0007
       Revision: 00000001    Serial number: SEZ1Z3L0207617
       Coding: 0106040004
       VCID: 6C81C3B2968FE57705D-8038
    End----------(Elapsed Time: 00:57, VBatt start/end: 12.5V/12.5V)-----------
    Jun 2014
    Sorry for my ignorance... but what is a "Squib"?
    Golf VII, 1.6TDI BM Ed. 40 - 110 PK
    Jul 2014
    Hi Mari,
    For some reason many people miss-name the clock spring or module that carries the connection to the steering wheel airbag a "squib". It derives from an English name for a firework or small explosive, you may have heard the saying "went off like a damp squib" meaning something did not work correctly. So the squib is really the explosive charges (pyro techniques) in the air bags and belt tensioners.
    Regards HMC
  4. Likes Dana liked this post
    Oct 2014
    Similar cars online have an older controller installed:
    Part No SW: 5K0 953 521 BN HW: 5K0 953 569 E
    Component: LENKS.MODUL 009 0136
    Revision: FF010039 Serial number: 20110103100351
    Coding: 1082140002
    VCID: 79F3CA8BF8F45287E0-802C
    Coding: E20000
    Assuming the new part is compatible with the above, it might be worth trying 1082140002 for the coding?
  6. Likes Dana liked this post
    Nov 2019
    Norwich, UK
    Quote Originally Posted by HMC View Post
    Hi Mari,
    Regards HMC
    It's what we have always called it in the trade squib/clockspring
    Nov 2019
    Norwich, UK
    Quote Originally Posted by langers2k View Post
    Coding: 1082140002
    Coding: E20000
    Thanks I will give that a try would of been a lot easier if I could of done a scan of the original before it was removed and binned 🙈
  9. Likes Dana liked this post
  10. #7
    United States
    I agree with the 1082140002 suggestion. We had one 1P-SE35 (7N0) scan with that 01 module and it was nearly identical:
    Coding: 108A140002
    Subsystem 1 - Part No SW: 1P0 959 538 D HW: 1P0 959 538 D Labels: 3C8-959-537.CLB
    Coding: E20000
    The difference is with/without PTT phone button.
  11. Likes Uwe liked this post
  12. #8
    Nov 2019
    Norwich, UK
    Thanks I will give it a go tou think that would explain the 01: fault then
  13. #9
    Jul 2014
    Quote Originally Posted by Marty.h View Post
    The clockspring doesn't explode, at least it's not deigned to. I have been in the trade 54 years, don't start me on calling suspension dampers shock absorbers!
    Regards HMC
    Regards
  14. Likes PetrolDave, Uwe, Fredrick Awuor liked this post
