Results 1 to 8 of 8
Thread: 5211 - Fuel Rail/System Pressure Too Low
    May 2018
    Norway
    Hello!
    I tried to search in the forums for a thread but could not find any relevant for my issue
    I also have a couple of questions regarding my troubleshooting
    According to RossTech Wiki P0087 there are several solutions for this faultcode.
    The HPFP was replaced last month, and the fuelfilter was replaced yesterday.
    The old HPFP pump was inspected for metal shavings, nothing to be found.
    I can read from the rosstech wiki that
    "When found in Audi Common Rail V6, V8 and V12 TDI engines, please see TPI 2020693 for Contaminated fuel found in fuel system concerns. After mechanical all repairs are made N276 may need to be adapted and the EDC may need to be flash updated on the Audi Dealer level. When a dealer level update applies SVM code 01A036 is used."
    Im not sure if the new pump was adapted, nor am I sure if this needs to be done.
    I have tried to log IDE00188 -- Fuel high pressure; actual value and IDE00201 -- High fuel pressure; specified value, but as you can see in the faultcode in the full scan, the actual value differences aprox 200bar from the specified value at the time it throws the fault code.
    Is there any way I can use this method belowto check for pressure leak in the fuel system, or is this for gasoline cars only? I tried to follow those steps but the actual fuel pressure value is not moving when the engine is off (and ignition on)
    Is there also any way to log or test the lift pump inside the dieseltank?
    Last question is regarding the VC scope, im not so familiar with that.
    Why wont the green line scale like the red one? I notice that it says "100" top left corner, but I cant change that. I have also tried to type in dozens of different values in the "vertical scale min/max" bottom right corner, but its only the red line that changes. What am I doing wrong?
    Wednesday,25,March,2020,20:25:15:21245
    VCDS Version: 19.6.2.0 (x64)  HEX-NET CB: 0.4513.4
    VIN: WAUZZZ4L9DD009457   License Plate: JIMETTER
    Mileage: 184060km-114369mi   Repair Order:
    Chassis Type: 4L-AU56 (4F0)
    Scan: 01 02 03 05 08 09 10 15 16 17 18 19 20 28 34 42 46 4C 4F 52
              55 56 5F 62 69 6D 6F 72
    VIN: WAUZZZ4L9DD009457   Mileage: 184060km-114369miles
    Address 01: Engine (J623-CRCA)       Labels:. 059-907-401-V2.clb
       Part No SW: 4L2 910 401 B    HW: 4L0 907 401 C
       Component: 3.0TDI EDC17  H39 0001
       Revision: 53H39---    Serial number:
       Coding: 2A2A401A253601020000
       Shop #: WSC 31414 790 00001
       ASAM Dataset: EV_ECM30TDI0114L2910401B 001001
       ROD: EV_ECM30TDI0114L1910401H.rod
       VCID: A306830BAA8785571A-80F6
              P0087 00 [167] - Too Low
                        Mileage: 184064 km
                        Date: 2020.03.25
                        Time: 20:18:26
                        Engine speed: 2948.00 /min
                        Normed load value: 99.2 %
                        Vehicle speed: 122 km/h
                        Coolant temperature: 71 °C
                        Intake air temperature: 11 °C
                        Voltage terminal 30: 14.720 V
                        Unlearning counter according OBD: 80
                        Fuel temperature: 10.1 °C
                        Mean injection quantity: 68.85 mg/stroke
                        Rail pressure regulation: status-Bits 0-7: 5
                        Fuel high pressure: actual value: 1.7754e+006 hPa
                        High fuel pressure: specified value: 1.963e+006 hPa
                        Pressure control valve adaptation factor: 1.1549
                        Fuel level: 98.00 l
       Part No SW: 0C8 927 750 AL    HW: 0C8 927 750 AL
       Component: AL1000 AISIN  001 2096
       Coding: 001578
       Shop #: WSC 26176 001 1048576
       ASAM Dataset: EV_TCMAL991031 002112
       ROD: EV_TCMAL991031_002.rod
       VCID: F6A08A5F499540FF0D-80A2
    Address 03: ABS Brakes        Labels:. 4L0-910-517-V2.clb
       Part No SW: 4L0 910 517 M    HW: 4L0 614 517 L
       Component: ESP ALLRAD MK25E1   0020
       Revision: 00H02001
       Coding: 2200673
       VCID: B4247057D76912EFF3-80E0
       Part No SW: 4F0 910 852 B    HW: 4F0 905 852 H
       Component: FBSAUDIC6 ELV   H08 0200
       Revision: 00H08000    Serial number: 10603702012499
       Coding: 0000131
       VCID: A5029D136CB37B6774-80F0
       Subsystem 1 - Part No: 4F0 910 132 E
       Component: FBSAUDIC6 EZS   H04 0020
       Component: FBSAUDIC6 IDG   H01 0054
       Part No SW: 4L0 910 043 D    HW: 4L0 820 043 AH
       Component: KLIMA 4 ZONEN H15 0070
       Revision: 00---026    Serial number: 00000030251205
       Coding: 01029816
       VCID: A5029D13ACB37B6774-80F0
       Part No SW: 4F0 910 279 AH    HW: 4F0 907 279 D
       Component: ILM Fahrer      H31 0400
       Coding: 0023221
       VCID: EFAEBF3BFECF7137CE-80BA
       Subsystem 1 - Part No: 4L1 910 113   Labels: 1KX-955-119.CLB
       Component: Wischer AU716   H18 0110
       Coding: 00064792
       Shop #: WSC 31414
       Coding: 00150059
       Shop #: WSC 31414
    Address 10: Park/Steer Assist (J446)       Labels:| 4L0-919-475-7X2.clb
       Part No SW: 4L0 919 475 A    HW: 4H0 919 475 C
       Component: PARKHILFE 8K  H07 0011
       Revision: 11001001    Serial number: 55901218700352
       Coding: 05031F
       ASAM Dataset: EV_EPHVA18AU7160000 001001
       ROD: EV_EPHVA18AU7160000.rod
       VCID: B42470571F6912EFF3-80E0
       Part No SW: 4L0 910 655 D    HW: 4L0 959 655 C
       Component: 70 AIRBAG AUDI8RH43 0230
       Revision: 04H43000    Serial number: 00399D09G40K
       Coding: 0014128
       VCID: AE10623F3945383F85-80FA
       Subsystem 1 - Serial number: 6332QSME001B32462
       Subsystem 2 - Serial number: 6342QSME181C1B46K
       Subsystem 3 - Serial number: 6352QSME7D1A4B60T
       Subsystem 4 - Serial number: 6362QSME001B194EI
       Subsystem 5 - Serial number: 63734SME0A17245E1
       Subsystem 6 - Serial number: 63834SME4A182C769
       Part No SW: 4F0 910 549 B    HW: 4F0 953 549 E
       Component: J0527               0830
       Revision: 00H08000    Serial number: 90055121490111
       Coding: 0002142
       VCID: A81C94271BA1660F4F-80FC
       Component: E0221           H03 0030
    Address 17: Instruments (J285)       Labels:. 4L0-920-xxx-17.clb
       Part No SW: 4L0 920 933 H    HW: 4L0 920 933 H
       Component: KOMBIINSTR.   H35 0316
       Revision: 00000000    Serial number: NGA22KR7D
       Coding: 1356630401010008000004
       VCID: B228764FED7D1CDFE1-80E6
    Address 18: Aux. Heat        Labels: 4L0-910-105.lbl
       Part No SW: 4L0 910 105     HW: 4L0 265 105 P
       Component: Heizgeraet      H09 0140
       Revision: 0000000C    Serial number: 00000009021078
       Coding: 0000101
       VCID: E08CCC073311DE4F47-80B4
       Part No SW: 4F0 907 468 S    HW: 4F0 907 468 G
       Component: GW-BEM 5CAN-M H06 0058
       Revision: MB700037    Serial number: 3700M127130103
       Coding: 00CF07
       VCID: BFCE2F7B2E2FC1B71E-80EA
       Subsystem 1 - Part No SW: 8K0 915 181 D    HW: 8K0 915 181 D
       Component: J367-BDM  H07 0125
       Serial number: 00000000002790776793
       Serial number: 12195000141011200181
       Part No SW: 4F0 857 511 K    HW: 4F0 857 511 K
       Component: FLA           H04 0004
       Revision: AA001002
       Coding: 02019064747464545425363E
       VCID: B02C7C47E3712ECF97-80E4
    Address 28: HVAC, Rear        Labels: None
       Part No SW: 4L0 910 158     HW: 4L0 919 158 AA
       Component: KLIMABETAETIGUNGH06 0060
       Revision: 00---010    Serial number: 00000030251691
       Coding: 0000006
       VCID: E89CD427DB21A60F8F-80BC
    Address 34: Level Control        Labels: 4L0-910-553.lbl
       Part No SW: 4L0 910 553 L    HW: 4L0 907 553 E
       Component: LUFTFDR.-CDC    H04 7890
       Revision: --H04001    Serial number: 15.1528-0194.2
       Coding: 0015520
       Shop #: WSC 12515 002 1048576
       VCID: B326734BD26715D7EA-80E6
       Part No SW: 4F0 959 793 T    HW: 8K0 959 793 M
       Component: TSG FA        H12 0362
       Revision:             Serial number: 0000034509798
       Coding: 011C02205040440004
       VCID: C8DC34A77BE1860FAF-809C
       Part No SW: 4L0 910 289 K    HW: 4L0 907 289 K
       Component: Komfortgeraet   H12 0130
       Revision: 0130 ---    Serial number: 01793982550000
       Coding: 3277189
       VCID: B83C4467CB01F68FDF-80EC
    Address 4C: Tire Pressure II        Labels: 4F0-910-274.clb
       Part No SW: 4F0 910 274 B    HW: 4F0 907 274
       Component: J793  RKA+      H04 0110
       Revision: 00000519    Serial number: 00005190187276
       Coding: 0758729
       VCID: A306830B628785571A-80F6
       Part No SW: 4F0 910 280     HW: 4F0 907 280
       Component: ILM Beifahrer   H16 0100
       Revision:             Serial number: 00000000648413
       Coding: 0011001
       VCID: DEF0F2FF0965E8BF75-808A
       Part No SW: 4F0 959 792 T    HW: 8K0 959 792 M
       Component: TSG BF        H12 0362
       Revision:             Serial number: 0000034534144
       VCID: C7DE379B76FF8977A6-8092
       Part No SW: 8X0 907 357 C    HW: 8X0 907 357 B
       Component: ****LWR12**** H02 0012
       Serial number: 120718-0002-095
       Coding: 11476F1010020500
       ROD: EV_HeadlRegulBasic.rod
       VCID: C2C8268F55DDAC5F71-8096
       Part No SW: 4G0 035 056 E    HW: 4G0 035 056
       Component: Radio U STD   H60 0093
       Revision: AB001007    Serial number: 230G/0C2566939
       Coding: 010003020100000000
       VCID: A306830BA28785571A-80F6
                007 - Short to Ground
                        Fault Status: 01100111
                        Reset counter: 241
                        Mileage: 184063 km
                        Date: 2020.03.25
                        Time: 20:13:33
                        Voltage: 15.00 V
       Part No SW: 4L2 035 666 E    HW: 4L2 035 666 D
       Component: H-BN-EU       H44 0528
       Revision: --------    Serial number: 219GZ0C7500961
       Coding: 180100060004B3ED010023556F632003E40000020100000000
       VCID: B12A7943E87B27C798-80E4
       Subsystem 1 - Part No: 8R0 060 884 AH
       Component: EUR 2012  1308
       Subsystem 2 - Part No SW: 8R0 919 604     HW: 8R0 919 604
       Component: DU7 High  H41 0104
       Serial number: A130GQ0C2503386
       Subsystem 3 - Part No SW: 4L0 919 614 B    HW: 4L0 919 614 B
       Component: E0380 Bedient  H01 0060
       Serial number: 00000002031740
       Subsystem 4 - Part No: 8R0 060 961 C
       Component: CD-Database  3638
       Part No SW: 4F0 959 795 Q    HW: 8K0 959 795 F
       Component: TSG HL        H11 0362
       Revision:             Serial number: 0000031577288
       Coding: 010800204040230004
    Address 69: Trailer (J345)       Labels: None
       Part No SW: 4L0 907 383 D    HW: 4L0 907 383 D
       Revision: 2C001001    Serial number: 00000179758228
       Coding: 0101010000000000
       Part No SW: 4L0 910 945     HW: 4L0 827 851 E
       Component: ValeoHeckdeckel H57 0500
       Revision: --H57001    Serial number: E5030000B
       Shop #: WSC 98765 666 38354
       VCID: EC94A837CFD98A2FEB-80B8
       Subsystem 2 - Serial number: 0
    ó
       Subsystem 3 - Serial number: RD18.07.12--H57001002G0368˙
       Subsystem 4 - Serial number: 2G0368˙
       Part No SW: 4L0 910 290     HW: 4L0 907 290
       Component: ILM HINTEN 2    H08 0080
       Revision: AAH08080    Serial number: 128756140-----
       Coding: 0000001
       VCID: E582DD132C33BB67B4-80B0
       Component: TSG HR        H11 0362
       Revision:             Serial number: 0000031577289
    End----------(Elapsed Time: 02:09, VBatt start/end: 14.9V/14.8V)-----------
  2. Likes Dana liked this post
  3. #2
    You must click on the item in question before you can change its scaling.
  4. Likes Znippie liked this post
  5. #3
    May 2018
    Norway
    Thanks! Now I got it right.
    But now a new problem accured;
    Everytime it exceeds a certain value the graph goes to zero in the graph window.
    Why? is it because the values recieves a letter (e+) when exceeding 1000bar?
    Its impossible to log the acceleration when it suddently drops to the floor during thepull
    Quote Originally Posted by Znippie View Post
    That is a distinct possibility. It would not be completely shocked if VC-Scope did not handle a dynamic data format change gracefully.
    In that case, the most expedient solution might be to log the data and graph it in Excel.
  7. Likes Dana liked this post
  8. #5
    United States
    I don't believe that TPI applies. No doubt, there appear to have been 2 flash updates over the years for that 4L2 910 401 B EDC and SVM code 01A183 would likely bump it from SWL 0001 to 0004 ... but the 2042993 TPI I located was glow plug specific. I don't think getting a dealer level flash is going to help in this case.
    The procedure in the video is gasoline specific but you can verify that injectors (or high side components) aren't stuck wide open by shutting it off and making sure the fuel pressure doesn't drop off immediately.
    You can run this procedure:
    http://wiki.ross-tech.com/wiki/index...CR_TDI_Engines
    Although it is intended for fuel filter replacement rather than pump testing that will operate the in-tank (and any in-line) pumps.
  9. Likes Znippie, Uwe, Jack@European_Parts liked this post
  10. #6
    May 2018
    Norway
    Thanks for the reply. As mentioned the actual fuel pressure value is not moving when the engine is off and ignition on, its standing on defualt 2500hpa.
    I did some test runs last night, and the ecu is asking for 2000bar but it only measures 1800 on actual pressure.
    The car was previously tuned (chip tune) but later overwritten to stock, but Im starting to think that there is a problem with that chiptuning.
    I have read somewhere that the 204hp V6 HPFH delivers 2000bar and the 245 V6 HPFP delivers 1800 bar, so there might be something worth checking out
  11. #7
    May 2018
    Norway
    Newest flash update (0004) did not help, and that kills my theori about a bad chip file.
    Next up is to find out if the pressure regulator valve is somehow leaking or is faulty.
    Pressure valve was changed 2 years ago
  12. Likes Dana liked this post
  13. #8
    Have you measured actual fuel PSI/Volume?
    JPPSG
    https://forums.ross-tech.com/showthr...l=1#post125791
    Mechanical issues must be qualified with actual test equipment to qualify block data as reported or basic isolated tests.
    Have you tried an isolation plug at each injector path on rail & to see if rail PSI is achieved during cranking in blocks or mechanical gauge?
    Did you know a fuel rail injection isolation cap can be made with an old line from junk yard cheap or purchased from any quality injection rebuild outfit for Bosch?
    This should be in any serious EU diesel shop tool box!
    Example:
    https://www.store.joma-tools.com/en/...s-leakage.html
  14. Likes Fredrick Awuor liked this post
