Results 1 to 2 of 2
Thread: How to change from rmc to mmi
    Mar 2020
    Dublin, Ireland
    Hello I was just wondering if its possible to change from rmc to mmi cause it seems the mmi systems has alot my extras than the rmc
    I'm running
    Rmc_eu_11474
    Wednesday,25,March,2020,16:05:53:42836
    VCDS Version: 19.6.2.2  HEX-V2 CB: 0.4508.4
    VIN: WAUZZZ4G3DN025277   License Plate: 12D58852
    Mileage: 233418km-145039mi   Repair Order:
    Chassis Type: 4G-AU57 (4G0)
    Scan: 01 02 03 05 08 09 10 15 16 17 19 3B 42 44 46 52 53 55 5F 62
              72
    VIN: WAUZZZ4G3DN025277   Mileage: 233418km-145039miles
    Address 01: Engine (J623-CGLC)       Labels:. 03L-906-018-CGL.clb
       Part No SW: 03L 906 018 LB    HW: 03L 906 018 JL
       Component: R4 2.0l TDI   X25 9978
       Revision: 45X25---
       Coding: 12034012242401080000
       Shop #: WSC 92521 052 00000
       ASAM Dataset: EV_ECM20TDI01103L906018LB 003012
       ROD: EV_ECM20TDI01103L906018HA.rod
       VCID: 75B7E002B54B43EFEA3-8020
    10065 - Mass Air Flow Sensor (G70)
              P0104 00 [032] - Intermittent
    Address 02: Auto Trans (J217)       Labels:| 0AW-927-156.clb
       Part No SW: 4G0 927 155 T    HW: 0AW 927 156 K
       Component: 0AW 20TDI RdW H04 0005
       Revision: --H04---    Serial number: 0000000532
       Coding: 000001
       Shop #: WSC 02311 785 00200
       ASAM Dataset: EV_TCMVL381 A02430
       ROD: EV_TCMVL381.rod
       VCID: 3C213526D6E1D2A7D5D-8068
    10077 - Valve for Transmission Fluid Cooler
              P2753 00 [047] - Open Circuit
                        Mileage: 217599 km
                        Date: 2019.07.27
                        Time: 16:19:53
                        Engine speed: 829.00 /min
                        Transmission input speed: 1 /min
                        Transmission output speed: 1 /min
                        Engine torque: 4 Nm
                        Transmission fluid temperature: 92 °C
                        Accelerator position: 0.0 %
                        Clutch status: 13
                        Occurrence_counter_over_length_of_life: 254
       Coding: 06A187016085E180DB00
       VCID: 3635270EE8CD08F7239-8062
       Part No SW: 4H0 907 064 CN    HW: 4H0 907 064 CN
       Component: BCM2 2.0      H32 0421
       Coding: 01B93046000000000000
       VCID: 77ABEA0AAFC731FFF8F-8022
       Serial number: 2312000124433014
       Part No SW: 4G0 820 043 AB    HW: 4G0 820 043 AB
       Component: KLIMA 2 ZONEN H11 0070
       Serial number: 22061200111751
       Coding: 34220008A1
       ASAM Dataset: EV_AirCondiBasisUDS 002040
       VCID: 5F9BA2AA27B7E9BF90F-800A
       Part No SW: 4H0 907 063 CE    HW: 4H0 907 063 E
       Revision: 19012002    Serial number: 00000001363889
       Coding: 2600E031413C9FE20185008400001D0C0F9DC70827090301000004606100
       VCID: 6D87C862DD9B8B2F123-8038
       Component: WWS57X 120512  H35 0080
       Serial number:         120604203030
       Coding: 0045F7
       Serial number: 20362856
       Coding: 02006D
       Subsystem 3 - Part No SW: 4G0 941 531 E    HW: 4G0 941 531 E
       Component: E1 - LDS  H07 0044
       Serial number: 21 06 2012  00001235
       Serial number: 0AD88336000000000001
                        Reset counter: 177
                        Mileage: 233324 km
                        Date: 2020.03.23
                        Time: 21:59:00
       Part No SW: 4H0 919 475 AG    HW: 4H0 919 475 AG
       Component: PARKHILFE ACC H01 0072
       Revision: 11001001    Serial number: 61061217801958
       Coding: 08C308
       ASAM Dataset: EV_EPHVA18AU57X0000 003008
       VCID: 77ABEA0AAF4731FFF8F-8022
    1079060 - Center Rear Left Parking Aid Sensor
              B1077 14 [008] - Open or Short to Ground
                        Reset counter: 210
                        Mileage: 233181 km
                        Date: 2020.03.22
                        Time: 11:59:02
       Revision: --------    Serial number: 003JG0096JF1
       Coding: 30323436313230303235554A305234473053
       Serial number: 3575HRB405T1EVLEAGIN
       Serial number: 3585HRB404T1DEDA7PQ7
       Serial number: 3515JRB40124UH24N9TO
       Serial number: 3525JRB400O4UH24JHJ/
       Serial number: 3554VRB40044UH245OU
       Serial number: 3564VRB40024UH24B8OL
       Revision: 00000000    Serial number: 20120627000989
       Coding: 000035
       VCID: 303911160A2926C7795-8064
       Component: E221 - MFL  H08 0009
       Part No SW: 4G8 920 950 N    HW: 4G8 920 950 N
       Component: MDieGb        H34 0306
       Revision: 26450232    Serial number: 658230612592057
       Coding: 33A710000B512600010200
       Shop #: WSC 09550 758 180955
       ASAM Dataset: EV_RBC7KMID 004045
       ROD: EV_RBC7KMID.rod
       VCID: 3A2D333EDCD5EC97C71-806E
    16776969 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
              [LDW_02_FR keine Kommunikation]
                        Reset counter: 215
                        Mileage: 221539 km
                        Date: 2019.09.22
                        Time: 11:44:04
       Part No SW: 4G0 907 468 AB    HW: 4G0 907 468 AA
       Component: J533--Gateway H10 0028
       Revision: --------    Serial number: 00000000579367
       Coding: 00CF074400
       ASAM Dataset: EV_GatewPkoUDS 001013
       VCID: 70B9D116CA2966C7395-8024
       Component: J367-BDM  H07 0141
       Serial number: 00000000003790439496
       Voltage stabilizer:
       Subsystem 2 - Part No SW: 8K0 959 663 D    HW: 8K0 959 663
       Serial number: 040412000000000002DA
    12290 - Quiescent Current
              U1406 00 [008] - Too High
                        Reset counter: 222
                        Mileage: 223997 km
                        Date: 2019.10.28
                        Time: 16:06:17
                        Voltage terminal 30: 12.4 V
                        Voltage terminal 15: 0.0 V
                        Control Module temperature: 12 °C
                        System status: LIN_active
                        Engine running: OFF
                        IN ZAS_Te_X: OFF
                        Terminal 15 status: OFF
                        Datenfeld: 0
              U140B 00 [008] - -
              [Powermanagement active]
                        Reset counter: 222
                        Mileage: 224029 km
                        Date: 2019.10.29
                        Time: 06:40:17
                        Voltage terminal 30: 12.3 V
                        Control Module temperature: 8 °C
                        Engine running: OFF
                        IN ZAS_Te_X: OFF
                        Datenfeld: 1
       Component: SARA 3D       H02 0053
       Revision: --------    Serial number: EJ1BPA72005MUH
       ASAM Dataset: EV_SARA2 005011
       ROD: EV_SARA2.rod
       VCID: 33331E1AFBBF1DDF047-8066
       Component: TSG FA        H03 0506
       Coding: 011F16005C01620002080002
       VCID: 47CB5ACA9FA7817F48F-8012
    02117 - Motor for Mirror Folding
                        Reset counter: 68
                        Mileage: 217678 km
                        Date: 2019.07.27
                        Time: 17:46:44
       Component: RCEPS         H35 0010
       Revision: 00001000    Serial number: 0005630172
       Coding: 101000010000
       ASAM Dataset: EV_RCEPS 009008
       ROD: EV_RCEPS_009.rod
       VCID: 323D1B1E04A514D70F1-8066
       Revision: 00002001    Serial number: 0179242157
       Coding: 017F162030B90080832009040001040F0000000000000000000000000000
       Component: TSG BF        H03 0506
       Coding: 011C16005401620002080002
       VCID: 46D557CE98AD9877B39-8012
                        Reset counter: 68
                        Mileage: 217678 km
                        Date: 2019.07.27
                        Time: 17:46:44
       Part No SW: 4H0 907 801 F    HW: 4H0 907 801 A
       Component: EPB-4         H03 0013
       Revision: --------    Serial number: 00000000385365
       ROD: EV_ParkiBrake_VW51.rod
       VCID: 2B03067A238F451F4C7-807E
    721152 - Brake Pad Replacement Mode Active
              C1011 00 [000] - -
       Serial number: 120626-0001-134
       Coding: 112296101000A300
       ROD: EV_HeadlRegulBasic.rod
       VCID: 2C0105662681422745D-8078
       Part No SW: 4G0 035 193 E    HW: 4G0 035 193 D
       Component: RMC Cnct Nav  H53 0775
       Coding: 0101010101415B47082B060301010000010000
       VCID: 2517F04245EB736F9A3-8070
       Subsystem 1 - Part No: 8X0 919 884 D
       Component: P13-50-11.06  0002
       Subsystem 2 - Part No SW: 4G0 919 603     HW: 4G0 919 603
       Component: DU6 Basic  H42 0084
       Serial number: 9464FZ0C2535463
       Subsystem 3 - Part No SW: 4G2 919 610 E    HW: 4G2 919 610 E
       Serial number: 90349NAO000IL
                        Reset counter: 212
                        Bin. Bits: 00000000 00000001
                        Bin. Bits: 00000000 00000000
       Component: TSG HL        H03 0506
       VCID: 49CF5CF289B3770F5EB-801C
       Component: TSG HR        H03 0506
    End----(Elapsed Time: 01:39, VBatt start/end: 11.7V/11.7V. VIgn 11.7V)
    Last edited by Boki Ar; 03-26-2020 at 05:05 AM. Reason: Fix - add only / in bottom [/Code] Tags
    I'm not sure what all would be involved in that car, but I'm sure of one thing: That would be a Retrofit, not a Tweak, so I'm moving this thread to the appropriate section.
