Results 11 to 20 of 24
Thread: VW TRANSPORTER 2008 T5 2.5TDI NO POWER AND VIBRATIONS UNDER LOAD.
    Jan 2020
    Germany (Auto-Intern)
    Hi, when I look at the Freeze Frame, it does not indicate any boost pressure. Are all relevant vacuum hoses attached? The turbocharger is a VTG charger, it needs negative pressure to build up the boost pressure. You also wrote that you replaced the boost pressure control valve. Have you accidentally swapped the hoses?
  2. Likes Uwe liked this post
  3. #12
    May 2018
    Australia
    Friday,27,March,2020,15:26:00:39620-VCID:E288F0DD3CD5F55F51-513C,VCDS Version: Release 19.6.2 (x64),Data version: 20190930 DS308.0
    070 906 016 DQ,,R5 2.5L EDC G000SG  1583,
    ,Group A:,'011,,,,Group B:, Not Running,,,,Group C:, Not Running
    ,,Engine Speed,Boost Pressure,Boost Pressure,Charge Pressure,,,,,,,,,,
    ,TIME,(G28),(specified),(actual),Control Duty Cycle,TIME,,,,,TIME,,,,
    Marker,STAMP, /min, mbar, mbar, %,STAMP,,,,,STAMP,,,,
    ,0.01,798,1009.8,1081.2,75.4,,,,,,,,,,
    ,0.27,798,1009.8,1081.2,75.4,,,,,,,,,,
    ,0.53,798,1009.8,1081.2,75.4,,,,,,,,,,
    ,0.80,798,1009.8,1081.2,75.4,,,,,,,,,,
    ,1.06,798,1009.8,1081.2,75.4,,,,,,,,,,
    ,1.32,798,1009.8,1081.2,75.4,,,,,,,,,,
    ,1.59,798,1009.8,1081.2,75.4,,,,,,,,,,
    ,1.86,798,1009.8,1081.2,75.4,,,,,,,,,,
    ,2.12,798,1009.8,1081.2,75.4,,,,,,,,,,
    ,2.39,798,1009.8,1081.2,75.4,,,,,,,,,,
    ,2.66,798,1009.8,1081.2,75.4,,,,,,,,,,
    ,2.92,798,1009.8,1081.2,75.4,,,,,,,,,,
    ,3.19,798,1009.8,1081.2,75.4,,,,,,,,,,
    ,3.45,798,1009.8,1081.2,75.4,,,,,,,,,,
    ,3.71,798,1009.8,1081.2,75.4,,,,,,,,,,
    ,3.99,798,1009.8,1081.2,75.4,,,,,,,,,,
    ,4.26,798,1009.8,1081.2,75.4,,,,,,,,,,
    ,4.52,798,1009.8,1081.2,75.4,,,,,,,,,,
    ,4.79,798,1009.8,1081.2,75.4,,,,,,,,,,
    ,5.05,798,1009.8,1081.2,75.4,,,,,,,,,,
    ,5.32,798,1009.8,1081.2,75.4,,,,,,,,,,
    ,5.58,882,1295.4,1081.2,75.4,,,,,,,,,,
    ,5.85,1470,1417.8,1091.4,73.4,,,,,,,,,,
    ,6.11,2058,1693.2,1142.4,63.9,,,,,,,,,,
    ,6.38,2709,2131.8,1315.8,19.7,,,,,,,,,,
    ,6.64,2898,1132.2,1550.4,19.7,,,,,,,,,,
    ,6.91,2898,1132.2,1234.2,47.3,,,,,,,,,,
    ,7.18,2898,1132.2,1132.2,49.7,,,,,,,,,,
    ,7.44,2898,1142.4,1132.2,52.1,,,,,,,,,,
    ,7.71,2898,1152.6,1142.4,53.7,,,,,,,,,,
    ,7.97,2898,1142.4,1162.8,50.5,,,,,,,,,,
    ,8.23,2898,1142.4,1162.8,50.5,,,,,,,,,,
    ,8.50,2898,1132.2,1173.0,47.7,,,,,,,,,,
    ,8.77,2898,1132.2,1173.0,48.5,,,,,,,,,,
    ,9.03,2898,1142.4,1173.0,48.1,,,,,,,,,,
    ,9.30,2898,1132.2,1173.0,46.2,,,,,,,,,,
    ,9.56,2898,1142.4,1173.0,48.5,,,,,,,,,,
    ,9.83,2898,1132.2,1173.0,45.8,,,,,,,,,,
    ,10.09,2898,1152.6,1173.0,49.7,,,,,,,,,,
    ,10.36,2898,1132.2,1173.0,48.5,,,,,,,,,,
    ,10.62,2898,1142.4,1173.0,48.1,,,,,,,,,,
    ,10.89,2898,1152.6,1162.8,50.9,,,,,,,,,,
    ,11.15,2877,1142.4,1173.0,49.3,,,,,,,,,,
    ,11.42,2898,1122.0,1162.8,46.6,,,,,,,,,,
    ,11.68,2898,1132.2,1162.8,46.6,,,,,,,,,,
    ,11.95,2898,1132.2,1162.8,46.9,,,,,,,,,,
    ,12.21,2667,1081.2,1162.8,36.7,,,,,,,,,,
    ,12.48,2226,1071.0,1162.8,38.7,,,,,,,,,,
    ,12.74,1806,1050.6,1122.0,46.6,,,,,,,,,,
    ,13.01,1470,1030.2,1091.4,59.6,,,,,,,,,,
    ,13.28,1134,1020.0,1091.4,73.8,,,,,,,,,,
    ,13.55,819,1009.8,1081.2,75.4,,,,,,,,,,
    ,13.80,798,1009.8,1071.0,75.4,,,,,,,,,,
    ,14.07,798,1009.8,1060.8,75.4,,,,,,,,,,
    ,14.33,798,1009.8,1050.6,75.4,,,,,,,,,,
    ,14.61,798,1009.8,1050.6,75.4,,,,,,,,,,
    ,14.95,798,1009.8,1040.4,75.4,,,,,,,,,,
    ,15.21,798,1009.8,1040.4,75.4,,,,,,,,,,
    ,15.47,798,1009.8,1040.4,75.4,,,,,,,,,,
    ,15.74,798,1009.8,1040.4,75.4,,,,,,,,,,
    ,16.01,798,1009.8,1040.4,75.4,,,,,,,,,,
    ,16.27,798,1009.8,1030.2,75.4,,,,,,,,,,
    ,16.54,798,1009.8,1030.2,75.4,,,,,,,,,,
    ,16.80,798,1009.8,1030.2,75.4,,,,,,,,,,
    ,17.06,798,1009.8,1030.2,75.4,,,,,,,,,,
    ,17.33,798,1009.8,1030.2,75.4,,,,,,,,,,
    ,17.59,777,1009.8,1030.2,75.4,,,,,,,,,,
    ,17.86,798,1193.4,1030.2,75.4,,,,,,,,,,
    ,18.13,1218,1642.2,1030.2,75.4,,,,,,,,,,
    ,18.39,1785,2223.6,1050.6,69.4,,,,,,,,,,
    ,18.66,2331,2376.6,1142.4,60.4,,,,,,,,,,
    ,18.92,2856,1356.6,1407.6,36.7,,,,,,,,,,
    ,19.19,2898,1122.0,1417.8,32.7,,,,,,,,,,
    ,19.45,2898,1122.0,1193.4,47.7,,,,,,,,,,
    ,19.72,2898,1132.2,1132.2,50.1,,,,,,,,,,
    ,19.98,2898,1142.4,1132.2,51.7,,,,,,,,,,
    ,20.25,2898,1132.2,1142.4,48.1,,,,,,,,,,
    ,20.51,2898,1142.4,1152.6,48.9,,,,,,,,,,
    ,20.78,2898,1132.2,1162.8,50.1,,,,,,,,,,
    ,21.04,2898,1132.2,1162.8,48.9,,,,,,,,,,
    ,21.31,2898,1132.2,1162.8,49.3,,,,,,,,,,
    ,21.57,2898,1142.4,1162.8,48.9,,,,,,,,,,
    ,21.84,2898,1122.0,1162.8,46.9,,,,,,,,,,
    ,22.10,2898,1152.6,1162.8,49.3,,,,,,,,,,
    ,22.37,2898,1132.2,1162.8,47.7,,,,,,,,,,
    ,22.64,2772,1091.4,1162.8,40.6,,,,,,,,,,
    ,22.90,2310,1071.0,1152.6,38.3,,,,,,,,,,
    ,23.16,1911,1050.6,1132.2,44.2,,,,,,,,,,
    ,23.43,1533,1040.4,1101.6,54.8,,,,,,,,,,
    ,23.70,1197,1020.0,1091.4,72.6,,,,,,,,,,
    ,23.96,882,1009.8,1081.2,75.4,,,,,,,,,,
    ,24.22,819,1009.8,1071.0,75.4,,,,,,,,,,
    ,24.49,798,1009.8,1060.8,75.4,,,,,,,,,,
    ,24.75,798,1009.8,1050.6,75.4,,,,,,,,,,
    ,25.02,798,1009.8,1050.6,75.4,,,,,,,,,,
    ,25.29,798,1009.8,1040.4,75.4,,,,,,,,,,
    ,25.55,798,1009.8,1040.4,75.4,,,,,,,,,,
    ,25.82,798,1009.8,1040.4,75.4,,,,,,,,,,
    ,26.08,798,1009.8,1040.4,75.4,,,,,,,,,,
    ,26.35,798,1009.8,1040.4,75.4,,,,,,,,,,
    ,26.61,798,1009.8,1040.4,75.4,,,,,,,,,,
    ,26.88,945,1305.6,1030.2,75.4,,,,,,,,,,
    ,27.14,1470,2070.6,1030.2,73.8,,,,,,,,,,
    ,27.41,2016,2305.2,1081.2,65.5,,,,,,,,,,
    ,27.67,2562,2407.2,1234.2,55.6,,,,,,,,,,
    ,27.94,2898,1132.2,1540.2,17.0,,,,,,,,,,
    ,28.20,2898,1132.2,1305.6,42.6,,,,,,,,,,
    ,28.47,2898,1132.2,1152.6,50.5,,,,,,,,,,
    ,28.73,2898,1132.2,1132.2,50.5,,,,,,,,,,
    ,29.00,2898,1132.2,1142.4,50.9,,,,,,,,,,
    ,29.26,2898,1122.0,1152.6,48.5,,,,,,,,,,
    ,29.53,2898,1152.6,1152.6,51.3,,,,,,,,,,
    ,29.80,2898,1132.2,1162.8,48.9,,,,,,,,,,
    ,30.06,2898,1132.2,1162.8,49.3,,,,,,,,,,
    ,30.32,2898,1132.2,1162.8,48.5,,,,,,,,,,
    ,30.59,2877,1142.4,1162.8,50.1,,,,,,,,,,
    ,30.86,2898,1142.4,1162.8,49.3,,,,,,,,,,
    ,31.12,2688,1081.2,1162.8,35.9,,,,,,,,,,
    ,31.39,2226,1071.0,1162.8,38.7,,,,,,,,,,
    ,31.65,1848,1050.6,1132.2,45.4,,,,,,,,,,
    ,31.92,1491,1030.2,1091.4,58.4,,,,,,,,,,
    ,32.18,1155,1020.0,1091.4,73.8,,,,,,,,,,
    ,32.45,840,1009.8,1081.2,75.4,,,,,,,,,,
    ,32.71,798,1009.8,1071.0,75.4,,,,,,,,,,
    ,32.98,798,1009.8,1060.8,75.4,,,,,,,,,,
    ,33.24,798,1009.8,1050.6,75.4,,,,,,,,,,
    ,33.51,798,1009.8,1050.6,75.4,,,,,,,,,,
    ,33.77,798,1009.8,1040.4,75.4,,,,,,,,,,
    ,34.04,798,1009.8,1040.4,75.4,,,,,,,,,,
    ,38.31,798,1009.8,1030.2,75.4,,,,,,,,,,
    ,38.56,798,1009.8,1030.2,75.4,,,,,,,,,,
    ,38.83,798,1009.8,1030.2,75.4,,,,,,,,,,
    ,39.09,798,1009.8,1030.2,75.4,,,,,,,,,,
    ,39.36,798,1009.8,1030.2,75.4,,,,,,,,,,
    ,39.62,798,1009.8,1030.2,75.4,,,,,,,,,,
    ,39.89,798,1009.8,1030.2,75.4,,,,,,,,,,
    ,40.16,798,1009.8,1030.2,75.4,,,,,,,,,,
    ,40.42,798,1009.8,1030.2,75.4,,,,,,,,,,
    ,40.69,798,1009.8,1030.2,75.4,,,,,,,,,,
    ,40.96,798,1009.8,1030.2,75.4,,,,,,,,,,
    ,41.22,798,1009.8,1030.2,75.4,,,,,,,,,,
    ,41.79,798,1009.8,1030.2,75.4,,,,,,,,,,
    ,42.06,798,1009.8,1030.2,75.4,,,,,,,,,,
    ,42.32,798,1009.8,1030.2,75.4,,,,,,,,,,
    ,42.59,798,1009.8,1030.2,75.4,,,,,,,,,,
    ,42.85,798,1009.8,1030.2,75.4,,,,,,,,,,
    ,43.12,798,1009.8,1030.2,75.4,,,,,,,,,,
    ,43.39,798,1009.8,1030.2,75.4,,,,,,,,,,
    ,43.65,798,1009.8,1030.2,75.4,,,,,,,,,,
    ,43.91,798,1009.8,1030.2,75.4,,,,,,,,,,
    ,44.18,798,1009.8,1030.2,75.4,,,,,,,,,,
    ,44.45,798,1009.8,1030.2,75.4,,,,,,,,,,
    ,44.72,798,1009.8,1030.2,75.4,,,,,,,,,,
    ,44.98,798,1009.8,1030.2,75.4,,,,,,,,,,
    ,45.24,798,1009.8,1030.2,75.4,,,,,,,,,,
    ,45.51,798,1009.8,1030.2,75.4,,,,,,,,,,
    ,45.77,798,1009.8,1030.2,75.4,,,,,,,,,,
    ,46.04,798,1009.8,1030.2,75.4,,,,,,,,,,
    ,46.30,798,1009.8,1030.2,75.4,,,,,,,,,,
    ,46.57,798,1009.8,1030.2,75.4,,,,,,,,,,
    ,46.83,798,1009.8,1030.2,75.4,,,,,,,,,,
    ,47.10,798,1009.8,1030.2,75.4,,,,,,,,,,
    ,47.36,798,1009.8,1030.2,75.4,,,,,,,,,,
    ,47.63,798,1009.8,1030.2,75.4,,,,,,,,,,
    ,47.89,798,1009.8,1030.2,75.4,,,,,,,,,,
    ,48.16,798,1009.8,1030.2,75.4,,,,,,,,,,
    ,48.42,798,1009.8,1030.2,75.4,,,,,,,,,,
    ,48.69,798,1009.8,1030.2,75.4,,,,,,,,,,
    ,48.95,798,1009.8,1030.2,75.4,,,,,,,,,,
    ,49.22,798,1009.8,1030.2,75.4,,,,,,,,,,
    ,49.48,798,1009.8,1030.2,75.4,,,,,,,,,,
    ,49.75,798,1009.8,1030.2,75.4,,,,,,,,,,
    ,50.01,798,1009.8,1030.2,75.4,,,,,,,,,,
    ,50.28,798,1009.8,1030.2,75.4,,,,,,,,,,
    ,50.54,798,1009.8,1030.2,75.4,,,,,,,,,,
    ,50.81,798,1009.8,1030.2,75.4,,,,,,,,,,
    ,51.07,798,1009.8,1030.2,75.4,,,,,,,,,,
    ,51.34,798,1009.8,1030.2,75.4,,,,,,,,,,
    ,51.60,798,1009.8,1030.2,75.4,,,,,,,,,,
    ,51.87,798,1009.8,1030.2,75.4,,,,,,,,,,
    ,52.13,798,1009.8,1030.2,75.4,,,,,,,,,,
    ,52.40,798,1009.8,1030.2,75.4,,,,,,,,,,
    ,52.67,798,1009.8,1030.2,75.4,,,,,,,,,,
    ,52.93,798,1009.8,1030.2,75.4,,,,,,,,,,
    ,53.19,798,1009.8,1030.2,75.4,,,,,,,,,,
    ,53.46,798,1009.8,1030.2,75.4,,,,,,,,,,
    ,53.72,798,1009.8,1030.2,75.4,,,,,,,,,,
    ,53.99,798,1009.8,1030.2,75.4,,,,,,,,,,
    ,54.25,798,1009.8,1030.2,75.4,,,,,,,,,,
    ,54.52,798,1009.8,1030.2,75.4,,,,,,,,,,
    ,54.79,798,1009.8,1030.2,75.4,,,,,,,,,,
    ,55.05,798,1009.8,1030.2,75.4,,,,,,,,,,
    ,55.32,798,1009.8,1030.2,75.4,,,,,,,,,,
    ,55.58,798,1009.8,1030.2,75.4,,,,,,,,,,
    ,55.85,798,1009.8,1030.2,75.4,,,,,,,,,,
    ,56.11,798,1009.8,1030.2,75.4,,,,,,,,,,
    ,56.38,798,1009.8,1030.2,75.4,,,,,,,,,,
    ,56.64,798,1009.8,1030.2,75.4,,,,,,,,,,
    ,56.91,798,1009.8,1030.2,75.4,,,,,,,,,,
    ,57.18,798,1009.8,1030.2,75.4,,,,,,,,,,
    ,57.44,798,1009.8,1030.2,75.4,,,,,,,,,,
    ,57.70,798,1009.8,1030.2,75.4,,,,,,,,,,
    ,57.97,798,1009.8,1030.2,75.4,,,,,,,,,,
    ,58.23,798,1009.8,1030.2,75.4,,,,,,,,,,
    ,58.50,798,1009.8,1030.2,75.4,,,,,,,,,,
    ,58.77,798,1009.8,1030.2,75.4,,,,,,,,,,
    ,59.03,798,1009.8,1030.2,75.4,,,,,,,,,,
    ,59.30,798,1009.8,1030.2,75.4,,,,,,,,,,
    ,59.56,798,1009.8,1030.2,75.4,,,,,,,,,,
    ,59.82,798,1009.8,1030.2,75.4,,,,,,,,,,
    ,60.09,798,1009.8,1030.2,75.4,,,,,,,,,,
    ,60.36,798,1009.8,1030.2,75.4,,,,,,,,,,
    ,60.62,798,1009.8,1030.2,75.4,,,,,,,,,,
    ,60.89,798,1009.8,1030.2,75.4,,,,,,,,,,
    ,61.15,798,1009.8,1030.2,75.4,,,,,,,,,,
    ,61.42,798,1009.8,1030.2,75.4,,,,,,,,,,
    ,61.68,798,1009.8,1030.2,75.4,,,,,,,,,,
    ,61.95,798,1009.8,1030.2,75.4,,,,,,,,,,
    ,62.21,798,1009.8,1030.2,75.4,,,,,,,,,,
    ,62.48,798,1009.8,1030.2,75.4,,,,,,,,,,
  4. #13
    Was the above data collected under load, or was it done in neutral, without any real load on the engine?
  5. #14
    May 2018
    Australia
  6. #15
    May 2018
    Australia
    what u mean accidentally?i had this issue before cos of this so didnt make difference...all hose attached no boost leak confirm
  7. #16
    May 2018
    Australia
    was stationary no while driving
  8. #17
    Jan 2020
    Quote Originally Posted by Gapel3 View Post
    I meant that it can happen quickly that you make a mistake when connecting the hoses. I probably hadn't read correctly and overlooked the fact that your problem existed before you replaced the valve, please excuse me.
  9. #18
    Jan 2020
    I would maybe first look with a vacuum pump and an external hose to see if the vacuum holds on to the turbocharger and whether the linkage moves slightly to the stop. If so, please drive with the external hose and the vacuum pump. If the boost pressure then rises and the power is there, then you at least know that the turbocharger is mechanically correct and all charge air pipes and hoses do not lose pressure.
  10. Likes Uwe, Jack@European_Parts liked this post
  11. #19
    Then that data doesn't really show much of anything useful. Stationary, the turbo never really has a chance to spool up.
  12. Likes ai_Ingo, Jack@European_Parts liked this post
  13. #20
    At idle you should be able to manipulate the WG arm with a mighty vac and see the deviation and then have a second tech under load actuate and again the log should show in VCDS.
    This looks to be a weak air motor or sticky WG VNT not a boost leak.
    I would watch the VNT air motor for full range and possible lubricate and clean, they often rust or carbon up.
    If so it can be removed from air motor in or out of vehicle and exercised with a fine lubricant then cleaned and a basic setting made of jam nut performed as per the RTFB.
    Additionally if a shaft is sheared on turbo charger it could be doing this too in a log or as described symptom!
    To verify the turbo shaft turbines, the exhaust will need to be removed and the inlet boot to verify the the shaft is with integrity.
    If lubricating exhaust manifold and turbo components, make sure they are clean and dry so no fires can be had during burn off!
  14. Likes Uwe, PetrolDave, ai_Ingo liked this post
