Results 1 to 7 of 7
Thread: Audi a4 b7 wastegate help
    New User
    Sep 2017
    Hi everyone I bought a project b7 2.0t with a broken timing belt, everything went well.now as I was inspecting the turbo before I install it . I applied pressure to the wastegate and the wastegate slowly creeps back.is it suppose to? Or is it suppose to hold? I used a hand held vacuum pump .I also made sure connections were tight . Ty so much and have a great day😊😊
    Moving to General VW/Audi Repair.
    United States
    The wastegate should have held the pressure in my opinion because the system dumps/vents that pressure back off via N75.
  4. Likes Uwe, Fredrick Awuor liked this post
    Jul 2014
    Hi audi4ever,
    Are you sure your vacuum pump is ok and holding vacuum?
    Regards HMC
  6. Likes Dana, Uwe liked this post
    New User
    Sep 2017
    When I plug my vacuum with my finger it holds well,but also know, it's not vacuum I'm using it's pressure,anything I could do to test the pressure side of my vacuum?
    Jul 2014
    You could connect it to a low pressure gauge and see what happens.
    Regards HMC
    New User
    Sep 2017
    Hi I used the same vacuum pump on my sons wastegate , his A5 , cuz he was doing a service on it and I just happen to be there .his wastegate did hold, unlike the one in my B7 2.0 T.so is my diaphram torn you think? I apply pressure to it, then it slowly retracts.
