Results 1 to 10 of 17
Thread: Seat leon 1P NOTHINGS WORKS nothing about CONFORT, CANNOT BE REACHED WITH ALL confort
    Oct 2019
    Alicante, Spain
    windows doesnt works, central lock neither, engine fan allways on, car starts fine
    checked all fuses all fine
    no comunnication with a lot of modules
    i changed confort module 3c0937049e with relay holder and its totally the same, i wan to cryyy
    Tuesday,24,March,2020,14:37:31:14610
    VIN: VSSZZZ1PZ6R068868   License Plate:
    Chassis Type: 1P (1K0)
    Scan: 01 02 03 08 09 15 16 17 19 25 37 42 44 46 52 55 56 62 72 77
    VIN: VSSZZZ1PZ6R068868   Mileage: 210920km-131059miles
    08-Auto HVAC -- Status: Cannot be reached 1100
    09-Cent. Elect. -- Status: Cannot be reached 1100
    16-Steering wheel -- Status: Cannot be reached 1100
    42-Door Elect, Driver -- Status: Cannot be reached 1100
    46-Central Conv. -- Status: Cannot be reached 1100
    52-Door Elect, Pass. -- Status: Cannot be reached 1100
    62-Door, Rear Left -- Status: Cannot be reached 1100
    72-Door, Rear Right -- Status: Cannot be reached 1100
    Address 01: Engine        Labels: 03G-906-016-BKD.clb
       Part No SW: 03G 906 016 EC    HW: 028 101 176 5
       Component: R4 2,0L EDC G000AG  8074
       Revision: 12345678
       Coding: 0050078
       Shop #: WSC 06441 785 00200
       VCID: 68884CE2FE704A67615-803C
    18107 - Powertrain Data Bus
                P1699 - 000 - Missing Message from Steering Wheel Electronics
                        Torque: 90.0 Nm
                        Voltage: 12.77 V
                        Bin. Bits: 00001100
                        Bin. Bits: 00000000
                        (no units): 1.0
    18043 - Powertrain Data Bus
                P1635 - 000 - Missing Message from A/C Controller
                        Torque: 90.0 Nm
                        Voltage: 12.77 V
                        Bin. Bits: 00001100
                        Bin. Bits: 00000000
                        (no units): 144.0
    Readiness: 0 0 1 1 1
       Part No SW: 02E 300 042 T    HW: 02E 927 770 AE
       Component: GSG DSG         070 1104
       Revision: 04507000    Serial number: 00000601191363
       VCID: 241018D242D86E078DD-8070
    18275 - Powertrain Data Bus
                P1867 - 000 - Missing Message from Steering Wheel (J527)
                        Fault Frequency: 255
                        Reset counter: 40
                        Mileage: 210921 km
       Part No SW: 1K0 907 379 AA    HW: 1K0 907 379 AA
       Revision: 00H13001
       Coding: 0006786
       VCID: 71BE2186CDAA8BAF36B-8024
                013 - Check DTC Memory
    Address 08: Auto HVAC
    Address 09: Cent. Elect.
       Part No SW: 3C0 909 605 H    HW: 3C0 909 605 H
       Component: R3 AIRBAG VW8   027 2521
       Revision: 09027000    Serial number: 003A1P1881Q/
       Coding: 0021043
       VCID: 2B02F3EE2F06A17F4C7-807E
       Subsystem 1 - Serial number: 6332MSME0E613548
       Subsystem 2 - Serial number: 6342MSME0E11496F
       Subsystem 3 - Serial number: 6351HTS64IKAHQ53
       Subsystem 4 - Serial number: 6361HTS63IKEM7F2
    Address 16: Steering wheel
       Part No: 1P0 920 840 C
       Component: KOMBIINSTRUMENT VO3 0518
       Coding: 0006101
       Shop #: WSC 07423 123 00816
       Part No SW: 1K0 907 530 F    HW: 1K0 907 951
       Component: Gateway         H10 0120
       Revision:   H10       Serial number: 28001061068520
       Coding: 7F3F03C8070202
       VCID: 2A0CF6EA20FCB877B71-807E
    9 Faults Found:
                        Reset counter: 41
                        Mileage: 210921 km
                        Time: 04:34:28
                        Reset counter: 41
                        Mileage: 210921 km
                        Time: 04:34:28
                        Reset counter: 41
                        Mileage: 210921 km
                        Time: 04:34:28
                        Reset counter: 41
                        Mileage: 210921 km
                        Time: 04:34:28
                        Reset counter: 41
                        Mileage: 210921 km
                        Time: 04:34:28
                        Reset counter: 41
                        Mileage: 210921 km
                        Time: 04:34:28
                        Reset counter: 41
                        Mileage: 210921 km
                        Time: 04:34:28
                        Reset counter: 41
                        Mileage: 210921 km
                        Time: 04:34:29
                        Reset counter: 41
                        Mileage: 210921 km
                        Time: 04:34:29
       Component: IMMO            VO3 0518
    Address 37: Navigation
       Part No: 1K1 909 144 K
       VCID: 3332EB8EF736F9BF047-8066
    Address 46: Central Conv.
    Address 52: Door Elect, Pass.
       Part No: 1T0 907 357
       Coding: 0000009
       Shop #: WSC 06403 785 00200
       VCID: 74B02892B2B8BE87DDD-8020
    Address 56: Radio
    Address 62: Door, Rear Left
    Address 72: Door, Rear Right
    Address 77: Telephone        Labels: 5P0-862-335.lbl
       Part No SW: 5P0 862 335 B    HW: 5P0 862 335 B
       Component: FSE_2P5x        H21 0060
       Revision: 00000001    Serial number: 00000000375880
       Coding: 0000555
       VCID: 323CEE8A082CF0B70F1-8066
                        Reset counter: 41
                        Mileage: 210921 km
                        Time: 04:58:23
    End----------(Elapsed Time: 00:54, VBatt start/end: 13.4V/13.1V)-----------
    big thankss
    Get wiring diagrams for this car, check where each of the modules that "Cannot be reached" get power from. I would guess that most if not all have some common source of power and that is where the problem lies.
  3. Likes gomarota, downtime liked this post
    Oct 2019
    Alicante, Spain
    thanks for the tip, but i have to pay for enter isnt it?
    Yes. But in Europe, I think you can buy 1 hour access, which should be enough to download WD for your car. Here in the US, we have to buy a whole day minimum.
  6. Likes PetrolDave, gomarota liked this post
    Oct 2019
    Alicante, Spain
    friend you are so good, thanks for advice, i just bought and i download convenience system wiring diagram, im triying to find steering wheel electronic too but i dont find...
    also suspecting dtc is this:
    according with canbus convenience system diagram
    https://we.tl/t-fZdZ5C9Jda
    is all about j519 Onboard supply control unit ( the unit i replaced)
    and j533 - Data bus diagnostic interface
    uhm im suspecting maybe j533 is culpable about this
    the convenience diagram is here
    https://wetransfer.com/downloads/e88...4183004/536dd1
    also, 6 of thees modules are attached to same connection CANBUS
    B406 -Connection 1 (drive train CAN bus, low), in main wiring harness
    and
    B398 -Connection 2 (convenience CAN bus, high), in main wiring harness
    like in this image,
    https://we.tl/t-F3k44kdIGg
    Jul 2014
    Hi gomarota,
    "is all about j519 Onboard supply control unit ( the unit i replaced)"
    Did you check it had the correct power and earths?
    Regards HMC
  9. Likes Uwe, gomarota liked this post
  10. #7
    Oct 2019
    Alicante, Spain
    i tested and all powers are fine im totally upset with this car... i spend so many hours.... i would like to pay someone for solve me this problem i dont know what to do more
    thanks added to all
  11. #8
    May 2017
    Check the wiring inside the rubber grommet going to each door. Those are prone to damage.
    Another thing, check the convenience control module itself behind the glovebox. Check that there's no water ingress.
    This is most likely a wiring issue. The VAG wiring is really shitty in MK5 and MK6 and comparable chassis' of the VAG range. They are really prone to crack and short circuit as the shielding of the cable crumbles away over time. Especially the wiring going to each door is BAD.
    As there's so many modules that are not able to communicate check that the groudings are ok. I don't think this is a signal wire problem, most probably a broken grounding at some area.
  12. Likes Uwe, Eric, gomarota liked this post
  13. #9
    Oct 2019
    Alicante, Spain
    thanks friend for the tip!! i wish to come to garage on monday for check if i find the problem!, the door i think is possible but is strange that doesnt have communication with convenience or other modules inside the car
    will dissasemble glovebox and check, and also down of the windshield,
    maybe a grounding problem can be too, but the question is where? car has km of cables
    thanks and have a good weekend in this hard times
  14. #10
    Oct 2019
    Alicante, Spain
    module behind glovebox is fine, no water or corrosion
    doors wiring is ok, no sign about cut or something
    dont know what to do more, im thinking in give up this car
