Results 1 to 10 of 18
Thread: Passat Died
    Dec 2019
    Passat Died
    Hello everyone,
    I was driving my 2006 Passat B6 2.0T the other day and I was waiting in a parking lot and the car died and would not restart. Previously, when the car was at a 1/4 tank, it would run out of gas. This time it was half a tank. So I added more fuel to see if that was what it was and it still didn't start. I removed the cover on top of the engine and checked there and everything seemed fine. With the cover off, I decided to start the car again and it started. It lasted for me to get home.
    When I get home, I ran the codes and received what you see below.
    Previous work I have done before this issue was I replaced the HPFP and follower, fuel pump under the back seat and also the fuel pressure regulator.
    Anyone know what else can be going on?
    Tuesday,24,March,2020,19:37:59:59102
    VIN: WVWEK73CX6P187147   License Plate:
    Mileage: 217310km-135030mi   Repair Order:
    Chassis Type: 3C (3C0)
    Scan: 01 02 03 08 09 0F 15 16 17 19 1C 25 42 44 46 52 53 56 62 65
              72
    VIN: WVWEK73CX6P187147   Mileage: 217310km-135030miles
       Part No SW: 3C0 907 115 F    HW: 3C0 907 115 F
       Component: 2.0l R4/4V TFSI     0030
       Revision: --H14---    Serial number: VWZCZ000000000
       Coding: 0404010A19070160
       Shop #: WSC 25129 444 64221
       VCID: 2313E981D7DB95FFF45-8076
    008851 - Fuel Pressure Regulator Valve (N276)
                   P2293 - 002 - Mechanical Malfunction - Intermittent
                        Mileage: 216062 km
                        Date: 2019.12.27
                        Time: 15:00:44
                        RPM: 1766 /min
                        Load: 43.9 %
                        Speed: 11.0 km/h
                        Temperature: 63.0∞C
                        Temperature: 24.0∞C
                        Absolute Pres.: 970.0 mbar
                        Voltage: 13.462 V
    012555 - Low Pressure Fuel regulation
                   P310B - 008 - Fuel Pressure Outside Specification - MIL ON
                        Fault Status: 11101000
                        Fault Frequency: 64
                        Mileage: 216062 km
                        Date: 2019.12.27
                        Time: 15:00:44
                        RPM: 2827 /min
                        Load: 35.7 %
                        Speed: 57.0 km/h
                        Temperature: 93.0∞C
                        Temperature: 25.0∞C
                        Absolute Pres.: 980.0 mbar
                        Voltage: 13.843 V
                   P310B - 004 - Fuel Pressure Outside Specification - Intermittent
                        Fault Frequency: 23
                        Mileage: 216072 km
                        Date: 2019.12.27
                        Time: 18:07:03
                        RPM: 2100 /min
                        Load: 59.6 %
                        Speed: 104.0 km/h
                        Temperature: 94.0∞C
                        Temperature: 46.0∞C
                        Voltage: 13.716 V
    000256 - Mass Air Flow Sensor (G70)
                   P0100 - 004 - Supply Voltage - Intermittent
                        Mileage: 217299 km
                        Temperature: 78.0∞C
                        Temperature: 68.0∞C
                        Voltage: 12.065 V
       Part No SW: 09G 927 750 HJ    HW: 09G 927 750 CJ
       Component: AQ 250 6F           1068
       Revision: 00H38000    Serial number:
       Coding: 0000072
       VCID: 0059860D660D6EE7C97-8054
                        Fault Status: 00101101
                        Fault Frequency: 19
                        Reset counter: 198
                        Mileage: 46122 km
                        Date: 2008.09.05
                        Time: 08:35:20
    Address 03: ABS Brakes        Labels:. 3C0-614-095-C2.clb
       Part No SW: 3C0 614 095 Q    HW: 3C0 614 095 Q
       Component: ESP 440 C2     H015 0003
       Revision:  H015       Serial number: 0667269566
       Coding: 0013755
       Shop #: WSC 00028 028 00001
       VCID: 303916CD962D3E67797-8064
                        Reset counter: 17
                        Mileage: 217299 km
                        Date: 2020.03.24
                        Time: 18:05:55
       Part No: 1K0 820 047 EC
       Component: Climatic PQ35   090 0505
       VCID: 698FBBA975778FAF7E9-803C
    Address 09: Cent. Elect.        Labels:. 3C0-937-049-23-M.lbl
       Part No SW: 3C0 937 049 AD    HW: 3C0 937 049 AD
       Component: Bordnetz-SG     H52 2002
       Revision: 00H52000    Serial number: 00000000602253
       Coding: 14058E234004150007140000001400000008730B5C0000
       VCID: 6B83C1A17F8B9DBF0C5-803E
       Subsystem 1 - Part No: 3C1 955 419   Labels: 1KX-955-119.CLB
       Component: Wischer VW461 001   0101
       Coding: 00063445
                        Reset counter: 18
                        Mileage: 216110 km
                        Date: 2020.01.27
                        Time: 10:36:00
                        Voltage: 12.60 V
    00156 - Control Circuit for Windshield Washer Pump
                        Fault Status: 00101001
                        Fault Frequency: 22
                        Reset counter: 54
                        Mileage: 216110 km
                        Date: 2020.01.27
                        Time: 10:30:00
                        Voltage: 14.40 V
    02399 - Control Circuit for Terminal 30 for Interior Illumination
                        Fault Status: 01111001
                        Reset counter: 18
                        Mileage: 216110 km
                        Date: 2020.01.27
                        Time: 10:36:00
                        Voltage: 12.45 V
    00059 - Terminal 30 for Interior Lighting
                        Reset counter: 18
                        Mileage: 216110 km
                        Date: 2020.01.27
                        Time: 10:30:00
                        Voltage: 14.40 V
    00975 - Heated Rear Window (Z1)
                        Fault Status: 00100110
                        Reset counter: 49
                        Mileage: 216437 km
                        Date: 2020.02.15
                        Time: 06:50:00
                        Voltage: 14.15 V
    Address 0F: Digital Radio        Labels: 8E0-035-593-XM.lbl
       Part No SW: 8E0 035 593 E    HW: 8E0 035 593 E
       Component: SDAR XM         H03 0080
       Revision: 00000000    Serial number: AUZ4Z7E0040619
       VCID: 2B0301A1BF0B5DBF4C5-807E
                        Reset counter: 48
                        Mileage: 216110 km
                        Date: 2020.01.27
                        Time: 10:30:23
    01304 - Radio
                        Reset counter: 203
                        Mileage: 216110 km
                        Date: 2020.01.27
                        Time: 10:30:22
       Part No SW: 3C0 909 605 K    HW: 3C0 909 605 K
       Component: 0N AIRBAG VW8R  029 2521
       Revision: 10029000    Serial number: 003A3P0KBM6E
       Coding: 0012366
       VCID: 2E0508B58C1928976BB-807A
       Subsystem 1 - Part No: 3C0 959 339 A
       Component: BF-Gewichtsens. 006 0002
       Subsystem 2 - Serial number: 00000000031JXZ
       Subsystem 3 - Serial number: 0001.01.000000600000000000ˇ63
       Subsystem 4 - Serial number: 000000ˇ6332MSME102D0B143ˇ63
       Subsystem 5 - Serial number: D0B143ˇ6342MSME1039677FKˇ63
       Subsystem 6 - Serial number: 9677FKˇ6351HTS63IKAD6924ˇ63
       Subsystem 7 - Serial number: AD6924ˇ6361HTS63IKAT2U2 ˇ63
       Subsystem 8 - Serial number: AT2U2 ˇ63727TS61IKI6KR2Sˇ63
       Subsystem 9 - Serial number: I6KR2Sˇ63827TS64IK635L2$ˇ
       Subsystem 10 - Serial number: 635L2$ˇ
       Part No SW: 3C0 953 549 E    HW: 3C0 953 549 E
       Revision: 00005000    Serial number: 3C5953507P
       Coding: 0002111
       Component: E0221           006 0080
       Part No SW: 3C0 920 970 R    HW: 3C0 920 970 R
       Revision: V0033000    Serial number: 00000000000000
       Coding: 0007205
       VCID: 333319C1673B057F045-8066
    00003 - Control Module
                014 - Defective
                        Fault Status: 01101110
                        Fault Frequency: 48
                        Mileage: 205145 km
                        Date: 2016.04.03
                        Time: 00:02:19
    Address 19: CAN Gateway        Labels:. 3C0-907-530-V1.clb
       Revision: 00007000    Serial number: 0700C062181192
       Coding: 3FFD0E04D31002
       VCID: 211FE389CDC787EFE69-8074
    01304 - Radio
                        Reset counter: 18
                        Mileage: 217312 km
                        Date: 2020.03.24
                        Time: 18:29:53
       Part No SW: 3C0 919 965     HW: 3C0 919 965
       Component: Kompass         005 0002
       Revision: 00005000    Serial number: 1166279TQDDX04
       VCID: 6D87CFB9419F938F121-8038
       Part No SW: 3C0 959 433 C    HW: 3C0 959 433 C
       Component:    IMMO         041 0364
       Revision: 00041000    Serial number: VWZCZ000000000
       Shop #: WSC 25129 444 54633
       VCID: 2A0D04A5B0F144B7B73-807E
       Subsystem 1 - Part No: 3C0 905 861 D
       Component:    ELV          024 0370
       3C0905861D     ELV          024 0370
       Part No: 1K0 959 701 K
       Component: Tuer-SG         024 2801
       Coding: 0001205
       VCID: 363520D57449105723B-8062
       Part No: 1K1 909 144 K
    00750 - Warning Lamp
                        Mileage: 6080 km
                        Temperature: 13.0∞C
                        Voltage: 12.50 V
                        Voltage: 12.30 V
       Component:    KSG PQ46 RDK 041 0213
       Coding: 13910F8801862E521804141FF00A0F0E081800
                003 - Mechanical Failure
                        Fault Status: 01100011
                        Reset counter: 209
                        Mileage: 216175 km
                        Date: 2020.01.31
                        Time: 18:47:41
       Part No: 1K0 959 702 K
       Coding: 0000004
       VCID: 372B2DD17343E95F38D-8062
       Revision:   013
       Coding: 0000013
    Address 56: Radio
       Part No: 1K0 959 703 D
       Component: Tuer-SG         021 2436
       Coding: 0000144
       VCID: 313F13C99D27376F769-8064
       Component:    RDK              0391
       Coding: 0100101
                        Reset counter: 204
                        Mileage: 216114 km
                        Date: 2020.01.29
                        Time: 15:52:31
    00667 - Ambient Temperature Signal
                        Reset counter: 34
                        Mileage: 216819 km
                        Date: 2020.02.28
                        Time: 15:12:54
       Part No: 1K0 959 704 D
       Coding: 0000144
       VCID: 323D1CC598210C770F3-8066
    End----------(Elapsed Time: 01:34, VBatt start/end: 12.4V/12.4V)-----------
    Tuesday,24,March,2020,19:47:49:59102
              72
                        Mileage: 217312 km
                        Date: 2020.03.24
                        Time: 18:41:17
                        RPM: 862 /min
                        Load: 20.8 %
                        Temperature: 95.0∞C
                        Temperature: 61.0∞C
                        Voltage: 13.335 V
    Readiness: 0110 0101
       Coding: 0000072
                        Fault Frequency: 19
                        Reset counter: 196
                        Mileage: 46122 km
                        Date: 2008.09.05
                        Time: 08:35:20
       Coding: 0013755
                        Reset counter: 17
                        Mileage: 217299 km
                        Date: 2020.03.24
                        Time: 18:05:55
       Coding: 00063445
                        Reset counter: 18
                        Mileage: 216110 km
                        Date: 2020.01.27
                        Time: 10:36:00
                        Voltage: 12.60 V
                        Fault Frequency: 22
                        Reset counter: 54
                        Mileage: 216110 km
                        Date: 2020.01.27
                        Time: 10:30:00
                        Voltage: 14.40 V
                        Reset counter: 18
                        Mileage: 216110 km
                        Date: 2020.01.27
                        Time: 10:36:00
                        Voltage: 12.45 V
                        Reset counter: 18
                        Mileage: 216110 km
                        Date: 2020.01.27
                        Time: 10:30:00
                        Voltage: 14.40 V
                        Reset counter: 49
                        Mileage: 216437 km
                        Date: 2020.02.15
                        Time: 06:50:00
                        Voltage: 14.15 V
                        Reset counter: 48
                        Mileage: 216110 km
                        Date: 2020.01.27
                        Time: 10:30:23
    01304 - Radio
                        Reset counter: 203
                        Mileage: 216110 km
                        Date: 2020.01.27
                        Time: 10:30:22
       Coding: 0012366
       Coding: 0002111
       Coding: 0007205
                014 - Defective
                        Fault Frequency: 48
                        Mileage: 205145 km
                        Date: 2016.04.03
                        Time: 00:02:19
    01304 - Radio
                        Reset counter: 18
                        Mileage: 217312 km
                        Date: 2020.03.24
                        Time: 18:29:53
       Coding: 0001205
                        Mileage: 6080 km
                        Temperature: 13.0∞C
                        Voltage: 12.50 V
                        Voltage: 12.30 V
                        Reset counter: 209
                        Mileage: 216175 km
                        Date: 2020.01.31
                        Time: 18:47:41
       Coding: 0000004
       Revision:   013
       Coding: 0000013
    Address 56: Radio
       Coding: 0000144
       Component:    RDK              0391
       Coding: 0100101
                        Reset counter: 204
                        Mileage: 216114 km
                        Date: 2020.01.29
                        Time: 15:52:31
                        Reset counter: 34
                        Mileage: 216819 km
                        Date: 2020.02.28
                        Time: 15:12:54
       Coding: 0000144
    End----------(Elapsed Time: 01:36, VBatt start/end: 12.2V/12.2V)-----------
    Last edited by Uwe; 03-25-2020 at 04:12 PM. Reason: QUOTE -> CODE & split sections
    Dec 2019
    Passat Died
    Hello everyone,
    Fuel pumps Low and module + HPP N276 maybe under safety campaign for free repair at dealer, did you check NHTSA yet?
  5. Likes Dana liked this post
    Dec 2019
    I have not. I am new at this and unsure which way to go. When I look for safety campaigns, I get "There are currently no Service Campaigns listed for your vehicle."
  7. Likes Dana liked this post
    Did you check campaign service history or if it was done at VAG directly and if not did you look up TSB's to make a request for a free repair for these known issues & which were all pretty well documented & so after you fork out money you can get reimbursed later?
    Did you know safety related campaigns never expire & if they have not been done correctly or experiencing the same condition it is warranted again even past useful life standards?
    United States
    Quote Originally Posted by akitchens View Post
    I would call the dealer with VIN but that does not look normal to me if it was at idle (unclear if it was running during the screen shot). The 106.2 number is too high and that's the in-tank fuel pump on-time Jack mentioned.
    Check MVBs 103, 106 and 230. Add those to a text log and let us know if it was running when you captured the data.
  10. #8
    Dec 2019
    The vehicle was running at the time. This is what is showed today for 103, 106, and 230
    https://photos.app.goo.gl/Lj4Kgn2msZ4vXaxHA
  11. Likes Dana liked this post
  12. #9
    United States
    Thanks for the clarification. In that case the 4029.0 mbar (which is only 4.0 bar) combined with nearly 70% on-time in-tank EFP points towards a Low Pressure Fuel specific problem. Most of those flaky G410 low pressure sensors have been recalled and replaced several times so I doubt the sensor is faulty. Instead, the in-tank pump, fuel filter and/or FPCM are suspect.
    Were both the new electric pump and fuel filter dealer sourced and ordered by VIN? Either way, please verify the new filter has a 6 or 6.6 bar stamping on it rather than the (incorrect 2.5L filter) 4 bar stamping.
  13. Likes Jack@European_Parts, Uwe liked this post
  14. #10
    Dec 2019
    The HPFP and in tank pump were not ordered by vin. Ordered from Rock Auto. I will get some time and check the stamping
